06-Network
HomeSupportSecurityH3C SecCenter CSAP-NTAConfigure & DeployConfiguration GuidesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Web-Based Configure Guide-6W60006-Network
22-NTP
22-NTP 14.18 KB
NTP
Introduction
Network Time Protocol (NTP) is used to synchronize system clocks among distributed time servers and clients on a network.
NTP uses stratums 1 to 15 to define clock accuracy. A lower stratum value represents higher accuracy.
If devices on a network cannot synchronize to an authoritative time source, you can perform the following tasks to achieve NTP synchronization on the network:
1.     Select a device that has a relatively accurate clock on the network.
2.     Configure the local clock of the device as its reference source.
3.     Configure the device as a time server to synchronize other devices on the network.
You can configure a local clock as the reference source from the Web interface.
Before configuring a local clock as the reference source, adjust the time on the local clock to ensure that it is accurate.
