| 11-Forwarding advanced settings | 36.20 KB |
Introduction
DF bit processing method
If the size of a packet to be forwarded exceeds the path MTU, the device must fragment it before forwarding it out. If the DF bit of this packet is set, the device does not forward the packet and a communication failure occurs. The device will only send an ICMP error message to the source host of the packet.
This feature allows the device to modify the DF bit setting of IP packets, so that the packets can be fragmented and forwarded.
The feature takes effect only on the IP packets to be forwarded and does not affect the DF bit setting of the locally generated packets.
Packet forwarding modes
Support for the packet distribution policy depends on the device model. |
· On a multi-CPU device, packets can be distributed among CPUs based on one of the following policies:
· Flow-based policy—Forwards packets of a flow to one CPU or multiple CPUs. This policy takes the first-in first-out rule. A data flow is defined by using the following criteria:
¡ One-tuple—Uses only one of the items for flow identification: source IP address, destination IP address, source port number, or destination port number.
¡ Three-tuple—Uses the combination of source IP address, destination IP address, and protocol number for flow identification.
¡ Five-tuple—Uses the combination of source IP address, source port number, destination IP address, destination port number, and protocol number for flow identification.
In enhanced mode, the device uses different CPUs to receive and forward packets of the same flow, improving the flow processing efficiency.
· Packet-based policy—Forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
