| 01-Scanner | 24.17 KB |
Scanner
This help contains the following topics:
Introduction
The scanner scans a variety of endpoints (including cameras, PCs, switches, servers, routers, firewalls, APs, printers, and ATMs) on the network and reports endpoint information to the endpoint management server. The endpoint management server manages and monitors the endpoints in a centralized way.
· Make sure the route between the device and the endpoint management server is available, so that the scanner can report endpoint information to the endpoint management server.
· When you modify the endpoint management server parameters, you must re-enter the plaintext or ciphertext key.
Configure the scanner
1. Click the Network tab.
2. In the navigation pane, select Scanner.
3. On the scanner page, select Enable for Scanner.
4. Configure the endpoint management server parameters as described in Table 1.
Table 1 Endpoint management server configuration items
Item |
IPv4 address |
Enter the IPv4 address of the endpoint management server. |
Port number |
Enter the port number of the endpoint management server. |
Encryption method |
Select an encryption method. Options are Plaintext key and Ciphertext key. |
Plaintext key |
Enter the plaintext key string for the communication between the scanner and the endpoint management server. This field is available when you select Plaintext key for Encryption method. |
Ciphertext key |
Enter the ciphertext key string for the communication between the scanner and the endpoint management server. This field is available when you select Ciphertext key for Encryption method. |
Log level |
Select a log level. Logs of a higher level contain more detailed information and consume more memory resources. |
Global parameters |
Enable this option to use the global parameter settings of the endpoint management server. If you do not enable this option, the locally configured parameters apply. |
5. Click Apply to save the configuration.
6. To download the scanning results, click Obtain log file.
