06-Network
HomeSupportSecurityH3C SecCenter CSAP-NTAConfigure & DeployConfiguration GuidesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Web-Based Configure Guide-6W60006-Network
05-Security zones
05-Security zones 27.43 KB
Security zones
Introduction
A security zone is a collection of interfaces that have the same security requirements. You can configure security zones to implement security zone-based security management.
Security zone members
A security zone can include the following types of members:
·     Layer 2 interface-VLAN combination
·     Layer 3 interface:
¡     Layer 3 Ethernet interface
¡     Layer 3 logical interface, such as a Layer 3 subinterface
Security zone-based packet processing rules
The following table describes how the device handles packets when security zone-based security management is configured:
Packets
Action
Packets between an interface that is in a security zone and an interface that is not in any security zone
Discard.
Packets between two interfaces that are in the same security zone
Discard by default.
Packets between two interfaces that belong to different security zones
Forward or discard, depending on the matching security control policy. If no policy is applied or the policy does not exist or does not take effect, the packets are discarded.
Packets between two interfaces that are not in any security zone
Discard.
Packets originated from or destined for the device itself
Forward or discard, depending on the matching object policy. By default, these packets are discarded.
·     The device management interface belongs to the Management security zone. You can log in to the Web interface of the device from the management interface to manage the device remotely. If you remove the management interface from the Management security zone, the Web access is terminated immediately.
·     A Layer 3 interface can be added to only one security zone.
·     A Layer 2 interface-VLAN combination can be added to only one security zone.
·     If a packet does not match any zone pair between specific security zones, the device searches for the any-to-any zone pair.
¡     If the zone pair exists, the device processes the packet by using the security policies applied to the zone pair.
¡     If the zone pair does not exist, the device discards the packet.
·     By default, the device forwards packets between the Management and Local zones.
·     For packets between the Management and Local security zones, the device uses only security control policies applied to the zone pairs of the two security zones.
