07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W60007-System
40-MAC address learning through a Layer 3 device
Introduction
This feature enables the device to learn the MAC address of a terminal (a PC for example) when a Layer 3 device (typically a gateway) exists between the device and the terminal for network traffic control.
Figure 1 MAC address learning through a Layer 3 device workflow
As shown in Figure 1, MAC address learning through a Layer 3 device proceeds as follows:
2.     The Layer 3 device learns the IP-MAC binding of the terminal, and then generates an ARP entry.
3.     The device sends SNMP requests to the Layer 3 device at the specified intervals to request the ARP entry.
4.     The Layer 3 device sends a response that contains the ARP entry.
5.     Upon receiving the response, the device saves the ARP entry in the memory. Then it can learn the MAC address of the terminal.
·     Make sure the Layer 3 device supports SNMPv2c or SNMPv3, has SNMP agent enabled, and has a community name configured.
·     Only MAC addresses mapped from IPv4 addresses can be learned.
·     Make sure no NAT devices exist between the device and the Layer 3 device.
·     This feature is not applicable to a VRF network.
Configure MAC address learning through a Layer 3 device
1.     Select System > Maintenance > MAC Learning Through L3 Device > L3 Device Access Setting.
2.     Click Enable to enable MAC address learning through a Layer 3 device.
3.     (Optional.) Set the polling interval and idle timeout
Table 1 Configuration items for MAC address learning through a Layer 3 device
Item
Polling interval
Interval for sending SNMP requests, in seconds
Idle timeout
Idle timeout for SNMP responses, in seconds
4.     Click Apply.
5.     Add a Layer 3 device:
a.     Click Add.
b.     Configure the following settings:
Item
SNMP version
SNMP version. Options include v2c and v3.
IP address
IP address of the target Layer 3 device, typically the gateway of the terminal network. Only IPv4 addresses are supported.
Community name (SNMPv2c)
Devices in a community use a community name for authentication. The device can communicate with the Layer 3 device only if it has the same community name as the SNMP agent on the Layer 3 device.
Username (SNMPv3)
Authentication can be performed only if the device and the SNMP agent on the Layer 3 device have the same username.
Authentication algorithm
For a successful authentication, make sure these settings are the same as those on the SNMP agent of the Layer 3 device.
Authentication password
Encryption algorithm
Encryption password
6.     Click OK.
