07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W60007-System
30-Report settings
30-Report settings 48.94 KB
Report settings
This help contains the following topics:
·     Introduction
¡     Report export
¡     Report subscription
¡     Email server
·     Configure report settings
¡     Export reports
¡     Configure report subscription
¡     Configure the email server
Introduction
Report export
Both scheduled export and manual export are supported. You can export reports periodically or export only one report as required:
·     Scheduled export—The device exports reports to the address specified by the user according to the specified export schedule. You can configure the statistical objects in the reports by using the report template.
·     Manual export—The device exports a report immediately according to the configured measured objects and time range.
Report subscription
After you add a subscriber for a report, the report will be sent to the subscriber through email.
For the subscribers to receive the report, you must configure the email server.
The device sends the daily report during the least busy hours (1 a.m. to 5 a.m.). The monthly report of the previous month is sent on the first day of each month.
The report subscription feature supports the following types of reports:
·     Summary report—Displays summarized service statistics collected over a time range.
·     Comparison report—Provides comparison of service statistics collected over two time ranges that contain the same number of days.
·     Intelligent report—Provides intelligent analysis of users' work efficiency, data leakage, and turnover risks based on their network access behaviors.
·     Comprehensive report—Illustrates the overall device operational and network security status based on analysis of critical service statistics.
Email server
To configure the device to send reports to the specified email address or enable the report subscription feature, you must configure the email server.
Export reports
Export reports periodically
1.     Click the System tab.
2.     In the navigation pane, select Report Settings > Report Export.
3.     Click the Report Templates tab.
4.     Click Create.
Table 1 Report template configuration items
Item
Template name
Enter a report template name.
Language
Select a report language.
Options are Chinese and English.
Statistical object
Select objects to be counted in the report.
The following options are available:
·     Link.
·     Routing policy.
·     Virtual server.
·     Real server.
·     Server farm.
·     Server farm member.
Link statistics
Link
Link measured items
Select links and select items to be measured for the links.
Options are:
·     Application.
·     Packet loss rate.
·     Network delay.
·     Connections.
·     Concurrent connections.
·     Abnormal traffic.
·     Status.
Routing policy statistics
Routing policy
Select routing policies.
If you select a routing policy, the system will count the number of matches with different classes in the routing policy.
Virtual server statistics
Virtual server
Statistics items
Select virtual servers and select items to be counted in the report for the virtual servers.
The following items are available:
·     Status.
·     HTTP status code.
·     Traffic compression ratio.
Real server statistics
Real server
Statistics items
Select real servers and select items to be counted in the report for the real servers.
Supported items are Status and HTTP delay.
Server farm statistics
Server farm
Select server farms.
If you select a server farm, the system will count status statistics for the server farm.
Server farm member statistics
Server farm
Server farm member
Statistics items
Select members from a server farm and select items to be counted in the report for the server farm members.
5.     Click OK.
The report template is displayed on the Report Templates page.
6.     Click the Auto Export tab.
7.     Click Create.
Table 2 Report export task configuration items
Item
Export destination
Select a report export destination.
Options are Local and Email.
Export schedule
Select a report export schedule.
Options are Hourly, Daily, Weekly, Monthly, Quarterly, and Yearly.
Report template
Select a report template used for a periodic report type.
Export a report manually
3.     Click the Manual Export tab.
Table 3 Manual export configuration items
Item
Statistical object
·     Link.
·     Routing policy.
·     Virtual server.
·     Real server.
·     Server farm.
Link statistics
Link
Link measured items
Options are:
·     Application.
·     Packet loss rate.
·     Network delay.
·     Connections.
·     Abnormal traffic.
·     Status.
Routing policy
Virtual server
Statistics items
·     Status.
·     HTTP status code.
Real server
Statistics items
Server farm
Server farm
Server farm member
Statistics items
Time range
Specify a time range for the report.
4.     Click Export now.
The device exports the reports according to the configured parameters.
2.     In the navigation pane, select Report Settings > Report Subscription.
3.     Click Add for a report.
4.     Enter the email address of the report subscriber and select a language for the reports.
2.     In the navigation pane, select Report Settings > Email Server.
3.     Configure the email server.
Table 4 Email server configuration items
Item
Email server address
Enter the IP address or host name of the email server.
Sender address
Enter the email sender address.
DNS server IP
Enter the IP address of the DNS server.
Identity authentication
Select Enable to enable email client authentication.
Enable email client authentication as required by the email server.
Secure user credential transmission
Select Enable to enable secure transmission of user authentication credentials.
Username
Enter the username for connecting to the email server.
Password
Enter the password for connecting to the email server.
4.     Click Apply.
