07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W60007-System
07-Email server
07-Email server 23.82 KB
Email server
This help contains the following topics:
·     Introduction
·     Configure the email server
Introduction
If you want to output logs through email, you must configure an email server. Then, logs can be sent to email recipients.
1.     Click the System tab.
2.     In the navigation pane, select Log Settings > Email Server.
3.     Click Create.
4.     Configure the email server settings.
Table 1 Email server configuration items
Item
Email server name
Enter the name of the email server.
Email server address
Enter the IP address or host name of the email server.
Sender address
Enter the email sender address.
Recipient addresses
·     Enter a colon-separated list of email recipient addresses.
DNS server address
Enter the IP address of the DNS server.
Identity authentication
Select Enable to enable email client authentication.
Enable this function if identity authentication is required by the email server.
Secure user info transmission
Select this item to enable secure transmission of user authentication credentials.
Username
Enter the username for logging in to the email server.
Password
Enter the password for logging in to the email server.
Email sending interval
Enter an interval for sending emails. The device caches the emails to be sent and sends them only when the interval expires.
Max. emails per interval
Specify the maximum number of emails to be sent per interval.
If the maximum number is reached within the sending interval and more emails are generated to send, the device compares the severity levels of the new emails and the existing emails. If the severity level of a new email is higher than that of an existing cached email, the new one overwrites the most recent email with the lowest severity level.
The severity level of an email is the severity level of the matching IPS signature of the log.
When multiple service modules are operating concurrently, this setting takes effect separately on each service module.
5.     Click OK.
