- 11-Security Command Reference
- 01-Security zone commands
- 02-AAA commands
- 03-Portal commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-Group domain VPN commands
- 11-SSH commands
- 12-SSL commands
- 13-SSL VPN commands
- 14-APR commands
- 15-ASPF commands
- 16-Session management commands
- 17-Connection limit commands
- 18-Object group commands
- 19-Object policy commands
- 20-Attack detection and prevention commands
- 21-IP source guard commands
- 22-ARP attack protection commands
- 23-ND attack defense commands
- 24-uRPF commands
- 25-Crypto engine commands
- 26-FIPS commands
01-Security zone commands | 86.67 KB |
display security-zone
Use display security-zone to display security zone information.
display security-zone [ name zone-name ]
name zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command displays all security zones, including system-defined and user-defined security zones.
When displaying all security zones, the command uses the following order:
1. System-defined security zones.
2. User-defined security zones in alphabetical order of security zone names.
# Display information about security zone myZone.
<Sysname> display security-zone name myZone
Members:
Service path 2 reversed
GigabitEthernet1/0
GigabitEthernet2/0
VLAN 150-200
192.168.1.0 255.255.255.0
192.168.0.0 255.255.0.0 vpn-instance abc
1001:1002::0 32
Name |
Security zone name. |
Members |
Members in the security zone: · Type and number of a Layer 3 interface. · Address and mask (or mask length) of an IPv4 subnet on the public network. · Address and prefix length of an IPv6 subnet on the public network. · Address, mask (or mask length), and VPN instance name of an IPv4 subnet on a VPN. · Address, prefix length, and VPN instance name of an IPv6 subnet on a VPN. · Service chain ID. · Service chain ID with the reversed flag. If a security zone does not have members, this field displays None. |
display zone-pair security
Use display zone-pair security to display all zone pairs.
# Display all zone pairs.
<Sysname> display zone-pair security
Source zone Destination zone
DMZ Local
Trust Local
import interface
Use import interface to add a Layer 3 interfaces to a security zone.
Use undo import interface to remove Layer 3 interfaces from a security zone.
import interface layer3-interface-type layer3-interface-number
undo import interface layer3-interface-type layer3-interface-number
A security zone does not have Layer 3 interface members.
Security zone view
interface layer3-interface-type layer3-interface-number: Specifies a Layer 3 interface by its type and number. Layer 3 interfaces include Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, and other types of Layer 3 logical interfaces.
You cannot add a member to the system-defined security zone Local. You can add members to the other system-defined security zones.
To add multiple Layer 3 interfaces to a security zone, execute this command multiple times.
A Layer 3 interface can belong to only one security zone. To move a Layer 3 interface from one security zone to another security zone, perform the following tasks:
1. Use the undo import interface command to remove the interface from the current security zone.
2. Use the import interface command to add the interface to the new security zone.
# Add Layer 3 Ethernet interface GigabitEthernet 1/0 to security zone Trust.
[Sysname] security-zone name trust
[Sysname-security-zone-Trust] import interface gigabitethernet 1/0
import interface vlan
Use import interface vlan to add Layer 2 interface-VLAN combinations to a security zone.
Use undo import interface vlan to remove Layer 2 interface-VLAN combinations from a security zone .
import interface layer2-interface-type layer2-interface-number vlan vlan-list
undo import interface layer2-interface-type layer2-interface-number vlan vlan-list
A security zone does not have Layer 2 interface-VLAN combination members.
Security zone view
interface layer2-interface-type layer2-interface-number: Specifies a Layer 2 interface by its type and number.
vlan vlan-list: Specifies a list of VLANs. The vlan-list argument must be a space-separated list of up to 10 VLAN items that meet the following requirements:
· Each item specifies a VLAN by its ID or a range of VLANs in the form of start-VLAN-ID to end-VLAN-ID. The end-VLAN-ID is greater than the start-VLAN-ID.
· The VLAN IDs are in the range of 1 to 4094.
· The VLANs already exist.
To add multiple Layer 2 Ethernet interface-VLAN combinations to a security zone, execute this command multiple times.
A Layer 2 interface-VLAN combination can belong to only one security zone. To move a Layer 2 interface-VLAN combination from one security zone to another security zone, perform the following tasks:
1. Use the undo import interface vlan command to remove the combination from the current security zone.
2. Use the import interface vlan command to add the combination to the new security zone.
# Add the combination of Layer 2 Ethernet interface GigabitEthernet 1/0 and VLAN 10 to security zone Untrust.
[Sysname] security-zone name untrust
[Sysname-security-zone-Untrust] import interface gigabitethernet 1/0 vlan 10
import ip
Use import ip to add an IPv4 subnet to a security zone.
Use undo import ip to remove an IPv4 subnet from a security zone.
import ip ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
undo import ip ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
A security zone does not have IPv4 subnet members.
Security zone view
ip-address: Specifies an IPv4 subnet by its subnet address or a host address on the subnet.
mask-length: Specifies the mask length in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the subnet belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the subnet resides on the public network, do not specify this option.
To add multiple IPv4 subnets to a security zone, execute this command multiple times.
A subnet can be added to only one security zone.
If one subnet includes another subnet, the system identifies them as different subnets. You can add them to the same security zone or different security zones. If you add them to different security zones, packets that match both subnets are identified as packets of the security zone to which the smaller subnet belongs. For example, you can assign 1.1.1.1/24 and 1.1.2.2/16 to different security zones. A packet with the IP address 1.1.1.3 is identified as a packet of the security zone to which 1.1.1.1/24 belongs.
For a dynamic routing protocol to operate correctly, add the multicast and broadcast addresses used by the protocol to security zones as needed.
# Add the 192.168.1.0/24 subnet to security zone a.
[Sysname] security-zone name a
[Sysname-security-zone-a] import ip 192.168.1.0 24
# Add the subnet that is identified by the address 192.168.2.1 and mask 255.255.255.0 to security zone a.
[Sysname-security-zone-a] import ip 192.168.2.1 255.255.255.0
# Add the subnet that is identified by the address 192.168.2.1 and mask 255.255.255.0 on VPN abc to the security zone a.
[Sysname-security-zone-a] import ip 192.168.2.1 255.255.255.0 vpn-instance abc
import ipv6
Use import ipv6 to add an IPv6 subnet to a security zone.
Use undo import ipv6 to remove an IPv6 subnet from a security zone.
import ipv6 ipv6-address prefix-length [ vpn-instance vpn-instance-name ]
undo import ipv6 ipv6-address prefix-length [ vpn-instance vpn-instance-name ]
A security zone does not have IPv6 subnet members.
Security zone view
ip-address: Specifies an IPv6 subnet by its subnet address or a host address on the subnet.
prefix-length: Specifies the prefix length in the range of 1 to 128.
To add multiple IPv6 subnets to a security zone, execute this command multiple times.
If one subnet includes another subnet, the system identifies them as different subnets. You can add them to the same security zone or different security zones. If you add them to different security zones, packets that match both subnets are identified as packets of the security zone to which the smaller subnet belongs. For example, you can assign 1:1:1::0/48 and 1:1:1::0/32 to different security zones. A packet with the address 1:1:1::2 is identified as a packet of the security zone to which 1:1:1::0/48 belongs.
# Add IPv6 subnet 1001:1002::0/32 (on the public network) to security zone a.
[Sysname-security-zone-a] import ipv6 1001:1002::1 32
# Add IPv6 subnet 1001:1002::0/32 (on VPN abc) to security zone a.
[Sysname-security-zone-a] import ipv6 1001:1002::1 32 vpn-instance abc
import service-chain path
Use import service-chain path to add a service chain to a security zone.
Use undo import service-chain path to remove a service chain from a security zone.
import service-chain path path-id [ reversed ]
undo Import service-chain path path-id [ reversed ]
A security zone does not have service chain members.
Security zone view
path-id: Specifies a service chain by its ID. The value range is 1 to 8388606.
reversed: Matches the backward traffic. If you do not specify this keyword, the service chain matches the forward traffic.
To add multiple service chains to a security zone, execute this command multiple times.
A service chain can be added to only one security zone.
For more information about service chains, see Service Chain Configuration Guide.
# Add service chain 100 to security zone zonetest.
<Sysname> system
[Sysname] security-zone name zonetest
[Sysname-security-zone-zonetest] import service-chain path 100
display service-chain path (Service Chain Command Reference)
security-zone
Use security-zone to create a security zone and enter its view, or enter the view of an existing security zone.
Use undo security-zone to delete a security zone.
security-zone name zone-name
undo security-zone name zone-name
By default, the device has the following security zones: Local, Trust, DMZ, Management, and Untrust.
name zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. It cannot be any. To include a backward slash (\) or quotation mark (") in the security zone name, you must use the escape character (\).
The device provides the following system-defined security zones: Local, Trust, DMZ, Management, and Untrust. The system creates these security zones automatically when one of following events occurs:
· The first command for creating a security zone is executed.
· The first command related to creating an interzone policy is executed.
System-defined security zones cannot be deleted.
You can use this command multiple times to create multiple security zones.
Deleting a security zone also deletes the following items:
· All zone pairs that use the security zone as the source or destination security zone.
· All interzone policy applications on the zone pairs.
# Create a security zone named zonetest and enter security zone view.
security-zone intra-zone default permit
Use security-zone intra-zone default permit to set the default action to permit for packets exchanged between interfaces in the same security zone.
Use undo security-zone intra-zone default permit to set the default action to deny for packets exchanged between interfaces in the same security zone.
The default action is deny for packets exchanged between interfaces in the same security zone.
The system uses the default action for packets that are exchanged between interfaces in the same security zone in the following situations:
· A zone pair from the security zone to the security zone itself is not configured.
· A zone pair from the security zone to the security zone itself is configured, but no interzone policy is applied to the zone pair.
# Set the default action to permit for packets exchanged between interfaces in the same security zone.
[Sysname] security-zone intra-zone default permit
zone-pair security
Use zone-pair security to create a zone pair and enter its view, or enter the view of an existing zone pair.
Use undo zone-pair security to delete a zone pair.
zone-pair security source { source-zone-name | any } destination { destination-zone-name | any }
undo zone-pair security source { source-zone-name | any } destination { destination-zone-name | any }
No zone pair exists.
source source-zone-name: Specifies the name of the source security zone, a case-insensitive string of 1 to 31 characters. This security zone must already exist.
destination destination-zone-name: Specifies the name of the destination security zone, a case-insensitive string of 1 to 31 characters. This security zone must already exist.
any: Specifies any security zone.
A zone pair has a source security zone and a destination security zone. The device examines received first data packets and uses zone pairs to identify data flows. You can apply interzone policies to zone pairs so the device processes data flows based on interzone policies.
You can use the zone-pair security source any destination any command to define the any-to-any zone pair. This zone pair matches all packets from one security zone to another security zone.
A zone pair between specific security zones has a higher priority than the any-to-any zone pair.
A packet between the Management and Local zones matches only zone pairs of the two zones. It does not match the any-to-any zone pair.
Deleting a zone pair deletes all interzone policy applications on the zone pair.
# Create a zone pair with the source security zone Trust and destination zone Untrust.
[Sysname] zone-pair security source trust destination untrust
[Sysname-zone-pair-security-Trust-Untrust]
zone-pair vsip-filter enable
Use zone-pair vsip-filter enable to enable filtering based on virtual service IP address for zone pairs.
Use undo zone-pair vsip-filter enable to restore the default.
Filtering based on virtual service IP address is disabled for zone pairs.
In scenarios where server load balancing is deployed, configure this command to enable the device to filter packets from external networks to internal servers by virtual service IP address. By default, filtering based on virtual service IP address is disabled. Before matching each of the packets against ACLs, the device translates the destination IP address (the virtual service IP address) to the real server IP address. For more information about packet filtering, see ACL configuration in ACL and QoS Configuration Guide.
# Configure an IPv4 advanced ACL to permit packets destined for virtual server IP address 10.10.10.10. Configure a zone pair from Untrust to DMZ, apply the ACL to the zone pair, and enable filtering based on virtual service IP address.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source any destination 10.10.10.10 0
[Sysname] zone-pair security source untrust destination dmz
[Sysname-zone-pair-security-Untrust-DMZ] packet-filter 3000
[Sysname-zone-pair-security-Untrust-DMZ] quit
[Sysname] zone-pair vsip-filter enable
