| 00-Preface | 25.38 KB |
Preface
This document describes the installation, setup of H3C CAS.
· Audience.
· Conventions.
Audience
· System administrators.
· Network planners and installation engineers.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
