07-Layer 3—IP Services Configuration Guide
HomeSupportResource CenterRoutersMSR5600 SeriesMSR5600 SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C MSR 5600 Routers Configuration Guides(V7)-R0821-6W50007-Layer 3—IP Services Configuration Guide
09-Multi-CPU packet distribution configuration
09-Multi-CPU packet distribution configuration 39.78 KB
Configuring multi-CPU packet distribution
About multi-CPU packet distribution
On a multi-CPU device, packets can be distributed among CPUs based on one of the following policies:
·     Flow-based policy—Forwards packets of a flow to one CPU or multiple CPUs. The CPU processes flow packets by following the first-in first-out rule. A data flow can be identified by the five-tuple: Source IP address, destination IP address, source port number, destination port number, and protocol number.
·     Packet-based policy—Forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
Restrictions and guidelines: Multi-CPU packet distribution configuration
If a service requires packets of a flow to be received by the same CPU, you must use the flow-based policy.
Specifying a packet distribution policy
2.     Specify a packet distribution policy.
forwarding policy { per-flowe | per-packet }
By default, the flow-based policy is used.
  • Become a Partner
  • Partner Resources
