12-Security Command Reference
HomeSupportResource CenterRoutersMSR5600 SeriesMSR5600 SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R0821-6W50012-Security Command Reference
23-Object policy commands
23-Object policy commands 123.28 KB
accelerate
Use accelerate to enable rule matching acceleration for an object policy.
Use undo accelerate to disable rule matching acceleration for an object policy.
accelerate
undo accelerate
Rule matching acceleration is enabled for an object policy.
Object policy view
Insufficient hardware resources cause acceleration failures. When the system has sufficient hardware resources, acceleration can take effect again under either of the following conditions:
·     You change or add rules for the policy.
·     You use this command to enable rule matching acceleration again.
After you enable rule matching acceleration, the following situations might occur:
·     Acceleration fails, and the matching process runs without acceleration.
·     Acceleration succeeds, and the matching process is accelerated. In this scenario, if you change or add a rule that causes resource insufficiency, the rule does not take effect.
Make sure the IP address object group specified for an object policy rule is not configured with excluded IP addresses or a wildcard mask. If an excluded IP address is configured, rule matching acceleration fails for the object policy.
With this feature enabled, the system detects rule changes at specific intervals and automatically accelerates rule matching if any rule changes. If there are more than 100 rules of an IP version (IPv4 or IPv6), the detection interval for these rules is 20 seconds. If there are less than or equal to 100 rules of an IP version, the detection interval for these rules is 2 seconds.
# Disable rule matching acceleration for IPv4 object policy op.
[Sysname] object-policy ip op
[Sysname-object-policy-ip-op] undo accelerate
display object-policy accelerate
description
Use description to configure a description for an object policy.
No description is configured for an object policy.
Object policy view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
If the object policy does not have a description, this command configures the description. Otherwise, this command overwrites the existing description for the policy.
# Configure the description as zone-pair security office to library for an IPv4 address object policy.
[Sysname] object-policy ip permit
[Sysname-object-policy-ip-permit] description zone-pair security office to library
display object-policy ip
display object-policy ipv6
Use display object-policy accelerate to display acceleration information for object policies.
In standalone mode:
display object-policy accelerate { summary { ip | ipv6 } | verbose { ip object-policy-name | ipv6 object-policy-name } slot slot-number }
In IRF mode:
display object-policy accelerate { summary { ip | ipv6 } | verbose { ip object-policy-name | ipv6 object-policy-name } chassis chassis-number slot slot-number }
summary: Displays brief acceleration information.
verbose: Displays detailed acceleration information.
ip: Displays acceleration information for IPv4 object policies.
ipv6: Displays acceleration information for IPv6 object policies.
object-policy-name: Specifies an object policy by its name, a case-insensitive string of 1 to 63 characters.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. (In IRF mode.)
# Display brief acceleration information for all IPv4 object policies.
<Sysname> display object-policy accelerate summary ip
Object-policy ip a
Object-policy ip c
# (In standalone mode.) Display detailed acceleration information for IPv4 object policy permit.
<Sysname> display object-policy accelerate verbose ip a slot 1
Object-policy ip a
 rule 0 drop
 rule 1 pass
# (In IRF mode.) Display detailed acceleration information for IPv4 object policy permit.
<Sysname> display object-policy accelerate verbose ip a chassis 1 slot 1
Object-policy ip a
 rule 0 drop
 rule 1 pass
Use display object-policy ip to display information about the specified IPv4 object policy.
display object-policy ip [ object-policy-name ]
object-policy-name: Specifies an object policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an object policy, this command displays information about all IPv4 object policies.
This command displays IPv4 object policy rules in the order they were configured.
# Display information about all IPv4 object policies.
<Sysname> display object-policy ip
Object-policy ip pass
This is an IPv4 object policy for the zone-pair security source office destination library
Object-policy accelerated
 rule 5 pass source-ip sourceip
 rule 5 comment This rule is used for source-ip sourceip
Name of the IPv4 object policy.
Description of the IPv4 object policy.
Rule matching acceleration is enabled for the IPv4 object policy.
Statement of rule 5. The value of sourceip is the name of the source IPv4 address object group.
Description of rule 5.
Use display object-policy ipv6 to display information about the specified IPv6 object policy.
display object-policy ipv6 [ object-policy-name ]
object-policy-name: Specifies an object policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an object policy, this command displays information about all IPv6 object policies.
This command displays IPv6 object policy rules in the order they were configured.
# Display information about all IPv6 object policies.
<Sysname> display object-policy ipv6
Object-policy ipv6 pass
This is an IPv6 object policy for the zone-pair security source office destination library
 rule 5 pass source-ip sourceipv6
 rule 5 comment This rule is used for source-ip sourceipv6
Name of the IPv6 object policy.
Description of the IPv6 object policy.
Rule matching acceleration is enabled for the IPv6 object policy.
Statement of rule 5. The value of sourceipv6 is the name of the source IPv6 address object group.
display object-policy statistics zone-pair security
Use display object-policy statistics zone-pair security to display statistics for the object policies applied to the specified zone pair.
display object-policy statistics zone-pair security source source-zone-name destination destination-zone-name [ ip | ipv6 ]
source source-zone-name: Specifies a source security zone name, a case-insensitive string of 1 to 31 characters.
destination destination-zone-name: Specifies a destination security zone name, a case-insensitive string of 1 to 31 characters.
ip: Displays statistics for IPv4 object policies.
ipv6: Displays statistics for IPv6 object policies.
If you specify neither the ip keyword nor the ipv6 keyword, the system displays statistics for all object policies applied to the specified zone pair.
# Display statistics for all object policies applied to the zone pair with source security zone office and destination security zone library.
<Sysname> display object-policy statistics zone-pair security source office destination library
Object-policy apply ip OfficeToLibrary
 rule 0 pass source-ip sourceip1 (5 packets,10 bytes)
Object-policy apply ipv6 OfficeToLibraryIPv6
 rule 0 pass source-ip sourceip3 (6 packets,13 bytes)
Name of the IPv4 object policy applied to the zone pair.
Statement of rule 0. The value of sourceip1 is the name of the source IPv4 address object group.
Name of the IPv6 object policy applied to the zone pair.
Statement of rule 0. The value of sourceip3 is the name of the source IPv6 address object group.
x packets,y bytes
The rule has matched x packets, a total of y bytes. This field is displayed only when the following conditions exist:
·     The counting or logging keyword is specified in the rule command.
·     The rule has been matched.
reset object-policy statistics
display object-policy zone-pair security
Use display object-policy zone-pair security to display information about the object policies applied to the specified zone pair.
display object-policy zone-pair security [ source source-zone-name destination destination-zone-name ]
If you do not specify a zone pair, the system displays information about the object policies applied to all zone pairs.
# Display information about the object policies applied to all zone pairs.
<Sysname> display object-policy zone-pair security
Zone-pair source office destination library
object-policy apply ip permit
object-policy apply ipv6 drop
Zone pair.
move rule
Use move rule to change the rule match order of a rule in an object policy.
move rule rule-id before insert-rule-id
Object policy view
rule-id: Specifies a rule by its ID in the range of 0 to 65534.
insert-rule-id: Specifies the ID of the target rule before which a rule is inserted. The target rule ID is in the range of 0 to 65535. If you specify 65535 as the target rule ID, the rule is moved to the end of the list.
The system does not execute the command in the following situations:
·     You specify the same value for the rule-id and insert-rule-id arguments.
·     You specify a nonexistent rule.
# Insert rule 5 before rule 2 for IPv4 object policy permit.
[Sysname-object-policy-ip-permit] move rule 5 before 2
object-policy ip
rule (IPv4 object policy view)
rule (IPv6 object policy view)
Use object-policy apply ip to apply an IPv4 object policy to a zone pair.
Use undo object-policy apply ip to restore the default.
object-policy apply ip object-policy-name
undo object-policy apply ip object-policy-name
IPv4 object policies are not applied to a zone pair.
Zone pair view
object-policy-name: Specifies an IPv4 object policy by its name, a case-insensitive string of 1 to 63 characters.
If the specified object policy does not exist, this command fails.
You can apply only one IPv4 object policy to each zone pair. To apply a new IPv4 object policy to an instance, remove the application of the existing IPv4 object policy.
# Configure an IPv4 object policy and apply it to a zone pair.
[Sysname-object-policy-ip-permit]quit
[Sysname] zone-pair security source office destination library
[Sysname-zone-pair-security-office-library] object-policy apply ip permit
object-policy ip
Use object-policy apply ipv6 to apply an IPv6 object policy to a zone pair.
Use undo object-policy apply ipv6 to restore the default.
object-policy apply ipv6 object-policy-name
undo object-policy apply ipv6 object-policy-name
IPv6 object policies are not applied to a zone pair.
Zone pair view
object-policy-name: Specifies an IPv6 object policy by its name, a case-insensitive string of 1 to 63 characters.
You can apply only one IPv6 object policy to each zone pair. To apply a new IPv6 object policy to an instance, remove the application of the existing IPv6 object policy.
# Configure an IPv6 object policy and apply it to a zone pair.
[Sysname] object-policy ipv6 permit
[Sysname-object-policy-ipv6-permit] quit
[Sysname-zone-pair-security-office-library] object-policy apply ipv6 permit
object-policy ipv6
object-policy ip
Use object-policy ip to configure an IPv4 object policy and enter its view, or enter the view of an existing IPv4 object policy.
Use undo object-policy ip to delete an IPv4 object policy.
object-policy ip object-policy-name
undo object-policy ip object-policy-name
No IPv4 object policies exist.
object-policy-name: Specifies an IPv4 object policy name, a case-insensitive string of 1 to 63 characters.
The IPv4 object policy name is unchangeable once configured.
You cannot delete an IPv4 object policy that has been applied to a zone pair.
# Configure an IPv4 object policy and enter its view.
[Sysname-object-policy-ip-permit] rule pass
object-policy ipv6
object-policy ipv6
Use object-policy ipv6 to configure an IPv6 object policy and enter its view, or enter the view of an existing IPv6 object policy.
Use undo object-policy ipv6 to delete an IPv6 object policy.
object-policy ipv6 object-policy-name
undo object-policy ipv6 object-policy-name
No IPv6 object policies exist.
object-policy-name: Configures the IPv6 object policy name, a case-insensitive string of 1 to 63 characters.
The IPv6 object policy name is unchangeable once configured.
You cannot delete an IPv6 object policy that has been applied to a zone pair.
# Configure an IPv6 object policy and enter its view.
[Sysname-object-policy-ipv6-permit] rule pass
object-policy ip
Use reset object-policy statistics to clear statistics for the object policies applied to zone pairs.
reset object-policy statistics [ zone-pair security source source-zone-name destination destination-zone-name ] [ ip | ipv6 ]
source source-zone-name: Specifies the source security zone name, a case-insensitive string of 1 to 31 characters.
destination destination-zone-name: Specifies the destination security zone name, a case-insensitive string of 1 to 31 characters.
ip: Clears statistics for IPv4 object policies.
ipv6: Clears statistics for IPv6 object policies.
If you do not specify a zone pair, the system clears statistics for the object policies applied to all zone pairs.
If you specify neither the ip keyword nor the ipv6 keyword, the system clears statistics for all object policies applied to the specified zone pairs.
# Clear statistics for all IPv4 object policies applied to the zone pair with source security zone office and destination security zone library.
<Sysname> reset object-policy statistics zone-pair security source office destination library ip
rule append
Use rule append to append a criterion to a rule for packet matching.
Use undo rule append to delete a criterion appended to a rule.
rule rule-id append { application application-name | app-group app-group-name | destination-ip object-group-name | service object-group-name | source-ip object-group-name }
undo rule rule-id append { application [ application-name ] | app-group [ app-group-name ] | destination-ip [ object-group-name ] | service [ object-group-name ] | source-ip [ object-group-name ] }
No criterion is appended to a rule for packet matching.
Object policy view
application application-name: Specifies an application by its name, a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
app-group app-group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
destination-ip object-group-name: Specifies a destination IPv4 or IPv6 address object group by its name, a case-insensitive string of 1 to 31 characters. The name any is not allowed.
service object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 31 characters. The name any is not allowed.
source-ip object-group-name: Specifies a source IPv4 or IPv6 address object group by its name, a case-insensitive string of 1 to 31 characters. The name any is not allowed.
Make sure the rule already exists before you execute this command.
You can execute this command multiple times to append multiple criteria to a rule. These criteria can be of the same type.
Actions taken on packets matching a rule is specified by the rule command.
If you do not specify a criterion when executing the undo command, the command deletes all appended criteria of the specified type.
# Configure rule 1 to allow packets that match source IP address object groups sourceip1, sourceip2, and sourceip3 to pass.
[Sysname-object-policy-ip-permit] rule 1 pass source-ip sourceip1 logging
[Sysname-object-policy-ip-permit] rule 1 append source-ip sourceip2
[Sysname-object-policy-ip-permit] rule 1 append source-ip sourceip3
app-group
nbar application
object-group
object-policy ip
object-policy ipv6
rule comment
Use rule comment to configure a description for the specified rule.
Use undo rule comment to delete the description for the specified rule.
rule rule-id comment text
undo rule rule-id comment
No description is configured for a rule.
Object policy view
If the specified rule does not exist, this command fails.
If the rule does not have a description, this command configures the description. Otherwise, this command overwrites the existing description for the rule.
# Create rule 0 for IPv4 object policy permit and configure a description for rule 0.
[Sysname-object-policy-ip-permit] rule 0 pass source-ip ip1
[Sysname-object-policy-ip-permit] rule 0 comment This rule is used for source-ip ip1
Use rule to configure a rule for an IPv4 object policy.
Use undo rule to partially or completely delete a rule for an IPv4 object policy.
rule [ rule-id ] { drop | pass | inspect app-profile-name } [ [ source-ip { object-group-name | any } ] [ destination-ip { object-group-name | any } ] [ service { object-group-name | any } ] [ vrf vrf-name ] [ application application-name ] [ app-group app-group-name ] [ counting ] [ disable ] [ logging ] [ time-range time-range-name ] ] *
undo rule rule-id [ source-ip | destination-ip | service | vrf | application | app-group | counting | disable | logging time-range ] *
No rules are configured for an IPv4 object policy.
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify an ID for the rule, the system automatically assigns the rule the integer next to the greatest ID being used. For example, if the greatest ID is 60000, the system automatically assigns 60001. If the greatest ID is 65534, the system assigns the rule the smallest unused number in the range.
drop: Discards the packets that match the rule.
pass: Allows the packets that match the rule to pass.
inspect app-profile-name: Applies a DPI application profile to the packets that match the rule. The app-profile-name argument represents the DPI profile name, a case-insensitive string of 1 to 100 characters. The string can contain only letters, digits, and underscores (_).
source-ip object-group-name: Specifies a source IPv4 address object group by its name, a case-insensitive string of 1 to 31 characters.
source-ip any: Specifies all source IPv4 address object groups.
destination-ip object-group-name: Specifies a destination IPv4 address object group by its name, a case-insensitive string of 1 to 31 characters.
destination-ip any: Specifies all destination IPv4 address object groups.
service any: Specifies all service object groups.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command applies to received packets of the public network.
application application-name: Specifies an application by its name, a case-insensitive string of 1 to 63 characters. The invalid and other applications are not supported.
app-group app-group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters. The invalid and other application groups are not supported.
counting: Enables match counting for the rule in an IPv4 object policy. By default, rule match counting is disabled.
disable: Disables the IPv4 object policy rule.
logging: Logs the packets that match the rule.
time-range time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 32 characters. If the specified time range does not exist, the system creates the rule and prompts you to configure the time range. The rule takes effect after you set the time range. For more information about time range configuration, see ACL and QoS Configuration Guide.
If the specified rule ID does not exist, this command creates a rule. Otherwise, this command changes the configuration of the specified rule.
If you do not configure any object groups in a rule, the rule applies to all packets.
If you specify a nonexistent object group in a rule, the device automatically creates the specified object group with empty configuration. A rule that contains an object group with empty configuration does not match any packets.
If you do not specify any options in the undo rule command, the command deletes the entire rule. Otherwise, the command deletes only the specified part of the rule statement.
You cannot delete a nonexistent rule. You can use the display object-policy ip command to display rules in an IPv4 object policy.
To use applications or application groups in an object policy, use only PBAR-classified applications. NBAR-classified applications cannot match any packets. For more information about PBAR and NBAR, see Security Configuration Guide.
The logging keyword enables the object policy module to send log messages to the information center when packets match an object policy.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output packet matching logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view packet matching logs stored on the device, use the display logbuffer command or open the object policy log page from the Web interface of the device. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Configure a rule to allow packets that match source IPv4 address object group sourceip1 to pass through during time range time1.
[Sysname-object-policy-ip-permit] rule pass source-ip sourceip1 logging time-range time1
# Configure a rule to apply DPI application profile profile1 to packets that match source IPv4 address object group sourceip1.
[Sysname] object-policy ip dpiproc
[Sysname-object-policy-ip-dpiproc] rule inspect profile1 source-ip sourceip1 logging
# Configure a rule to permit packets that match application aaa.
[Sysname-object-policy-ip-dpiproc] rule pass application aaa
app-profile (DPI Command Reference)
move rule
object-policy ip
time-range (ACL and QoS Command Reference)
Use rule to configure a rule for an IPv6 object policy.
Use undo rule to partially or completely delete a rule for an IPv6 object policy.
undo rule rule-id [ source-ip | destination-ip | service | vrf | application | app-group | counting | disable | logging | time-range ] *
No rules are configured for an IPv6 object policy.
source-ip object-group-name: Specifies a source IPv6 address object group by its name, a case-insensitive string of 1 to 31 characters.
source-ip any: Specifies all source IPv6 address object groups.
destination-ip object-group-name: Specifies a destination IPv6 address object group by its name, a case-insensitive string of 1 to 31 characters.
destination-ip any: Specifies all destination IPv6 address object groups.
counting: Enables match counting for the rule in an IPv6 object policy. By default, rule match counting is disabled.
disable: Disables the IPv6 object policy rule.
time-range time-range-name: Specifies the rule effective time range by its name, a case-insensitive string of 1 to 32 characters. If you configure a rule without setting the effective time period, the system creates the rule and prompts you to configure the time period. The rule takes effect after you set the time period. For more information about time range configuration, see ACL and QoS Configuration Guide.
You cannot delete a nonexistent rule. You can use the display object-policy ipv6 command to display rules in an IPv6 object policy.
# Configure a rule to allow packets that match source IPv6 address object group sourceip1 to pass through during time range time1.
[Sysname-object-policy-ipv6-permit] rule pass source-ip sourceip1 logging time-range time1
[Sysname] object-policy ipv6 dpiproc
[Sysname-object-policy-ipv6-dpiproc] rule inspect profile1 source-ip sourceip1 logging
[Sysname-object-policy-ipv6-dpiproc] rule pass application aaa
move rule
object-policy ipv6
  • Become a Partner
  • Partner Resources
