02-Monitor
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40202-Monitor
03-Blacklist logs
03-Blacklist logs 17.75 KB
Blacklist logs
Introduction
After you enable blacklist logging, the device outputs logs in the following situations:
·     A blacklist entry is manually added.
·     A blacklist entry is dynamically added by the scanning attack detection feature.
·     A blacklist entry is manually deleted.
·     A blacklist entry ages out.
A blacklist log records the following information:
·     Source IP address of the blacklist entry.
·     Remote IP address of the DS-Lite tunnel.
·     VPN instance (VRF) name.
·     Reason for adding or deleting the blacklist entry.
·     Aging time for the blacklist entry.
