02-Monitor
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40202-Monitor
12-URL visit trends
12-URL visit trends 23.55 KB
URL visit trends
Introduction
The URL visit trends allow the administrator to obtain user online information by viewing URL visit peak times and visit count.
The administrator can set statistics conditions to view URL visit trends for virtual servers, statistics nodes, and visit sources.
Table 1 Common filter option
Item
Statistics object
Select a statistics object:
·     Virtual server
·     Statistics node
·     Visit source
Table 2 Filter options for virtual server statistics object
Item
Query scope
Select the query scope for the virtual server statistics object:
·     Top 5 virtual servers: Collects URL visit trend statistics for the top 5 virtual servers by URL visit count.
·     Specify virtual servers: Collects URL visit trend statistics for the specified virtual servers.
Virtual server name
Specify the names of the virtual servers for which the URL visit trend statistics are collected.
This parameter is available only when you select Specify virtual servers for Query scope.
Table 3 Filter options for statistics node statistics object
Item
Virtual server name
Specify a virtual server. The URL visit trend statistics are collected for the HTTP statistics nodes that belong to the virtual server.
Query scope
Select the query scope for the statistics node statistics object:
·     Top 5 statistics nodes: Collects URL visit trend statistics for the top 5 statistics nodes of the specified virtual server by URL visit count.
·     Specify statistics nodes: Collects URL visit trend statistics for the specified statistics nodes of specified virtual server.
Statistics node name
Specify the names of the statistics nodes for which the URL visit trend statistics are collected.
This parameter is available only when you select Specify statistics nodes for Query scope.
Table 4 Filter options for visit source statistics object
Item
Virtual server name
Specify a virtual server. The URL visit trend statistics are collected for the visit sources that belong to the virtual server.
Specify the name of the statistics node accessed by the visit source.
Query scope
Select the query scope for the visit source statistics object:
·     Top 5 visit sources: Collects URL visit trend statistics for the top 5 visit sources by URL visit count.
·     Specify visit sources: Collects URL visit trend statistics for the specified visit sources.
Visit source name
Specify the source address object group names or source IP addresses for which the URL visit trend statistics are collected.
This parameter is available only when you select Specify visit sources for Query scope.
Click Start to enable the device to collect URL access statistics based on the specified statistics conditions.
