02-Monitor
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40202-Monitor
17-Single-packet attack logs
17-Single-packet attack logs 18.42 KB
Introduction
If logging is enabled for single-packet attack events, the device outputs a log when a packet with a specific signature is detected.
By default, log aggregation for single-packet attack events is enabled. The device aggregates multiple logs generated during a period of time and outputs one log. Logs that are aggregated must have the following attributes in common:
·     Security zone where the attacks are detected.
·     Attack type.
·     Attack prevention action.
·     Source and destination IP addresses.
·     VPN instance (VRF) to which the victim IP address belongs.
You can disable log aggregation for single-packet attack events on the System > Log Settings > Attack Defense Log Settings page. As a best practice, do not disable log aggregation if single-packet attacks frequently occur. A large number of logs will consume the display resources.
