02-Virtual Technologies Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6520X-EI[HI][SI] & S6520-SI & S5560X-HI Switch Series Configuration Guides-R65xx-6W10302-Virtual Technologies Configuration Guide
01-IRF configuration
01-IRF configuration 930.79 KB
Configuring an IRF fabric· 1
About IRF· 1
IRF network model 1
IRF benefits· 1
Basic concepts· 2
IRF network topology· 4
Master election· 4
Interface naming conventions· 5
File system naming conventions· 5
Configuration synchronization· 6
Multi-active handling procedure· 6
MAD mechanisms· 8
Restrictions and guidelines: IRF configuration· 13
Hardware compatibility with IRF· 13
Software requirements for IRF· 13
Candidate IRF physical interfaces· 14
Transceiver modules and cables selection for IRF· 14
IRF port connection· 15
IRF physical interface configuration restrictions and guidelines· 15
Feature compatibility and configuration restrictions with IRF· 16
Configuration rollback restrictions· 17
IRF tasks at a glance· 17
Planning the IRF fabric setup· 17
Setting up an IRF fabric· 18
IRF setup tasks at a glance· 18
Assigning a member ID to each IRF member device· 18
Specifying a priority for each member device· 19
Binding physical interfaces to IRF ports· 19
Bulk-configuring basic IRF settings for a member device· 20
Connecting IRF physical interfaces· 21
Accessing the IRF fabric· 21
Configuring MAD·· 21
Restrictions and guidelines for MAD configuration· 21
Configuring LACP MAD·· 22
Configuring BFD MAD·· 23
Configuring ARP MAD·· 27
Configuring ND MAD·· 30
Excluding interfaces from the shutdown action upon detection of multi-active collision· 33
Recovering an IRF fabric· 34
Optimizing IRF settings for an IRF fabric· 34
Configuring a member device description· 34
Configuring IRF bridge MAC address settings· 34
Enabling software auto-update for software image synchronization· 36
Setting the IRF link down report delay· 36
Removing an interface module that has IRF physical interfaces· 37
Replacing an interface module that has IRF physical interfaces· 37
Display and maintenance commands for IRF· 38
IRF configuration examples· 38
Example: Configuring an LACP MAD-enabled IRF fabric· 38
Example: Configuring a BFD MAD-enabled IRF fabric· 42
Example: Configuring an ARP MAD-enabled IRF fabric· 46
Example: Configuring an ND MAD-enabled IRF fabric· 51
Configuring an IRF 3.1 system·· 56
About IRF 3.1· 56
IRF 3.1 network model 56
IRF 3.1 benefits· 56
Network topology· 57
Basic concepts· 57
IRF 3.1 system setup process· 58
Interface naming conventions· 59
Configuration management 59
Data forwarding· 59
Protocols and standards· 60
Restrictions and guidelines: IRF 3.1 configuration· 60
Hardware compatibility with IRF 3.1· 60
System operating mode restrictions· 60
PEX upstream member interface requirements· 60
Loop elimination· 61
Link aggregation restrictions and guidelines· 61
IRF split detection requirements· 61
Configuration rollback restrictions· 61
IRF 3.1 tasks at a glance· 61
Configuring an IRF 3.1 system with manually configured PEXs· 62
Configuring an IRF 3.1 system with automatically configured PEXs· 62
Planning the IRF 3.1 system setup· 62
Setting up the parent fabric· 63
Creating a PEX group· 63
Configuring cascade ports· 63
Assigning virtual slot numbers to PEXs· 64
Enabling PEX autoconfiguration· 65
Connecting the PEXs to the parent fabric· 66
Enabling PEX local forwarding· 66
Enabling PEX persistent forwarding· 67
Logging in to a PEX from the parent fabric· 67
Deleting idle cascade ports· 67
Removing PEXs from an IRF 3.1 system·· 68
Display and maintenance commands for IRF 3.1· 68
IRF 3.1 configuration examples· 69
Example: Configuring an IRF 3.1 system·· 69
About IRF
The Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. IRF virtualization technology offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
IRF network model
Figure 1 shows an IRF fabric that has two devices, which appear as a single node to the upper-layer and lower-layer devices.
Figure 1 IRF application scenario
IRF benefits
IRF provides the following benefits:
·     Simplified topology and easy management—An IRF fabric appears as one node and is accessible at a single IP address on the network. You can use this IP address to log in at any member device to manage all the members of the IRF fabric. In addition, you do not need to run the spanning tree feature among the IRF members.
·     1:N redundancy—In an IRF fabric, one member acts as the master to manage and control the entire IRF fabric. All the other members process services while backing up the master. When the master fails, all the other member devices elect a new master from among them to take over without interrupting services.
·     IRF link aggregation—You can assign several physical links between neighboring members to their IRF ports to create a load-balanced aggregate IRF connection with redundancy.
·     Multichassis link aggregation—You can use the Ethernet link aggregation feature to aggregate the physical links between the IRF fabric and its upstream or downstream devices across the IRF members.
·     Network scalability and resiliency—Processing capacity of an IRF fabric equals the total processing capacities of all the members. You can increase ports, network bandwidth, and processing capacity of an IRF fabric simply by adding member devices without changing the network topology.
Basic concepts
IRF member roles
IRF uses two member roles: master and standby (called subordinate throughout the documentation).
When devices form an IRF fabric, they elect a master to manage and control the IRF fabric, and all the other devices back up the master. When the master device fails, the other devices automatically elect a new master. For more information about master election, see "Master election."
IRF member ID
An IRF fabric uses member IDs to uniquely identify and manage its members. This member ID information is included as the first part of interface numbers and file paths to uniquely identify interfaces and files in an IRF fabric. Two devices cannot form an IRF fabric if they use the same member ID. A device cannot join an IRF fabric if its member ID has been used in the fabric.
Member priority
Member priority determines the possibility of a member device to be elected the master. A member with higher priority is more likely to be elected the master.
IRF port
An IRF port is a logical interface that connects IRF member devices. Every IRF-capable device has two IRF ports.
The IRF ports are named IRF-port n/1 and IRF-port n/2, where n is the member ID of the device. The two IRF ports are referred to as IRF-port 1 and IRF-port 2.
To use an IRF port, you must bind a minimum of one physical interface to it. The physical interfaces assigned to an IRF port automatically form an aggregate IRF link. An IRF port goes down when all its IRF physical interfaces are down.
IRF physical interfaces connect IRF member devices and must be bound to an IRF port. They forward traffic between member devices, including IRF protocol packets and data packets that must travel across IRF member devices.
IRF split
IRF split occurs when an IRF fabric breaks up into multiple IRF fabrics because of IRF link failures, as shown in Figure 2. The split IRF fabrics operate with the same IP address. IRF split causes routing and forwarding problems on the network. To quickly detect a multi-active collision, configure a minimum of one MAD mechanism (see "Configuring MAD").
Figure 2 IRF split
IRF merge
IRF merge occurs when two split IRF fabrics reunite or when two independent IRF fabrics are united, as shown in Figure 3.
Figure 3 IRF merge
MAD
An IRF link failure causes an IRF fabric to split in two IRF fabrics operating with the same Layer 3 settings, including the same IP address. To avoid IP address collision and network problems, IRF uses multi-active detection (MAD) mechanisms to detect the presence of multiple identical IRF fabrics, handle collisions, and recover from faults.
IRF domain ID
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
As shown in Figure 4, IRF fabric 1 contains Device A and Device B, and IRF fabric 2 contains Device C and Device D. Both fabrics use the LACP aggregate links between them for MAD. When a member device receives an extended LACPDU for MAD, it checks the domain ID to determine whether the packet is from the local IRF fabric. Then, the member device can handle the packet correctly.
Figure 4 A network that contains two IRF domains
An IRF fabric can use a daisy-chain or ring topology. As shown in Figure 5, a ring topology is more reliable. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy-chain topology. Rather, the IRF fabric changes to a daisy-chain topology without interrupting network services.
Figure 5 Daisy-chain topology vs. ring topology
Master election
Master election occurs each time the IRF fabric topology changes in the following situations:
·     The IRF fabric is established.
·     The master device fails or is removed.
·     The IRF fabric splits.
·     Independent IRF fabrics merge.
Master election does not occur when split IRF fabrics merge. For information about the master device of the merged IRF fabric, see "Failure recovery."
Master election selects a master in descending order:
1.     Current master, even if a new member has higher priority.
When an IRF fabric is being formed, all members consider themselves as the master. This rule is skipped.
2.     Member with higher priority.
3.     Member with the longest system uptime.
Two members are considered to start up at the same time if the difference between their startup times is equal to or less than 10 minutes. For these members, the next tiebreaker applies.
4.     Member with the lowest CPU MAC address.
For the setup of a new IRF fabric, the subordinate devices must reboot to complete the setup after the master election.
For an IRF merge, devices must reboot if they are in the IRF fabric that fails the master election.
A physical interface is numbered in the chassis-number/slot-number/interface-index format.
·     chassis-number—Member ID of the device. The default value for this argument is 1. Any change to the member ID takes effect after a reboot.
·     slot-number—Slot number of the front panel or slot number of interface modules on the rear panel.
¡     The slot number of the front panel is fixed at 0.
¡     The slot numbers of the interface modules are 1 and 2, from left to right, when you face the slots.
·     interface-index—Interface index on the device. Interface index depends on the number of physical interfaces available on the device. To identify the index of a physical interface, examine its index mark on the chassis.
For example, Ten-GigabitEthernet 2/0/1 represents the first fixed physical interface on member device 2. Set its link type to trunk, as follows:
[Sysname] interface ten-gigabitethernet 2/0/1
[Sysname-Ten-GigabitEthernet2/0/1] port link-type trunk
On a single-chassis fabric, you can use its storage device name to access its file system.
On a multichassis IRF fabric, you can use the storage device name to access the file system of the master. To access the file system of any other member device, use the name in the slotmember-ID#storage-device-name format.
For more information about storage device naming conventions, see Fundamentals Configuration Guide.
For example:
·     To create and access the test folder under the root directory of the flash memory on the master switch:
<Master> mkdir test
<Master> cd test
<Master> dir
Directory of flash:/test
The directory is empty.
1038336 KB total (690572 KB free)
·     To create and access the test folder under the root directory of the flash memory on member device 3:
<Master> mkdir slot3#flash:/test
Creating directory slot3#flash:/test... Done.
<Master> cd slot3#flash:/test
<Master> dir
Directory of slot3#flash:/test
IRF uses a strict running-configuration synchronization mechanism. In an IRF fabric, all devices obtain and run the running configuration of the master. Configuration changes are automatically propagated from the master to the remaining devices. The configuration files of these devices are retained, but the files do not take effect. The devices use their own startup configuration files only after they are removed from the IRF fabric.
As a best practice, back up the next-startup configuration file on a device before adding the device to an IRF fabric as a subordinate.
A subordinate device's next-startup configuration file might be overwritten if the master and the subordinate use the same file name for their next-startup configuration files. You can use the backup file to restore the original configuration after removing the subordinate from the IRF fabric.
For more information about configuration management, see Fundamentals Configuration Guide.
The multi-active handling procedure includes detection, collision handling, and failure recovery.
Detection
IRF provides MAD mechanisms by extending LACP, BFD, ARP, and IPv6 ND to detect multi-active collisions. As a best practice, configure a minimum of one MAD mechanism on an IRF fabric. For more information about the MAD mechanisms and their application scenarios, see "MAD mechanisms."
For information about LACP, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide. For information about BFD, see High Availability Configuration Guide. For information about ARP, see Layer 3—IP Services Configuration Guide. For information about ND, see IPv6 basics in Layer 3—IP Services Configuration Guide.
Collision handling
When detecting a multi-active collision, MAD disables all IRF fabrics except one from forwarding data traffic by placing them in Recovery state. The IRF fabrics placed in Recovery state are called inactive IRF fabrics. The IRF fabric that continues to forward traffic is called the active IRF fabric.
BFD MAD and LACP MAD use the following process to handle a multi-active collision:
1.     Compare the number of members in each fabric.
2.     Set all fabrics to the Recovery state except the one that has the most members.
3.     Compare the member IDs of their masters if all IRF fabrics have the same number of members.
4.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
5.     Shut down all common network interfaces in the Recovery-state fabrics except for the following interfaces:
¡     Interfaces automatically excluded from being shut down by the system.
¡     Interfaces specified by using the mad exclude interface command.
ARP MAD and ND MAD use the following process to handle a multi-active collision:
1.     Compare the member IDs of the masters in the IRF fabrics.
2.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
3.     Shut down all common network interfaces in the Recovery-state fabrics except for the following interfaces:
Failure recovery
To merge two split IRF fabrics, first repair the failed IRF link and remove the IRF link failure.
When the failed IRF link between two split IRF fabrics is recovered, all member devices in the inactive IRF fabric automatically reboot to join the active IRF fabric as subordinate members. The network interfaces that have been shut down by MAD automatically restore their original state, as shown in Figure 6.
Figure 6 Recovering the IRF fabric
If the active IRF fabric fails before the IRF link is recovered (see Figure 7), use the mad restore command on the inactive IRF fabric to recover the inactive IRF fabric. This command brings up all network interfaces that were shut down by MAD. After the IRF link is repaired, merge the two parts into a unified IRF fabric.
Figure 7 Active IRF fabric fails before the IRF link is recovered
MAD mechanisms
IRF provides MAD mechanisms by extending LACP, BFD, ARP, and IPv6 ND.
Table 1 compares the MAD mechanisms and their application scenarios.
Table 1 Comparison of MAD mechanisms
MAD mechanism
Advantages
Disadvantages
Application scenarios
LACP MAD
·     Detection speed is fast.
·     Runs on existing aggregate links without requiring MAD-dedicated physical links or Layer 3 interfaces.
Requires an intermediate device that supports extended LACP for MAD.
Link aggregation is used between the IRF fabric and its upstream or downstream device.
BFD MAD
·     Intermediate device, if used, can come from any vendor.
Requires MAD dedicated physical links and Layer 3 interfaces, which cannot be used for transmitting user traffic.
·     No special requirements for network scenarios.
·     If no intermediate device is used, this mechanism is only suitable for IRF fabrics that have only two members that are geographically close to one another.
ARP MAD
·     No intermediate device is required.
·     Does not require MAD dedicated ports.
·     Detection speed is slower than BFD MAD and LACP MAD.
·     The spanning tree feature must be enabled if common Ethernet ports are used for ARP MAD links.
Spanning tree-enabled non-link aggregation IPv4 network scenarios if common Ethernet ports are used.
ND MAD
·     The spanning tree feature must be enabled if common Ethernet ports are used for ND MAD links.
Spanning tree-enabled non-link aggregation IPv6 network scenarios if common Ethernet ports are used.
LACP MAD
As shown in Figure 8, LACP MAD has the following requirements:
·     Every IRF member must have a link with an intermediate device.
·     All the links form a dynamic link aggregation group.
·     The intermediate device must be a device that supports extended LACP for MAD.
The IRF member devices send extended LACPDUs that convey a domain ID and an active ID (the member ID of the master). The intermediate device transparently forwards the extended LACPDUs received from one member device to all the other member devices.
·     If the domain IDs and active IDs sent by all the member devices are the same, the IRF fabric is integrated.
·     If the extended LACPDUs convey the same domain ID but different active IDs, a split has occurred. LACP MAD handles this situation as described in "Collision handling."
Figure 8 LACP MAD scenario
BFD MAD
BFD MAD detects multi-active collisions by using BFD.
You can use common or management Ethernet ports for BFD MAD.
If management Ethernet ports are used, BFD MAD has the following requirements:
·     Use an intermediate device and make sure each IRF member device has a BFD MAD link to the intermediate device.
·     Assign each member device a MAD IP address on the master's management Ethernet port.
If common Ethernet ports are used, BFD MAD has the following requirements:
·     If an intermediate device is used, each member device must have a BFD MAD link to the intermediate device. If no intermediate device is used, all member devices must have a BFD MAD link to each other.
·     Assign all ports on the BFD MAD links to the same VLAN or Layer 3 aggregate interface. Assign each member device a MAD IP address on the VLAN interface or Layer 3 aggregate interface.
When you use BFD MAD, follow these restrictions and guidelines:
·     As a best practice, preferentially use management Ethernet ports for BFD MAD.
·     As a best practice, use an intermediate device to connect IRF member devices if the IRF fabric has more than two member devices. A full mesh of IRF members might cause broadcast loops.
·     The BFD MAD links and BFD MAD VLAN (or Layer 3 aggregate interface) must be dedicated. Do not use the BFD MAD links or BFD MAD VLAN (or Layer 3 aggregate interface) for any other purposes.
·     When you use a Layer 3 aggregate interface for BFD MAD, make sure its member ports do not exceed the maximum number of Selected ports allowed for an aggregation group. If the number of member ports exceeds the maximum number of Selected ports, some member ports cannot become Selected. BFD MAD will be unable to work correctly and its state will change to Faulty. For more information about setting the maximum number of Selected ports for an aggregation group, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide.
·     The MAD addresses identify the member devices and must belong to the same subnet.
·     Of all management Ethernet ports on an IRF fabric, only the master's management Ethernet port is accessible.
Figure 9 shows a typical BFD MAD scenario that uses an intermediate device. On the intermediate device, assign the ports on the BFD MAD links to the same VLAN.
Figure 10 shows a typical BFD MAD scenario that does not use an intermediate device.
With BFD MAD, the master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the split IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
Figure 9 BFD MAD scenario with an intermediate device
Figure 10 BFD MAD scenario without an intermediate device
ARP MAD
ARP MAD detects multi-active collisions by using extended ARP packets that convey the IRF domain ID and the active ID.
You can use common or management Ethernet ports for ARP MAD.
If management Ethernet ports are used, ARP MAD must work with an intermediate device. Make sure the following requirements are met:
·     Connect a management Ethernet port on each member device to the intermediate device.
·     On the intermediate device, you must assign the ports used for ARP MAD to the same VLAN.
If common Ethernet ports are used, ARP MAD can work with or without an intermediate device. Make sure the following requirements are met:
·     If an intermediate device is used, connect each IRF member device to the intermediate device, as shown in Figure 11. Run the spanning tree feature between the IRF fabric and the intermediate device. In this situation, data links can be used.
·     If no intermediate device is used, connect each IRF member device to all other member devices. In this situation, IRF links cannot be used for ARP MAD.
Each IRF member compares the domain ID and the active ID (the member ID of the master) in incoming extended ARP packets with its domain ID and active ID.
·     If the domain IDs are different, the extended ARP packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
·     If the domain IDs are the same, the device compares the active IDs.
¡     If the active IDs are different, the IRF fabric has split.
¡     If the active IDs are the same, the IRF fabric is integrated.
Figure 11 ARP MAD scenario (common Ethernet ports)
ND MAD
ND MAD detects multi-active collisions by using NS packets to transmit the IRF domain ID and the active ID.
You can use common or management Ethernet ports for ND MAD.
If management Ethernet ports are used, ND MAD must work with an intermediate device. Make sure the following requirements are met:
·     On the intermediate device, you must assign the ports used for ND MAD to the same VLAN.
If common Ethernet ports are used, ND MAD can work with or without an intermediate device. Make sure the following requirements are met:
·     If an intermediate device is used, connect each IRF member device to the intermediate device, as shown in Figure 12. Run the spanning tree feature between the IRF fabric and the intermediate device. In this situation, data links can be used.
·     If no intermediate device is used, connect each IRF member device to all other member devices. In this situation, IRF links cannot be used for ND MAD.
Each IRF member device compares the domain ID and the active ID (the member ID of the master) in incoming NS packets with its domain ID and active ID.
·     If the domain IDs are different, the NS packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
Figure 12 ND MAD scenario (common Ethernet ports)
A switch from the following switch series can form an IRF fabric only with switches in the same series:
·     S6520X-EI.
·     S6520X-HI.
·     S6520X-SI.
·     S6520-SI.
·     S5560X-HI.
·     S5000-EI.
·     MS4600.
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
Use Table 2 to select ports for establishing IRF links.
Table 2 Candidate IRF physical ports on the switches
Hardware platforms
Candidate physical IRF interfaces
S5000-EI switch series
MS4600 switch series
SFP+ ports
The SFP+ ports must operate at 10 Gbps.
S5560X-HI switch series
Ports on the front panel or on the interface module:
·     SFP+ ports.
·     SFP28 ports.
·     QSFP+ ports.
·     5G/2.5G/1000BASE-T autosensing Ethernet ports.
·     10G/5G/2.5G/1000BASE-T autosensing Ethernet ports.
Set these ports to operate at their highest rate when you use them as IRF physical ports.
You cannot use the SFP+ breakout interfaces of a QSFP+ port as IRF physical interfaces.
S6520X-EI switch series
S6520X-HI switch series
·     SFP+ ports.
·     SFP28 ports.
·     QSFP+ ports.
·     QSFP28 ports.
You cannot use the SFP+ or SFP28 breakout interfaces of a QSFP+ or QSFP28 port as IRF physical interfaces.
S6520X-SI switch series
·     5G/2.5G/1000/100 BASE-T autosensing Ethernet ports.
·     10G/5G/2.5G/1000/100 BASE-T autosensing Ethernet ports.
·     10G/1GBase-T Ethernet ports.
·     SFP+ ports.
·     SFP28 ports.
·     QSFP+ ports.
You cannot use ports on the LSPM4G4T6P module as IRF physical interfaces.
S6520-SI switch series
·     SFP+ ports.
·     QSFP+ ports.
When you select transceiver modules and cables, follow these restrictions and guidelines:
·     For 5G/2.5G/1000BASE-T, 5G/2.5G/1000/100 BASE-T, 10G/5G/2.5G/1000BASE-T, and 10G/5G/2.5G/1000/100 BASE-T Ethernet ports, the applicable cables vary by port rate and connection distance. For more information, see the installation guide for the device.
·     To connect 10G/1GBase-T Ethernet ports, use Category 6 (or above) twisted-pair cables for a short-distance connection.
·     For SFP+ ports, use SFP+ transceiver modules and fibers for a long-distance connection and use SFP+ cables for a short-distance connection.
·     For SFP28 ports, use SFP28 transceiver modules and fibers for a long-distance connection and use SFP28 cables for a short-distance connection.
·     For QSFP+ ports, use QSFP+ transceiver modules and fibers for a long-distance connection and use QSFP+ cables for a short-distance connection.
·     For QSFP28 ports:
Use the following media for a long-distance connection:
¡     QSFP28 transceiver modules and fibers.
¡     QSFP+ transceiver modules and fibers.
Use QSFP28 or QSFP+ cables for a short-distance connection.
·     The transceiver modules at the two ends of an IRF link must be the same type.
For more information about the transceiver modules and cables, see the switch installation guide and H3C Transceiver Modules User Guide.
The transceiver modules and cables available for the switch are subject to change over time. For the most up-to-date list of transceiver modules and cables, contact your H3C sales representative.
IRF port connection
When you connect two neighboring IRF members, follow these restrictions and guidelines:
·     You must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
·     For high availability, bind multiple physical interfaces to an IRF port. In Release 6510, you can bind a maximum of eight physical interfaces to an IRF port. In R6515P06 and later, you can bind a maximum of 16 physical interfaces to an IRF port.
Figure 13 Connecting IRF physical interfaces
Command configuration restrictions
On a physical interface bound to an IRF port, you can execute only the following commands:
·     Basic interface commands, including shutdown and description. For more information about these commands, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
·     The flow-interval command, which sets the statistics polling interval on an interface. For more information about this command, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
·     MAC address table configuration commands, including the mac-address static source-check enable command. In a VXLAN or EVPN network, to ensure successful forwarding of Layer 3 traffic across member devices, use the undo mac-address static source-check enable command on each IRF physical interface. For information about this command, see Layer 2—LAN Switching Command Reference.
·     LLDP commands, including:
¡     lldp admin-status.
¡     lldp check-change-interval.
¡     lldp enable.
¡     lldp encapsulation snap.
¡     lldp notification remote-change enable.
¡     lldp tlv-enable.
For more information about these commands, see Layer 2—LAN Switching Command Reference.
·     The mirroring-group reflector-port command, which specifies the physical interface as a reflector port for remote mirroring. For more information about this command, see port mirroring in Network Management and Monitoring Command Reference.
IMPORTANT
IMPORTANT:
Do not execute the mirroring-group reflector-port command on an IRF physical interface if that interface is the only member interface of an IRF port. Doing so will split the IRF fabric, because this command also removes the binding of the physical interface and IRF port.
Suppressing SNMP notifications of packet drops on IRF physical interfaces
Before an IRF member device forwards a packet, it examines its forwarding path in the IRF fabric for a loop. If a loop exists, the device discards the packet on the source interface of the looped path. This loop elimination mechanism will drop a large number of broadcast packets on the IRF physical interfaces.
To suppress SNMP notifications of packet drops that do not require attention, do not monitor packet forwarding on the IRF physical interfaces.
To form an IRF fabric, all member devices must work in the same system operating mode. To set the system operating mode, use the switch-mode command. For more information about the system operating mode, see device management in Fundamentals Configuration Guide.
Routing settings
To form an IRF fabric, all member devices must use the same settings for the maximum number of ECMP routes (set by using the max-ecmp-num command).
For more information about the routing features, see basic IP routing in Layer 3—IP Routing Configuration Guide.
The configuration rollback feature cannot roll back the following IRF settings:
·     Member device description (set by using the irf member description command).
·     Member device priority (set by using the irf member priority command).
·     IRF physical interface and IRF port bindings (set by using the port group interface command).
For more information about the configuration rollback feature, see configuration file management in Fundamentals Configuration Guide.
To configure IRF, perform the following tasks:
1.     Setting up an IRF fabric
2.     Configuring MAD
Configure a minimum of one MAD mechanism on an IRF fabric. For the MAD compatibility, see "MAD mechanism compatibility."
¡     Configuring LACP MAD
¡     Configuring BFD MAD
¡     Configuring ARP MAD
¡     Configuring ND MAD
¡     Excluding interfaces from the shutdown action upon detection of multi-active collision
This feature excludes an interface from the shutdown action for management or other special purposes when an IRF fabric transits to the Recovery state.
¡     Recovering an IRF fabric
3.     (Optional.) Optimizing IRF settings for an IRF fabric
¡     Configuring a member device description
¡     Configuring IRF bridge MAC address settings
¡     Enabling software auto-update for software image synchronization
This feature automatically synchronizes the current software images of the master to devices that are attempting to join the IRF fabric.
¡     Setting the IRF link down report delay
¡     Removing an interface module that has IRF physical interfaces
¡     Replacing an interface module that has IRF physical interfaces
Consider the following items when you plan an IRF fabric:
·     Hardware compatibility and restrictions.
·     IRF fabric size.
·     Master device.
·     Member ID and priority assignment scheme.
·     Fabric topology and cabling scheme.
·     IRF physical interfaces.
To set up an IRF fabric, perform the following tasks:
1.     Configure member IDs, priorities, and IRF physical interfaces separately.
a.     Assigning a member ID to each IRF member device
b.     (Optional.) Specifying a priority for each member device
c.     Binding physical interfaces to IRF ports
Skip these tasks if you configure member IDs, priorities, domain ID, and IRF physical interfaces in bulk.
2.     Bulk-configuring basic IRF settings for a member device
Skip this task if you configure member IDs, priorities, domain ID, and IRF physical interfaces separately.
3.     Connecting IRF physical interfaces
4.     Accessing the IRF fabric
To create an IRF fabric, you must assign a unique IRF member ID to each member device.
The new member ID of a device takes effect at a reboot. After the device reboots, the settings on all member ID-related physical resources (including common physical network interfaces) are removed, regardless of whether you have saved the configuration.
In an IRF fabric, changing IRF member IDs might cause undesirable configuration changes and data loss. Before you do that, back up the configuration, and make sure you fully understand the impact on your network.
2.     Assign a member ID to a member device.
irf member member-id renumber new-member-id
The default IRF member ID is 1.
CAUTION
CAUTION:
An IRF member ID change can invalidate member ID-related settings and cause data loss. Make sure you fully understand its impact on the live network.
3.     (Optional.) Save the configuration.
save
If you have bound physical interfaces to IRF ports or assigned member priority, you must perform this step for these settings to take effect after the reboot.
4.     Return to user view.
5.     Reboot the device.
IRF member priority represents the possibility for a device to be elected the master in an IRF fabric. A larger priority value indicates a higher priority.
A change to member priority affects the election result at the next master election, but it does not cause an immediate master re-election.
2.     Specify a priority for the device.
irf member member-id priority priority
The default IRF member priority is 1.
Select qualified physical interfaces as IRF physical interfaces as described in "Candidate IRF physical interfaces."
After binding physical interfaces to IRF ports for the first time, you must use the irf-port-configuration active command to activate the settings on the IRF ports.
The system activates the IRF port settings automatically only in the following situations:
·     The configuration file that the device starts with contains IRF port bindings.
·     You are adding physical interfaces to an IRF port (in UP state) after an IRF fabric is formed.
2.     Enter interface view or interface range view.
¡     Enter interface view.
¡     Enter interface range view. Choose one of the following commands:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
interface range name name [ interface { interface-type interface-number [ to interface-type interface-number ] } &<1-24> ]
To shut down a range of IRF physical interfaces, enter interface range view.
To shut down one IRF physical interface, enter its interface view.
3.     Shut down the physical interfaces.
shutdown
By default, a physical interface is not administratively down.
4.     Return to system view.
5.     Enter IRF port view.
irf-port member-id/irf-port-number
6.     Bind each physical interface to the IRF port.
port group interface interface-type interface-number
By default, no physical interfaces are bound to an IRF port.
Repeat this step to assign multiple physical interfaces to the IRF port.
7.     Return to system view.
8.     Enter interface view or interface range view.
9.     Bring up the physical interfaces.
10.     Return to system view.
11.     Save the configuration.
save
Activating IRF port configurations causes IRF merge and reboot. To avoid data loss, save the running configuration to the startup configuration file before you perform the operation.
12.     Activate the IRF port settings.
Use the easy IRF feature to bulk-configure basic IRF settings for a member device, including the member ID, domain ID, priority, and IRF port bindings.
The easy IRF feature provides the following configuration methods:
·     Interactive method—Enter the easy-irf command without parameters. The system will guide you to set the parameters step by step.
·     Non-interactive method—Enter the easy-irf command with parameters.
As a best practice, use the interactive method if you are new to IRF.
CAUTION
CAUTION:
·     An IRF member ID change can invalidate member ID-related settings and cause data loss. Make sure you fully understand its impact on your live network.
·     A member device reboots immediately after you specify a new member ID for it. Make sure you are aware of the impact on the network.
If you execute the easy-irf command multiple times, the following settings take effect:
·     The most recent settings for the member ID, domain ID, and priority.
·     IRF port bindings added through repeated executions of the command. To remove an IRF physical interface from an IRF port, you must use the undo port group interface command in IRF port view.
If you specify IRF physical interfaces by using the interactive method, you must also follow these restrictions and guidelines:
·     Do not enter spaces between the interface type and interface number.
·     Use a comma (,) to separate two physical interfaces. No spaces are allowed between interfaces.
2.     Bulk-configure basic IRF settings for the device.
easy-irf [ member member-id [ renumber new-member-id ] domain domain-id [ priority priority ] [ irf-port1 interface-list1 ] [ irf-port2 interface-list2 ] ]
Make sure the new member ID is unique in the IRF fabric to which the device will be added.
Follow the restrictions in "IRF port connection" to connect IRF physical interfaces as well as based on the topology and cabling scheme. The devices perform master election. The member devices that fail the master election automatically reboot to form an IRF fabric with the master device.
The IRF fabric appears as one device after it is formed. You configure and manage all IRF members at the CLI of the master. All settings you have made are automatically propagated to the IRF members.
The following methods are available for accessing an IRF fabric:
·     Local login—Log in through the console port of any member device.
·     Remote login—Log in at a Layer 3 interface on any member device by using methods including Telnet and SNMP.
When you log in to an IRF fabric, you are placed at the CLI of the master, regardless of at which member device you are logged in.
For more information, see login configuration in Fundamentals Configuration Guide.
Configuring MAD
As a best practice, configure a minimum of one MAD mechanism on an IRF fabric for prompt IRF split detection. Because MAD mechanisms use different collision handling processes, follow these restrictions and guidelines when you configure multiple MAD mechanisms on an IRF fabric:
·     Do not configure LACP MAD together with ARP MAD or ND MAD.
·     Do not configure BFD MAD together with ARP MAD or ND MAD.
Assigning IRF domain IDs
An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
If LACP MAD, ARP MAD, or ND MAD runs between two IRF fabrics, assign each fabric a unique IRF domain ID. (For BFD MAD, this task is optional.)
Actions on interfaces shut down by MAD
To prevent a multi-active collision from causing network issues, avoid using the undo shutdown command to bring up the interfaces shut down by a MAD mechanism on a Recovery-state IRF fabric.
2.     Assign a domain ID to the IRF fabric.
irf domain domain-id
The default IRF domain ID is 0.
CAUTION
CAUTION:
Changing the IRF domain ID of an IRF member device will remove that member device from the IRF fabric. This member device will be unable to exchange IRF protocol packets with the remaining member devices in the IRF fabric.
3.     Create an aggregate interface and enter aggregate interface view.
¡     Enter Layer 2 aggregate interface view.
¡     Enter Layer 3 aggregate interface view.
Perform this step also on the intermediate device.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
LACP MAD takes effect only on dynamic aggregate interfaces.
5.     Enable LACP MAD.
mad enable
By default, LACP MAD is disabled.
6.     Return to system view.
7.     Enter Ethernet interface view or interface range view.
¡     Enter Ethernet interface view.
To assign a range of ports to the aggregation group, enter interface range view.
To assign one port to the aggregation group, enter Ethernet interface view.
8.     Assign the Ethernet port or the range of Ethernet ports to the specified aggregation group.
Multichassis link aggregation is allowed.
Configuring BFD MAD
Restrictions and guidelines for configuring BFD MAD
As a best practice, use the following procedure to set up BFD MAD:
1.     Choose a BFD MAD link scheme as described in "BFD MAD."
2.     Configure BFD MAD.
3.     Connect the BFD MAD links.
When you configure BFD MAD on a VLAN interface, follow these restrictions and guidelines:
Category
BFD MAD VLAN
·     Do not enable BFD MAD on VLAN-interface 1.
·     If you are using an intermediate device, perform the following tasks:
¡     On the IRF fabric and the intermediate device, create a VLAN for BFD MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of BFD MAD links to the BFD MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the BFD MAD VLAN.
·     Make sure the IRF fabrics on the network use different BFD MAD VLANs.
·     Make sure the BFD MAD VLAN contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if that port is not on a BFD MAD link. If you have assigned that port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude that port from the BFD MAD VLAN.
·     When VSI interfaces exist, follow these restrictions and guidelines:
¡     On the S6520X-SI, S6520-SI, and MS4600 switch series, VLAN interfaces numbered in the range of 3581 to 4092 cannot be used for BFD MAD.
¡     On the S6520X-EI switch series, VLAN interfaces numbered in the range of 3069 to 4092 cannot be used for BFD MAD.
¡     On the S6520X-HI, S5560X-HI, and S5000-EI switch series, VLAN interfaces numbered in the range of 2045 to 4092 cannot be used for BFD MAD.
BFD MAD VLAN and feature compatibility
Do not use the BFD MAD VLAN and its member ports for any purpose other than configuring BFD MAD.
·     Use only the mad bfd enable and mad ip address commands on the BFD MAD-enabled VLAN interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
·     Disable the spanning tree feature on any Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature.
MAD IP address
·     To avoid network issues, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled VLAN interface.
·     Make sure all the MAD IP addresses are on the same subnet.
When you configure BFD MAD on a Layer 3 aggregate interface, follow these restrictions and guidelines:
Category
BFD MAD-enabled Layer 3 aggregate interface
·     Make sure the Layer 3 aggregate interface operates in static aggregation mode.
·     Make sure the member ports in the aggregation group do not exceed the maximum number of Selected ports allowed for an aggregation group. If the number of member ports exceeds the maximum number of Selected ports, some member ports cannot become Selected. BFD MAD will be unable to work correctly and its state will change to Faulty.
BFD MAD VLAN
·     On the intermediate device (if any), assign the ports on the BFD MAD links to the same VLAN. Do not assign the ports to an aggregate interface. If the ports are hybrid ports, make sure these ports are untagged members of their PVIDs.
·     If the intermediate device acts as a BFD MAD intermediate device for multiple IRF fabrics, assign different BFD MAD VLANs to the IRF fabrics.
·     Do not use the BFD MAD VLAN on the intermediate device for any purposes other than BFD MAD.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if that port is not on a BFD MAD link. If you have assigned that port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude that port from the BFD MAD VLAN.
BFD MAD-enabled Layer 3 aggregate interface and feature compatibility
Use only the mad bfd enable and mad ip address commands on the BFD MAD-enabled interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
MAD IP address
·     To avoid network issues, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled interface.
When you configure BFD MAD on a management Ethernet port, follow these restrictions and guidelines:
Category
Management Ethernet ports for BFD MAD
Connect a management Ethernet port on each IRF member device to the common Ethernet ports on the intermediate device.
BFD MAD VLAN
·     On the intermediate device, create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports.
Configuring BFD MAD on a VLAN interface
2.     (Optional.) Assign a domain ID to the IRF fabric.
By default, the domain ID of an IRF fabric is 0.
CAUTION
CAUTION:
3.     Create a VLAN dedicated to BFD MAD.
vlan vlan-id
By default, only VLAN 1 exists.
Perform this step also on the intermediate device (if any).
5.     Enter Ethernet interface view or interface range view.
To assign a range of ports to the BFD MAD VLAN, enter interface range view.
To assign one port to the BFD MAD VLAN, enter Ethernet interface view.
6.     Assign the port or the range of ports to the BFD MAD VLAN.
¡     Assign the ports to the VLAN as access ports.
port access vlan vlan-id
¡     Assign the ports to the VLAN as trunk ports.
port trunk permit vlan vlan-id
¡     Assign the ports to the VLAN as hybrid ports.
port hybrid vlan vlan-id { tagged | untagged }
The link type of BFD MAD ports can be access, trunk, or hybrid.
The default link type of a port is access.
8.     Enter VLAN interface view.
interface vlan-interface vlan-interface-id
9.     Enable BFD MAD.
mad bfd enable
By default, BFD MAD is disabled.
10.     Assign a MAD IP address to a member device on the VLAN interface.
mad ip address ip-address { mask | mask-length } member member-id
By default, no MAD IP addresses are configured on any VLAN interfaces.
Repeat this step to assign a MAD IP address to each member device on the VLAN interface.
Configuring BFD MAD on a Layer 3 aggregate interface
CAUTION
CAUTION:
3.     Create a Layer 3 aggregate interface for BFD MAD.
5.     Enter interface view or interface range view.
To assign a range of ports to the aggregation group for the aggregate interface, enter interface range view.
To assign one port to the aggregation group for the aggregate interface, enter Ethernet interface view.
6.     Assign the port or the range of ports to the aggregation group for the aggregate interface.
port link-aggregation group number
8.     Enter Layer 3 aggregate interface view.
9.     Enable BFD MAD.
mad bfd enable
10.     Assign a MAD IP address to a member device on the Layer 3 aggregate interface.
By default, no MAD IP addresses are configured on aggregate interfaces.
Repeat this step to assign a MAD IP address to each member device on the aggregate interface.
Configuring BFD MAD on a management Ethernet port
CAUTION
CAUTION:
3.     Enter management Ethernet interface view.
interface m-gigabitethernet interface-number
4.     Enable BFD MAD.
mad bfd enable
5.     Assign a MAD IP address to each member device.
By default, no MAD IP addresses are configured.
Configuring ARP MAD
Restrictions and guidelines for configuring ARP MAD
As a best practice, use the following procedure to set up ARP MAD:
1.     Choose an ARP MAD link scheme as described in "ARP MAD."
2.     Configure ARP MAD.
3.     Connect the ARP MAD links if you are not using existing data links as ARP MAD links.
When you configure ARP MAD on a VLAN interface, follow these restrictions and guidelines:
Category
ARP MAD VLAN
·     Do not enable ARP MAD on VLAN-interface 1.
¡     On the IRF fabric and the intermediate device, create a VLAN for ARP MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of ARP MAD links to the ARP MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the ARP MAD VLAN.
·     Do not use the ARP MAD VLAN for any other purposes.
ARP MAD and feature configuration
If an intermediate device is used, make sure the following requirements are met:
·     Run the spanning tree feature between the IRF fabric and the intermediate device to ensure that there is only one ARP MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
·     Enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
·     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
When you configure ARP MAD on a management Ethernet port, follow these restrictions and guidelines:
Category
Management Ethernet ports for ARP MAD
Connect a management Ethernet port on each member device to the common Ethernet ports on the intermediate device.
ARP MAD VLAN
On the intermediate device, create a VLAN for ARP MAD, and assign the ports used for ARP MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
Configuring ARP MAD on a VLAN interface
CAUTION
CAUTION:
3.     Configure the IRF bridge MAC address to change as soon as the address owner leaves.
undo irf mac-address persistent
By default, the IRF bridge MAC address remains unchanged for 6 minutes after the address owner leaves.
CAUTION
CAUTION:
IRF bridge MAC address change will cause transient traffic disruption.
4.     Create a VLAN dedicated to ARP MAD.
vlan vlan-id
Do not configure ARP MAD on VLAN-interface 1.
Perform this task also on the intermediate device (if any).
5.     Return to system view.
6.     Enter Ethernet interface view or interface range view.
To assign a range of ports to the ARP MAD VLAN, enter interface range view.
To assign one port to the ARP MAD VLAN, enter Ethernet interface view.
7.     Assign the port or the range of ports to the ARP MAD VLAN.
The link type of ARP MAD ports can be access, trunk, or hybrid.
8.     Return to system view.
9.     Enter VLAN interface view.
10.     Assign the interface an IP address.
By default, no IP addresses are assigned to any VLAN interfaces.
11.     Enable ARP MAD.
mad arp enable
By default, ARP MAD is disabled.
Configuring ARP MAD on a management Ethernet port
CAUTION
CAUTION:
CAUTION
CAUTION:
4.     Enter management Ethernet interface view.
5.     Assign an IP address to the management Ethernet port.
By default, no IP addresses are configured.
6.     Enable ARP MAD.
mad arp enable
Configuring ND MAD
Restrictions and guidelines for configuring ND MAD
As a best practice, use the following procedure to set up ND MAD:
1.     Choose an ND MAD link scheme as described in "ND MAD."
2.     Configure ND MAD.
3.     Connect the ND MAD links if you are not using existing data links as ND MAD links.
When you configure ND MAD on a VLAN interface, follow these restrictions and guidelines:
Category
ND MAD VLAN
·     Do not enable ND MAD on VLAN-interface 1.
¡     On the IRF fabric and the intermediate device, create a VLAN for ND MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of ND MAD links to the ND MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the ND MAD VLAN.
·     Do not use the ND MAD VLAN for any other purposes.
ND MAD and feature configuration
·     Run the spanning tree feature between the IRF fabric and the intermediate device to ensure that there is only one ND MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
When you configure ND MAD on a management Ethernet port, follow these restrictions and guidelines:
Category
Management Ethernet ports for ND MAD
ND MAD VLAN
On the intermediate device, create a VLAN for ND MAD, and assign the ports used for ND MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
Configuring ND MAD on a VLAN interface
CAUTION
CAUTION:
By default, the IRF bridge MAC address remains unchanged for 6 minutes after the address owner leaves the fabric.
CAUTION
CAUTION:
4.     Create a VLAN dedicated to ND MAD.
vlan vlan-id
Do not configure ND MAD on VLAN-interface 1.
To assign a range of ports to the ND MAD VLAN, enter interface range view.
To assign one port to the ND MAD VLAN, enter Ethernet interface view.
7.     Assign the port or the range of ports to the ND MAD VLAN.
The link type of ND MAD ports can be access, trunk, or hybrid.
10.     Assign the interface an IPv6 address.
ipv6 address { ipv6-address/prefix-length | ipv6-address prefix-length }
By default, no IPv6 addresses are assigned to a VLAN interface.
11.     Enable ND MAD.
mad nd enable
By default, ND MAD is disabled.
Configuring ND MAD on a management Ethernet port
CAUTION
CAUTION:
CAUTION
CAUTION:
5.     Assign an IPv6 address to the management Ethernet port.
ipv6 address { ipv6-address/pre-length | ipv6 address pre-length }
By default, no IPv6 addresses are assigned to a management Ethernet port.
6.     Enable ND MAD.
mad nd enable
When an IRF fabric transits to the Recovery state, the system automatically excludes the following network interfaces from being shut down:
·     Interfaces used for BFD MAD.
·     Member interfaces of an aggregate interface if the aggregate interface is excluded from being shut down.
You can exclude an interface from the shutdown action for management or other special purposes. For example:
·     Exclude a port from the shutdown action so you can Telnet to the port for managing the device.
·     Exclude a VLAN interface and its Layer 2 ports from the shutdown action so you can log in through the VLAN interface.
If the Layer 2 ports of a VLAN interface are distributed on multiple member devices, the exclusion operation might introduce IP collision risks. The VLAN interface might be up on both active and inactive IRF fabrics.
2.     Configure an interface to not shut down when the IRF fabric transits to the Recovery state.
mad exclude interface interface-type interface-number
By default, all network interfaces on a Recovery-state IRF fabric are shut down, except for the network interfaces automatically excluded by the system.
If the active IRF fabric fails before the IRF link is recovered, perform this task on the inactive IRF fabric to recover the inactive IRF fabric for traffic forwarding. The manual recovery operation brings up all interfaces that were shut down by MAD on the inactive IRF fabric.
2.     Recover the inactive IRF fabric.
mad restore
2.     Configure a description for a member device.
irf member member-id description text
By default, no member device description is configured.
The bridge MAC address of a system must be unique on a switched LAN. IRF bridge MAC address identifies an IRF fabric by Layer 2 protocols (for example, LACP) on a switched LAN.
By default, an IRF fabric uses the bridge MAC address of the master as the IRF bridge MAC address. After the master leaves, the IRF bridge MAC address persists for a period of time or permanently depending on the IRF bridge MAC persistence setting. When the IRF bridge MAC persistence timer expires, the IRF fabric uses the bridge MAC address of the current master as the IRF bridge MAC address.
In special occasions that require a fixed special IRF bridge MAC address, you can specify that MAC address as the IRF bridge MAC address. For example, when you replace an IRF fabric as a whole, you can configure the new IRF fabric with the IRF bridge MAC address of the existing IRF fabric before the replacement to minimize service interruption.
The IRF bridge MAC persistence setting does not take effect on the manually specified IRF bridge MAC address.
If IRF fabric merge occurs, IRF determines the IRF bridge MAC address of the merged IRF fabric as follows:
1.     When IRF fabrics merge, IRF ignores the IRF bridge MAC addresses and checks the bridge MAC address of each member device in the IRF fabrics. IRF merge fails if any two member devices have the same bridge MAC address.
2.     After IRF fabrics merge, the merged IRF fabric uses the bridge MAC address of the merging IRF fabric that won the master election as the IRF bridge MAC address.
Restrictions and guidelines for IRF bridge MAC address configuration
CAUTION
CAUTION:
Bridge MAC address change will cause transient traffic disruption.
When you configure IRF bridge MAC persistence, follow these restrictions and guidelines:
·     If ARP MAD or ND MAD is used with the spanning tree feature, you must disable IRF bridge MAC persistence by using the undo irf mac-address persistent command. In addition, do not specify a MAC address as the IRF bridge MAC address.
·     If the IRF fabric has multichassis aggregate links, do not use the undo irf mac-address persistent command. Use of this command might cause traffic disruption.
When you specify a MAC address as the IRF bridge MAC address, follow these restrictions and guidelines:
·     Do not specify any of the following MAC addresses as the IRF bridge MAC address:
¡     Static MAC addresses.
¡     Dynamic MAC addresses.
¡     Blackhole MAC addresses.
¡     Multiport unicast MAC addresses.
·     IRF reserves the IRF bridge MAC address and its subsequent higher 127 MAC addresses. These MAC addresses cannot be configured as any types of MAC addresses listed above.
Configuring IRF bridge MAC persistence
2.     Configure IRF bridge MAC persistence.
¡     Retain the bridge MAC address permanently even if the address owner has left the fabric.
irf mac-address persistent always
¡     Retain the bridge MAC address for 6 minutes after the address owner leaves the fabric.
irf mac-address persistent timer
¡     Change the bridge MAC address as soon as the address owner leaves the fabric.
The irf mac-address persistent timer command avoids unnecessary bridge MAC address changes caused by device reboot, transient link failure, or purposeful link disconnection.
Specifying a MAC address as the IRF bridge MAC address
2.     Specify a MAC address as the IRF bridge MAC address.
irf mac-address mac-address
CAUTION
CAUTION:
If an IRF fabric splits after you configure the IRF bridge MAC address, both the split IRF fabrics use the configured bridge MAC address as the IRF bridge MAC address.
The software auto-update feature automatically synchronizes the current software images of the master to devices that are attempting to join the IRF fabric.
To join an IRF fabric, a device must use the same software images as the master in the fabric.
When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations:
1.     Downloads the current software images of the master.
2.     Sets the downloaded images as its main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new device with the software images running on the IRF fabric if software auto-update is disabled.
To ensure a successful software auto-update in a multi-user environment, prevent anyone from rebooting member devices during the auto-update process. To inform administrators of the auto-update status, configure the information center to output the status messages to configuration terminals (see Network Management and Monitoring Configuration Guide).
Make sure the device you are adding to the IRF fabric has sufficient storage space for the new software images.
If sufficient storage space is not available, the device automatically deletes the current software images. If the reclaimed space is still insufficient, the device cannot complete the auto-update. You must reboot the device, and then access the BootWare menu to delete files.
2.     Enable software auto-update.
irf auto-update enable
By default, software auto-update is enabled.
To prevent frequent IRF splits and merges during link flapping, configure the IRF ports to delay reporting link down events.
An IRF port does not report a link down event to the IRF fabric immediately after its link changes from up to down. If the IRF link state is still down when the delay is reached, the port reports the change to the IRF fabric.
IRF ports do not delay link up events. They report the link up event immediately after the IRF link comes up.
Make sure the IRF link down report delay is shorter than the heartbeat or hello timeout settings of upper-layer protocols (for example, CFD and OSPF). If the report delay is longer than the timeout setting of a protocol, unnecessary recalculations might occur.
Set the delay to 0 seconds in the following situations:
·     The IRF fabric requires a fast master/subordinate or IRF link switchover.
·     The RRPP, BFD, or GR feature is used.
·     You want to shut down an IRF physical interface or reboot an IRF member device. (After you complete the operation, reconfigure the delay depending on the network condition.)
2.     Set the IRF link down report delay.
irf link-delay interval
The default IRF link down report delay is 4 seconds.
To remove an interface module that provides IRF physical interfaces:
1.     Perform one of the following tasks to eliminate temporary packet loss:
¡     Remove cables from the IRF physical interfaces on the module.
¡     Shut down the IRF physical interfaces on the module by using the shutdown command.
2.     Remove the module.
Replacing the old module with a different model replacement module
1.     Shut down the IRF physical interfaces on the old module by using the shutdown command.
2.     Remove the IRF port bindings that contain the physical interfaces.
3.     Remove the old module, and then install the replacement module.
4.     Verify that the replacement module has been correctly installed by using the display device command.
5.     Reconfigure the IRF port bindings, as described in "Binding physical interfaces to IRF ports."
6.     Activate the IRF port settings by using the irf-port-configuration active command.
You can skip this step if the IRF port is in UP state when you add bindings.
Replacing the old module with the same model replacement module
2.     Remove the old module, and then install the replacement module.
3.     Verify that the replacement module has been correctly installed by using the display device command.
Bring up the physical interfaces by using the undo shutdown command after the interface module completes startup.
Display and maintenance commands for IRF
Display information about all IRF members.
display irf
Display the IRF fabric topology.
display irf topology
Display IRF link information.
display irf link
Display IRF configuration.
display irf configuration
Display MAD configuration.
display mad [ verbose ]
IRF configuration examples
The IRF configuration examples show how to set up IRF fabrics that use different MAD mechanisms.
Example: Configuring an LACP MAD-enabled IRF fabric
As shown in Figure 14, set up a four-chassis IRF fabric at the access layer of the enterprise network.
Configure LACP MAD on the multichassis aggregation to Device E, which supports extended LACP.
Figure 14 Network diagram
1.     Configure Device A:
# Shut down the physical interfaces used for IRF links. In this example, the physical interfaces are shut down in batch. For more information, see Layer 2—LAN Switching Configuration Guide.
[Sysname] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[Sysname-if-range] shutdown
[Sysname-if-range] quit
# Bind Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to IRF-port 1/1.
[Sysname] irf-port 1/1
[Sysname-irf-port1/1] port group interface ten-gigabitethernet 1/0/1
[Sysname-irf-port1/1] port group interface ten-gigabitethernet 1/0/2
[Sysname-irf-port1/1] quit
# Bind Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 to IRF-port 1/2.
[Sysname] irf-port 1/2
[Sysname-irf-port1/2] port group interface ten-gigabitethernet 1/0/3
[Sysname-irf-port1/2] port group interface ten-gigabitethernet 1/0/4
[Sysname-irf-port1/2] quit
# Bring up the physical interfaces and save the configuration.
[Sysname-if-range] undo shutdown
[Sysname] save
# Activate the IRF port configuration.
[Sysname] irf-port-configuration active
2.     Configure Device B:
# Change the member ID of Device B to 2 and reboot the device to have the change take effect.
[Sysname] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 14, and log in to Device B. (Details not shown.)
# Shut down the physical interfaces for IRF links.
[Sysname] interface range ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/4
# Bind Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/2 to IRF-port 2/1.
[Sysname] irf-port 2/1
[Sysname-irf-port2/1] port group interface ten-gigabitethernet 2/0/1
[Sysname-irf-port2/1] port group interface ten-gigabitethernet 2/0/2
[Sysname-irf-port2/1] quit
# Bind Ten-GigabitEthernet 2/0/3 and Ten-GigabitEthernet 2/0/4 to IRF-port 2/2.
[Sysname] irf-port 2/2
[Sysname-irf-port2/2] port group interface ten-gigabitethernet 2/0/3
[Sysname-irf-port2/2] port group interface ten-gigabitethernet 2/0/4
[Sysname-irf-port2/2] quit
[Sysname] save
The two devices perform master election, and the one that has lost the election reboots to form an IRF fabric with the master.
3.     Configure Device C:
# Change the member ID of Device C to 3 and reboot the device to have the change take effect.
[Sysname] irf member 1 renumber 3
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 14, and log in to Device C. (Details not shown.)
[Sysname] interface range ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/4
# Bind Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to IRF-port 3/1.
[Sysname] irf-port 3/1
[Sysname-irf-port3/1] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port3/1] port group interface ten-gigabitethernet 3/0/2
[Sysname-irf-port3/1] quit
# Bind Ten-GigabitEthernet 3/0/3 and Ten-GigabitEthernet 3/0/4 to IRF-port 3/2.
[Sysname] irf-port 3/2
[Sysname-irf-port3/2] port group interface ten-gigabitethernet 3/0/3
[Sysname-irf-port3/2] port group interface ten-gigabitethernet 3/0/4
[Sysname-irf-port3/2] quit
[Sysname] save
Device C reboots to join the IRF fabric.
4.     Configure Device D:
# Change the member ID of Device D to 4 and reboot the device to have the change take effect.
[Sysname] irf member 1 renumber 4
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 14, and log in to Device D. (Details not shown.)
# Shut down the physical interfaces.
[Sysname] interface range ten-gigabitethernet 4/0/1 to ten-gigabitethernet 4/0/4
# Bind Ten-GigabitEthernet 4/0/1 and Ten-GigabitEthernet 4/0/2 to IRF-port 4/1.
[Sysname] irf-port 4/1
[Sysname-irf-port4/1] port group interface ten-gigabitethernet 4/0/1
[Sysname-irf-port4/1] port group interface ten-gigabitethernet 4/0/2
[Sysname-irf-port4/1] quit
# Bind Ten-GigabitEthernet 4/0/3 and Ten-GigabitEthernet 4/0/4 to IRF-port 4/2.
[Sysname] irf-port 4/2
[Sysname-irf-port4/2] port group interface ten-gigabitethernet 4/0/3
[Sysname-irf-port4/2] port group interface ten-gigabitethernet 4/0/4
[Sysname-irf-port4/2] quit
[Sysname] save
Device D reboots to join the IRF fabric. A four-chassis IRF fabric is formed.
5.     Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
[Sysname] irf domain 1
# Create a dynamic aggregate interface and enable LACP MAD.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] link-aggregation mode dynamic
[Sysname-Bridge-Aggregation2] mad enable
[Current domain ID is: 1]:
The assigned domain ID is: 1
[Sysname-Bridge-Aggregation2] quit
# Assign Ten-GigabitEthernet 1/0/5, Ten-GigabitEthernet 2/0/5, Ten-GigabitEthernet 3/0/5, and Ten-GigabitEthernet 4/0/5 to the aggregate interface.
[Sysname] interface range ten-gigabitethernet 1/0/5 ten-gigabitethernet 2/0/5 ten-gigabitethernet 3/0/5 ten-gigabitethernet 4/0/5
[Sysname-if-range] port link-aggregation group 2
6.     Configure Device E as the intermediate device:
CAUTION
CAUTION:
If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
# Create a dynamic aggregate interface.
# Assign Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, Ten-GigabitEthernet 1/0/3, and Ten-GigabitEthernet 1/0/4 to the aggregate interface.
Example: Configuring a BFD MAD-enabled IRF fabric
As shown in Figure 15, set up a four-chassis IRF fabric at the distribution layer of the enterprise network.
·     Configure BFD MAD on the IRF fabric and set up BFD MAD links between each member device and the intermediate device.
·     Disable the spanning tree feature on the ports used for BFD MAD, because the two features conflict with each other.
Figure 15 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 15, and log in to Device B. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 15, and log in to Device C. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 15, and log in to Device D. (Details not shown.)
[Sysname] save
5.     Configure BFD MAD on the IRF fabric:
# Create VLAN 3, and add Ten-GigabitEthernet 1/0/5, Ten-GigabitEthernet 2/0/5, Ten-GigabitEthernet 3/0/5, and Ten-GigabitEthernet 4/0/5 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] port ten-gigabitethernet 1/0/5 ten-gigabitethernet 2/0/5 ten-gigabitethernet 3/0/5 ten-gigabitethernet 4/0/5
[Sysname-vlan3] quit
# Create VLAN-interface 3, and configure a MAD IP address for each member device on the VLAN interface.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad bfd enable
[Sysname-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[Sysname-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[Sysname-Vlan-interface3] mad ip address 192.168.2.3 24 member 3
[Sysname-Vlan-interface3] mad ip address 192.168.2.4 24 member 4
[Sysname-Vlan-interface3] quit
# Disable the spanning tree feature on Ten-GigabitEthernet 1/0/5, Ten-GigabitEthernet 2/0/5, Ten-GigabitEthernet 3/0/5, and Ten-GigabitEthernet 4/0/5.
[Sysname-if-range] undo stp enable
# Create VLAN 3, and assign Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, Ten-GigabitEthernet 1/0/3, and Ten-GigabitEthernet 1/0/4 to VLAN 3 for forwarding BFD MAD packets.
<DeviceE> system-view
[DeviceE] vlan 3
[DeviceE-vlan3] port ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[DeviceE-vlan3] quit
Example: Configuring an ARP MAD-enabled IRF fabric
As shown in Figure 16, set up a four-chassis IRF fabric in the enterprise network.
·     Configure ARP MAD on the IRF fabric and use the links connected to Device E for transmitting ARP MAD packets.
·     To prevent loops, run the spanning tree feature between Device E and the IRF fabric.
Figure 16 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 16, and log in to Device B. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 16, and log in to Device C. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 16, and log in to Device D. (Details not shown.)
[Sysname] save
5.     Configure ARP MAD on the IRF fabric:
# Enable the spanning tree feature globally. Map the ARP MAD VLAN to MSTI 1 in the MST region.
[Sysname] stp global enable
[Sysname-mst-region] region-name arpmad
[Sysname-mst-region] instance 1 vlan 3
[Sysname-mst-region] quit
# Configure the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
[Sysname] undo irf mac-address persistent
# Create VLAN 3, and assign Ten-GigabitEthernet 1/0/5, Ten-GigabitEthernet 2/0/5, Ten-GigabitEthernet 3/0/5, and Ten-GigabitEthernet 4/0/5 to VLAN 3.
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IP address, and enable ARP MAD on the interface.
[Sysname-Vlan-interface3] ip address 192.168.2.1 24
[Sysname-Vlan-interface3] mad arp enable
CAUTION
CAUTION:
If the intermediate device is also in an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
[DeviceE] stp global enable
[DeviceE] stp region-configuration
[DeviceE-mst-region] region-name arpmad
[DeviceE-mst-region] instance 1 vlan 3
[DeviceE-mst-region] active region-configuration
[DeviceE-mst-region] quit
# Create VLAN 3, and assign Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, Ten-GigabitEthernet 1/0/3, and Ten-GigabitEthernet 1/0/4 to VLAN 3 for forwarding ARP MAD packets.
[DeviceE] vlan 3
Example: Configuring an ND MAD-enabled IRF fabric
As shown in Figure 17, set up a four-chassis IRF fabric in the IPv6 enterprise network.
·     Configure ND MAD on the IRF fabric and use the links connected to Device E for transmitting ND MAD packets.
Figure 17 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 17, and log in to Device B. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 17, and log in to Device C. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 17, and log in to Device D. (Details not shown.)
[Sysname] save
5.     Configure ND MAD on the IRF fabric:
# Enable the spanning tree feature globally. Map the ND MAD VLAN to MSTI 1 in the MST region.
[Sysname-mst-region] region-name ndmad
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IPv6 address, and enable ND MAD on the interface.
[Sysname-Vlan-interface3] ipv6 address 2001::1 64
[Sysname-Vlan-interface3] mad nd enable
CAUTION
CAUTION:
[DeviceE-mst-region] region-name ndmad
# Create VLAN 3, and add Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, Ten-GigabitEthernet 1/0/3, and Ten-GigabitEthernet 1/0/4 to VLAN 3 for forwarding ND MAD packets.
[DeviceE] vlan 3
Configuring an IRF 3.1 system
About IRF 3.1
IRF 3.1 integrates multiple lower-layer devices with a higher-layer IRF fabric to provide high-density, low-cost connectivity at the access layer. IRF 3.1 is implemented based on IEEE 802.1BR.
In an IRF 3.1 system, the higher-layer IRF fabric is called the parent fabric and the lower-layer devices are called bridge port extenders (PEXs). You manage and configure the PEXs from the parent fabric as if they were interface modules on the parent fabric.
IRF 3.1 network model
Typically, IRF 3.1 works at the access layer of data centers and large-scale enterprise networks. As shown in Figure 18, the access layer of a network is virtualized into an IRF 3.1 system. The system contains one parent fabric (a two-chassis IRF fabric) and multiple PEXs to provide connectivity for servers and hosts.
Figure 18 IRF 3.1 application scenario
IRF 3.1 benefits
IRF 3.1 provides the following benefits:
·     Simplified topology—Devices in an IRF 3.1 system appear as one node. For redundancy and load balancing, a downstream or upstream device can connect to the IRF 3.1 system through multichassis link aggregation. Together with link aggregation, IRF 3.1 creates a loop-free Layer 2 network. The spanning tree feature is not needed among devices in the IRF 3.1 system or on the link aggregations. IRF 3.1 also simplifies the Layer 3 network topology because it reduces the number of routing peers. The network topology does not change when a device is added to or removed from the IRF 3.1 system.
·     Single point of management—An IRF 3.1 system is accessible at a single IP address on the network. You can use this IP address to log in through any network port to manage all the devices in the system. For an SNMP NMS, an IRF 3.1 system is one managed network node.
·     Network scalability and resiliency—You can increase the number of ports in an IRF 3.1 system by adding PEXs without changing network topology.
·     High availability—Each PEX has multiple high-speed physical ports for uplink connectivity to the parent fabric. The links on these ports are aggregated and load balanced automatically.
·     Decreased TCO—IRF 3.1 decreases hardware investments and management costs. In an IRF 3.1 system, the parent fabric performs all the management and routing functions, and the PEXs only forward traffic. You can add low-performance devices as PEXs to an IRF 3.1 system for network scalability.
·     High software compatibility—The software versions of the parent fabric and PEXs are highly compatible. You can independently upgrade software for the parent and PEXs.
Network topology
You can set up an IRF 3.1 system that contains one tier of PEXs. Each PEX is connected to the parent fabric through a Layer 2 aggregate interface in dynamic aggregation mode.
IMPORTANT
IMPORTANT:
To avoid loops, do not connect one PEX to another PEX.
Figure 19 IRF 3.1 network topology
Basic concepts
IRF 3.1 includes IRF concepts and adds the concepts in this section.
IRF 3.1 roles
The devices in an IRF 3.1 system have the following roles:
·     Parent fabric—Higher-layer single-chassis or multichassis IRF fabric that controls the entire IRF 3.1 system, including PEXs. Each IRF 3.1 system has one parent fabric.
·     Parent devices—Member devices in the parent fabric.
·     Master device—The device that controls and manages the entire IRF 3.1 system, including all parent devices and PEXs. The master device in the parent fabric is also the master device for the IRF 3.1 system. You configure all devices (including PEXs and parent devices) from the master device.
·     PEXs—Operate as I/O modules of the parent fabric to receive and transmit traffic. All forwarding decisions are made on the parent fabric. PEXs can be configured only on the parent fabric. Table 3 shows the operating states of PEXs.
Table 3 PEX operating states
Offline
The PEX is offline. The PEX and the parent fabric have not established a PE CSP connection. The PEX cannot be managed by the parent fabric.
Online
The PEX is online. An online PEX has been discovered by the parent fabric through LLDP and has finished Port Extender Control and Status Protocol (PE CSP) negotiation with the parent fabric.
Cascade port
A cascade port is a Layer 2 dynamic aggregate interface with PEX connection capability enabled, and it connects the parent fabric to a PEX. The physical interfaces assigned to a cascade port are cascade member interfaces.
Upstream port
An upstream port is a Layer 2 dynamic aggregate interface automatically created on a PEX for parent fabric connection. The aggregate interface automatically aggregates physical interfaces that connect the PEX to the cascade member interfaces of the parent fabric.
PEX group
A PEX group contains a group of PEXs that are connected to cascade ports assigned to the same PEX group.
Extended port
In an IRF 3.1 system, the physical interfaces on PEXs are called extended ports, except for the physical interfaces aggregated in the upstream ports.
Layer 2 extended-link aggregate interface
A Layer 2 extended-link aggregate interface aggregates a group of extended ports. The aggregation group of a Layer 2 extended-link aggregate interface is a Layer 2 extended-link aggregation group.
Layer 2 extended-link aggregate interfaces can act as interfaces that forward service traffic.
For more information about extended-link aggregate interfaces, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
Virtual slot number
Each PEX is identified by a unique virtual slot number in an IRF 3.1 system.
IRF 3.1 system setup process
Neighbor discovery
After you finish configuration on the parent fabric and a PEX and the PEX link is up, the parent fabric and the PEX send LLDP packets to each other for neighbor discovery.
PE CSP connection establishment
After the parent fabric and the PEX finish neighbor discovery, they send PE CSP Open requests to each other. If the parent fabric and the PEX can receive PE CSP Open responses from each other within 60 seconds, the connection between them is established.
PEX registration
After the connection is established between the parent and PEX, the PEX uses the following process to join the IRF 3.1 system:
1.     The PEX requests to register with the parent fabric. The parent fabric assigns the configured virtual slot number to the PEX.
2.     The PEX requests to create its extended ports on the parent fabric. After receiving the request, the parent fabric creates the extended ports of the PEX on the parent fabric and assigns an E-channel Identifier (ECID) to each port. The ECID must be unique in the PEX group. At the same time, the interface attributes such as link state, duplex state, and rate are synchronized from the PEX to the parent fabric.
PEX link maintenance
The parent fabric and the PEX use Layer 2 aggregate interfaces in dynamic aggregation mode to connect each other. The Layer 2 aggregate interface uses LACP and PE CSP to detect and maintain link status. The PEX is offline when the aggregate interface is down or when the parent fabric and PEX do not receive PE CSP responses from each other within 60 seconds. For the PEX to come online again, the parent fabric and PEX must send PE CSP Open requests to each other and can receive Open responses from each other.
Interface naming conventions
After a PEX joins an IRF 3.1 system, the first segment in its interface numbers changes to the virtual slot number assigned to the PEX. For example, a PEX has an interface numbered 1/0/1 before it is added to an IRF 3.1 system. After it is added to an IRF 3.1 system as slot 100, the interface number changes to 100/0/1.
Configuration management
An IRF 3.1 system manages all its settings (including settings for PEXs) on the master device. You can configure and manage PEXs from the master device. The running configuration on the master device typically has all settings in the IRF 3.1 system, including settings for PEXs. When a PEX reboots or is added, the master device issues the running configuration of the virtual chassis or slot to the PEX.
Data forwarding
When PEX local forwarding is enabled for a PEX, the PEX performs local forwarding for Layer 2 unicast packets with known MAC addresses. For other packets, the PEX forwards them to the parent fabric for processing.
When PEX local forwarding is disabled for a PEX, the PEX sends any incoming traffic to the parent fabric. The parent fabric makes forwarding decisions and sends the traffic to the outgoing interfaces (see Figure 20).
When the PEX receives a packet, it tags the packet with an E-tag. The E-tag carries the ECID of the interface that receives the packet. IRF 3.1 forwards the packet based on the ECID within the IRF 3.1 system. When the packet leaves the IRF 3.1 system, the E-tag is removed.
Figure 20 Data forwarding model
Protocols and standards
IEEE 802.1BR, Virtual Bridged Local Area Networks—Bridge Port Extension
Restrictions and guidelines: IRF 3.1 configuration
Hardware compatibility with IRF 3.1
A switch from this series can act only as a parent device in an IRF 3.1 system.
You can attach the FS4100 switch series as fit PEXs to a parent fabric of this switch series.
You do not need to configure the FS4100 fit switches. After you connect the upstream member interfaces of an FS4100 fit switch to the cascade member interfaces of the parent fabric, the switch will act as a fit PEX.
System operating mode restrictions
Before you configure IRF 3.1 settings, you must use the switch-mode 2 command to set the system operating mode to 802.1BR. For more information about setting the system operating mode, see device management in Fundamentals Configuration Guide.
PEX upstream member interface requirements
You can use only some high-speed physical interfaces on a PEX as upstream member interfaces. To identify candidate upstream member interfaces, use one of the following methods:
·     Obtain information from the configuration guide for the device to be used as a PEX.
·     Execute the display system internal pex upstreamport command in probe view on the device to be used as a PEX when the device operates in PEX mode.
Loop elimination
By default, the spanning tree feature is disabled on the ports of PEXs to prevent unnecessary topology calculations and conserve system resources. When you set up an IRF 3.1 system, you must make sure it is physically or logically loop free.
To conserve system resources, set up a physically loop-free IRF 3.1 system as shown in "Network topology." Make sure no connections exist between PEXs or between PEXs and parent devices except the cascade links.
If a port on a PEX is in a loop because of physical redundancy design, you must enable the spanning tree feature on that port.
Link aggregation restrictions and guidelines
To assign extended ports to a Layer 2 extended-link aggregation group, make sure the PEXs that contain the ports meet the following requirements:
·     The PEXs belong to the same switch series.
·     The PEXs are in the same PEX group.
An FS4100 fit PEX does not support Layer 2 extended-link aggregate interfaces.
IRF split detection requirements
For the PEXs to quickly identify parent fabric split events, perform the following tasks on the parent fabric:
·     Use the lacp system-priority command to set the system LACP priority to a value lower than 32768.
·     Use the undo irf mac-address persistent command to disable IRF bridge MAC persistence. In addition, do not specify an IRF bridge MAC address by using the irf mac-address mac-address command.
Ports on a PEX cannot be used for IRF MAD of the parent fabric.
Configuration rollback restrictions
As a best practice, do not roll back the configuration if the replacement configuration file contains IRF 3.1 settings different than the running configuration. If you roll back the configuration, the system might fail to reconfigure IRF 3.1 settings as expected. For more information about the configuration rollback feature, see configuration file management in Fundamentals Configuration Guide.
IRF 3.1 tasks at a glance
IRF 3.1 supports manual PEX configuration and PEX autoconfiguration.
For PEXs to come online or operate correctly, do not manually configure PEXs when the PEX autoconfiguration feature is enabled on the IRF 3.1 system.
Configuring an IRF 3.1 system with manually configured PEXs
To configure an IRF 3.1 system with manually configured PEXs, perform the following tasks:
1.     Setting up the parent fabric
2.     Configuring PEXs on the parent fabric
a.     Creating a PEX group
b.     Configuring cascade ports
c.     Assigning virtual slot numbers to PEXs
d.     Connecting the PEXs to the parent fabric
3.     (Optional.) Maintaining an IRF 3.1 system
¡     Enabling PEX local forwarding
¡     Enabling PEX persistent forwarding
¡     Logging in to a PEX from the parent fabric
¡     Deleting idle cascade ports
4.     Removing PEXs from an IRF 3.1 system
Configuring an IRF 3.1 system with automatically configured PEXs
To configure an IRF 3.1 system with automatically configured PEXs, perform the following tasks:
2.     Enabling PEX autoconfiguration
3.     Connecting the PEXs to the parent fabric
4.     (Optional.) Maintaining an IRF 3.1 system
5.     Removing PEXs from an IRF 3.1 system
Planning the IRF 3.1 system setup
Consider the following items when you plan an IRF 3.1 system:
·     IRF 3.1 system size.
·     Parent devices and PEXs.
·     Cascade ports, cascade member interfaces, upstream member interfaces, and cabling scheme.
·     Virtual slot assignment for PEXs.
The plan must meet the requirements described in "Restrictions and guidelines: IRF 3.1 configuration."
For more information about hardware and cabling, see the installation guide for the device.
You can use a single-member or multimember IRF fabric as the parent fabric. Before you set up the parent fabric, change the operating mode of its member devices to switch. To set up the parent fabric, use the procedure described in "Configuring an IRF fabric."
After a PEX group is created, the device automatically enables the NTP service and specifies the local clock as the reference source at stratum 2.
If you delete a PEX group, all PEXs in that group will go offline with all settings issued from the parent device removed.
2.     Create a PEX group.
pex group group-id
3.      (Optional.) Configure a description for the PEX group.
By default, the description for a PEX group uses the PEX group group-id format.
Perform this task to configure a cascade port to connect the parent fabric to a PEX.
The cascade port must be a Layer 2 aggregate interface that contains the physical interfaces towards that PEX. On that aggregate interface, you must enable its PEX connection capability.
The system automatically places a Layer 2 aggregate interface in dynamic aggregation mode after you enable its PEX connection capability. In addition, the system automatically configures the aggregate interface as an edge port of the spanning tree feature for the PEX to quickly come online.
Make sure all physical interfaces assigned to a cascade port connect to the same PEX.
For PEXs to come online successfully, do not execute any other commands on cascade ports except for the IRF 3.1 commands, the shutdown command, and the description command. In addition, do not execute any other commands on the cascade member interfaces except for the lldp enable command.
Disabling PEX connection capability on a cascade port causes the attached PEX to go offline. When you assign a cascade port to a new PEX group, its attached PEX goes offline and then comes online again. When the PEX goes offline in either situation, all settings issued from the parent fabric are automatically removed from the PEX.
2.     Enable LLDP globally.
lldp global enable
On the S5560X-HI, S6520X-EI, S6520X-HI, S6520X-SI, and S6520-SI switch series, the default setting varies by startup configuration.
¡     If the device starts up with the initial configuration, LLDP is disabled globally.
¡     If the device starts up with factory defaults, LLDP is enabled globally.
On the S5000-EI switch series, LLDP is disabled globally by default.
3.     Create a Layer 2 aggregate interface and enter Layer 2 aggregate interface view.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number as the aggregate interface. The aggregation group operates in static aggregation mode by default.
4.     Enable PEX connection capability on the Layer 2 aggregate interface and assign it to a PEX group.
pex-capability enable group group-id
By default, an aggregate interface cannot connect PEXs.
6.     Enter Layer 2 Ethernet interface view or Layer 2 Ethernet interface range view.
7.     Assign Layer 2 Ethernet ports to the aggregation group.
All physical interfaces assigned to the aggregate interface must connect to the same PEX
8.     Enable LLDP on the ports.
lldp enable
By default, LLDP is enabled on a port.
When you remove or change the virtual PEX slot number of an online PEX, make sure you understand its impact on that PEX:
·     If you remove the virtual slot number, the PEX goes offline.
·     If you change the virtual slot number, the PEX goes offline and then comes online with the new virtual slot number.
·     All settings issued from the parent fabric are cleared on the PEX after the PEX goes offline.
2.     Enter Layer 2 aggregate interface view.
3.     Assign a virtual slot number to the PEX.
pex associate slot slot-number
By default, no virtual slot number is assigned to a PEX.
After PEX autoconfiguration is enabled, the parent fabric identifies a device as a PEX once it receives LLDP packets carrying the Port Extension TLV from the device. The parent fabric automatically establishes a connection with the device and issues PEX settings to the device.
A PEX is automatically configured in the following process:
1.     The parent fabric automatically creates PEX group 1 for PEXs to come online through autoconfiguration.
2.     After receiving LLDP packets from the PEX, the parent fabric creates a Layer 2 aggregate interface and assigns the physical interfaces connecting to the PEX to the aggregation group. The number of the Layer 2 aggregate interface is randomly selected from the unused interface numbers in the system.
3.     The parent fabric enables PEX connection capability on the Layer 2 aggregate interface and assigns the interface to PEX group 1.
4.     The parent fabric assigns an unused virtual slot number to the PEX.
After the process, the PEX comes online.
You can view log messages or execute the display current-configuration command to obtain the detailed PEX settings issued by the PEX autoconfiguration feature.
For an IRF 3.1 system enabled with PEX autoconfiguration to operate correctly, follow these restrictions and guidelines:
·     Do not execute any other commands on the cascade ports except for the automatically configured IRF 3.1 commands.
·     Do not execute any other commands on the cascade member interfaces except for the lldp enable command.
Disabling PEX autoconfiguration does not affect the PEX configuration already issued.
lldp global enable
3.     Enter Layer 2 Ethernet interface view or Layer 2 Ethernet interface range view.
¡     Enter interface view.
¡     Enter interface range view.
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
To enable LLDP on one port, enter Ethernet interface view.
To enable LLDP on a range of ports, enter interface range view.
4.     Enable LLDP on the ports.
lldp enable
6.     Enable PEX autoconfiguration.
pex auto-config enable
By default, PEX autoconfiguration is disabled.
Connect the upstream member interfaces on a PEX to the cascade member interfaces of the cascade port on the parent fabric.
To identify candidate upstream member interfaces, see "PEX upstream member interface requirements."
For information about connection restrictions and guidelines, see "Network topology."
This feature enables a PEX to perform local forwarding for Layer 2 unicast packets with known MAC addresses. The PEX reports other packets to the parent fabric for processing.
If PEX local forwarding is disabled for a PEX, the PEX sends any incoming traffic to the parent fabric. The parent fabric makes forwarding decisions and sends the traffic to the outgoing interfaces.
When you enable or disable PEX local forwarding on a cascade port, the PEX will go offline and then come online again.
With PEX local forwarding enabled, an FS4100 PEX delivers all packets except for Layer 2 known unicast packets to the parent fabric through the CPU. The delivery rate is limited by the CPU forwarding rate.
2.     Enter Layer 2 aggregate interface view of a cascade port.
3.     Enable PEX local forwarding.
pex local-forwarding
By default, PEX local forwarding is disabled.
If PEX persistent forwarding is enabled for a PEX, the system will not clear the running data or shut down the network interfaces on the PEX after the PEX goes offline. The PEX can still perform local forwarding.
If PEX persistent forwarding is disabled for a PEX, the system clears the running data and shuts down all network interfaces on the PEX after the PEX goes offline. However, the system does not shut down the upstream member interfaces on the PEX. The PEX will attempt to recover the connection with the parent fabric by sending protocol control packets out of the upstream member interfaces.
For PEX persistent forwarding to take effect on a PEX, you must enable PEX local forwarding for that PEX.
3.     Enable PEX persistent forwarding.
pex persistent-forwarding
By default, PEX persistent forwarding is disabled.
After you log in to a PEX, you can execute the following commands:
·     The display commands.
·     File system management commands. To obtain information about the access permissions to the commands, use the display role feature name filesystem command in RBAC. For more information about the file system management and RBAC commands, see Fundamentals Command Reference.
2.     Log in to a PEX.
switchto pex slot slot-number
Perform this task to delete all the cascade ports of which the connected PEXs are offline to release resources.
For the connected PEX of a deleted cascade port to come online again, you must reconfigure a cascade port for connecting the PEX. Do not delete a cascade port if the connected PEX goes offline temporarily.
2.     Delete idle cascade ports.
pex idle-cascade delete
To temporarily remove a PEX from an IRF 3.1 system, disconnect the PEX links between the PEX and the parent fabric or power off the PEX.
To remove a PEX from an IRF 3.1 system and use it as an independent device, log in to the PEX through the console port and change the operating mode to switch.
2.     Change the PEX to switch mode.
pex system-working-mode switch
By default, the device operates in auto mode.
CAUTION
CAUTION:
Make sure you set the operating mode of the device in compliance with the network design. When you change its operating mode, make sure you understand the impact of the change on the network.
For more information about this command, see the command references for the PEX.
3.     Save the running configuration.
save
The device will operate in the mode set in the startup configuration after a reboot if you do not save the running configuration.
4.     Return to user view.
5.     Reboot the PEX for the mode change to take effect.
reboot
Display and maintenance commands for IRF 3.1
Display device information.
display device
Display electronic label information for the device.
display device manuinfo
Display information about PEX state and PE CSP statistics for a cascade port or for all cascade ports.
display pex interface [ interface-name ] [ brief ]
Display PEX topology information.
display pex topology
Display system version information.
display version
For information about the display device, display device manuinfo, and display version commands, see Fundamentals Command Reference.
IRF 3.1 configuration examples
Example: Configuring an IRF 3.1 system
As shown in Figure 21, set up an IRF 3.1 system that contains the following devices:
·     A two-chassis parent fabric that contains switches from this series.
·     Two FS4100-26S PEXs (PEX 100 and PEX 101).
Figure 21 Network diagram
# Log in to Member 1 and Member 2, and change the operating mode of Member 1 and Member 2 to switch, respectively.
[Sysname] pex system-working-mode switch
# Set up a two-chassis IRF fabric with Member 1 and Member 2, as described in "Configuring an IRF fabric." (Details not shown.)
Configuring cascade ports for PEXs on the parent fabric
# Enter the system view.
# Enable LLDP globally.
[Sysname] lldp global enable
# Create PEX group 1.
[Sysname] pex group 1
[Sysname-pex-group-1] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 100. The aggregate interface will act as the cascade port to the PEX in slot 100.
[Sysname] interface bridge-aggregation 100
# Enable PEX connection capability on Bridge-Aggregation 100 and assign Bridge-Aggregation 100 to PEX group 1.
[Sysname-Bridge-Aggregation100] pex-capability enable group 1
The aggregate interface was automatically set to dynamic aggregation mode and configured as an STP edge port.
# Assign virtual slot number 100 to the PEX.
[Sysname-Bridge-Aggregation100] pex associate slot 100
[Sysname-Bridge-Aggregation100] quit
# Enable LLDP on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 2/0/1 in interface range view, and assign the ports to aggregation group 100. The ports will act as cascade member interfaces.
[Sysname] interface range ten-gigabitethernet 1/0/1 ten-gigabitethernet 2/0/1
[Sysname-if-range] lldp enable
[Sysname-if-range] port link-aggregation group 100
# Create Layer 2 aggregate interface Bridge-Aggregation 101. The aggregate interface will act as the cascade port to the PEX in slot 101.
[Sysname] interface bridge-aggregation 101
# Enable PEX connection capability on Bridge-Aggregation 101 and assign the interface to PEX group 1.
[Sysname-Bridge-Aggregation101] pex-capability enable group 1
# Assign virtual slot number 101 to the PEX.
[Sysname-Bridge-Aggregation101] pex associate slot 101
[Sysname-Bridge-Aggregation101] quit
# Enable LLDP on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 2/0/2 in interface range view, and assign the ports to aggregation group 101. The ports will act as cascade member interfaces.
[Sysname] interface range ten-gigabitethernet 1/0/2 ten-gigabitethernet 2/0/2
[Sysname-if-range] port link-aggregation group 101
Configuring PEXs
# Connect the highest numbered two ports on the PEX device panel to the cascade member interfaces of the parent fabric. Because the FS4100 switches are fit PEXs, no additional configuration is required.
# Display device information on the parent fabric. Verify that the output contains information about both the parent fabric and the PEXs.
<Sysname> display device
# Display PEX topology information.
<Sysname> display pex topology
Group  1
  Tier 1
    PEX 100 -----> Parent
    PEX 101 -----> Parent
  • Become a Partner
  • Partner Resources
