- 06-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-MLD snooping commands
- 09-IPv6 PIM snooping commands
- 10-IPv6 multicast VLAN commands
- 11-IPv6 multicast routing and forwarding commands
- 12-MLD commands
- 13-IPv6 PIM commands
| 06-PIM commands | 280.23 KB |
bsm-fragment enable (PIM view)
bsm-reflection enable (PIM view)
display interface register-tunnel
hello-option dr-priority (PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (PIM view)
holdtime join-prune (PIM view)
pim hello-option neighbor-tracking
pim hello-option override-interval
register-suppression-timeout (PIM view)
register-whole-checksum (PIM view)
spt-switch-threshold (PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (PIM view)
PIM commands
anycast-rp (PIM view)
Use anycast-rp to add an anycast RP member to an Anycast RP set.
Use undo anycast-rp to remove an anycast RP member from an Anycast RP set.
anycast-rp anycast-rp-address member-address
undo anycast-rp anycast-rp-address member-address
No Anycast RP sets exist.
PIM view
anycast-rp-address: Specifies an Anycast RP address. It must be a legal unicast IP address that is not in the range of 127.0.0.0/8.
member-address: Specifies an Anycast RP member address. It must be a legal unicast IP address that is not in the range of 127.0.0.0/8 and must be different from the Anycast RP address.
To add multiple RP member addresses to an Anycast RP set, execute this command multiple times with the same Anycast RP address but different RP member addresses.
To configure multiple Anycast RP sets, execute this command multiple times with different Anycast RP addresses.
# Add Anycast RP members 1.1.0.1 and 1.2.0.1 to Anycast RP set 1.1.0.0.
[Sysname] pim
[Sysname-pim] anycast-rp 1.1.0.0 1.1.0.1
[Sysname-pim] anycast-rp 1.1.0.0 1.2.0.1
display pim rp-info
auto-rp enable (PIM view)
Use auto-rp enable to enable Auto-RP listening.
Use undo auto-rp enable to disable Auto-RP listening.
auto-rp enable
undo auto-rp enable
Auto-RP listening is disabled.
PIM view
After Auto-RP listening is enabled, the device can receive and forward Auto-RP announcement and discovery messages, but it cannot send these messages unsolicitedly.
# Enable Auto-RP listening.
[Sysname] pim
[Sysname-pim] auto-rp enable
bidir-pim enable (PIM view)
Use bidir-pim enable to enable BIDIR-PIM.
Use undo bidir-pim enable to disable BIDIR-PIM.
bidir-pim enable
BIDIR-PIM is disabled.
PIM view
This command takes effect only when IP multicast routing is enabled on the public network or for a VPN instance to which the device belongs.
# Enable IP multicast routing, and enable BIDIR-PIM.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] pim
[Sysname-pim] bidir-pim enable
multicast routing
bidir-rp-limit (PIM view)
Use bidir-rp-limit to set the maximum number of BIDIR-PIM RPs.
Use undo bidir-rp-limit to restore the default.
bidir-rp-limit limit
undo bidir-rp-limit
The maximum number of BIDIR-PIM RPs is 6.
PIM view
limit: Specifies the maximum number of BIDIR-PIM RPs, in the range of 1 to 32.
In a BIDIR-PIM domain, one DF election per RP is implemented on all PIM interfaces. To avoid unnecessary DF elections, do not configure multiple BIDIR-PIM RPs.
This command sets a limit on the number of BIDIR-PIM RPs. If the number of RPs exceeds the limit, excess RPs can be used only for DF election rather than multicast data forwarding.
# Set the maximum number of BIDIR-PIM RPs to 3.
[Sysname] pim
[Sysname-pim] bidir-rp-limit 3
Use bsm-fragment enable to enable bootstrap message (BSM) semantic fragmentation.
Use undo bsm-fragment enable to disable BSM semantic fragmentation.
bsm-fragment enable
BSM semantic fragmentation is enabled.
PIM view
Disable BSM semantic fragmentation if the PIM-SM or BIDIR-PIM domain contains a device that does not support BSM semantic fragmentation.
# Disable BSM semantic fragmentation.
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
Use bsm-reflection enable to enable the device to forward BSMs out of their incoming interfaces.
Use undo bsm-reflection enable to disable the device from forwarding BSMs out of their incoming interfaces.
The device forwards BSMs out of their incoming interfaces.
PIM view
Disable this feature if all the devices in the PIM-SM or BIDIR-PIM domain have consistent routing information.
# Disable the device from forwarding BSMs out of their incoming interfaces.
[Sysname] pim
[Sysname-pim] undo bsm-reflection enable
bsr-policy (PIM view)
Use bsr-policy to configure a BSR policy.
Use undo bsr-policy to restore the default.
bsr-policy ipv4-acl-number
undo bsr-policy
No BSR policy exists, and all bootstrap messages are regarded as legal.
PIM view
ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999.
A BSR policy filters bootstrap messages to guard against BSR spoofing.
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
· The source source-address source-wildcard option specifies a BSR address.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure a BSR policy so that only the devices on subnet 10.1.1.0/24 can act as the BSR.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] bsr-policy 2000
c-bsr (PIM view)
c-bsr (PIM view)
Use c-bsr to configure a candidate-BSR (C-BSR).
Use undo c-bsr to remove the configuration of a C-BSR.
c-bsr ip-address [ scope group-address { mask-length | mask } ] [ hash-length hash-length | priority priority ] *
undo c-bsr ip-address [ scope group-address { mask-length | mask } ]
No C-BSRs exist.
PIM view
ip-address: Specifies the IP address of a C-BSR. You must specify the IP address of a local PIM interface.
scope group-address: Specifies a multicast group by its IP address in the range of 239.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command designates the C-BSR to the global-scoped zone.
mask-length: Specifies an address mask length in the range of 8 to 32.
mask: Specifies an address mask.
hash-length hash-length: Specifies a hash mask length in the range of 0 to 32. The default setting is 30.
priority priority: Specifies a C-BSR priority in the range of 0 to 255. The default setting is 64. The greater the value, the higher the priority.
If you execute this command for a zone multiple times, the most recent configuration takes effect.
You can configure the same C-BSR for different zones.
# Configure the interface with IP address 1.1.1.1 as a C-BSR for the global-scoped zone.
[Sysname] pim
[Sysname-pim] c-bsr 1.1.1.1
c-rp (PIM view)
Use c-rp to configure a candidate-RP (C-RP).
Use undo c-rp to remove the configuration of a C-RP.
c-rp ip-address [ advertisement-interval adv-interval | group-policy { ipv4-acl-number | name ipv4-acl-name } | holdtime hold-time | priority priority ] * [ bidir ]
undo c-rp ip-address
No C-RPs exist.
PIM view
ip-address: Specifies the IP address of a C-RP. You must specify the IP address of a local PIM interface.
advertisement-interval adv-interval: Specifies a C-RP advertisement interval in the range of 1 to 65535 seconds. The default value is 60 seconds.
group-policy ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, this command designates the C-RP to IPv4 multicast groups in C-RP advertisement messages that the ACL permits. The C-RP is designated to all IPv4 multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not have valid rules.
group-policy name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If you specify an ACL, this command designates the C-RP to IPv4 multicast groups in C-RP advertisement messages that the ACL permits. The C-RP is designated to all IPv4 multicast groups when one of the following conditions exists:
holdtime hold-time: Specifies a C-RP lifetime in the range of 1 to 65535 seconds. The default value is 150 seconds.
priority priority: Specifies a C-RP priority in the range of 0 to 255. The default setting is 192. The greater the value, the lower the priority.
bidir: Specifies BIDIR-PIM to which the C-RP is designated. If you do not specify this keyword, the C-RP provides services for PIM-SM.
To designate a C-RP to multiple multicast group ranges, create multiple rules that specify different multicast group ranges in the ACL.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
· For the rule to take effect, do not specify the vpn-instance vpn-instance option.
· The source source-address source-wildcard option specifies a multicast group range. A-CRP advertisement message is permitted if the multicast group address in the message matches the source option.
If you execute this command by using the same C-RP address multiple times, the most recent configuration takes effect.
# Configure the interface with IP address 1.1.1.1 as a C-RP for multicast group ranges 225.1.0.0/16 and 226.2.0.0/16 and set its priority to 10.
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp 1.1.1.1 group-policy 2000 priority 10
crp-policy (PIM view)
Use crp-policy to configure a C-RP policy.
Use undo crp-policy to restore the default.
crp-policy ipv4-acl-number
undo crp-policy
No C-RP policy exists, and all C-RP messages are regarded as legal.
PIM view
ipv4-acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999.
A C-RP policy filters C-RP advertisement messages to guard against C-RP spoofing.
The device uses only the prefixes of the multicast group ranges in advertisement messages to match the destination field in ACL rules. For example, the multicast group range in an advertisement message is 224.1.0.0/16. If the prefix 224.1.0.0 is in the range specified by the destination field of an ACL rule, the specified C-RPs are designated to this multicast group range.
When you configure a rule in the IPv4 advanced ACL, follow these restrictions and guidelines:
· The source source-address source-wildcard option specifies an RP address.
· The destination dest-address dest-wildcard option specifies a multicast group address.
# Configure a C-RP policy so that only devices in the range of 1.1.1.1/24 can be C-RPs for the groups in the range of 225.1.1.0/24.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] crp-policy 3000
c-rp (PIM view)
Use display interface register-tunnel to display register-tunnel interface information.
display interface [ register-tunnel [ interface-number ] ] [ brief [ description | down ] ]
register-tunnel [ interface-number ]: Specifies a register-tunnel interface by its number. The device has only one register-tunnel interface, Register-Tunnel 0. If you specify the register-tunnel keyword, this command displays information about Register-Tunnel 0 regardless of whether you specify an interface number. If you do not specify the register-tunnel keyword, this command displays information about all interfaces.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
description: Displays the full interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description.
down: Displays information about the interfaces in down state and the reasons why the interfaces are down. If you do not specify this keyword, the command displays information about interfaces in all states.
The register-tunnel interface is a virtual interface that is automatically created by the system. You cannot configure it or delete it, but you can display the interface information by using this command.
In the initial stage of multicast source registration, the register-tunnel interface is used to establish a channel between the source-side DR and the RP to transmit multicast register messages. The process of initial source registration is as follows:
1. After receiving the first multicast data from the source, the source-side DR encapsulates the multicast data into a register message. Then, it forwards the message to the RP through the register-tunnel interface.
2. The register message reaches RP on the register-tunnel interface on the RP. The RP decapsulates the register message and forwards the multicast data to the receiver hosts. At the same time, the RP learns the IP address of the multicast source.
3. The RP sends a join message toward the multicast source to build an SPT.
4. After the SPT is built, the multicast data travels to the RP along the SPT rather than through the register-tunnel interface.
# Display detailed information about Register-Tunnel 0.
<Sysname> display interface register-tunnel 0
Register-Tunnel0
Current state: UP
Line protocol state: DOWN
Description: Register-Tunnel0 Interface
Maximum transmission unit: 1536
Physical: Unknown
# Display brief information about Register-Tunnel 0.
<Sysname> display interface register-tunnel 0 brief
Protocol: (s) - spoofing
REG0 UP -- --
Current state |
Physical link state of the interface. This field always displays UP. |
Line protocol state |
Data link layer state of interface. This field always displays DOWN. |
Description of the interface. It is not configurable. |
Maximum transmission unit |
MTU of the register-tunnel interface. It is not configurable. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Physical |
Physical type of the interface. This field always displays Unknown, because the physical type of the interface is unknown. |
Last 300 seconds input rate |
Average incoming rate in the last 300 seconds. This field always displays 0. |
Last 300 seconds output rate |
Average outgoing rate in the last 300 seconds. This field always displays 0. |
Input |
Number of incoming packets, incoming bytes, and discarded packets. This field always displays 0. |
Output |
Number of outgoing packets, outgoing bytes, and discarded packets. This field always displays 0. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Link |
Protocol |
Data link layer protocol state of the interface. This field always displays two hyphens (--) because the interface does not support a data link layer protocol. |
Primary IP |
Primary IP address of the interface. This field always displays two hyphens (--) because the interface does not have a primary IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. This field always displays Not connected because no physical connection exists. |
Description of the interface. This field is empty because the interface cannot be configured with a description. |
Related command
reset counters interface register-tunnel
display pim bsr-info
Use display pim bsr-info to display BSR information.
# Display BSR information.
<Sysname> display pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:01:44
Elected BSR address: 12.12.12.1
Priority: 64
Hash mask length: 30
Uptime: 00:21:56
Scope: 239.4.0.0/16
State: Accept Any
Scope-zone expiry timer: 00:21:12
Scope: 239.1.0.0/16
State: Elected
Bootstrap timer: 00:00:26
Elected BSR address: 17.1.11.1
Priority: 64
Uptime: 02:53:37
Candidate BSR address: 17.1.11.1
Priority: 64
Scope: 239.2.2.0/24
State: Candidate
Bootstrap timer: 00:01:56
Elected BSR address: 61.2.37.1
Priority: 64
Uptime: 02:53:32
Candidate BSR address: 17.1.12.1
Priority: 64
Scope: 239.3.3.0/24
State: Pending
Bootstrap timer: 00:00:07
Candidate BSR address: 17.1.13.1
Priority: 64
Bootstrap timer |
Aging timer for the BSR. |
Scope-zone expiry timer |
Aging timer for the scoped zone. |
Elected BSR address |
Address of the elected BSR. |
Candidate BSR address |
Address of the C-BSR. |
Priority |
BSR priority. |
Uptime |
Length of time the BSR has been up. |
display pim claimed-route
Use display pim claimed-route to display information about all routes that PIM uses.
display pim claimed-route [ source-address ]
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about all routes that PIM uses.
# Display information about all routes that PIM uses.
<Sysname> display pim claimed-route
RPF-route selecting rule: longest-match
Route/mask: 7.11.0.0/16 (unicast (direct))
RPF interface: Vlan-interface2, RPF neighbor: 8.0.0.2
Total number of (S,G) or (*,G) dependent on this route entry: 4
(7.11.0.10, 225.1.1.1)
(7.11.0.10, 226.1.1.1)
(7.11.0.10, 227.1.1.1)
(*, 228.1.1.1)
Route/mask: 7.12.0.0/16 (multicast static)
RPF interface: Vlan-interface2, RPF neighbor: 8.0.0.3,
Config NextHop: 8.0.0.5
Total number of (S,G) or (*,G) dependent on this route entry: 2
(7.12.0.10, 226.1.1.1)
(7.12.0.10, 225.1.1.1)
Route/mask |
Route entry. Route types in parentheses include: · igp—IGP unicast route. · egp—EGP unicast route. · unicast (direct)—Direct unicast route. · unicast—Other unicast route, such as static unicast route. · mbgp—MBGP route. · multicast static—Static multicast route. |
RPF interface |
Name of the RPF interface. |
RPF neighbor |
IP address of the RPF neighbor. |
Config NextHop |
Address of the configured next hop. This field is displayed only when the static multicast route is configured with a next hop. |
Total number of (S,G) or (*,G) dependent on this route entry |
Total number of (S, G) or (*, G) entries associated with the RPF route and the entry list. |
display pim c-rp
Use display pim c-rp to display C-RP information.
display pim c-rp [ local ]
local: Specifies local C-RPs. If you do not specify this keyword, the command displays information about all C-RPs.
You can view information about learned C-RPs only on the BSR. On other devices, you can view information about the locally configured C-RPs.
# Display information about learned C-RPs.
<Sysname> display pim c-rp
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4
C-RP address Priority HoldTime Uptime Expires
1.1.1.1 (local) 192 150 03:01:36 00:02:29
2.2.2.2 192 150 1d:13h 00:02:02
Group/MaskLen: 226.1.1.0/24 [B] Expires: 00:00:33
Group/MaskLen: 225.1.0.0/16 [B]
C-RP Address Priority HoldTime Uptime Expires
3.3.3.3 192 150 12w:5d 00:02:05
# Display information about the locally configured C-RPs.
<Sysname> display pim c-rp local
Candidate RP: 12.12.12.9(Loop1)
Priority: 192
HoldTime: 150
Advertisement interval: 60
Next advertisement scheduled at: 00:00:48
Group/MaskLen |
Multicast group to which the C-RP is designated. |
[B] |
BIDIR-PIM C-RP. This field is not displayed if the C-RP is a PIM-SM C-RP. |
C-RP address |
IP address of the C-RP. If the C-RP resides on the device where the command is executed, this field displays (local) after the address. |
Priority |
Priority of the C-RP. |
HoldTime |
Lifetime of the C-RP. |
Uptime |
Length of time the C-RP has been up: · w—Weeks. · d—Days. · h—Hours. |
Expires |
Remaining lifetime for the C-RP and the multicast group. |
Candidate RP |
IP address of the locally configured C-RP. |
Advertisement interval |
Interval between two advertisement messages sent by the locally configured C-RP. |
Next advertisement scheduled at |
Remaining time for the locally configured C-RP to send the next advertisement message. |
display pim df-info
Use display pim df-info to display BIDIR-PIM DF information.
display pim df-info [ rp-address ]
rp-address: Specifies a BIDIR-PIM RP by its IP address.
# Display BIDIR-PIM DF information.
<Sysname> display pim df-info
RP address: 12.12.12.12
Interface: Vlan-interface1
State : Win DF preference: 10
DF metric : 1562 DF uptime : 00:06:59
DF address: 30.1.1.11 (local)
Interface: Tunnel2, 100.1.1.12
State : Lose DF preference: 0
DF metric : 0 DF uptime : 00:06:59
DF address: 100.1.1.12
Table 5 Command output
RP address |
IP address of the BIDIR-PIM RP. |
DF interface. |
State |
DF election state: · Win—The interface wins the DF election. · Lose—The interface loses the DF election. · Offer—The interface is in the initial state of the DF election. · Backoff—The interface is acting as the DF, but there are more appropriate devices running for the DF. This field displays a hyphen (-) if the interface does not participate in the DF election. |
DF preference |
Advertised route preference for DF election. |
DF metric |
Advertised route metric for DF election. |
DF uptime |
Length of time the DF has been up. |
DF address |
IP address of DF. If the DF resides on the device where the command is executed, this field displays (local) after the IP address. |
display pim interface
Use display pim interface to display PIM information for interfaces.
display pim interface [ interface-type interface-number ] [ verbose ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PIM information for all interfaces.
verbose: Displays detailed PIM information. If you do not specify this keyword, the command displays brief PIM information.
# Display brief PIM information for all interfaces.
<Sysname> display pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
Vlan1 1 30 1 10.1.1.2
Vlan2 0 30 1 172.168.0.2 (local)
Vlan3 1 30 1 20.1.1.2
Table 6 Command output
NbrCnt |
Number of PIM neighbors. |
HelloInt |
Interval for sending hello messages. |
DR-Pri |
Priority for DR election. |
DR-Address |
IP address of the DR. If the DR resides on the device where the command is executed, this field displays (local) after the address. |
# Display detailed PIM information for VLAN-interface 1.
<Sysname> display pim interface vlan-interface 1 verbose
Interface: Vlan-interface1, 10.1.1.1
PIM version: 2
PIM mode: Sparse
PIM DR: 10.1.1.2
PIM DR Priority (configured): 1
PIM neighbors count: 1
PIM hello interval: 30 s
PIM LAN delay (negotiated): 500 ms
PIM LAN delay (configured): 500 ms
PIM override interval (negotiated): 2500 ms
PIM override interval (configured): 2500 ms
PIM neighbor tracking (negotiated): disabled
PIM neighbor tracking (configured): disabled
PIM generation ID: 0xF5712241
PIM require generation ID: disabled
PIM hello hold interval: 105 s
PIM assert hold interval: 180 s
PIM triggered hello delay: 5 s
PIM J/P interval: 60 s
PIM J/P hold interval: 210 s
PIM BSR domain border: disabled
PIM BFD: disabled
PIM passive: disabled
Number of routers on network not using DR priority: 0
Number of routers on network not using LAN delay: 0
Number of routers on network not using neighbor tracking: 2
Table 7 Command output
PIM version |
Version of the PIM protocol. |
PIM mode |
PIM mode: dense or sparse. |
PIM DR |
IP address of the DR. |
PIM DR Priority (configured) |
Configured priority for DR election. |
PIM neighbors count |
Total number of PIM neighbors. |
PIM hello interval |
Interval between two hello messages. |
PIM LAN delay (negotiated) |
Negotiated PIM message propagation delay. |
PIM LAN delay (configured) |
Configured PIM message propagation delay. |
PIM override interval (negotiated) |
Negotiated interval for overriding prune messages. |
PIM override interval (configured) |
Configured interval for overriding prune messages. |
PIM neighbor tracking (negotiated) |
Negotiated neighbor tracking status: enabled or disabled. |
PIM neighbor tracking (configured) |
Configured neighbor tracking status: enabled or disabled. |
PIM require generation ID |
Whether the feature of discarding hello messages without Generation_ID is enabled. |
PIM hello hold interval |
PIM neighbor lifetime. |
PIM assert hold interval |
Assert holdtime timer. |
PIM triggered hello delay |
Maximum delay for sending hello messages. |
PIM J/P interval |
Interval between two join/prune messages. |
PIM J/P hold interval |
Joined/pruned state holdtime timer. |
PIM BSR domain border |
Whether a PIM domain border is configured. |
PIM BFD |
Whether PIM is enabled to work with BFD. |
PIM passive |
Whether PIM passive mode is enabled on the interface. |
Number of routers on network not using DR priority |
Number of routers that do not use the DR priority field on the subnet where the interface resides. |
Number of routers on network not using LAN delay |
Number of routers that do not use the LAN delay field on the subnet where the interface resides. |
Number of routers on network not using neighbor tracking |
Number of routers that are not enabled with neighbor tracking on the subnet where the interface resides. |
display pim neighbor
Use display pim neighbor to display PIM neighbor information.
display pim neighbor [ neighbor-address | interface interface-type interface-number | verbose ] *
neighbor-address: Specifies a PIM neighbor by its IP address. If you do not specify a PIM neighbor, this command displays information about all PIM neighbors.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PIM neighbor information on all interfaces.
verbose: Displays detailed PIM neighbor information. If you do not specify this keyword, the command displays brief PIM neighbor information.
# Display brief information about all PIM neighbors.
<Sysname> display pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires DR-Priority Mode
10.1.1.2 Vlan1 02:50:49 00:01:31 1
20.1.1.2 Vlan2 02:49:39 00:01:42 1
# Display detailed information about the PIM neighbor with IP address 11.110.0.20.
<Sysname> display pim neighbor 11.110.0.20 verbose
Neighbor: 11.110.0.20
Interface: Vlan-interface3
Uptime: 00:00:10
Expiry time: 00:00:30
DR Priority: 1
Generation ID: 0x2ACEFE15
Holdtime: 105 s
LAN delay: 500 ms
Override interval: 2500 ms
State refresh interval: 60 s
Neighbor tracking: Disabled
Bidirectional PIM: Enabled
Secondary address(es):
22.1.1.2
22.1.1.3
22.1.1.4
22.1.1.5
22.1.1.6
22.1.1.7
22.1.1.8
Table 8 Command output
Total Number of Neighbors |
Neighbor |
IP address of the PIM neighbor. |
Interface that connects to the PIM neighbor. |
Uptime |
Length of time the PIM neighbor has been up. |
Expires/Expiry time |
Remaining lifetime for the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays never. |
DR-Priority/DR Priority |
Priority of the PIM neighbor. |
Mode |
RPF vector is not supported in the current software version. PIM mode: · B—The PIM mode is BIDIR-PIM. · P—The RPF proxy vector is enabled. This field is empty if the PIM mode is not BIDIR-PIM and the RPF vector is disabled. |
Generation ID |
Generation ID of the PIM neighbor. (A random value represents a status change of the PIM neighbor.) |
Holdtime |
Lifetime of the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays forever. |
LAN delay |
PIM message propagation delay on a shared-media LAN. |
Override interval |
Interval for overriding prune messages. |
State refresh interval |
Interval for refreshing state. This field is displayed only when the PIM neighbor operates in the PIM-DM mode and the state refresh capability is enabled. |
Neighbor tracking |
Neighbor tracking status: enabled or disabled. |
Bidirectional PIM |
Whether BIDIR-PIM is enabled. |
Secondary address(es) |
Secondary addresses of the PIM neighbor. |
display pim routing-table
Use display pim routing-table to display PIM routing entries.
display pim routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number ] *
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays PIM routing entries for all multicast groups.
mask-length: Specifies an address mask length in the range of 0 to 32. The default value is 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
flags flag-value: Specifies a flag. If you do not specify a flag, this command displays PIM routing entries that contain all flags. The following lists the values for the flag-value argument and their meanings:
· 2msdp: Specifies PIM routing entries to be contained in the next SA message to notify an MSDP peer.
· act: Specifies PIM routing entries that have been used for routing data.
· del: Specifies PIM routing entries to be deleted.
· exprune: Specifies PIM routing entries containing outgoing interfaces pruned by other multicast routing protocols.
· ext: Specifies PIM routing entries containing outgoing interfaces provided by other multicast routing protocols.
· loc: Specifies PIM routing entries on the devices that reside on the same subnet as the multicast source.
· msdp: Specifies PIM routing entries learned from MSDP SA messages.
· niif: Specifies PIM routing entries containing unknown incoming interfaces.
· nonbr: Specifies PIM routing entries with PIM neighbor lookup failure.
· rc: Specifies PIM routing entries that have received C-Multicast route information.
· rpt: Specifies PIM routing entries on the RPT branches where (S, G) prunes have been sent to the RP.
· rq: Specifies PIM routing entries of the receiving side of the data-MDT switchover.
· spt: Specifies PIM routing entries on the SPT.
· sq: Specifies PIM routing entries of the originator side of data-MDT switchover.
· src-act: Specifies PIM routing entries that have received Source Active A-D route information.
· swt: Specifies PIM routing entries in the process of RPT-to-SPT switchover.
· vxlan: Specifies VXLAN overlay entries maintained by PIM.
· wc: Specifies PIM routing entries with wildcards.
fsm: Displays detailed information about the finite state machine.
incoming-interface interface-type interface-number: Specifies an incoming interface. If you do not specify an incoming interface, this command displays PIM routing entries that contain all incoming interfaces.
mode mode-type: Specifies a PIM mode. If you do not specify a PIM mode, this command displays PIM routing entries in all PIM modes. The available PIM modes include:
· bidir: Specifies BIDIR-PIM.
· dm: Specifies PIM-DM.
· sm: Specifies PIM-SM.
· ssm: Specifies PIM-SSM.
outgoing-interface { exclude | include | match } interface-type interface-number: Specifies an outgoing interface. If you do not specify an outgoing interface, this command displays PIM routing entries that contain all outgoing interfaces. Whether an outgoing interface is contained in the PIM routing table depends on the following conditions:
· If you specify an excluded interface, this command displays PIM routing entries that do not contain the specified outgoing interface.
· If you specify an included interface, this command displays PIM routing entries that contain the specified outgoing interface.
· If you specify a matching interface, this command displays PIM routing entries that contain only the specified outgoing interface.
# Display PIM routing entries.
<Sysname> display pim routing-table
Total 0 (*, G) entries; 1 (S, G) entries
(172.168.0.12, 227.0.0.1)
RP: 2.2.2.2
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Vlan-interface1
Upstream neighbor: NULL
RPF prime neighbor: NULL
Downstream interface information:
1: Vlan-interface2
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
Total 0 (*, G) entries; 1 (S, G) entries |
Total number of (*, G) entries, and the total number of (S, G) entries. |
(172.168.0.12, 227.0.0.1) |
(S, G) entry. |
Protocol |
PIM mode. |
Flag |
Flag of the (S, G) entry or (*, G) entry: · 2MSDP—The entry is to be advertised by the MSDP module in the next (S, A) message. · ACT—The entry has been used for routing data. · DEL—The entry is to be removed. · EXPRUNE—Some outgoing interfaces are pruned by other multicast routing protocols. · EXT—The entry contains outgoing interfaces provided by other multicast routing protocols. · LOC—The entry is on a router directly connected to the same subnet with the multicast source. · MSDP—The entry is learned from an MSDP (S, A) message. · NIIF—The entry contains unknown incoming interfaces. · NONBR—The entry has a PIM neighbor lookup failure. · RC—The entry has received C-Multicast route information. · RPT—The entry is on an RPT branch where (S, G) prunes have been sent to the RP. · SPT—The entry is on the SPT. · SQ—The entry triggers the default-MDT to data-MDT switchover. · SRC-ACT—The entry has received Source Active A-D route information. · SWT—The entry is in the process of RPT-to-SPT switchover. · VXLAN—The entry is a VXLAN overlay entry. · WC—The entry contains a wildcard. |
Uptime |
Length of time for which the (S, G) entry or (*, G) entry has been up. |
Upstream interface |
Upstream (incoming) interface of the (S, G) entry or (*, G) entry. |
Upstream neighbor |
Upstream neighbor of the (S, G) entry or (*, G) entry. |
RPF prime neighbor |
RPF neighbor of the (S, G) or (*, G) entry: · For a (*, G) entry, if the RPF neighbor is the RP, the field displays NULL. · For an (S, G) entry, if the RPF neighbor is a router that directly connects to the multicast source, this field displays NULL. |
Downstream interface information |
Information about the downstream interfaces: · Total number of downstream interfaces. · Names of the downstream interfaces. · Protocol type on the downstream interfaces. · Uptime of the downstream interfaces. · Expiration time of the downstream interfaces. |
display pim rp-info
Use display pim rp-info to display PIM RP information.
display pim rp-info [ group-address ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays RP information for all multicast groups.
# Display RP information for multicast group 224.0.1.1.
<Sysname> display pim rp-info 224.0.1.1
BSR RP address is: 2.2.2.2
Priority: 192
HoldTime: 180
Uptime: 03:01:10
Expires: 00:02:30
Static RP address is: 3.3.3.5
Preferred: Yes
Configured ACL: 2003
RP mapping for this group is: 3.3.3.5
Anycast-RP 3.3.3.5 members:
Member address State
1.1.0.1 Active
1.2.0.2 Local
1.2.0.1 Remote
# Display RP information for all multicast groups.
BSR RP information:
Scope: non-scoped
1.1.1.1 (local) 192 180 03:01:36 00:02:29
2.2.2.2 192 180 1d:13h 00:02:02
3.3.3.3 192 180 12w:5d 00:02:05
Static RP information:
RP address ACL Mode Preferred
3.3.3.1 2000 pim-sm No
3.3.3.2 2001 pim-sm Yes
3.3.3.3 2002 pim-sm No
3.3.3.4 pim-sm No
3.3.3.5 2002 pim-sm Yes
Anycast-RP information:
RP address Member address State
3.3.3.5 1.1.0.1 Active
3.3.3.5 1.1.0.2 Local
3.3.3.5 1.2.0.1 Remote
BSR RP address is |
IP address of the RP. |
BSR RP information |
Information about the RP. |
Group/MaskLen |
Multicast group to which the RP is designated. |
[B] |
The RP is a BIDIR-PIM RP. This field is not displayed if the RP is a PIM-SM RP. |
RP address |
IP address of the RP. If the RP resides on the device where the command is executed, this field displays (local) after the address. |
Priority |
Priority of the RP. |
HoldTime |
RP lifetime. |
Uptime |
Length of time the RP has been up. |
Expires |
Remaining lifetime for the RP. |
Preferred |
Whether the static RP is preferred. |
Configured ACL/ACL |
ACL defining the multicast groups to which the static RP is designated. |
Mode |
RP service mode: PIM-SM or BIDIR-PIM. |
RP mapping for this group |
IP address of the RP that provides services for the multicast group. |
Anycast-RP 3.3.3.5 members |
Members of Anycast RP 3.3.3.5. |
Member address |
IP address of the Anycast RP member. |
State |
State of the interface from which the member address originates: · Active—Activated local interface. · Local—Inactivated local interface. · Remote—Remote interface. |
display pim statistics
Use display pim statistics to display statistics for PIM packets.
# Display statistics for PIM packets.
<Sysname> display pim statistics
Received PIM packets: 3295
Sent PIM packets : 5975
Valid Invalid Succeeded Failed
Hello : 3128 0 4333 0
Reg : 14 0 0 0
Reg-stop : 0 0 0 0
JP : 151 0 561 0
BSM : 0 0 1081 0
Assert : 0 0 0 0
Graft : 0 0 0 0
Graft-ACK: 0 0 0 0
C-RP : 0 0 0 0
SRM : 0 0 0 0
DF : 0 0 0 0
AutoRP : 0 0 0 0
Table 11 Command output
Received PIM packets |
Total number of received PIM protocol packets. |
Sent PIM packets |
Total number of sent PIM protocol packets. |
Valid |
Number of received legal PIM protocol packets. |
Invalid |
Number of received illegal PIM protocol packets. |
Succeeded |
Number of PIM protocol packets that were sent successfully. |
Failed |
Number of PIM protocol packets that failed to be sent. |
Hello |
Hello message statistics. |
Reg |
Register message statistics. |
Reg-stop |
Register-stop message statistics. |
JP |
Join/prune message statistics. |
BSM |
Bootstrap message statistics. |
Assert |
Assert message statistics. |
Graft |
Graft message statistics. |
Graft-ACK |
Graft-ACK message statistics. |
C-RP |
C-RP message statistics. |
SRM |
State refresh message statistics. |
DF |
Designated forwarder statistics. |
AutoRP |
Auto-RP message statistics. |
dscp
Use dscp to set the DSCP value for outgoing PIM protocol packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing PIM protocol packets is 48.
PIM view
dscp-value: Specifies the DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet to determine the transmission priority of the packet. A greater DSCP value represents a higher priority.
# Set the DSCP value for outgoing PIM protocol packets to 63.
[Sysname] pim
[Sysname-pim] dscp 63
Use hello-option dr-priority to set the DR priority globally.
Use undo hello-option dr-priority to restore the default.
The DR priority is 1.
PIM view
priority: Specifies a DR priority in the range of 0 to 4294967295. The greater the value, the higher the priority.
You can set the DR priority globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global DR priority to 3.
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
pim hello-option dr-priority
Use hello-option holdtime to set the PIM neighbor lifetime globally.
Use undo hello-option holdtime to restore the default.
hello-option holdtime time
The PIM neighbor lifetime is 105 seconds.
PIM view
time: Specifies a PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, PIM neighbors are always reachable.
You can set the PIM neighbor lifetime globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global PIM neighbor lifetime to 120 seconds.
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
pim hello-option holdtime
Use hello-option lan-delay to set the PIM message propagation delay on a shared-media LAN globally.
Use undo hello-option lan-delay to restore the default.
hello-option lan-delay delay
The PIM message propagation delay on a shared-media LAN is 500 milliseconds.
PIM view
delay: Specifies a PIM message propagation delay on a shared-media LAN, in the range of 1 to 32767 milliseconds.
You can set the PIM message propagation delay globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global PIM message propagation delay on a shared-media LAN to 200 milliseconds.
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
pim hello-option lan-delay
Use hello-option neighbor-tracking to enable neighbor tracking globally.
Use undo hello-option neighbor-tracking to disable neighbor tracking globally.
Neighbor tracking is disabled.
PIM view
You can enable neighbor tracking globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Enable neighbor tracking globally.
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
Use hello-option override-interval to set the override interval globally.
Use undo hello-option override-interval to restore the default.
The override interval is 2500 milliseconds.
PIM view
interval: Specifies an override interval in the range of 1 to 65535 milliseconds.
You can set the override interval globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global override interval to 2000 milliseconds.
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
Use holdtime join-prune to set the joined/pruned state holdtime globally.
Use undo holdtime join-prune to restore the default.
holdtime join-prune time
The joined/pruned state holdtime is 210 seconds.
PIM view
time: Specifies a joined/pruned state holdtime in the range of 1 to 65535 seconds.
You can set the joined/pruned state holdtime globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must set the join/prune interval to be less than the joined/pruned state holdtime.
# Set the global joined/pruned state holdtime to 280 seconds.
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
pim holdtime join-prune
timer join-prune (PIM view)
jp-pkt-size (PIM view)
Use jp-pkt-size to set the maximum size of a join or prune message.
Use undo jp-pkt-size to restore the default.
jp-pkt-size size
undo jp-pkt-size
The maximum size of a join or prune message is 1200 bytes.
PIM view
size: Specifies the maximum size of a join or prune message, in the range of 100 to 8100 bytes.
# Set the maximum size of a join or prune message to 1500 bytes.
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
pim
Use pim to enter PIM view.
Use undo pim to remove all configurations in PIM view.
pim
undo pim
# Enable IP multicast routing and enter PIM view.
[Sysname-mrib] quit
[Sysname] pim
[Sysname-pim]
multicast routing-enable
pim bfd enable
Use pim bfd enable to enable BFD for PIM.
Use undo pim bfd enable to disable BFD for PIM.
pim bfd enable
undo pim bfd enable
BFD is disabled for PIM.
Interface view
This command takes effect only when PIM-DM or PIM-SM is enabled on the interface.
# Enable IP multicast routing. Then, enable PIM-DM on VLAN-interface 100, and enable BFD for PIM on the interface.
[Sysname-mrib] quit
[Sysname-Vlan-interface100] pim dm
[Sysname-Vlan-interface100] pim bfd enable
pim dm
pim sm
pim bsr-boundary
Use pim bsr-boundary to configure a PIM-SM domain border (a bootstrap message boundary).
Use undo pim bsr-boundary to restore the default.
pim bsr-boundary
An interface is not a PIM-SM domain border.
Interface view
# Configure VLAN-interface 100 as a PIM-SM domain border.
[Sysname-Vlan-interface100] pim bsr-boundary
c-bsr (PIM view)
multicast boundary
pim dm
Use pim dm to enable PIM-DM.
Use undo pim dm to disable PIM-DM.
pim dm
undo pim dm
PIM-DM is disabled.
Interface view
This command takes effect only when IP multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
# Enable IP multicast routing, and enable PIM-DM on VLAN-interface 100.
[Sysname-mrib] quit
multicast routing
Use pim hello-option dr-priority to set the DR priority on an interface.
Use undo pim hello-option dr-priority to restore the default.
pim hello-option dr-priority priority
Interface view
You can set the DR priority for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the DR priority to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option dr-priority 3
Use pim hello-option holdtime to set the PIM neighbor lifetime on an interface.
Use undo pim hello-option holdtime to restore the default.
pim hello-option holdtime time
Interface view
time: Specifies a PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, the PIM neighbor is always reachable.
You can set the PIM neighbor lifetime for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the PIM neighbor lifetime to 120 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option holdtime 120
Use pim hello-option lan-delay to set the PIM message propagation delay on a shared-media LAN for an interface.
Use undo pim hello-option lan-delay to restore the default.
pim hello-option lan-delay delay
Interface view
delay: Specifies a PIM message propagation delay on a shared-media LAN in the range of 1 to 32767 milliseconds.
You can set the PIM message propagation delay for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the PIM message propagation delay on a shared-media LAN to 200 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option lan-delay 200
Use pim hello-option neighbor-tracking to enable neighbor tracking on an interface.
Use pim hello-option neighbor-tracking disable to disable neighbor tracking on an interface when neighbor tracking is enabled globally.
Use undo pim hello-option neighbor-tracking to restore neighbor tracking setting on an interface to be consistent with the global setting.
Neighbor tracking is disabled on an interface.
Interface view
You can enable neighbor tracking for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Enable neighbor tracking on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option neighbor-tracking
# Disable neighbor tracking on VLAN-interface 100 when neighbor tracking is enabled globally.
[Sysname] pim
[Sysname-pim] quit
[Sysname-Vlan-interface100] pim hello-option neighbor-tracking disable
Use pim hello-option override-interval to set the override interval on an interface.
Use undo pim hello-option override-interval to restore the default.
pim hello-option override-interval interval
Interface view
You can set the override interval for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the override interval to 2000 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option override-interval 2000
Use pim holdtime join-prune to set the joined/pruned state holdtime on an interface.
Use undo pim holdtime join-prune to restore the default.
pim holdtime join-prune time
Interface view
You can set the joined/pruned state holdtime for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must configure the join/prune interval to be less than the joined/pruned state holdtime.
# Set the joined/pruned state holdtime to 280 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim holdtime join-prune 280
pim timer join-prune
pim join-policy
Use pim join-policy to configure a PIM join policy to filter joined multicast sources and groups in PIM join or prune messages on an interface.
Use undo pim join-policy to restore the default.
pim join-policy { { ipv4-acl-number | name ipv4-acl-name } | [ asm { ipv4-acl-number | name ipv4-acl-name } | ssm { ipv4-acl-number | name ipv4-acl-name } ] * }
No PIM join policy is configured and joined multicast sources and groups in PIM join or prune messages are not filtered.
Interface view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number. The value range is 2000 to 2999 for an IPv4 basic ACL and 3000 to 3999 for an IPv4 advanced ACL. If the ACL does not exist or does not have valid rules, all joined multicast sources and groups in PIM join or prune messages are filtered out.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL does not exist or does not have valid rules, all joined multicast sources and groups in PIM join or prune messages are filtered out.
asm { ipv4-acl-number | name ipv4-acl-name }: Specifies an ACL for filtering joined multicast groups in the ASM range. If you do not specify an ACL, or the specified ACL does not exist or does not have valid rules, all multicast groups in the ASM range are filtered out.
· ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999.
· name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all.
ssm { ipv4-acl-number | name ipv4-acl-name }: Specifies an ACL for filtering joined multicast groups in the SSM range. If you do not specify an ACL, or the specified ACL does not exist or does not have valid rules, all multicast groups in the SSM range are filtered out.
This command does not take effect on PIM-DM.
The PIM join policy filters joined multicast sources and groups in PIM join or prune messages to protect the device against invalid PIM join or prune message attacks. The policy identifies valid joined multicast source and groups in PIM join or prune messages and filters out invalid joined multicast source and groups. The device creates (*, G) or (S, G) entries only for valid joined multicast sources and groups.
· In a basic ACL, the source source-address source-wildcard option specifies the multicast group address range in the PIM join or prune messages.
· In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address range. To match join information of (*, G) entries, set the source IP address to 0.0.0.0. The destination dest-address dest-wildcard option specifies a multicast group range.
# On VLAN-interface 100, configure a PIM join policy to permit join information only for source addresses in the range of 10.10.0.0/16 and multicast group addresses in the range of 225.1.1.1/16.
[Sysname] acl advanced 3005
[Sysname-acl-ipv4-adv-3005] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-ipv4-adv-3005] quit
[Sysname-Vlan-interface100] pim join-policy ssm 3005
pim neighbor-policy
Use pim neighbor-policy to configure a PIM hello policy.
Use undo pim neighbor-policy to restore the default.
pim neighbor-policy { ipv4-acl-number | name ipv4-acl-name }
No PIM hello policy exists on an interface, and all PIM hello messages are regarded as legal.
Interface view
ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If the ACL with the specified number does not exist or does not have valid rules, all PIM hello messages are filtered out.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL with the specified name does not exist or does not have valid rules, all PIM hello messages are filtered out.
A PIM hello policy filters PIM hello messages to guard against hello message spoofing.
· The source source-address source-wildcard option specifies a source IP address. A PIM hello message is permitted if the source IP address of the message matches the source option.
# Configure a PIM hello policy on VLAN-interface 100 so that only the devices on subnet 10.1.1.0/24 can become PIM neighbors of this switch.
[Sysname-Vlan-interface100] pim neighbor-policy 2000
pim non-stop-routing
Use pim non-stop-routing to enable PIM NSR.
Use undo pim non-stop-routing to disable PIM NSR.
PIM NSR is disabled.
# Enable PIM NSR.
[Sysname] pim non-stop-routing
pim passive
Use pim passive to enable PIM passive mode on an interface.
Use undo pim passive to disable PIM passive mode on an interface.
pim passive
undo pim passive
PIM passive mode is disabled on an interface.
Interface view
# Enable IP multicast routing. Then, enable PIM-DM and PIM passive mode on VLAN-interface 100.
[Sysname-mrib] quit
[Sysname-Vlan-interface100] pim passive
pim require-genid
Use pim require-genid to enable dropping hello messages without the generation ID options.
Use undo pim require-genid to restore the default.
pim require-genid
Hello messages without the generation ID options are accepted.
Interface view
# Enable VLAN-interface 100 to drop hello messages without the generation ID options.
[Sysname-Vlan-interface100] pim require-genid
pim sm
Use pim sm to enable PIM-SM.
Use undo pim sm to disable PIM-SM.
pim sm
undo pim sm
PIM-SM is disabled.
Interface view
When PIM-SM and BIDIR-PIM work together, do no configure PIM-SM in Layer 3 Ethernet interface view.
# Enable IP multicast routing, and enable PIM-SM on VLAN-interface 100.
[Sysname-mrib] quit
[Sysname-Vlan-interface100] pim sm
multicast routing
pim state-refresh-capable
Use pim state-refresh-capable to enable the state refresh feature on an interface.
Use undo pim state-refresh-capable to disable the state refresh feature.
The state refresh feature is enabled.
Interface view
# Disable the state refresh feature on VLAN-interface 100.
[Sysname-Vlan-interface100] undo pim state-refresh-capable
state-refresh-ttl (PIM view)
pim timer graft-retry
Use pim timer graft-retry to set a graft retry timer.
Use undo pim timer graft-retry to restore the default.
pim timer graft-retry interval
The graft retry timer is 3 seconds.
Interface view
interval: Specifies a graft retry timer in the range of 1 to 65535 seconds.
# Set the graft retry timer to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer graft-retry 80
pim timer hello
Use pim timer hello to set the hello interval on an interface.
Use undo pim timer hello to restore the default.
pim timer hello interval
The hello interval is 30 seconds.
Interface view
interval: Specifies a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send hello messages.
You can set the hello interval for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the hello interval to 40 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer hello 40
timer hello (PIM view)
Use pim timer join-prune to set the join/prune interval on an interface.
Use undo pim timer join-prune to restore the default.
pim timer join-prune interval
The join/prune interval is 60 seconds.
Interface view
interval: Specifies a join/prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send join or prune messages.
You can set the join/prune interval for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
The configuration takes effect after the current interval ends.
# Set the join/prune interval to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer join-prune 80
pim triggered-hello-delay
Use pim triggered-hello-delay to set the triggered hello delay (maximum delay for sending a hello message).
Use undo pim triggered-hello-delay to restore the default.
pim triggered-hello-delay delay
The triggered hello delay is 5 seconds.
Interface view
delay: Specifies a triggered hello delay in the range of 1 to 60 seconds.
# Set the triggered hello delay to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim triggered-hello-delay 3
register-policy (PIM view)
Use register-policy to configure a PIM register policy.
Use undo register-policy to restore the default.
register-policy { ipv4-acl-number | name ipv4-acl-name }
No PIM register policy exists, and all PIM register messages are regarded as legal.
PIM view
ipv4-acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999. If the ACL with the specified number does not exist or does not have valid rules, all PIM register messages are filtered out.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL with the specified name does not exist or does not have valid rules, all PIM register messages are filtered out.
A PIM register policy enables an RP to filter PIM register messages so that the RP is designated only to multicast groups permitted by the ACL.
· In a basic ACL, the source source-address source-wildcard option specifies a multicast source address. A PIM register message is permitted if the multicast source address of the message matches the source option.
· In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group range. A PIM register message is permitted if the multicast source address and multicast group address of the message match the source and destination options.
# Configure a PIM register policy. Then, the device accepts only register messages from the sources on the subnet 10.10.0.0/16 to the groups on the subnet 225.1.0.0/16.
[Sysname-acl-ipv4-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
register-suppression-timeout (PIM view)
Use register-suppression-timeout to set the register suppression time.
Use undo register-suppression-timeout to restore the default.
The register suppression time is 60 seconds.
PIM view
interval: Specifies a register suppression time in the range of 1 to 65535 seconds.
# Set the register suppression time to 70 seconds.
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
register-whole-checksum (PIM view)
Use register-whole-checksum to configure the device to calculate the checksum based on an entire register message.
Use undo register-whole-checksum to restore the default.
The device calculates the checksum based on the register message header.
PIM view
# Configure the device to calculate the checksum based on an entire register message.
[Sysname] pim
[Sysname-pim] register-whole-checksum
snmp-agent trap enable pim
Use snmp-agent trap enable pim to enable SNMP notifications for PIM.
Use undo snmp-agent trap enable pim to disable SNMP notifications for PIM.
snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
undo snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
SNMP notifications for PIM are enabled.
candidate-bsr-win-election: Specifies notifications about winning the BSR election.
elected-bsr-lost-election: Specifies notifications about losing the BSR election.
neighbor-loss: Specifies notifications about losing neighbors.
If you do not specify an optional keyword, this command enables or disables PIM to generate SNMP notifications.
To report critical PIM events to an NMS, enable SNMP notifications for PIM. For PIM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for PIM.
[Sysname] undo snmp-agent trap enable pim
source-lifetime (PIM view)
Use source-lifetime to set the multicast source lifetime.
Use undo source-lifetime to restore the default.
source-lifetime time
The multicast source lifetime is 210 seconds.
PIM view
time: Specifies a multicast source lifetime in the range of 0 to 31536000 seconds. If you set the value to 0 seconds, multicast sources never age out.
# Set the multicast source lifetime to 200 seconds.
[Sysname] pim
[Sysname-pim] source-lifetime 200
source-policy (PIM view)
Use source-policy to configure a multicast source policy.
Use undo source-policy to restore the default.
source-policy ipv4-acl-number
undo source-policy
No multicast source policy exists. The device does not filter multicast data packets.
PIM view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL number in the range of 2000 to 3999.
A multicast source policy filters multicast data packets to control information available to downstream receivers.
· In a basic ACL, the source source-address source-wildcard option specifies a source IP address.
· In an advanced ACL, the source source-address source-wildcard option specifies a source IP address. The destination dest-address dest-wildcard option specifies a multicast group address.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure a multicast source policy to accept multicast data from source 10.10.1.2 and to deny multicast data from source 10.10.1.1.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-ipv4-basic-2000] rule deny source 10.10.1.1 0
[Sysname] pim
[Sysname-pim] source-policy 2000
spt-switch-threshold (PIM view)
Use spt-switch-threshold to configure a criterion for an RPT-to-SPT switchover.
Use undo spt-switch-threshold to remove criteria for RPT-to-SPT switchovers.
spt-switch-threshold { immediacy | infinity } [ group-policy ipv4-acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy ipv4-acl-number ]
The first multicast packet triggers an RPT-to-STP switchover.
PIM view
immediacy: Triggers an RPT-to-STP switchover immediately.
infinity: Disables RPT-to-STP switchover.
group-policy ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the configuration applies to the multicast groups that the ACL permits. The configuration applies to all multicast groups when one of the following conditions exists:
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
· The source source-address source-wildcard option specifies a multicast group address.
Some devices cannot encapsulate multicast data in register messages destined to the RP. As a best practice to avoid multicast data forwarding failures, do not disable the switchover to SPT on C-RPs that might become the RP.
# Disable RPT-to-STP switchover on a receiver-side DR.
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
ssm-policy (PIM view)
Use ssm-policy to configure the SSM group range.
Use undo ssm-policy to restore the default.
ssm-policy { ipv4-acl-number | name ipv4-acl-name }
undo ssm-policy
The SSM group range is 232.0.0.0/8.
PIM view
ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If the ACL with the specified number does not exist or does not have valid rules, the device does not use the PIM-SSM node.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL with the specified name does not exist or does not have valid rules, the device does not use the PIM-SSM node.
This command defines a multicast group range that is used by PIM-SSM. For multicast packets that are permitted by the ACL, the PIM-SSM mode is used. For multicast packets that are not permitted by the ACL, the PIM-SM mode is used.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
· For the rule to take effect, do not specify the vpn-instance vpn-instance option.
· The source source-address source-wildcard option specifies a multicast group range. A multicast packet is permitted if the multicast source address of the message matches the source option.
# Configure the SSM group range as 232.1.0.0/16.
[Sysname-acl-ipv4-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
state-refresh-interval (PIM view)
Use state-refresh-interval to set the state refresh interval.
Use undo state-refresh-interval to restore the default.
The state refresh interval is 60 seconds.
PIM view
interval: Specifies a state refresh interval in the range of 1 to 255 seconds.
# Set the state refresh interval to 70 seconds.
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
state-refresh-rate-limit (PIM view)
Use state-refresh-rate-limit to set the waiting time to accept a new state refresh message.
Use undo state-refresh-rate-limit to restore the default.
state-refresh-rate-limit time
The device waits 30 seconds before it accepts a new state refresh message.
PIM view
time: Specifies the waiting time to accept a new refresh message, in the range of 1 to 65535 seconds.
# Set the waiting time to 45 seconds to accept a new state refresh message.
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
Use state-refresh-ttl to set the TTL value for state refresh messages.
Use undo state-refresh-ttl to restore the default.
state-refresh-ttl ttl-value
The TTL value for state refresh messages is 255.
PIM view
ttl-value: Specifies the TTL value for state refresh messages, in the range of 1 to 255.
# Set the TTL value to 45 for state refresh messages.
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
pim state-refresh-capable (PIM view)
static-rp (PIM view)
Use static-rp to configure a static RP.
Use undo static-rp to delete a static RP.
static-rp rp-address [ { ipv4-acl-number | name ipv4-acl-number } | bidir | preferred ] *
undo static-rp rp-address
No static RPs exist.
PIM view
rp-address: Specifies the IP address of the static RP. The IP address must be valid and cannot be on the subnet 127.0.0.0/8. For a static PIM-SM RP, you must specify a used IP address.
ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the static RP is designated only to multicast groups that the ACL permits. The static RP is designated to all multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not have valid rules.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If you specify an ACL, the static RP is designated only to multicast groups that the ACL permits. The static RP is designated to all multicast groups when one of the following conditions exists:
bidir: Configures the static RP as a BIDIR-PIM RP. If you do not specify this keyword, this command configures the static RP as a PIM-SM RP.
preferred: Gives priority to the static RP if a dynamic RP also exists on the network. The dynamic RP takes effect only when the static RP fails. If you do not specify this keyword, the dynamic RP has priority, and the static RP takes effect only when the dynamic RP fails.
You do not need to enable PIM on an interface that acts as a static RP.
· The source source-address source-wildcard option specifies a multicast group address. A multicast packet is permitted if the multicast source address of the message matches the source option.
When rules in the ACL used by a static RP change, new RPs are dynamically elected for all multicast groups.
You can configure multiple static RPs by using this command multiple times. However, if you specify the same static RP address or use the same ACL in the command, the most recent configuration takes effect. If you configure multiple static RPs for the same multicast group, the static RP with the highest IP address is used.
# Configure the interface with IP address 11.110.0.6 as a static RP for multicast group range 225.1.1.0/24 and give priority to this static RP.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
display pim rp-info
Use timer hello to set the hello interval globally.
Use undo timer hello to restore the default.
undo timer hello
PIM view
interval: Specifies a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the device does not send hello messages.
You can set the hello interval globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global hello interval to 40 seconds.
[Sysname] pim
[Sysname-pim] timer hello 40
pim timer hello
Use timer join-prune to set the join/prune interval globally.
Use undo timer join-prune to restore the default.
PIM view
interval: Specifies a join/prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the device does not send join or prune messages.
You can set the join/prune interval globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from expiring, you must set the join/prune interval to be less than the joined/pruned state holdtime.
# Set the global join/prune interval to 80 seconds.
[Sysname] pim
[Sysname-pim] timer join-prune 80
holdtime join-prune (PIM view)
