- 03-Layer 2—LAN Switching Command Reference
- 01-Ethernet interface commands
- 02-Loopback, null, and inloopback interface commands
- 03-Bulk interface commands
- 04-MAC address table commands
- 05-Ethernet link aggregation commands
- 06-DRNI commands
- 07-Port isolation commands
- 08-Spanning tree commands
- 09-Loop detection commands
- 10-VLAN commands
- 11-MVRP commands
- 12-QinQ commands
- 13-VLAN mapping commands
- 14-LLDP commands
- 15-L2PT commands
- 16-PPP commands
| 05-Ethernet link aggregation commands | 229.42 KB |
display link-aggregation capability
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation troubleshooting
display link-aggregation verbose
lacp default-selected-port disable
link-aggregation auto-aggregation enable
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, the command displays information about all interfaces.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
Tagged VLANs: None
UnTagged VLANs: 1
Last 300 seconds input: 6900 packets/sec 885160 bytes/sec 0%
Last 300 seconds output: 3150 packets/sec 404430 bytes/sec 0%
Input (total): 5364747 packets, 686688416 bytes
2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
Input (normal): 5364747 packets, 686688416 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
- ignored, - parity errors
Output (total): 1042508 packets, 133441832 bytes
1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
Output (normal): 1042508 packets, 133441832 bytes
1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
- lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
0 packets input, 0 bytes, 0 drops
0 packets output, 0 bytes, 0 drops
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
Interface Link Speed Duplex Type PVID Description
BAGG1 DOWN auto A A 1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1 UP UP --
Bridge-Aggregation1 |
Layer 2 aggregate interface name. |
Route-Aggregation1 |
Layer 3 aggregate interface name. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
IPv6 packet frame type |
IPv6 packet framing format. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps. |
Port priority |
Port priority of the interface. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
Port link-type |
Port link type: · Access. · Trunk. · Hybrid. |
Tagged VLANs |
VLAN whose packets are sent out of this interface with a tag. |
Untagged VLANs |
VLAN whose packets are sent out of this interface without a tag. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 seconds input/output rate |
Average input or output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received or sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received or sent on the interface. |
Line protocol state |
Data link layer state of the interface: · UP. · DOWN. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · Unnumbered—IP address borrowed from another interface. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Brief information on interfaces in bridge mode |
Brief information about Layer 2 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. |
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Actor System ID: 0x8000, 0000-fc00-6504 |
Local system ID, which contains the LACP system priority (0x8000 in this sample output) and the LACP system MAC address (0000-FC00-6504 in this sample output). |
Use display link-aggregation capability to display the link aggregation capability for the device.
This command is available in R6515P06 and later.
# Display the link aggregation capability for the device.
NOTE: The display command is supported only in the following switch series: · S6520X-HI series. · S6520X-EI series. · S6520X-SI series (except for S6520X-26XC-UPWR-SI and S6520X-54XC-UPWR-SI). · S5560X-HI series. · MS4600 series. · S6520-26Q-SI. |
<Sysname> display link-aggregation capability
Default link aggregation capability:
Maximum groups: 128
Maximum Selected ports per group: 8
Current link aggregation capability:
Maximum groups: 128
Link aggregation capability at the next reboot:
Maximum groups: 125
Maximum Selected ports per group: 16
Supported link aggregation capability list:
128*8 125*16 61*32
NOTE: The display command is supported only in the following switch series: · S6520-SI series (except for S6520-26Q-SI). · S5000-EI series. · S6520X-26XC-UPWR-SI. · S6520X-54XC-UPWR-SI. |
Maximum groups: 128
Maximum groups: 128
Maximum groups: 29
61*8 29*16 13*32
Supported link aggregation capability list |
Link aggregation capabilities supported by the device. Each item in the list is in the format of maximum number of aggregation groups*maximum number of Selected ports per aggregation group. |
Use display link-aggregation load-sharing mode to display the global link-aggregation load sharing mode.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
destination-mac address, source-mac address
Link-aggregation load-sharing mode |
Global link-aggregation load sharing mode. By default, this field displays the link-aggregation load sharing modes for Layer 2 and Layer 3 traffic. If you have configured the global link-aggregation load sharing mode, this field displays the configured mode. |
Layer 2 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 2 traffic. By default, Layer 2 traffic is load shared based on source and destination MAC addresses, source and destination IP addresses, and source and destination port numbers. |
Layer 3 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 3 traffic. By default, Layer 3 traffic is load shared based on source and destination MAC addresses, source and destination IP addresses, and source and destination port numbers. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses. |
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about Ten-GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port ten-gigabitethernet 1/0/1
G -- Defaulted, H -- Expired
Ten-GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about Ten-GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port ten-gigabitethernet 1/0/2
Ten-GigabitEthernet1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
# Display detailed information about all link aggregation member ports that are enabled with automatic assignment.
<Sysname> display link-aggregation member-port auto
Ten-GigabitEthernet1/0/3:
Preference Aggregation Interface: Bridge-Aggregation11
Aggregate Interface: Bridge-Aggregation11
Local:
Port Number: 3
Oper-Key: 1
Flag: {ACDEF}
Remote:
System ID: 0x8000, a057-75a2-0100
Port Number: 3
Oper-Key: 1
Flag: {ACDEF}
Received LACP Packets: 3 packet(s)
Sent LACP Packets: 6 packet(s)
Table 5 Command output
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0. · A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive. · B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no. · D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no. · E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no. · F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no. · G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no. · H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no. |
Aggregate Interface |
Aggregate interface to which the member port belongs. |
Preferred Aggregate Interface |
Aggregate interface to which you prefer to assign the member port during automatic assignment. |
Local |
Information about the local end. |
Oper-key |
Operational key. |
Flag |
LACP protocol state flag. |
Remote |
Information about the peer end. |
System ID |
Peer system ID, containing the LACP system priority and the LACP system MAC address. |
Received LACP Packets |
Total number of LACP packets received. |
Illegal |
Total number of illegal packets. |
Sent LACP Packets |
Total number of LACP packets sent. |
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
RAGG10 S None 1 0 0 NonS
BAGG20 D 0x8000,00e0-fcff-ff01 2 0 0 Shar
Table 6 Command output
Aggregate Interface Type |
Aggregate interface type: · BAGG—Layer 2. · RAGG—Layer 3. |
Aggregation Mode |
Aggregation group type: · S—Static. · D—Dynamic. |
Loadsharing Type |
Load sharing type: · Shar—Load-sharing. · NonS—Non-load-sharing. |
Actor System ID |
Local system ID, which contains the local LACP system priority and the local LACP system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the peer system, which contains the peer LACP system priority and the peer LACP system MAC address. |
Selected Ports |
Total number of Selected ports. |
Unselected Ports |
Total number of Unselected ports. |
Individual Ports |
Total number of Individual ports. |
Share Type |
Load sharing type. |
Use display link-aggregation troubleshooting to display the aggregation states of aggregation member ports and the reason why a port was placed in Unselected state.
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you do not specify an aggregate interface type, the command displays information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregation groups of the specified type.
You can specify the bridge-aggregation or route-aggregation keyword only when aggregate interfaces of the specified type exist on the device.
# Display the aggregation states of aggregation member ports for all aggregation groups and the reason why a port was placed in Unselected state.
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Bridge-Aggregation2
Member ports:
XGE1/0/2
Status: Selected
XGE1/0/3
Status: Unselected
Reason: The physical or line protocol state of the port is down
Advice: Check the connection
Table 7 Command output
Reason |
Reason why the port was placed in Unselected state. |
Advice |
Recommended action. |
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
The bridge-aggregation or route-aggregation keyword is available only when aggregate interfaces of the corresponding type exist on the device.
This command does not display the interfaces that are enabled with automatic assignment if they have not joined an aggregation group.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
Port Status Priority Index Oper-Key Flag
XGE1/0/1 S 32768 61 2 {ACDEF}
XGE1/0/2 S 32768 62 2 {ACDEF}
XGE1/0/3 S 32768 63 2 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
XGE1/0/1(R) 32768 111 2 0x8000, 000f-e267-57ad {ACDEF}
XGE1/0/2 32768 112 2 0x8000, 000f-e267-57ad {ACDEF}
XGE1/0/3 32768 113 2 0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
Port Status Priority Oper-Key
XGE1/0/1(R) S 32768 1
XGE1/0/2 S 32768 1
XGE1/0/3 S 32768 1
Table 8 Command output
Loadsharing Type |
Port Status |
Port state: · Selected. · Unselected. · Individual. |
Port |
Port type: · Auto port—The port is enabled with automatic assignment. · Management port—The port is a management port. This value is not supported in the current software version. · Reference port—The port is a reference port. |
Flags |
Name of the aggregate interface. |
Creation Mode |
Creation mode of the dynamic aggregate interface: · Auto. · Manual. |
Aggregation Mode |
Management VLANs |
(This field is not supported in the current software version.) Management VLANs. If no management VLANs are specified, this field displays None. |
System ID |
Local system ID, containing the local LACP system priority and the local LACP system MAC address. |
Local |
Information about the local end: · Port—Port type and number. · Status—Port state, which can be Selected, Unselected, or Individual. · Priority—Port priority. · Index—Port index. · Oper-Key—Operational key. · Flag—LACP state flag. NOTE: For static aggregation groups, the Index and Flag fields are not displayed. |
Remote |
Information about the peer end: · Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port. · Priority—Priority of the peer port. · Index—Index of the peer port. · Oper-Key—Operational key of the peer port. · System ID—System ID of the peer end. · Flag—LACP state flag of the peer end. |
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An interface allows jumbo frames with a maximum length of 10000 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value range for this argument is 1536 to 10000.
# Allow jumbo frames on Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not enable the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short LACP timeout interval (3 seconds) on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] lacp period short
lacp select speed
Use lacp select speed to configure a dynamic aggregation group to use port speed as the prioritized criterion for reference port selection.
Use undo lacp select speed to restore the default.
lacp select speed
Port ID is the prioritized criterion for reference port selection in a dynamic aggregation group.
CAUTION: Changing reference port selection criteria might cause transient traffic interruption. When you use this command, make sure you understand its impact on your network. |
This command enables a dynamic aggregation group to select a high-speed member port as the reference port.
You must execute this command at both ends of the aggregate link so the peer aggregation systems use the same criteria for reference port selection.
As a best practice, shut down the peer aggregate interfaces before you execute this command and bring up the interfaces after this command is executed on both of them.
This command takes effect only on dynamic aggregate interfaces. On a static aggregate interface, you can execute this command, but the setting cannot take effect.
# Specify port speed as the prioritized criterion for reference port selection on Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] lacp select speed
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero, all-F, or multicast MAC address.
All S-MLAG devices must use the same LACP system MAC address.
LACPDUs carry the LACP system MAC address configured by using this command. To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system MAC address globally and in aggregate interface view. The global LACP system MAC address takes effect on all aggregation groups, and an aggregate-interface-specific LACP system MAC address takes precedence over the global LACP system MAC address.
On a DR system, DR interfaces in the same DR group must use the same LACP system MAC address.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
port lacp system-mac
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
You must assign a unique LACP system number to each S-MLAG device.
The LACP system number configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system number in LACPDUs. To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the LACP system priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The LACP system priority is 32768.
priority: Specifies the LACP system priority in the range of 0 to 65535. The smaller the value, the higher the LACP system priority.
LACPDUs carry the LACP system priority configured by using this command. To identify the LACP system priority used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system priority globally and in aggregate interface view. The global LACP system priority takes effect on all aggregation groups, and an aggregate-interface-specific LACP system priority takes precedence over the global LACP system priority.
# Set the LACP system priority to 64.
[Sysname] lacp system-priority 64
port lacp system-priority
lacp transparent enable
Use lacp transparent enable to enable transparent LACPDU transmission on an interface.
Use undo lacp transparent enable to disable transparent LACPDU transmission on an interface.
Transparent LACPDU transmission is disabled on an interface.
To establish a dynamic aggregation between two remote CEs in an L2VPN network, use transparent LACPDU transmission on the PEs to which the CEs are attached.
On the PEs, enable transparent LACPDU transmission on the interfaces that transmit traffic between CEs and PEs and between PEs.
Do not use an interface for dynamic link aggregation if you enable transparent LACPDU transmission on that interface. With transparent LACPDU transmission enabled, an interface cannot be selected for aggregation.
# Enable transparent LACPDU transmission on Ten-GigabitEthernet 1/0/1.
<Sysname> system
[Sysname-Ten-GigabitEthernet1/0/1] lacp transparent enable
Use link-aggregation auto-aggregation enable to enable automatic link aggregation.
Use undo link-aggregation auto-aggregation enable to disable automatic link aggregation.
Automatic link aggregation is disabled.
After you enable automatic link aggregation and LLDP on two connected devices, they automatically establish a dynamic link aggregation based on the information in incoming LLDP frames. The devices each automatically create a dynamic aggregate interface and assign the redundant ports connected to the peer to the aggregation group of that interface. If you disable LLDP or automatic link aggregation on one device, that device removes the aggregation member ports from the aggregation group, but it will retain the aggregate interface. This event will not trigger member port removal actions on the peer device.
If automatic link aggregation is enabled, subinterface creation might fail on LLDP-enabled Layer 3 Ethernet interfaces. As a best practice, do not create subinterfaces on LLDP-enabled Layer 3 Ethernet interfaces.
To ensure correct operation of an automatically created aggregate interface, do not modify the configuration on the member ports of its aggregation group. Doing so might cause the member ports to be removed from the aggregation group.
For DRNI to operate correctly, do not use this command on a DR system.
On an interface, the port link-aggregation group setting takes precedence over automatic link aggregation. The interface will not be added to the aggregation group of an automatically created aggregate interface if it has been the member port of a manually created aggregate interface.
# Enable automatic link aggregation.
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
lldp enable
lldp global enable
link-aggregation bfd ipv4
Use link-aggregation bfd ipv4 to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ip-address destination ip-address
BFD is disabled for an aggregation group.
source ip-address: Specifies the unicast source IP address of BFD sessions. The source IP address cannot be 0.0.0.0.
destination ip-address: Specifies the unicast destination IP address of BFD sessions. The destination IP address cannot be 0.0.0.0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
As a best practice, configure the same source and destination IP addresses for BFD sessions on the DR interfaces in the same DR group.
# Enable BFD for Layer 2 aggregation group 1, and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation capability to configure the link aggregation capability for the device.
Use undo link-aggregation capability to restore the default.
link-aggregation capability max-group max-group-number max-selected-port max-selected-port-number
By default, the device supports a maximum of 128 aggregation groups and a maximum of 8 Selected ports per aggregation group.
max-group max-group-number: Specifies the maximum number of aggregation groups that the device supports. The value of the max-group-number argument varies by device model.
The following compatibility matrix shows the value ranges for the max-group-number argument:
Device model |
Value range |
· S6520X-HI series. · S6520X-EI series. · S6520X-SI (except for S6520X-26XC-UPWR-SI and S6520X-54XC-UPWR-SI). · S5560X-HI series. · MS4600 series. · S6520-26Q-SI. |
61,125, or 128 |
· S6520-SI (except for S6520-26Q-SI). · S5000-EI series. · S6520X-26XC-UPWR-SI. · S6520X-54XC-UPWR-SI. |
13, 29, or 61 |
max-selected-port max-selected-port-number: Specifies the maximum number of Selected ports per aggregation group. The value of the max-selected-port-number argument can be 8, 16, or 32.
After you execute this command, save the configuration and reboot the device for the configuration to take effect. Before rebooting the device, make sure you know the possible impact on the network.
This command fails if the number of existing aggregation groups exceeds the configured maximum number.
If you create aggregation groups after executing the link-aggregation capability command and the number of aggregation groups exceeds the configured number, some aggregation groups are deleted at the next reboot.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number set by using the link-aggregation selected-port maximum command.
· Maximum number of Selected ports allowed by the link aggregation capability.
For link aggregation to operate correctly, set the same link aggregation capability for both ends of an aggregate link.
If you execute this command multiple times, the most recent configuration takes effect at the next reboot.
# Configure the device to support a maximum of 125 aggregation groups and a maximum of 16 Selected ports per aggregation group.
[Sysname] link-aggregation capability max-group 125 max-selected-port 16
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Please save the configuration, and reboot the device.
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
Packets are load shared based on the following information:
· Source and destination IP addresses.
· Source and destination MAC addresses.
· Source and destination ports.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
ingress-port: Distributes traffic based on ingress ports.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
The following are global load sharing modes supported on the device:
· Default mode (load sharing mode automatically determined based on the packet type).
· Source IP.
· Destination IP.
· Source MAC.
· Destination MAC.
· Ingress port.
· Source IP and destination IP.
· Source IP and source port.
· Destination IP and destination port.
· Source IP, source port, destination IP, and destination port.
· Any combinations of ingress port, source MAC, and destination MAC.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
link-aggregation lacp isolate
Use link-aggregation lacp isolate to isolate aggregate interfaces on the device.
Use undo link-aggregation lacp isolate to remove aggregate interface isolation.
Aggregate interfaces are not isolated.
This command is available in Release 6526 and later.
Aggregate interface isolation is applicable to the aggregate interfaces that act as DR interfaces when the device acts a DR member device in a DR system. It gracefully changes all DR interfaces on the device to the Unselected state and switch traffic over to their counterpart DR interfaces on the other DR member device.
This feature takes effect only on dynamic aggregate interfaces. It cannot isolate static aggregate interfaces or IPPs in a DR system.
As a best practice, make sure no DR interfaces are in DRNI MAD DOWN state before you isolate them. If one of the DR interfaces is in DRNI MAD DOWN state when you isolate them, that DR interface will persist in that state and cannot forward traffic after the isolation is removed.
# Isolate aggregate interfaces.
[Sysname] link-aggregation lacp isolate
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
· The port is shut down by using the shutdown command.
· The slot that hosts the port reboots, and the aggregation group spans multiple slots.
NOTE: The device does not redirect traffic to member ports that become Selected during the traffic redirection process. |
This feature ensures zero packet loss for known unicast traffic, but it does not protect other types of traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
Global link-aggregation traffic redirection settings take effect on all aggregation groups. A link aggregation group preferentially uses the group-specific link-aggregation traffic redirection settings. If group-specific link-aggregation traffic redirection is not configured, the group uses the global link-aggregation traffic redirection settings.
As a best practice, enable link-aggregation traffic redirection on a per-interface basis. If you enable this feature globally, communication with a third-party peer device might be affected if the peer is not compatible with this feature.
As a best practice, make sure the status of link-aggregation traffic redirection is the same on the DR interfaces in the same DR group.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation.
Local-first load sharing is enabled for link aggregation.
Use local-first load sharing in a multidevice link aggregation scenario to distribute traffic preferentially across member ports on the ingress card or device. Local-first load sharing takes effect only on known unicast traffic.
If you disable local-first load sharing, packets on an aggregate interface are load shared among all its Selected ports on IRF member devices.
# Disable local-first load sharing for link aggregation.
[Sysname] undo link-aggregation load-sharing mode local-first
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
When you change the aggregation mode, make sure you understand the impact of the change on services.
Aggregation mode change might cause Selected member ports to become Unselected.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/2.
[Sysname-Ten-GigabitEthernet1/0/2] link-aggregation port-priority 64
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number [ lacp-sync ]
The maximum number of Selected ports allowed in an aggregation group is 8.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 8.
lacp-sync: Synchronizes the maximum number of Selected ports through LACPDUs. If you do not specify this keyword, the aggregate interface does not synchronize the maximum number of Selected ports with the peer.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
For a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
For a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
The maximum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
You can implement backup between two ports by performing the following tasks:
· Assigning two ports to an aggregation group.
· Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
link-aggregation selected-port minimum { min-number | percentage number }
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 8.
percentage number: Sets the minimum percentage of Selected ports in an aggregation group. The value range for the number argument is 1 to 100.
IMPORTANT: After you set the minimum percentage of Selected ports for an aggregation group, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this setting when you configure it on a live network. |
You can set either the minimum number or the minimum percentage of Selected ports for an aggregation group. If you configure both settings on an aggregate interface, the higher Selected port number limit takes effect.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
You must set the same minimum number or minimum percentage of Selected ports at the two ends of an aggregate link.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
· If you do not specify the msec keyword, the value range is 0 to 120 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can configure this feature to suppress link-down events, link-up events, or both. If an event of the specified type persists when the suppression interval expires, the system reports the event.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for an event type, the most recent configuration takes effect on that event type.
# Set the link-down event suppression interval to 8 seconds on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-delay down 8
# Set the link-down event suppression interval to 8 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay down 8
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies an MTU in bytes. The value range for this argument is 128 to 1560.
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
Use port lacp system-mac to set the LACP system MAC address on an aggregate interface.
Use undo port lacp system to restore the default.
port lacp system-mac mac-address
undo port lacp system-mac
Member devices in an S-MLAG system must use the same LACP system MAC address.
# Set the LACP system MAC address to 0002-0002-0002 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port lacp system-mac 2-2-2
lacp system-mac
Use port lacp system-priority to set the LACP system priority on an aggregate interface.
Use undo port lacp system-priority to restore the default.
port lacp system-priority priority
Member devices in an S-MLAG system must use the same LACP system priority.
# Set the LACP system priority to 32 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port lacp system-priority 32
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 1024.
force: Enables the current interface to synchronize attribute configurations from the aggregate interface. If you do not specify this keyword, the current interface does not synchronize attribute configurations from the aggregate interface when it joins the aggregation group. This keyword is supported only on Layer 2 Ethernet interfaces.
auto: Enables automatic assignment.
A Layer 2 Ethernet interface can be assigned to a Layer 2 aggregation group only. A Layer 3 Ethernet interface can be assigned to a Layer 3 aggregation group only.
An interface can belong to only one aggregation group.
An interface cannot join an aggregation group if it has different attribute configurations from the aggregate interface. After joining an aggregation group, an interface inherits the attribute configurations on the aggregate interface. You can modify the attribute configurations only on the aggregate interface.
The force keyword takes effect only when you assign the interface to an aggregation group. It cannot be saved in the running configuration or a configuration file.
Automatic assignment is available only on Layer 2 and Layer 3 Ethernet interfaces.
When you enable automatic assignment, you can specify a preferred aggregation group, which must be in dynamic mode.
The device assigns the interface to the preferred aggregation group as long as the LACPDUs received on the interface match the peer information of the reference port in the group.
If you do not specify a preferred group or if the preferred group match fails, the device attempts to select a matching group from the existing dynamic aggregation groups. If no match is found, the device creates a dynamic aggregation group based on the LACPDUs and assigns the interface to that aggregation group.
As a best practice, do not modify the configuration on an automatically created aggregate interface or its member ports.
# Assign Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-Ten-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/2 to Layer 3 aggregation group 2.
[Sysname-Ten-GigabitEthernet1/0/2] port link-aggregation group 2
port s-mlag group
Use port s-mlag group to assign an aggregate interface to an S-MLAG group.
Use undo port s-mlag group to restore the default.
port s-mlag group group-id
An aggregate interface is not in any S-MLAG group.
group-id: Specifies an S-MLAG group number in the range of 1 to 1024.
Use S-MLAG only for setting up multichassis link aggregations to servers.
You can assign only Layer 2 aggregate interfaces in dynamic mode to an S-MLAG group.
Each S-MLAG group can contain only one aggregate interface on each device.
# Assign Bridge-Aggregation 1 to S-MLAG group 1.
[Sysname-Bridge-Aggregation1] port s-mlag group 1
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics for all interfaces in the system.
If you specify only an aggregate interface type, the command clears statistics for all aggregate interfaces of the specified type.
# Clear the statistics about interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
CAUTION: The shutdown command will disconnect all links established on an interface. Make sure you are fully aware of the impacts of this command when you use it on a live network. |
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
