- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
| 06-BGP commands | 1.16 MB |
bestroute origin-as-validation
bgp apply-policy on-startup duration
bgp update-delay on-startup prefix-list
bgp update-delay on-startup ipv6-prefix-list
display bgp dampening parameter
display bgp non-stop-routing status
display bgp peer received prefix-list
display bgp routing-table dampened
display bgp routing-table dedicated
display bgp routing-table flap-info
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 unicast
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 unicast
forwarding-conversational-learning
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
ip vpn-instance (BGP instance view)
peer advertise additional-paths best
peer advertise origin-as-validation
peer advertise-policy exist-policy
peer advertise-policy non-exist-policy
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer capability-advertise conventional
peer capability-advertise orf non-standard
peer capability-advertise orf prefix-list
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer graceful-restart timer restart extra
peer nexthop-recursive-policy disable
reset bgp bmp server statistics
route-update-interval withdrawn enable
router-id (BGP-VPN instance view)
BGP commands
additional-paths select-best
Use additional-paths select-best to set the maximum number of Add-Path optimal routes that can be advertised to all peers.
Use undo additional-paths select-best to restore the default.
A maximum of one Add-Path optimal route can be advertised to all peers.
BGP IPv4 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv6 unicast address family view
BGP EVPN address family view
best-number: Specifies the maximum number of Add-Path optimal routes that can be advertised to all peers, in the range of 2 to 32.
The number of optimal routes cannot exceed the maximum number of Add-Path optimal routes that can be advertised to all peers.
# In BGP IPv4 unicast address family view, set the maximum number to 3 for Add-Path optimal routes that can be advertised to all peers.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] additional-paths select-best 3
peer additional-paths
address-family dedicated
Use address-family dedicated to create the BGP dedicated address family and enter its view, or enter the view of the existing BGP dedicated address family.
Use undo address-family dedicated to remove the BGP dedicated address family and all its configurations.
No BGP dedicated address family exists.
BGP instance view
Configurations made in BGP dedicated address family view apply only to the BGP dedicated routes.
# In BGP instance view, create the BGP dedicated address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family dedicated
[Sysname-bgp-default-dedicated]
address-family ipv4
Use address-family ipv4 to create the BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv4 RT filter address family, or BGP IPv4 multicast address family, and enter its view, or enter the view of the existing address family.
Use undo address-family ipv4 to remove the BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv4 RT filter address family, or BGP IPv4 multicast address family, and all its configurations.
In BGP instance view:
address-family ipv4 [ multicast | rtfilter | unicast ]
undo address-family ipv4 [ multicast | rtfilter | unicast ]
In BGP-VPN instance view:
undo address-family ipv4 [ unicast ]
No BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv4 RT filter address family, or BGP IPv4 multicast address family exists.
multicast: Specifies the IPv4 multicast address family.
rtfilter: Specifies the BGP IPv4 RT filter address family.
unicast: Specifies the IPv4 unicast address family. If this command is executed with the unicast keyword in BGP instance view, it places you into BGP IPv4 unicast address family view. If this command is executed with the unicast keyword in BGP-VPN instance view, it places you into BGP-VPN IPv4 unicast address family view.
Configurations made in BGP IPv4 unicast address family view apply only to the BGP IPv4 unicast routes and peers of the public network.
Configurations made in BGP-VPN IPv4 unicast address family view apply only to the BGP IPv4 unicast routes and peers of the specified VPN instance.
Configurations made in BGP IPv4 multicast address family view apply only to the BGP IPv4 multicast routes and peers.
Configurations made in BGP IPv4 RT filter address family view apply only to the BGP IPv4 RT filter routes and peers.
By default, the unicast keyword is used if you do not specify the multicast, rtfilter, or unicast keyword.
# In BGP instance view, create the BGP IPv4 unicast address family and enter its view.
[Sysname] bgp 100
address-family ipv6
Use address-family ipv6 to create the BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, or BGP IPv6 multicast address family, and enter its view, or enter the view of the existing address family.
Use undo address-family ipv6 to remove the BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, or BGP IPv6 multicast address family, and all its configurations.
address-family ipv6 [ multicast | unicast ]
undo address-family ipv6 [ multicast | unicast ]
undo address-family ipv6 [ unicast ]
No BGP IPv6 unicast address family, BGP-VPN IPv6 unicast address family, or BGP IPv6 multicast address family exists.
unicast: Specifies the IPv6 unicast address family. If this command is executed with the unicast keyword in BGP instance view, it places you into BGP IPv6 unicast address family view. If this command is executed with the unicast keyword in BGP-VPN instance view, it places you into BGP-VPN IPv6 unicast address family view.
multicast: Specifies the IPv6 multicast address family.
Configurations made in BGP IPv6 unicast address family view apply only to the BGP IPv6 unicast routes and peers of the public network.
Configurations made in BGP-VPN IPv6 unicast address family view apply only to the BGP IPv6 unicast routes and peers of the specified VPN instance.
Configurations made in BGP IPv6 multicast address family view apply only to the BGP IPv6 multicast routes and peers.
By default, the unicast keyword is used if neither the multicast keyword nor the unicast keyword is specified.
# In BGP instance view, create the BGP IPv6 unicast address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6]
address-family link-state
Use address-family link-state to create the BGP LS address family and enter its view, or enter the view of the existing address family.
Use undo address-family link-state to remove the BGP LS address family and all its configurations.
No BGP LS address family exists.
BGP instance view
Configurations made in BGP LS address family view apply only to the BGP LS routes and peers of the public network.
# In BGP instance view, create the BGP LS address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family link-state
[Sysname-bgp-default-ls]
advertise-rib-active
Use advertise-rib-active to enable BGP to advertise only the optimal BGP routes in the IP routing table.
Use undo advertise-rib-active to restore the default.
In BGP instance view, BGP advertises optimal routes in the BGP routing table, regardless of whether they are optimal in the IP routing table. In other views, the setting is the same as that in BGP instance view.
The advertise-rib-active command does not apply to the following routes:
· Routes redistributed by the import-route command.
· Routes advertised by the network command.
· Default routes redistributed by the default-route imported command.
· IPv4 multicast routes.
· IPv6 multicast routes.
This command takes effect only on the routes generated after you execute this command. To apply this command to existing routes, use the reset bgp command to reset BGP sessions.
The setting in BGP unicast address family view applies when it is different from that in BGP instance view.
This command is mutually exclusive with the routing-table bgp-rib-only command.
# In BGP instance view, enable BGP to advertise optimal routes in the IP routing table.
[Sysname] bgp 100
[Sysname-bgp-default] advertise-rib-active
aggregate
Use aggregate to create a summary route in the BGP routing table.
Use undo aggregate to remove a summary route.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP IPv4 multicast address family view:
undo aggregate ipv4-address { mask-length | mask }
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view/BGP IPv6 multicast address family view:
undo aggregate ipv6-address prefix-length
No summary routes are configured.
ipv4-address: Specifies an IPv4 summary address.
mask-length: Specifies a mask length for the IPv4 summary address, in the range of 0 to 32.
mask: Specifies a mask for the IPv4 summary address, in dotted decimal notation.
ipv6-address: Specifies an IPv6 summary address.
prefix-length: Specifies a prefix length for the IPv6 summary address, in the range of 0 to 128.
as-set: Enables the AS_PATH attribute of the summary route to contain the AS path information for all summarized routes. The AS_PATH attribute is of the AS_SET type that requires no sequence when arranging AS numbers. If you do not specify this keyword, the AS_PATH attribute of the summary route contains only the AS number of the local router.
attribute-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set attributes for the summary route.
detail-suppressed: Advertises only the summary route. If you do not specify this keyword, BGP advertises both the summary route and the more specific routes.
origin-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to select routes to be summarized.
suppress-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter more specific routes to be advertised. Routes permitted by the specified routing policy are not advertised. Routes denied by the specified routing policy are advertised.
This command creates a summary route. If the BGP routing table has routes whose destination addresses fall within the specified network, the summary route is added to the BGP routing table. For example, if two routes 10.1.1.0/24 and 10.1.2.0/24 exist in the BGP routing table, configuring the aggregate 10.1.0.0 16 command creates a summary route 10.1.0.0/16.
If the summarized routes have different ORIGIN attributes, the summary route selects the ORIGIN attribute in the sequence of INCOMPLETE, EGP, and IGP. For example, if the ORIGIN attributes of the summarized routes include INCOMPLETE and IGP, the ORIGIN attribute of the summary route is INCOMPLETE.
The COMMUNITY attribute of the summary route includes all the COMMUNITY (or extended community) attribute values if the routes have the following details:
· Summarized routes have different COMMUNITY (or extended community) attribute values.
· The summary route does not have the ATOMIC_AGGREGATE attribute.
Table 1 Functions of the keywords
Keywords |
Function |
as-set |
Enables the summary route to carry the AS path information for all summarized routes. This feature can help avoid routing loops. However, if many routes are summarized and are changed frequently, do not specify this keyword. This configuration causes the summary route to flap with the more specific routes. |
Sets attributes except the AS-PATH attribute for the summary route. The peer route-policy command can achieve the same purpose. The attribute-policy and as-set keywords are mutually exclusive when they are used to modify the AS_PATH attribute for the summary route. Modifying the AS_PATH attribute of the summary route might cause routing loops. |
detail-suppressed |
Disables advertisement of all more specific routes. To disable advertisement of some more specific routes, use the suppress-policy keyword or the peer filter-policy command. |
origin-policy |
Summarizes only routes matching a routing policy. If the destination address of a route falls within the summary network but does not match the routing policy, the route is not summarized. It is not controlled by the detail-suppressed and suppress-policy keywords. There is no need to configure apply clauses for the routing policy applied by the origin-policy keyword because they do not take effect. |
suppress-policy |
Disables advertisement of some more specific routes filtered by a routing policy. The routing policy uses if-match clauses to filter routes. There is no need to configure apply clauses for the routing policy applied by the suppress-policy keyword because they do not take effect. |
# In BGP IPv4 unicast address family view, create summary route 1.1.0.0/16 in the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] aggregate 1.1.0.0 255.255.0.0
summary automatic
balance
Use balance to enable load balancing and set the maximum number of BGP ECMP routes for load balancing.
Use undo balance to disable load balancing.
balance [ ebgp | eibgp | ibgp ] number
undo balance [ ebgp | eibgp | ibgp ]
Load balancing is disabled.
ebgp: Enables load balancing over EBGP routes.
eibgp: Enables load balancing between EBGP and IBGP routes.
ibgp: Enables load balancing over IBGP routes.
number: Specifies the maximum number of BGP ECMP routes for load balancing. When it is set to 1, load balancing is disabled.
Unlike IGP, BGP has no explicit metric for making load balancing decision. Instead, it implements load balancing by modifying route selection rules.
If multiple BGP routes destined for a network meet the following conditions, the device selects the specified number of routes for load balancing:
BGP uses the following load balancing criteria to determine load balanced routes:
· The routes have the same ORIGIN, LOCAL_PREF, and MED attributes.
· The routes meet the following requirements on the AS_PATH attribute:
¡ If the balance as-path-neglect command is configured, the routes can have different AS_PATH attributes.
¡ If only the balance as-path-relax command is configured, the routes can have different AS_PATH attributes, but the length of the AS_PATH attributes must be the same.
¡ If neither the balance as-path-neglect nor the balance as-path-relax command is configured, the routes must have the same AS_PATH attribute.
· The next hops of the routes meet the following requirements on IGP metrics:
¡ If the bestroute igp-metric-ignore command is not configured, the next hops of the routes must have the same IGP metric value.
¡ If the bestroute igp-metric-ignore command is configured, the next hops of the routes can have different IGP metric values.
· The routes have the same MPLS label assignment status (labeled or not labeled).
The value range for the number argument depends on the max-ecmp-num command. If you set the maximum number of ECMP routes to m by using the max-ecmp-num command and reboot the device, the number argument in the balance command is in the range of 1 to m.
If you do not specify the ibgp, eibgp, or ebgp keyword, this command enables load balancing over EBGP routes and IBGP routes, but not between EBGP and IBGP routes.
The configuration of the balance eibgp number command can be removed only by executing the undo balance eibgp command.
After you execute the balance eibgp number command, the balance [ ebgp | ibgp ] number command cannot be executed; and vice versa.
# In BGP IPv4 unicast address family view, enable load balancing and set the maximum number of BGP ECMP routes used for load balancing to 2.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance 2
Use balance as-path-neglect to enable BGP to ignore the AS_PATH attribute when it implements load balancing.
Use undo balance as-path-neglect to restore the default.
BGP does not ignore the AS_PATH attribute when it implements load balancing.
For BGP to implement load balancing over routes with different AS_PATH attributes, you must use this command together with the balance command.
After this command is executed, BGP ignores the AS_PATH attributes in the routes for load balancing and changes the attributes of the advertised routes to those of the optimal route. The operations might cause routing loops. Therefore, use this command with caution.
# In BGP IPv4 unicast address family view, enable BGP to ignore the AS_PATH attribute when it implements load balancing.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance as-path-neglect
balance
Use balance as-path-relax to enable load balancing for routes that have different AS_PATH attributes of the same length.
Use undo balance as-path-relax to restore the default.
balance as-path-relax [ ebgp | ibgp ]
undo balance as-path-relax [ ebgp | ibgp ]
BGP cannot perform load balancing for routes that have different AS_PATH attributes of the same length.
ebgp: Enables load balancing for EBGP routes that have different AS_PATH attributes of the same length.
ibgp: Enables load balancing for IBGP routes that have different AS_PATH attributes of the same length.
For BGP to perform load balancing for routes with different AS_PATH attributes of the same length, you must use this command together with the balance command.
If you configure both the balance as-path-relax and balance as-path-neglect commands, the balance as-path-neglect command takes effect.
If you do not specify the ibgp or ebgp keyword when you execute this command, the following rules apply:
· BGP performs load balancing for EBGP routes that have different AS_PATH attributes of the same length.
· BGP performs load balancing for IBGP routes that have different AS_PATH attributes of the same length.
· BGP does not perform load balancing between EBGP and IBGP routes that have different AS_PATH attributes of the same length.
After this command is executed, BGP ignores the AS_PATH attributes in the routes for load balancing and changes the attributes of the advertised routes to those of the optimal route. This might cause routing loops. Therefore, use this command with caution.
# In BGP IPv4 unicast address family view, enable load balancing for EBGP routes that have different AS_PATH attributes of the same length.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance as-path-relax ebgp
bestroute as-path-neglect
Use bestroute as-path-neglect to configure BGP to ignore the AS_PATH attribute during optimal route selection.
Use undo bestroute as-path-neglect to restore the default.
BGP considers the AS_PATH attribute during optimal route selection.
# In BGP instance view, ignore AS_PATH during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute as-path-neglect
bestroute compare-med
Use bestroute compare-med to enable MED comparison for routes on a per-AS basis.
Use undo bestroute compare-med to restore the default.
MED comparison for routes on a per-AS basis is disabled.
By default, BGP does not compare MEDs for routes from the same AS. When a router learns a new route, it compares the route with the optimal route in its BGP routing table. If the new route is more optimal, it becomes the optimal route in the BGP routing table. In this way, route learning sequence might affect optimal route selection.
To solve the selection problem, the router puts routes received from the same AS into a group when the bestroute compare-med command is configured. The router then selects the route with the lowest MED from the same group, and compares routes from different groups.
# In BGP instance view, enable MED comparison for routes on a per-AS basis.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute compare-med
Use bestroute igp-metric-ignore to configure BGP to ignore IGP metrics during optimal route selection.
Use undo bestroute igp-metric-ignore to restore the default.
BGP considers IGP metrics during optimal route selection, and selects the route with the smallest IGP metric as the optimal route.
# In BGP instance view, ignore IGP metrics during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute igp-metric-ignore
bestroute med-confederation
Use bestroute med-confederation to enable MED comparison for routes received from confederation peers.
Use undo bestroute med-confederation to restore the default.
MED comparison is disabled for routes received from confederation peers.
This command enables BGP to compare the MEDs of routes received from confederation peers. However, if a route from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008, which does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
# In BGP instance view, enable MED comparison for routes received from confederation peers.
[Sysname] bgp 100
[Sysname-bgp-default] bestroute med-confederation
bestroute ipv6-nexthop
Use bestroute ipv6-nexthop to enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
Use undo bestroute ipv6-nexthop to restore the default.
BGP prefers routes with an IPv4 next hop during optimal route selection.
Execute this command for the VXLAN packets in an EVPN network to be forwarded through IPv6 routes when both IPv4 and IPv6 routes exist.
# In BGP EVPN address family view, enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] bestroute ipv6-nexthop
Use bestroute origin-as-validation to apply the BGP RPKI validation state to optimal route selection.
Use undo bestroute origin-as-validation to restore the default.
bestroute origin-as-validation [ allow-invalid ]
BGP ignores the BGP RPKI validation state during optimal route selection.
allow-invalid: Allows routes with a validation state of Invalid to participate in optimal route selection. If you do not specify this keyword, routes with a validation state of Invalid cannot participate in optimal route selection.
If multiple routes to the same destination are available, BGP first discards routes with unreachable next hops, and then selects the optimal route according to the following rules:
· Routes with a BGP RPKI validation state of Valid takes precedence over routes with a validation state of Not-found or Invalid.
· Routes with a BGP RPKI validation state of Not-found takes precedence over routes with a validation state of Invalid.
· Routes without a BGP RPKI validation state have the same priority as routes with a BGP RPKI validation state of Not-found.
# In BGP IPv4 unicast address family view, apply the BGP RPKI validation state to optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] bestroute origin-as-validation
bestroute router-id-ignore
Use bestroute router-id-ignore to configure BGP to ignore router IDs during optimal route selection.
Use undo bestroute router-id-ignore to restore the default.
By default, BGP compares router IDs during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest router ID as the optimal route.
BGP instance view
# In BGP instance view, configure BGP to ignore router IDs during optimal route selection.
[Sysname] bgp 1
[Sysname-bgp-default] bestroute router-id-ignore
bgp
Use bgp to enable a BGP instance and enter its view.
Use undo bgp to disable a BGP instance.
undo bgp [ as-number [ instance instance-name ] ]
BGP is disabled and no BGP instances exist.
as-number: Specifies a local AS by its number in the range of 1 to 4294967295.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command enables the BGP instance default.
A router supports 4-byte AS number.
A BGP router can run multiple BGP processes. Each BGP process corresponds to a BGP instance. BGP maintains an independent routing table for each BGP instance.
You can create multiple public address families for a BGP instance. However, each public address family (except for public IPv4 unicast address family, public IPv6 unicast address family) can belong to only one BGP instance.
You can create multiple VPN instances for a BGP instance, and each VPN instance can have multiple address families. A VPN instance can belong to only one BGP instance.
You cannot specify the same peer for the same address family of different BGP instances.
The IPv4 and IPv6 multicast address families must belong to the same BGP instance.
Different BGP instances can have the same AS number but cannot have the same name.
# Enable BGP instance default, set the local AS number to 100, and enter BGP instance view.
[Sysname] bgp 100
Use bgp apply-policy on-startup duration to specify the period after reboot within which the startup policy is effective.
Use undo bgp apply-policy on-startup duration to restore the default.
The startup policy does not take effect.
BGP instance view
seconds: Specifies the period after reboot within which the startup policy is effective, in the range of 0 to 3600 seconds. The number of 0 indicates that the startup policy is effective permanently.
This command allows BGP to send route updates with the attribute values specified in the startup policy within the specified period after reboot. Then, BGP can forward traffic through other devices to avoid traffic loss caused by reboot.
# In BGP instance view, set the period after reboot to 100 seconds within which the startup policy is effective.
[Sysname] bgp 100
[Sysname-bgp-default] bgp apply-policy on-startup duration 100
bgp policy on-startup med
Use bgp policy on-startup med to set the MED attribute value in the startup policy.
Use undo bgp policy on-startup med to restore the default.
The MED attribute value in the startup policy is 4294967295.
BGP instance view
med-value: Specifies the MED attribute value in the startup policy, in the range of 0 to 4294967295.
After you configure this command, BGP uses the specified MED attribute value to send route updates within the specified period after reboot.
# In BGP instance view, set the MED attribute value in the startup policy to 100.
[Sysname] bgp 100
[Sysname-bgp-default] bgp policy on-startup med 100
Use bgp update-delay on-startup to configure BGP to delay sending route updates on reboot.
Use undo bgp update-delay on-startup to restore the default.
BGP sends route updates immediately on reboot.
seconds: Specifies the delay time in the range of 0 to 3600 seconds. The value of 0 indicates that BGP does not send route updates after the device reboots.
After you execute this command, BGP redistributes all routes from other neighbors on reboot, selects the optimal route, and then advertises it. Using this command can reduce traffic loss caused by reboot.
# In BGP instance view, configure BGP to delay sending route updates on reboot and set the delay time to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup 100
Use bgp update-delay on-startup prefix-list to configure BGP to immediately send route updates for routes that match an IPv4 prefix list.
Use undo bgp update-delay on-startup prefix-list to restore the default.
No IPv4 prefix list is specified to filter routes.
ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters.
After the bgp update-delay on-startup command is configured, BGP delays sending updates for all routes on reboot. For BGP to immediately send updates for the specified routes, execute the bgp update-delay on-startup prefix-list command.
# In BGP instance view, configure BGP to send updates 100 seconds after reboot and immediately send updates for routes that match IPv4 prefix list aaa.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup prefix-list aaa
Use bgp update-delay on-startup ipv6-prefix-list to configure BGP to immediately send route updates for routes that match an IPv6 prefix list.
Use undo bgp update-delay on-startup ipv6-prefix-list to restore the default.
bgp update-delay on-startup ipv6-prefix-list ipv6-prefix-list-name
No IPv6 prefix list is specified to filter routes.
BGP instance view
ipv6-prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
After the bgp update-delay on-startup command is configured, BGP delays sending updates for all routes on reboot. For BGP to immediately send updates for the specified routes, execute the bgp update-delay on-startup ipv6-prefix-list command.
# In BGP instance view, configure BGP to send updates 100 seconds after reboot and immediately send updates for routes that match IPv6 prefix list bbb.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup ipv6-prefix-list bbb
bmp server
Use bmp server to create a BGP monitoring protocol (BMP) server and enter BMP server view.
Use undo bmp server to remove a BMP server and all its configurations.
bmp server server-number
undo bmp server server-number
No BMP servers exist.
server-number: Specifies a BMP server by its number in the range of 1 to 8.
# Create BMP server 5 and enter its view.
[Sysname] bmp server 5
[Sysname-bmpserver-5]
check-origin-validation
Use check-origin-validation to enable BGP RPKI validation.
Use undo check-origin-validation to disable BGP RPKI validation.
BGP RPKI validation is disabled.
BGP RPKI view
This command enables BGP to validate the prefix and origin AS number of a received route and place the route to one of the following validation states:
· Not-found—No ROA matches the prefix.
· Valid—One or multiple ROAs match both the prefix and origin AS number.
· Invalid—One or multiple ROAs match the prefix, but none of these ROAs matches the origin AS number.
You can configure a routing policy to filter routes based on the BGP RPKI validation state.
# Enable BGP RPKI validation.
[Sysname] bgp 100
[Sysname-bgp-default] rpki
[Sysname-bgp-default-rpki] check-origin-validation
compare-different-as-med
Use compare-different-as-med to enable MED comparison for routes from peers in different ASs.
Use undo compare-different-as-med to restore the default.
MED comparison is disabled for routes from peers in different ASs.
If multiple routes to a destination exist, the route with the smallest MED is selected.
Do not use this command unless relevant ASs adopt the same IGP protocol and routing selection method.
# In BGP instance view, enable MED comparison for routes from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-default] compare-different-as-med
confederation id
Use confederation id to configure a confederation ID.
Use undo confederation id to restore the default.
confederation id as-number
No confederation ID is configured.
as-number: Specifies an AS number that identifies the confederation, in the range of 1 to 4294967295.
You can split an AS into several sub-ASs, and each sub-AS remains fully meshed. These sub-ASs form a confederation. Key path attributes of a route, such as the Next_HOP, MED, and LOCAL_PREF, are not discarded when crossing each sub-AS. The sub-ASs still look like one AS from the perspective of other ASs. The AS number is the confederation ID.
Confederation can ensure the integrity of the former AS, and solve the problem of too many IBGP connections in the AS.
Configure the same confederation ID for all routers in one confederation.
For a non-confederation BGP router that establishes a BGP connection to a router in a confederation, the confederation ID is the AS number of the router.
# Confederation 9 consists of four sub-ASs numbered 38, 39, 40 and 41. Peer 10.1.1.1 is a member of sub-AS 38. Peer 200.1.1.1 is a member outside of confederation 9, which belongs to AS 98. Confederation 9 looks like one AS (with AS number 9) from the perspective of peer 200.1.1.1. This example uses a router in sub-AS 41.
[Sysname] bgp 41
[Sysname-bgp-default] confederation id 9
[Sysname-bgp-default] confederation peer-as 38 39 40
[Sysname-bgp-default] group Confed38 external
[Sysname-bgp-default] peer Confed38 as-number 38
[Sysname-bgp-default] peer 10.1.1.1 group Confed38
[Sysname-bgp-default] group Remote98 external
[Sysname-bgp-default] peer Remote98 as-number 98
[Sysname-bgp-default] peer 200.1.1.1 group Remote98
confederation nonstandard
Use confederation nonstandard to enable compatibility with routers not compliant with RFC 3065 in the confederation.
Use undo confederation nonstandard to restore the default.
The device is compatible with only routers compliant with RFC 3065 in the confederation.
Configure this command on all routers compliant with RFC 3065 to interact with those routers not compliant with RFC 3065 in the confederation.
# Confederation 100 consists of two sub-ASs, 64000 and 65000, and contains routers not compliant with RFC 3065. Enable compatibility with routers not compliant with RFC 3065 in the confederation.
[Sysname] bgp 64000
[Sysname-bgp-default] confederation id 100
[Sysname-bgp-default] confederation peer-as 65000
[Sysname-bgp-default] confederation nonstandard
confederation id
Use confederation peer-as to specify confederation peer sub-ASs.
Use undo confederation peer-as to remove the specified confederation peer sub-ASs.
undo confederation peer-as [ as-number-list ]
No confederation peer sub-ASs are specified.
as-number-list: Specifies a sub-AS number list. A maximum of 32 sub-ASs can be configured in one command line. The expression is as-number-list = as-number &<1-32>. The as-number argument specifies a sub-AS number in the range of 1 to 4294967295, and &<1-32> indicates that a maximum of 32 numbers can be specified.
Before this configuration, use the confederation id command to specify the confederation ID for the sub-ASs.
If the undo confederation peer-as command is executed without the as-number-list argument, all confederation peer sub-ASs are removed.
# In BGP instance view, specify confederation peer sub-ASs 2000 and 2001.
[Sysname] bgp 100
[Sysname-bgp-default] confederation peer-as 2000 2001
confederation id
dampening
Use dampening to enable BGP route dampening.
Use undo dampening to restore the default.
undo dampening
Route dampening is disabled.
half-life-reachable: Specifies a half-life for active routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes, in the range of 1 to 20000. A suppressed route whose penalty value decreases under the value is reused. By default, the reuse value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies a suppression threshold in the range of 1 to 20000. The route with a penalty value greater than the threshold is suppressed. The default value is 2000.
ceiling: Specifies a ceiling penalty value in the range of 1001 to 20000. The value must be greater than the suppress value. By default, the value is 16000.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
This command dampens only EBGP routes.
If an EBGP peer goes down after you configure this command, routes coming from the peer are dampened but not deleted.
# In BGP IPv4 unicast address family view, configure BGP route dampening. Set the half-life for both active and suppressed routes to 10 minutes, the reuse threshold to 1000, the suppression threshold to 2000, and the ceiling penalty to 10000.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] dampening 10 10 1000 2000 10000
default local-preference
Use default local-preference to configure a default local preference.
Use undo default local-preference to restore the default.
The default local preference is 100.
value: Specifies a default local preference in the range of 0 to 4294967295. A larger value represents a higher preference.
You can also use the apply local-preference command in a routing policy to configure the local preference for BGP routes. If no routing policy is configured, all BGP routes use the local preference set by the default local-preference command. If a routing policy is configured, BGP routes matching the routing policy use the local preference set by the apply local-preference command. Other BGP routes use the local preference set by the default local-preference command.
# In BGP IPv4 unicast address family view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default local-preference 180
route-policy
default med
Use default med to specify a default MED value.
Use undo default med to restore the default.
default med med-value
undo default med
The default MED value is 0.
med-value: Specifies the default MED value in the range of 0 to 4294967295.
BGP selects a MED value in the following order:
1. MED set by the apply cost command.
2. MED set by the med keyword in the import-route command.
3. MED set by the default med command.
4. Original MED of a BGP route, or MED changed from the metric of a redistributed IGP route.
# In BGP IPv4 unicast address family view, set the default MED to 25.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default med 25
apply cost
import-route
route-policy
Use default-route imported to enable default route redistribution into the BGP routing table.
Use undo default-route imported to restore the default.
Default route redistribution into the BGP routing table is disabled.
By default, BGP does not redistribute default IGP routes. To redistribute default IGP routes into the BGP routing table, you must use the default-route imported command together with the import-route command.
# In BGP IPv4 unicast address family view, enable default route redistribution from OSPF process 1 into the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default-route imported
[Sysname-bgp-default-ipv4] import-route ospf 1
import-route
default-route update-first
Use default-route update-first to configure BGP to send withdrawal messages of the default route prior to other routes.
Use undo default-route update-first to restore the default.
BGP does not send withdrawal messages of the default route prior to other routes.
BGP instance view
Typically a BGP router does not send withdrawal messages of the default route prior to other routes to its peers. If the peer relationship is down, the default route cannot be withdrawn first. Traffic interruption might occur. Use this command to configure BGP to send the withdrawal messages of the default route prior to other routes. This can reduce the traffic interruption time when the peer relationship is down.
# In BGP instance view, configure BGP to send withdrawal messages of the default route prior to other routes.
[Sysname] bgp 100
[Sysname-bgp-default] default-route update-first
display bgp bmp server
Use display bgp bmp server to display BMP server information.
display bgp [ instance instance-name ] bmp server server-number
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BMP server information for the default BGP instance.
# Display information about BMP server 1.
<Sysname> display bgp bmp server 1
BMP server number: 1
Server VPN instance name: vpna
Server address: 100.1.1.1 Server port: 6895
Client address: 100.1.1.2 Client port: 21452
BMP server state: Connected Up for 00h41m53s
TCP source interface has been configured
Message statistics:
Total messages sent: 15
INITIATION: 1
TERMINATION: 0
STATS-REPORT: 0
PEER-UP: 4
PEER-DOWN: 3
ROUTE-MON: 7
BMP monitor BGP peers:
10.1.1.1
Server VPN instance name |
Name of the VPN instance to which the BMP server belongs. If the VPN instance has been deleted, this field displays (Deleted). If the BMP server belongs to the public network, this field displays --. |
Server address |
IP address of the BMP server used by the TCP connection to the BMP client. |
Server port |
Port number of the BMP server used by the TCP connection to the BMP client. |
Client address |
IP address of the BMP client used by the TCP connection to the BMP server. |
Client port |
Port number of the BMP client used by the TCP connection to the BMP server. |
BMP server current state |
TCP connection status: · Connected. · Not connected. |
Up for |
Duration of the TCP connection. |
TCP source interface has been configured |
Source interface of TCP connections to the BMP server. |
Total messages sent |
Number of messages that BGP sends to the BMP server. |
INITIATION |
Number of initiation messages that BGP sends to the BMP server. |
TERMINATION |
Number of termination messages that BGP sends to the BMP server. |
STATS-REPORT |
Number of statistics messages that BGP sends to the BMP server. |
PEER-UP |
Number of peer-up messages that BGP sends to the BMP server. |
PEER-DOWN |
Number of peer-down messages that BGP sends to the BMP server. |
ROUTE-MON |
Number of route monitoring messages that BGP sends to the BMP server. |
BMP monitor BGP peers |
Peers that are monitored by the BMP server. |
Use display bgp dampening parameter to display BGP route dampening parameters.
display bgp [ instance instance-name ] dampening parameter { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
display bgp [ instance instance-name ] dampening parameter vpnv4
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP route dampening parameters for the default BGP instance.
ipv4: Displays BGP IPv4 route dampening parameters.
ipv6: Displays BGP IPv6 route dampening parameters.
vpnv4: Displays IBGP VPNv4 route dampening parameters.
multicast: Displays BGP multicast route dampening parameters.
unicast: Displays BGP unicast route dampening parameters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP route dampening parameters for the public network.
# Display BGP IPv4 unicast route dampening parameters.
<Sysname> display bgp dampening parameter ipv4
Maximum suppression time (in seconds) : 3973
Ceiling value : 16000
Reuse value : 750
Half-life time for reachable routes (in seconds) : 900
Half-life time for unreachable routes (in seconds) : 900
Suppression threshold : 2000
Maximum suppression time |
Maximum time (in seconds) for the penalty value to decrease from the ceiling value to the reuse value. |
Ceiling value |
Penalty ceiling value. |
Reuse value |
Reuse threshold. |
dampening
dampening ibgp (MPLS Command Reference)
display bgp group
Use display bgp group to display BGP peer group information.
display bgp [ instance instance-name ] group ipv4 [ multicast | rtfilter | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ group-name group-name ]
display bgp [ instance instance-name ] group ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ group-name group-name ]
display bgp [ instance instance-name ] group link-state [ group-name group-name ]
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ]
display bgp [ instance instance-name ] group dedicated [ group-name group-name ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP peer group information for the default BGP instance.
ipv4: Displays IPv4 BGP peer group information.
ipv6: Displays IPv6 BGP peer group information.
link-state: Displays BGP LS peer group information.
multicast: Displays BGP multicast peer group information.
rtfilter: Displays BGP IPv4 RT filter peer group information.
unicast: Displays BGP unicast peer group information.
evpn: Displays BGP EVPN peer group information.
dedicate: Displays BGP dedicated peer group information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP peer group information for the public network.
group-name group-name: Specifies a BGP peer group by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a group, this command displays brief information about all BGP peer groups for the specified address family.
By default, the unicast keyword is used if the unicast and multicast keywords are not specified.
# Display brief information about all BGP IPv4 unicast peer groups.
BGP peer group: group1
Remote AS: 600
Type: external
Members:
1.1.1.10
Remote AS number: not specified
Type: external
Members:
# Display detailed information about BGP IPv4 unicast peer group group1.
<Sysname> display bgp group ipv4 group-name group1
Remote AS: 600
Type: external
Maximum number of prefixes allowed: 4294967295
Threshold: 75%
Configured hold time: 180 seconds
Keepalive time: 60 seconds
Minimum time between advertisements: 30 seconds
Peer preferred value: 0
Site-of-Origin: Not specified
Routing policy configured:
Members:
1.1.1.10 600 0 0 0 0 00:00:55 Established
# Display detailed information about BGP IPv6 unicast peer group group2.
<Sysname> display bgp group ipv6 group-name group2
BGP peer group: group2
Remote AS: 600
Type: external
Threshold: 75%
Members:
2::2 600 0 0 0 0 00:00:45 Established
3::3 600 0 0 0 0 00:00:40 Established
BGP peer group |
Name of the BGP peer group. |
Remote AS |
AS number of the peer group. |
Type |
Type of the peer groups: · external—EBGP peer group. · internal—IBGP peer group. |
Maximum number of prefixes allowed |
Maximum number of routes allowed to learn from the peer. |
Threshold |
Percentage of received routes from the peer to maximum routes allowed to learn from the peer. If the percentage is reached, the system generates a log message. |
Configured hold time |
Configured hold interval in seconds. |
Keepalive time |
Keepalive interval in seconds. |
Minimum time between advertisements |
Minimum route advertisement interval in seconds. |
Peer preferred value |
Preferred value specified for routes from the peer. |
Site-of-Origin |
SoO for the peer group. |
Routing policy configured |
Routing policy configured for the peer group. If you do not specify a routing policy, this field displays No routing policy is configured. |
Members |
Information about peers included in the peer group. |
* - Dynamically created peer |
An asterisk (*) before a peer address indicates that the peer is a dynamic peer. |
Peer |
IPv4 or IPv6 address of the peer. |
AS |
AS number of the peer. |
MsgRcvd |
Number of messages received. |
MsgSent |
Number of messages sent. |
OutQ |
Number of messages to be sent. |
PrefRcv |
For the IPv4 and IPv6 address families, this field displays the number of prefixes received from the peer. |
Up/Down |
Lasting time of the current BGP session state. |
State |
Current state of the BGP session between the local router and the peer. |
IPsec profile name |
IPsec profile applied to the IPv6 BGP peer group. |
display bgp instance-info
Use display bgp instance-info to display information about all BGP instances.
# Display information about all BGP instances.
<Sysname> display bgp instance-info
Total BGP instances: 3
BGP instance name AS
BGP1 100
BGP2 200
BGP3 300
Table 5 Command output
Total BGP instances |
Number of BGP instances. |
BGP instance name |
BGP instance name. |
AS |
AS number of the BGP instance. |
display bgp link-state
Use display bgp link-state to display BGP LS information.
display bgp [ instance instance-name ] link-state [ ls-prefix [ advertise-info ] | peer { ipv4-address | ipv6-address } { advertised | received } [ statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP LS information for the default BGP instance.
advertise-info: Displays advertisement information for the specified LS prefix.
ls-prefix: Specifies an LS prefix. If you do not specify this argument, the command displays all BGP LS information.
ipv4-address: Specifies a peer by its IPv4 address.
ipv6-address: Specifies a peer by its IPv6 address.
advertised: Displays advertised LS information.
received: Displays received LS information.
statistics: Displays statistics about LS messages.
If you do not specify any parameters, this command displays brief BGP LS information.
# Display brief BGP LS information for the public network.
<Sysname> display bgp link-state
Total number of routes: 2
BGP local router ID is 1.1.2.1
Status codes: * - valid, > - best, d – dampened, h – history,
s – suppressed, S – stale, i - internal, e - external
a - additional-path
Prefix codes: E link, V node, T IP reachable route, u/U unknown,
I Identifier, N local node, R remote node, L link, P prefix,
L1/L2 ISIS level-1/level-2, O OSPF, D direct, S static, B BGP
a area-ID, , l link-ID, t topology-ID, s ISO-ID,
c confed-ID/ASN, b bgp-identifier, r router-ID,
i if-address, n peer-address, o OSPF Route-type, p IP-prefix
d designated router address
* >e Network : [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376
NextHop : 1.1.1.2 LocPrf :
PrefVal : 0 OutLabel : NULL
MED :
Path/Ogn: 20i
* >e Network : [T][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]][P[o0x1][p1.1.1.0/24]]/480
MED :
Path/Ogn: 20i
Table 6 Command output
Status codes |
Status codes: · * – valid—Valid route. · > – best—Optimal route. · d - dampened—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – stale—Stale route. · i – internal—Internal route. · e – external—External route. · a - additional-path—Add-Path optimal route. |
Prefix codes |
Route status codes: · B – BGP. · E – link. · V – node. · T – IP reachable route. · u/U – unknown. · I – Identifier. · N – local node. · R – remote node. · L – link. · P – prefix. · L1/L2 – ISIS level-1/level-2. · O – OSPF. · D – direct. · S – static. · a – area-ID. · l – link-ID. · t – topology-ID. · s – ISO-ID. · c – confed-ID/ASN. · b – bgp-identifier. · r – router-ID. · i – if-address. · n – peer-address. · o – OSPF Route-type. · p – IP-prefix. · d – designated router address. · a - additional-path. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised with the network command is IGP. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE. |
Network |
NLRI for the LS. |
NextHop |
Next hop IP address. |
LocPrf |
Local preference. |
OutLabel |
This field is not supported in the current software version. Outgoing label of the route. |
MED |
MED attribute. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed, which avoids routing loops. · ORIGIN—Identifies the origin of the route. |
# Display detailed BGP LS information with the specified LS prefix.
<Sysname> display bgp link-state [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376
BGP local router ID: 1.1.1.2
Local AS number: 20
Paths: 1 available, 1 best
BGP LS information of [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376:
Imported route.
Original nexthop: 0.0.0.0
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0xffffffff
LS : Node flag bits: 30[EA]
AS-path : (null)
Origin : igp
Attribute value : pref-val 32768
State : valid, local, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Table 7 Command output
Paths |
Number of routes: · available—Number of valid routes. · best—Number of optimal routes. |
BGP LS information of |
NLRI prefix. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message. |
LS |
LS attribute: · Node flag bits—Node attribute in hexadecimal format: ¡ 10[A]—OSPF ABR bit. ¡ 30[E]—OSPF External bit. · Metric—Link or prefix cost. |
RxPathID |
Add-path ID of received routes. |
TxPathID |
Add-path ID of advertised routes. |
AS-path |
AS_PATH attribute of the route, which records the ASs the route has passed and avoids routing loops. |
Attribute value |
BGP path attributes: · MED—MED value. · localpref—Local preference value. · pref-val—Preferred value. · pre—Route preference. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. |
IP precedence |
IP precedence in the range of 0 to 7. N/A indicates that the route does not support this field. |
QoS local ID |
QoS local ID in the range of 1 to 4095. N/A indicates that the route does not support this field. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field. |
# Display advertisement information for the specified LS prefix.
<Sysname> display bgp link-state [E][B][I0x0][N[r1.1.1.2]][c65008][R[r44.33.22.11]][c65009]][L[i2.1.1.3][n1.1.1.3]]/536 advertise-info
Local AS number: 65008
Paths: 1 best
BGP LS information of [E][B][I0x0][N[r1.1.1.2]][c65008][R[r44.33.22.11]][c65009]][L[i2.1.1.3][n1.1.1.3]]/536
(TxPathID:0):
10.1.1.2
LS attribute :
Peer node segment identifier : Flag c0[VL], Metric 0, Label 23001
Table 8 Command output
Paths |
NLRI prefix. |
Advertised to peers (1 in total) |
Peers to which the information has been advertised, and the total number of such peers. |
Peer node segment identifier |
Peer node SID: · Flag c0[VL]: ¡ V—Value flag. If set, the SID carries a label value. ¡ L—Local flag. If set, the SID has local significance. · Metric—Link cost. · Label—Label value. |
TxPathID |
display bgp network
Use display bgp network to display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp [ instance instance-name ] network { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the default BGP instance.
ipv4: Displays IPv4 address family information.
ipv6: Displays IPv6 address family information.
multicast: Displays BGP multicast address family information.
unicast: Displays BGP unicast address family information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays routing information for the public network.
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv4 unicast address family.
<Sysname> display bgp network ipv4
Local AS number: 100
Network Mask Route-policy Short-cut
20.1.1.0 255.255.255.0 No
40.1.1.0 255.255.255.0 abc No
30.1.1.0 255.255.255.0 Yes
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv6 unicast address family.
<Sysname> display bgp network ipv6
Network PrefixLen Route-policy Short-cut
1:: 24 No
2:: 24 No
3:: 64 policy1 No
2:: 24 Yes
Table 9 Command output
Network |
Destination network address of the routes advertised by the network command and the shortcut routes. |
Mask |
Mask of the destination network address. |
PrefixLen |
Prefix length of the destination network address. |
Route-policy |
Routing policy that is applied to the route. |
Short-cut |
Whether the route is a shortcut route: · Yes. · No. |
Use display bgp non-stop-routing status to display BGP NSR status information.
display bgp [ instance instance-name ] non-stop-routing status
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP NSR status information for the default BGP instance.
# Display BGP NSR status information.
<Sysname> display bgp non-stop-routing status
Location of preferred standby process: -
TCP NSR status: Not ready
Table 10 Command output
BGP NSR status |
BGP NSR status: · Ready—BGP NSR has backed up BGP neighbor and routing information from the active process to the standby process. In this state, BGP NSR can ensure continuous routing when an active/standby process switchover occurs. · Not ready—BGP NSR is backing up BGP neighbor and routing information from the active process to the standby process. If an active/standby process switchover occurs in this state, traffic is interrupted and the BGP session will be re-established. · Not configured—BGP NSR is disabled. |
Location of preferred standby process |
ID of the IRF member device where the preferred standby process resides. This field displays - if no standby processes exist. |
TCP NSR status |
TCP NSR status: · Ready—TCP NSR has backed up TCP connection information from the active process to the standby process. · Not ready—TCP NSR is backing up TCP connection information from the active process to the standby process. |
display bgp paths
Use display bgp paths to display BGP path attribute information.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP path attribute information for the default BGP instance.
as-regular-expression: Displays information about BGP path attributes whose AS_PATH attribute matches the specified regular expression. The as-regular-expression argument is a string of 1 to 256 characters. If you do not specify this argument, the command displays information about all BGP path attributes.
# Display information about all BGP path attributes.
<Sysname> display bgp paths
RefCount MED Path/Origin
3 0 ?
2 0 100i
3 0 100i
1 0 ?
1 0 ?
1 0 ?
Table 11 Command output
RefCount |
Number of BGP routes with these path attributes. |
MED |
MULTI_EXIT_DISC attribute. |
Path/Origin |
AS_PATH and ORIGIN attributes of the route: · AS_PATH attribute—Records the ASs the route has passed, which avoids routing loops. · ORIGIN attribute—Identifies the origin of the route: ¡ i—Originated in the AS. The origin of routes advertised with the network command is IGP. ¡ e—Learned through EGP. ¡ ?—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE. |
display bgp peer
Use display bgp peer to display BGP peer or peer group information.
display bgp [ instance instance-name ] peer ipv4 [ multicast | rtfilter | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | { ipv6-address | link-local-address interface interface-type interface-number | group-name group-name } log-info | [ ipv6-address | link-local-address interface interface-type interface-number ] verbose ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer { ipv4 | ipv6 } [ unicast ] vpn-instance-all [ verbose ]
display bgp [ instance instance-name ] peer link-state [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer l2vpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer dedicated [ { ipv4-address mask-length | ipv6-address prefix-length } | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP peer or peer group information for the default BGP instance.
ipv4: Displays information about a BGP peer or peer group in IPv4 address family.
ipv6: Displays information about a BGP peer or peer group in IPv6 address family.
link-state: Displays BGP LS peer or peer group information.
evpn: Displays BGP EVPN peer or peer group information.
multicast: Displays BGP multicast peer or peer group information.
rtfilter: Displays BGP IPv4 RT filter peer or peer group information.
dedicated: Displays BGP dedicated peer or peer group information.
unicast: Displays BGP unicast peer or peer group information.
vpn-instance-all: Displays BGP peer or peer group information for all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP peer or peer group information for the public network.
ipv4-address mask-length: Specifies a subnet. The value range for the mask length is 0 to 32. If you specify a subnet, this command displays information about all dynamic peers in the subnet.
ipv6-address prefix-length: Specifies a subnet. The value range for the prefix length is 0 to 128. If you specify a subnet, this command displays information about all dynamic peers in the subnet.
link-local-address: Specifies a peer by its link-local address. This argument is not supported in multicast address family view.
group-name group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
log-info: Displays log information.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief BGP peer or peer group information.
If you do not specify any parameters, this command displays brief information about all BGP peers for the specified address family.
# Display brief information about all BGP IPv4 unicast peers.
<Sysname> display bgp peer ipv4
BGP local router ID: 192.168.100.1
Total number of peers: 1 Peers in established state: 1
^ - Peer created through link-local address
10.2.1.2 200 13 16 0 0 00:10:34 Established
# Display brief BGP IPv4 unicast peer information for all VPN instances.
<Sysname> display bgp peer ipv4 vpn-instance-all
VPN instance: 1
BGP local router ID: 111.1.1.1
Total number of peers: 2 Peers in established state: 0
111.1.1.1 100 0 0 0 0 00:00:34 Connect
111.1.1.2 100 0 0 0 0 00:00:34 Connect
VPN instance: 2
BGP local router ID: 112.1.1.1
112.1.1.1 100 0 0 0 0 00:00:06 Idle
112.1.1.2 100 0 0 0 0 00:00:06 Idle
Table 12 Command output
^ - Peer created through link-local address |
A caret (^) before a peer address indicates that the peer is created by using a link-local address. |
VPN instance |
Name of the VPN instance to which the peer belongs. |
Peer |
AS |
MsgRcvd |
MsgSent |
OutQ |
PrefRcv |
For the IPv4 and IPv6 address families, this field displays the number of prefixes that have been received from the peer and added into the local BGP routing table. |
Up/Down |
State |
# Display brief information about all dynamic peers in network 1.1.1.0/24.
<Sysname> display bgp peer ipv4 1.1.1.0 24
Dynamic address range: 1.1.1.0 24
Configured: Active Hold Time: 3 sec Keepalive Time: 1 sec
Address family IPv4 Unicast: Configured
Maximum allowed prefix number: 100
Threshold: 75%
Minimum time between advertisements is 100 seconds
Optional capabilities:
Nexthop self has been configured
Keep-all-routes has been configured
Send community has been configured
Send extend community has been configured
Default route originating has been configured
Multi-hop ebgp has been enabled
Peer preferred value: 100
BFD: Enabled
Site-of-Origin: 1:1
No import as-path-acl list
Export as-path-acl list is: 22
No import prefix list
Export prefix list is: p1
No import route policy
Export route policy is: p1
No import filter-policy
No export filter-policy
Dynamic peers:
# Display brief information about all dynamic peers in network 1::/64.
<Sysname> display bgp peer ipv6 1:: 64
Dynamic address range: 1:: 64
Configured: Active Hold Time: 180 sec Keepalive Time: 60 sec
Address family IPv6 Unicast: Configured
Threshold: 75%
Minimum time between advertisements is 15 seconds
Dynamic peers:
1::1
Table 13 Command output
Type |
BGP connection type between the local router and the dynamic peer: · IBGP link—IBGP connection. · EBGP link—EBGP connection. |
Configured |
Timers configured on the local router in seconds, including the hold time (Active Hold Time) and keepalive interval (Keepalive Time). |
Address family IPv4 Unicast |
IPv4 unicast address family capability. |
Address family link-state |
LS address family capability. |
Address family IPv6 Unicast |
IPv6 unicast address family capability. |
Address family IPv4 Multicast |
IPv4 multicast address family capability. |
Address family IPv6 Multicast |
IPv6 multicast address family capability. |
Address family Dedicated |
Dedicated address family capability. |
Maximum allowed prefix number |
Threshold |
Percentage of received routes from the peer to maximum routes allowed to learn from the peer. If the percentage is reached, the system generates alarm messages. |
Optional capabilities |
Optional capabilities supported by the local end. |
Peer Preferred Value |
Preferred value specified for the routes from the peer. |
BFD |
Whether BFD is enabled to detect the link to the BGP peers. |
IPsec profile applied to the IPv6 BGP peer. This field is available only for the IPv6 unicast and IPv6 multicast address families. |
Routing policy configured for the peer. If you do not specify a routing policy, this field displays No routing policy is configured. |
Dynamic peers |
IP addresses of dynamic peers. |
# Display detailed information about BGP 10.2.1.2 in IPv4 unicast address family.
<Sysname> display bgp peer ipv4 10.2.1.2 verbose
Peer: 10.2.1.2 Local: 192.168.100.1
BGP version 4, remote router ID 192.168.100.2
BGP current state: Established, Up for 00h11m10s
BGP current event: RecvKeepalive
BGP last state: OpenConfirm
Port: Local - 179 Remote - 60672
Received : Active Hold Time: 180 sec
Negotiated: Active Hold Time: 180 sec Keepalive Time: 60 sec
Peer optional capabilities:
Peer supports BGP multi-protocol extension
Peer supports BGP route refresh capability
Peer supports BGP route AS4 capability
Address family IPv4 Unicast: advertised and received
InQ updates: 0, OutQ updates: 0
NLRI statistics:
Rcvd: UnReach NLRI 0, Reach NLRI 0
Sent: UnReach NLRI 0, Reach NLRI 0
Message statistics:
Msg type Last rcvd time/ Current rcvd count/ History rcvd count/
Last sent time Current sent count History sent count
Open 10:38:50-2019.7.23 1 1
Update 10:38:51-2019.7.23 1 1
Notification - 0 0
- 0 0
Keepalive 10:38:50-2019.7.23 1 1
RouteRefresh - 0 0
- 0 0
Total - 3 3
- 3 3
Threshold: 75%
GTSM has been enabled, and the maximum number of hops is 10
BFD: Enabled
# Display detailed information about BGP peer 2::2 in IPv4 unicast address family.
<Sysname> display bgp peer ipv4 2::2 verbose
Peer: 2::2 Local: 2.2.2.2
Type: EBGP link
BGP version 4, remote router ID 3.3.3.3
BGP current state: Established, Up for 00h24m31s
Port: Local - 179 Remote - 51971
Peer supports BGP extended nexthop encoding capability
NLRI statistics:
Rcvd: UnReach NLRI 0, Reach NLRI 1
Sent: UnReach NLRI 0, Reach NLRI 5
Message statistics:
Open 15:45:52-2019.4.19 1 2
Update 15:45:53-2019.4.19 2 4
15:45:52-2019.4.19 6 12
Notification 15:45:50-2019.4.19 0 1
- 0 0
Keepalive 16:09:25-2019.4.19 25 31
16:10:13-2019.4.19 30 36
RouteRefresh - 0 0
- 0 0
Total - 28 38
- 37 50
Threshold: 75%
Extended nexthop encoding has been enabled
# Display detailed information about BGP peer 1::2 in IPv6 unicast address family.
<Sysname> display bgp peer ipv6 1::2 verbose
Peer: 1::2 Local: 192.168.1.136
Type: EBGP link
Link-local interface: GigabitEthernet1/0/1
BGP version 4, remote router ID 192.168.1.135
BGP current state: Established, Up for 00h05m48s
Port: Local - 13184 Remote - 179
NLRI statistics:
Sent: UnReach NLRI 0, Reach NLRI 3
Message statistics:
Open 18:59:15-2019.4.24 1 1
18:59:15-2019.4.24 1 2
Update - 0 0
18:59:16-2019.4.24 1 1
Notification - 0 0
18:59:15-2019.4.24 0 1
Keepalive 18:59:15-2019.4.24 1 1
RouteRefresh - 0 0
- 0 0
Total - 2 2
- 3 5
Threshold: 75%
BFD: Enabled
# Display detailed BGP IPv4 unicast peer information for all VPN instances.
<Sysname> display bgp peer ipv4 vpn-instance-all verbose
Peer: 111.1.1.1 Local: 111.1.1.1
VPN instance: 1
Type: IBGP link
BGP version 4, remote router ID 0.0.0.0
BGP current state: Connect
BGP current event: CRTimerExpired
BGP last state: Connect
NLRI statistics:
Message statistics:
Open - 0 0
- 0 0
Update - 0 0
- 0 0
Notification - 0 0
- 0 0
Keepalive - 0 0
- 0 0
RouteRefresh - 0 0
- 0 0
Total - 0 0
- 0 0
Threshold: 75%
Peer: 111.1.1.2 Local: 111.1.1.1
VPN instance: 1
Type: IBGP link
NLRI statistics:
Message statistics:
Open - 0 0
- 0 0
Update - 0 0
- 0 0
Notification - 0 0
- 0 0
Keepalive - 0 0
- 0 0
RouteRefresh - 0 0
- 0 0
Total - 0 0
- 0 0
Threshold: 75%
Peer: 112.1.1.1 Local: 112.1.1.1
VPN instance: 2
Type: IBGP link
NLRI statistics:
Message statistics:
Open - 0 0
- 0 0
Update - 0 0
- 0 0
Notification - 0 0
- 0 0
Keepalive - 0 0
- 0 0
RouteRefresh - 0 0
- 0 0
Total - 0 0
- 0 0
Threshold: 75%
Peer: 112.1.1.2 Local: 112.1.1.1
VPN instance: 2
Type: IBGP link
NLRI statistics:
Message statistics:
Open - 0 0
- 0 0
Update - 0 0
- 0 0
Notification - 0 0
- 0 0
Keepalive - 0 0
- 0 0
RouteRefresh - 0 0
- 0 0
Total - 0 0
- 0 0
Threshold: 75%
Table 14 Command output
Peer |
Local |
Local router ID. |
VPN instance |
Type |
BGP connection type between the local router and the peer: · IBGP link—IBGP connection. · EBGP link—EBGP connection. |
Link-local interface |
Interface used to establish the connection to a peer created by using a link-local address. |
remote router ID |
Router ID of the peer. |
BGP current state |
Up for |
Lasting time of the BGP session. |
BGP current event |
Current event of the BGP session between the local router and the peer. |
BGP last state |
Previous state of the BGP session. |
Port |
TCP port numbers of the local router and its peer. |
Configured |
Received |
Received timer (configured on the peer) in seconds, including the hold time (Active Hold Time). |
Negotiated |
Negotiated timers in seconds, including the hold time (Active Hold Time) and keepalive interval (Keepalive Time). |
Peer optional capabilities |
Optional capabilities supported by the peer. |
Peer supports BGP route AS4 capability |
The peer supports 4-byte AS number. |
Peer supports BGP extended nexthop encoding capability |
Peers in IPv4 unicast address family support extended next hop encoding capability. |
IPv4 unicast address family capability: routes of the address family can be advertised and received. |
Address family LS |
LS address family capability: routes of the address family can be advertised and received. |
IPv6 unicast address family capability: routes of the address family can be advertised and received. |
IPv4 multicast address family capability: routes of the address family can be advertised and received. |
IPv6 multicast address family capability: routes of the address family can be advertised and received. |
Dedicated address family capability: routes of the address family can be advertised and received. |
InQ updates |
Number of received updates to be processed. |
OutQ updates |
Number of updates to be sent to the peer. |
NLRI statistics |
Number of the reachable and unreachable routes received from and sent to the peer after the BGP session is established. |
Message statistics |
BGP message statistics. |
Msg type |
BGP message type. |
Last rcvd time/Last sent time |
Time when the most recent BGP message was received from or sent to the peer. |
Current rcvd count/Current sent count |
Number of BGP messages received from or sent to the peer on the current BGP session. |
History rcvd count/History sent count |
Number of BGP messages received from or sent to the peer since the BGP peer relationship was established. |
Total |
Total number of received and sent messages. |
Threshold |
Extended Nexthop Encoding has been enabled |
The local end supports the extended next hop encoding capability. |
GTSM has been enabled |
GTSM is supported. |
the maximum number of hops |
Maximum number of hops to the specified peer. |
BFD |
Whether BFD is enabled to detect the link to the BGP peer. |
# Display log information for BGP IPv4 unicast peer 1.1.1.1.
<Sysname> display bgp peer ipv4 1.1.1.1 log-info
Date Time State Notification
Error/SubError
06-Feb-2019 22:54:42 Down Send notification with error 6/4
<administrative reset>
# Display log information for BGP IPv6 unicast peer fe80::2.
<Sysname> display bgp peer ipv6 fe80::2 interface gigabitethernet 1/0/1 log-info
Peer : FE80::2 Interface: GigabitEthernet1/0/1
Error/SubError
11-Jun-2019 08:43:10 Down Send notification with error 6/4
Cease/Administrative Reset
Table 15 Command output
Peer |
Interface type and number. |
Date |
Date on which the Notification was sent or received. |
Time |
Time at which the Notification was sent or received. |
State |
BGP session state: · Up—The BGP session is in Established state. · Down—The BGP session is down. |
Notification Error/SubError |
Error code of the Notification, indicating the cause of why the BGP session was down. · Error—Refers to the error code, which identifies the type of the Notification. · SubError—Refers to the error subcode of the Notification, which identifies the specific information about the reported error. |
display bgp peer received prefix-list
Use display bgp peer received prefix-list to display the ORF prefix information received by a peer.
display bgp [ instance instance-name ] peer ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] ipv4-address received prefix-list
display bgp [ instance instance-name ] peer ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] ipv6-address received prefix-list
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ORF prefix information for the default BGP instance.
ipv4: Displays BGP IPv4 peer information.
ipv6: Displays BGP IPv6 peer information.
multicast: Displays BGP multicast peer information.
unicast: Displays BGP unicast peer information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an instance, this command displays information for the public network.
# Display the ORF prefix information received by peer 10.110.25.20.
<Sysname> display bgp peer ipv4 10.110.25.20 received prefix-list
ORF prefix list entries: 2
index: 10 prefix 1.1.1.0/24 ge 26 le 32
index: 20 prefix 2.1.1.0/24 ge 26 le 32
Table 16 Command output
ORF prefix list entries |
Number of ORF prefixes. |
index |
Prefix index. |
prefix |
Prefix information. |
ge |
Greater than or equal to. |
le |
Less than or equal to. |
display bgp routing-table dampened
Use display bgp routing-table dampened to display dampened BGP routes.
display bgp [ instance instance-name ] routing-table dampened { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
display bgp [ instance instance-name ] routing-table dampened vpnv4
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays dampened BGP routes for the default BGP instance.
ipv4: Displays dampened BGP IPv4 routes.
ipv6: Displays dampened BGP IPv6 routes.
vpnv4: Displays dampened IBGP VPNv4 routes.
multicast: Displays dampened BGP multicast routes.
unicast: Displays dampened BGP unicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays dampened BGP routes for the public network.
By default, the unicast keyword is used if neither the multicast keyword nor the unicast keyword is specified.
# Display dampened BGP IPv4 unicast routes.
<Sysname> display bgp routing-table dampened ipv4
BGP local router ID is 192.168.1.135
Status codes: * - valid, > - best, d - dampened, h - history
a – additional-path
Network From Reuse Path/Ogn
de 20.1.1.0/24 10.1.1.2 00:56:27 100i
# Display dampened BGP IPv6 unicast routes.
<Sysname> display bgp routing-table dampened ipv6
a – additional-path
de Network : 2:: PrefixLen : 64
Path/Ogn: 100i
Path/Ogn: 100i
Table 17 Command output
Status codes |
Status codes: · * – valid—Valid route. · > – best—Optimal route. · d – dampened—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – stale—Stale route. · i – internal—Internal route. · e – external—External route. · a – additional-path—Add-Path optimal route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised with the network command is IGP. · e – EGP—Learned through EGP. · ?– incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE. |
Network |
Destination network address. |
From |
IP address from which the route was received. |
Reuse |
Reuse time of the route. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH attribute—Records the ASs the route has passed, which avoids routing loops. · ORIGIN attribute—Identifies the origin of the route. |
dampening
reset bgp dampening
display bgp routing-table dedicated
Use display bgp routing-table dedicated to display BGP dedicated routing information.
display bgp [ instance instance-name ] routing-table dedicated [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-type mac-ip ] [ { dedicated-route route-length | dedicated-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
peer: Displays BGP dedicated routing information advertised to or received from the specified peer.
advertised-routes: Displays advertised BGP dedicated routing information.
received-routes: Displays received BGP dedicated routing information.
statistics: Displays BGP dedicated route statistics.
route-type: Displays BGP dedicated routes of the specified type. Only MAC/IP routes are supported in the current software version.
mac-ip: Displays MAC/IP routes.
dedicated-route route-length: Displays detailed information about the specified BGP dedicated route. The dedicated-route argument specifies the BGP dedicated routing information, in the range of 1 to 512 characters. The route-length argument specifies the length of the BGP dedicated routing information, in the range of 0 to 65535 bits.
dedicated-prefix: Displays detailed information about the specified BGP dedicated route. The dedicated-prefix argument is a case-insensitive string of 1 to 512 characters and specifies the routing information and routing information length of the dedicated route in dedicated-route/route-length format.
advertise-info: Displays advertisement information for BGP dedicated routes.
ipv4-address: Displays BGP dedicated routes that carry the specified IPv4 address.
ipv6-address: Displays BGP dedicated routes that carry the specified IPv6 address.
mac-address: Displays BGP dedicated routes that carry the specified MAC address.
# Display brief information about all BGP dedicated routes.
<Sysname> display bgp routing-table dedicated
BGP local router ID is 8.8.8.8
a – additional-path
* >e Network : [1][48][0011-0022-0033][32][11.22.33.44][3]/104
NextHop : 1.2.3.4 LocPrf : 100
PrefVal : 0
MED : 0
Path/Ogn: 200i
* >e Network : [1][48][0710-0101-3451][0][3]/72
NextHop : 1.2.3.9 LocPrf : 100
PrefVal : 0
MED : 0
Path/Ogn: 200i
Table 18 Command output
BGP local router ID |
Local router ID. |
Status codes |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised with the network command is IGP. · e – EGP—Learned through EGP. · ?– incomplete—Unknown origin. |
Total number of routes |
Total number of BGP dedicated routes. |
Network |
BGP dedicated route/route length in [1][MACLength][MAC][IPAddressLength][IPAddress][OriginType] format: · 1—The route is a MAC/IP route and carries IPSG binding information. · MACLength—MAC address length. · MAC—MAC address. · IPAddressLength—IP address length. · IPAddress—IP address. · OriginType—IPSG binding source. Options include the following: ¡ 3—DHCP relay. ¡ 7—ND snooping. ¡ 8—DHCPv6 relay. |
NextHop |
LocPrf |
Local preference value. |
PrefVal |
Preferred value of the route. |
MED |
MED attribute. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed, which avoids routing loops. This field can display only 16 AS numbers. Exceeding AS numbers are omitted. You can view the omitted AS numbers by displaying the detailed route information. · ORIGIN—Identifies the origin of the route. |
# Display detailed information about BGP dedicated route [1][48][0011-0022-0033][32][11.22.33.44][3]/120.
<Sysname> display bgp routing-table dedicated [1][48][0011-0022-0033][32][11.22.33.44][3]/120
Total number of routes: 1
Paths: 2 available, 1 best
BGP routing table information of [1][48][0011-0022-0033][32][11.22.33.44][3]/120:
Rely nexthop : 10.1.1.2
Original nexthop: 10.1.1.2
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : egp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Route type : MAC/IP route
MAC length : 48
MAC address : 0011-0022-0033
IP length : 32
IP address : 11.22.33.44
Origin type : DHCP relay agent
VLAN ID : 4096
Inner VLAN ID : 10
Origin router ID: 1.1.1.2
Table 19 Command output
Local router ID. |
Local AS number |
Local AS number. |
Paths |
BGP routing table information of [1][48][0011-0022-0033][32][11.22.33.44][3]/120 |
Detailed information about BGP dedicated route [1][48][0011-0022-0033][32][11.22.33.44][3]/120. |
From |
IP address of BGP peer that advertised the route. |
Rely Nexthop |
Next hop found by route recursion. If no next hop is found, this field displays not resolved. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP UPDATE message, the original next hop is the next hop IP address in the message. |
OutLabel |
Outgoing label of the route. This field is not supported in BGP dedicated address family. |
RxPathID |
Add-path ID of received routes. This field is not supported in BGP dedicated address family. |
TxPathID |
Add-path ID of advertised routes. This field is not supported in BGP dedicated address family. |
AS-path |
AS_PATH attribute of the route. |
Origin |
Origin of the route: · igp—Originated in the AS. · egp—Learned through EGP. · incomplete—Unknown origin. |
Attribute value |
State |
Current state of the route: · valid. · internal. · external. · local. · best. |
IP precedence |
QoS local ID |
Traffic index |
Route Type |
Route type. Only MAC/IP is supported in the current software version. |
MAC Length |
Length of the MAC address carried in the dedicated route. |
MAC |
IPAddressLength |
Length of the IP address carried in the dedicated route. |
IPAddress |
Origin type |
IPSG binding origin: · ND snooping. · DHCP relay agent. · DHCPv6 relay agent. |
VLAN ID |
VLAN ID carried in the dedicated route. |
Inner VLAN ID |
Inner VLAN ID carried in the dedicated route. This field displays N/A if the route carries only one VLAN tag. |
Origin router ID |
ID of the router that generates the route. |
# Display advertisement information about BGP dedicated route [1][48][0011-0022-0033][32][11.22.33.44][3]/120.
<Sysname> display bgp routing-table dedicated [1][48][0011-0022-0033][32][11.22.33.44][3]/120 advertise-info
BGP local router ID: 192.168.1.136
Paths: 1 best
BGP routing table information of [1][48][0011-0022-0033][32][11.22.33.44]/104:
10.1.1.2
Table 20 Command output
Local router ID. |
Local AS number |
Local AS number. |
Paths |
Number of optimal routes to the destination. |
Advertisement information about BGP dedicated route [1][48][0011-0022-0033][32][11.22.33.44][3]/120. |
Peers to which the route has been advertised. |
# Display statistics for BGP dedicated routes advertised to peer 1::1.
<Sysname> display bgp routing-table dedicated peer 1::1 advertised-routes statistics
Advertised routes total: 1
# Display statistics for BGP dedicated routes received from peer 1::1.
<Sysname> display bgp routing-table dedicated peer 1::1 received-routes statistics
Received routes total: 1
Table 21 Command output
Advertised routes total |
Total number of BGP dedicated routes advertised to the peer. |
Received routes total |
Total number of BGP dedicated routes received from the peer. |
# Display BGP dedicated route statistics.
<Sysname> display bgp routing-table dedicated statistics
Total number of routes: 4
Table 22 Command output
display bgp routing-table flap-info
Use display bgp routing-table flap-info to display BGP route flap statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ]
display bgp [ instance instance-name ] routing-table flap-info vpnv4 [ ipv4-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP route flap statistics for the default BGP instance.
ipv4: Displays BGP IPv4 route flap statistics.
ipv6: Displays BGP IPv6 route flap statistics.
vpnv4: Displays IBGP VPNv4 route flap statistics.
multicast: Displays BGP multicast route flap statistics.
unicast: Displays BGP unicast route flap statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP route flap statistics for the public network.
ipv4-address: Specifies a destination network address.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a network mask in dotted decimal notation.
longest-match: Specifies longest match mode, which selects the longest matching route through the following steps:
1. ANDs the specified network address with the mask of each route.
2. Matches a route if the AND result is the same as the network address of the route and the mask of the route is shorter than or equal to the specified mask.
3. Selects the route with the longest mask among the matching routes.
ipv6-address prefix-length: Displays route flap statistics for BGP IPv6 routes that match the specified network address, and match the prefix length in the range of 0 to 128.
as-path-acl as-path-acl-number: Displays route flap statistics for BGP routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays route flap statistics for BGP routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
If you specify only the ipv4-address argument, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays flap statistics of the route.
If you specify the ipv4-address mask or ipv4-address mask-length argument, and do not specify the longest-match keyword, the command displays flap statistics of the BGP IPv4 unicast or multicast route that matches both the specified destination network address and the mask (or mask length).
# Display BGP IPv4 unicast route flap statistics.
<Sysname> display bgp routing-table flap-info ipv4
a – additional-path
Network From Flaps Duration Reuse Path/Ogn
de 20.1.1.0/24 10.1.1.2 1 00:02:36 00:53:58 100i
# Display BGP IPv6 unicast route flap statistics.
<Sysname> display bgp routing-table flap-info ipv6
a – additional-path
Duration: 00:03:25 Reuse : 00:39:28
Path/Ogn: 100i
Path/Ogn: 100i
Table 23 Command output
Status codes |
Status codes: · * – valid—Valid route. · > – best—Optimal route. · d – dampened—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – stale—Stale route. · i – internal—Internal route. · e – external—External route. · a – additional-path. |
Origin |
Network |
From |
Source IP address of the route. |
Flaps |
Number of routing flaps. |
Duration |
Duration time of the flap route. |
Reuse |
Path/Ogn |
dampening
reset bgp flap-info
display bgp routing-table ipv4 multicast
Use display bgp routing-table ipv4 multicast to display BGP IPv4 multicast routing information.
display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv4 multicast routing information for the default BGP instance.
advertise-info: Displays advertisement information for BGP IPv4 multicast routes.
as-path-acl as-path-acl-number: Displays BGP IPv4 multicast routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv4 multicast routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
community-list: Displays BGP IPv4 multicast routes that match a community list.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
whole-match: Displays BGP IPv4 multicast routes exactly matching the specified community list. If you do not specify this keyword, the command displays BGP IPv4 multicast routes whose COMMUNITY attributes include the specified community list.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
peer ipv4-address: Displays BGP IPv4 multicast routing information advertised to or received from the specified peer.
advertised-routes: Displays BGP IPv4 multicast routing information advertised to the specified peer.
received-routes: Displays BGP IPv4 multicast routing information received from the specified peer.
statistics: Displays routing statistics.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 multicast routes.
If you specify only the ipv4-address argument, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays information about the route.
If you specify the ipv4-address mask or ipv4-address mask-length argument and do not specify the longest-match keyword, this command displays information about the BGP IPv4 multicast route that matches both the specified destination network address and the mask (or mask length).
# Display brief information about all BGP IPv4 multicast routes.
<Sysname> display bgp routing-table ipv4 multicast
BGP local router ID is 192.168.1.62
a – additional-path
* > 5.5.5.5/32 127.0.0.1 0 32768 ?
* > 192.168.1.0 192.168.1.62 0 32768 ?
* > 192.168.1.62/32 127.0.0.1 0 32768 ?
# Display information about BGP IPv4 multicast routes that match AS path list 20.
<Sysname> display bgp routing-table ipv4 multicast as-path-acl 20
a – additional-path
# Display information about BGP IPv4 multicast routes that match BGP community list 100.
<Sysname> display bgp routing-table ipv4 multicast community-list 100
a – additional-path
# Display information about all BGP IPv4 multicast routes advertised to peer 192.168.1.139.
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.139 advertised-routes
a – additional-path
Network NextHop MED LocPrf Path/Ogn
* > 5.5.5.5/32 127.0.0.1 0 100 ?
* > 192.168.1.0 192.168.1.62 0 100 ?
# Display information about all BGP IPv4 multicast routes received from peer 192.168.1.139.
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.139 received-routes
a – additional-path
* >i 8.8.8.8/32 192.168.1.139 0 100 0 ?
* i 192.168.1.0 192.168.1.139 0 100 0 ?
Table 24 Command output
Status codes |
Origin |
Network |
NextHop |
MED |
LocPrf |
PrefVal |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed. · ORIGIN—Identifies the origin of the route. |
# Display detailed information about BGP IPv4 multicast routes destined to network 5.5.5.5/32.
<Sysname> display bgp routing-table ipv4 multicast 5.5.5.5 32
BGP local router ID: 192.168.1.139
BGP routing table information of 5.5.5.5/32:
Rely nexthop : 192.168.1.62
Original nexthop: 192.168.1.62
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
State : valid, internal, best, delay
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Table 25 Command output
Paths |
From |
Rely Nexthop |
Original nexthop |
OutLabel |
RxPathID |
Add-Path ID of received routes. |
TxPathID |
Add-Path ID of advertised routes. |
AS-path |
Origin |
Origin of the route: · igp—Originated in the AS. The origin of routes advertised with the network command is IGP. · egp—Learned through EGP. · incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE. |
Attribute value |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · delay—The route will be delayed for optimal route selection. This field is displayed only in the detailed command output. |
IP precedence |
QoS local ID |
Traffic index |
# Display statistics for BGP IPv4 multicast routes advertised to peer 192.168.1.62.
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.62 advertised-routes statistics
# Display statistics for BGP IPv4 multicast routes received from peer 192.168.1.62.
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.62 received-routes statistics
Table 26 Command output
Total number of advertised routes. |
Total number of received routes. |
# Display BGP IPv4 multicast route statistics.
<Sysname> display bgp routing-table ipv4 multicast statistics
Table 27 Command output
Total number of routes. |
# Display advertisement information for the BGP IPv4 multicast route destined to network 8.8.8.8/32.
<Sysname> display bgp routing-table ipv4 multicast 8.8.8.8 32 advertise-info
BGP routing table information of 8.8.8.8/32(TxPathID:0):
Table 28 Command output
Local BGP router ID. |
Local AS number |
Local AS number. |
Paths |
BGP routing table information of 8.8.8.8/32(TxPathID:0) |
Advertisement information for network 8.8.8.8/32. |
Peers to which the network has been advertised. |
ip as-path
ip community-list
display bgp routing-table ipv4 rtfilter
Use display bgp routing-table ipv4 rtfilter to display BGP IPv4 RT filter routing information.
display bgp [ instance instance-name ] routing-table ipv4 rtfilter [ default-rt [ advertise-info ] | [ origin-as as-number ] [ route-target [ advertise-info ] ] | peer ipv4-address { advertised-routes | received-routes } [ default-rt | [ origin-as as-number ] [ route-target ] | statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv4 RT filter routing information for the default BGP instance.
default-rt: Displays BGP IPv4 RT filter routing information for an all-zero RT.
origin-as as-number: Specifies an origin AS by its number.
route-target: Specifies an RT, a string of 3 to 21 characters.
An RT has the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
advertise-info: Displays advertisement information for BGP IPv4 RT filter routes.
peer ipv4-address: Displays BGP IPv4 RT filter routing information advertised to or received from the specified peer.
advertised-routes: Displays BGP IPv4 RT filter routing information advertised to the specified peer.
received-routes: Displays BGP IPv4 RT filter routing information received from the specified peer.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 RT filter routes.
# Display brief information about all BGP IPv4 RT filter routes.
<Sysname> display bgp routing-table ipv4 rtfilter
BGP local router ID is 192.168.1.136
a - additional-path
Total number of routes from all PEs: 2
Origin AS: 100
* >e Network : <100:1> PrefixLen : 96
PrefVal : 0
MED :
Path/Ogn: 100i
* >e Network : <1.1.1.1:1> PrefixLen : 96
PrefVal : 0
MED :
Path/Ogn: 100i
# Display information about BGP IPv4 RT filter routes that match origin AS 100.
<Sysname> display bgp routing-table ipv4 rtfilter origin-as 100
a - additional-path
Origin AS: 100
PrefVal : 0
MED :
Path/Ogn: 100i
PrefVal : 0
MED :
Path/Ogn: 100i
# Display information about all public BGP IPv4 RT filter routes advertised to peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 advertised-routes
a - additional-path
Origin AS: 100
* > Network : <100:1> PrefixLen : 96
MED : 0
Path/Ogn: i
# Display information about all public BGP IPv4 RT filter routes received from peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 received-routes
a - additional-path
Origin AS: 100
NextHop : 10.1.1.1 LocPrf :
PrefVal : 0
MED : 0
Path/Ogn: 100i
Table 29 Command output
Origin AS |
Origin AS of the RT filter routes. |
Status codes |
Status codes: · * – valid—Valid route. · > – best—Optimal route. · d – dampened—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – stale—Stale route. · i – internal—Internal route. · e – external—External route. · a - additional-path—Add-Path optimal route. |
Origin |
Network |
NextHop |
MED |
LocPrf |
PrefVal |
Path/Ogn |
# Display detailed information about BGP IPv4 RT filter route 100:1.
<Sysname> display bgp routing-table ipv4 rtfilter 100:1
Origin AS: 100
BGP routing table information of <100:1>/96:
Imported route.
Original nexthop: 10.2.1.1
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : igp
Attribute value : MED 0, pref-val 32768, pre 0
State : valid, local, best, delay
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Table 30 Command output
Paths |
Imported route |
The BGP RT filter route is locally generated. |
Original nexthop |
OutLabel |
RxPathID |
TxPathID |
AS-path |
Origin |
Attribute value |
State |
From |
Rely Nexthop |
IP precedence |
QoS local ID |
Traffic index |
Backup route |
The route is a backup route. |
# Display statistics for BGP IPv4 RT filter routes advertised to peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 advertised-routes statistics
Advertised routes total: 2
# Display statistics for BGP IPv4 RT filter routes received from peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 received-routes statistics
Received routes total: 2
Table 31 Command output
# Display BGP IPv4 RT filter route statistics.
<Sysname> display bgp routing-table ipv4 rtfilter statistics
Total number of routes from all PEs: 6
Origin AS: 100
Origin AS: 200
# Display advertisement information for the BGP IPv4 RT filter route 1.1.1.1:1/96.
<Sysname> display bgp routing-table ipv4 rtfilter 1.1.1.1:1 advertise-info
Paths: 1 best
Origin AS: 100
Paths: 1 best
BGP route-target filter information of <1.1.1.1:1>/96:
1.1.1.2
Origin AS: 200
Paths: 1 best
1.1.1.2
Table 32 Command output
Paths |
BGP route-target filter information of <1.1.1.1:1>/96 |
Information about BGP IPv4 RT filter route 1.1.1.1:1/96. |
Advertised to VPN peers (1 in total) |
display bgp routing-table ipv4 unicast
Use display bgp routing-table ipv4 unicast to display BGP IPv4 unicast routing information.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv4 unicast routing information for the default BGP instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the BGP IPv4 unicast routing information for the public network.
advertise-info: Displays advertisement information for BGP IPv4 unicast routes.
as-path-acl as-path-acl-number: Displays BGP IPv4 unicast routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv4 unicast routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
community-list: Displays BGP IPv4 unicast routes that match a community list.
whole-match: Displays routes exactly matching the specified community list. If you do not specify this keyword, the command displays routes whose COMMUNITY attributes include the specified community list.
peer ipv4-address: Displays BGP IPv4 unicast routing information advertised to or received from the specified IPv4 peer.
peer ipv6-address: Displays BGP IPv4 unicast routing information advertised to or received from the specified IPv6 peer.
advertised-routes: Displays routing information advertised to the specified peer.
received-routes: Displays routing information received from the specified peer.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 unicast routes.
If you specify the ipv4-address mask or ipv4-address mask-length argument and do not specify the longest-match keyword, this command displays information about the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length).
This command displays BGP IPv4 unicast routing information regardless of whether the unicast keyword is specified.
# Display brief information about all BGP IPv4 unicast routes.
BGP local router ID is 192.168.100.1
a – additional-path
* > 10.2.1.0/24 10.2.1.1 0 0 i
e 10.2.1.2 0 0 4294967295
4294967294 4294967293 4294967292 4294967291 4294967290 4294967215 4294967225 4294967235 4294967245 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290... i
* > 192.168.1.0 192.168.1.135 0 0 i
* e 10.2.1.2 0 0 200i
# Display information about BGP IPv4 unicast routes that match AS path list 1.
<Sysname> display bgp routing-table ipv4 as-path-acl 1
a – additional-path
* >e 30.1.1.0/24 20.1.1.1 0 200i
# Display information about all public BGP IPv4 unicast routes advertised to peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes
Status codes: * - valid, > - best, d - damped, h - history,
s - suppressed, S - Stale, i - internal, e - external
a – additional-path
# Display information about all public BGP IPv4 unicast routes received from peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes
a – additional-path
e 10.2.1.0/24 10.2.1.2 0 0 200i
* e 192.168.1.0 10.2.1.2 0 0 200i
Status codes |
Origin |
Network |
NextHop |
MED |
LocPrf |
PrefVal |
Path/Ogn |
# Display detailed information about BGP IPv4 unicast routes destined to network 10.2.1.0/24.
<Sysname> display bgp routing-table ipv4 10.2.1.0 24
BGP routing table information of 10.2.1.0/24:
Imported route.
OutLabel : NULL
Ext-Community : <HostRoute>, <IP Mobility: Flag 0, SeqNum 3>
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : igp
Attribute value : MED 0, pref-val 0, pre 0
State : valid, local, best, delay, bgp-rib-only
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
Rely nexthop : not resolved
Original nexthop: 10.2.1.2
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
Attribute value : MED 0, pref-val 0, pre 255
State : external
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
# Display detailed information about the BGP IPv4 unicast route destined to address 1.1.1.1/32.
<Sysname> display bgp routing-table ipv4 1.1.1.1 32
BGP routing table information of 1.1.1.1/32:
Rely nexthop : 10.2.1.1
OutLabel : 16201
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : igp
PrefixSID : Label index 201
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Backup route.
Rely nexthop : 10.2.1.2
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : external
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Table 34 Command output
Paths |
Original nexthop |
OutLabel |
Ext-Community |
Extended community attribute: · HostRoute—Host route. · IP Mobility—IP migration attribute. Flag indicates whether the IP address can be migrated. 1 indicates that the IP address cannot be migrated and 0 indicates that the IP address can be migrated. SeqNum represents the host migration serial number. The larger the serial number, the later the migration. |
RxPathID |
TxPathID |
AS-path |
Origin |
PrefixSID |
Prefix SID: · Label index—Label index. · SRGB—SRGB range. |
Attribute value |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · delay—The route will be delayed for optimal route selection. This field is displayed only in the detailed command output. · bgp-rib-only—The route will not be flushed to the routing table. This field is displayed only in the detailed command output. |
From |
IP address of the BGP peer that advertised the route. |
Rely Nexthop |
IP precedence |
QoS local ID |
Traffic index |
Tunnel policy |
Tunnel policy that takes effect. NULL indicates that no tunnel policy takes effect. |
Rely Tunnel IDs |
Tunnel index IDs after route recursion. This field displays multiple tunnel index IDs if ECMP tunnels exist and displays N/A if no tunnels are found by route recursion. |
# Display statistics for public BGP IPv4 unicast routes advertised to peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes statistics
# Display statistics for public BGP IPv4 unicast routes received from peer 10.2.1.2.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes statistics
Table 35 Command output
# Display BGP IPv4 unicast route statistics.
<Sysname> display bgp routing-table ipv4 statistics
Table 36 Command output
# Display advertisement information for the BGP IPv4 unicast route destined to network 10.2.1.0/24.
<Sysname> display bgp routing-table ipv4 10.2.1.0 24 advertise-info
BGP routing table information of 10.2.1.0/24(TxPathID:0):
Table 37 Command output
Local AS number |
Local AS number. |
Paths |
BGP routing table information of 10.2.1.0/24(TxPathID:0) |
Advertisement information for network 10.2.1.0/24. |
ip as-path
ip community-list
display bgp routing-table ipv6 multicast
Use display bgp routing-table ipv6 multicast to display BGP IPv6 multicast routing information.
display bgp [ instance instance-name ] routing-table ipv6 multicast [ ipv6-address prefix-length [ advertise-info ] | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv6 multicast routing information for the default BGP instance.
ipv6-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If you do not specify this argument, the command displays brief information about all BGP IPv6 multicast routing information.
advertise-info: Displays advertisement information for BGP IPv6 multicast routes. If you do not specify this keyword, the command displays the BGP IPv6 multicast routing table.
as-path-acl as-path-acl-number: Displays BGP IPv6 multicast routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv6 multicast routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
community-list: Displays BGP IPv6 multicast routes that match a community list.
whole-match: Displays BGP IPv6 multicast routes exactly matching the specified community list. If you do not specify this keyword, the command displays BGP IPv6 multicast routes whose COMMUNITY attributes include the specified community list.
peer: Displays BGP IPv6 multicast routing information advertised to or received from the specified peer.
ipv6-address: Specifies the peer IPv6 address.
advertised-routes: Displays BGP IPv6 multicast routing information advertised to the specified peer.
received-routes: Displays BGP IPv6 multicast routing information received from the specified peer.
# Display brief information about all BGP IPv6 multicast routes.
<Sysname> display bgp routing-table ipv6 multicast
BGP local router ID is 192.168.1.139
a – additional-path
* > Network : 1:: PrefixLen : 64
NextHop : :: LocPrf :
MED : 0
Path/Ogn: ?
* i Network : 1:: PrefixLen : 64
NextHop : 1::1 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: ?
* > Network : 1::2 PrefixLen : 128
NextHop : ::1 LocPrf :
MED : 0
Path/Ogn: ?
* > Network : 2::2 PrefixLen : 128
MED : 0
Path/Ogn: ?
* >i Network : 5::5 PrefixLen : 128
MED : 0
Path/Ogn: ?
# Display information about BGP IPv6 multicast routes that match AS path list 1.
<Sysname> display bgp routing-table ipv6 multicast as-path-acl 1
a – additional-path
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
# Display information about BGP IPv6 multicast routes that match BGP community list 100.
<Sysname> display bgp routing-table ipv6 multicast community-list 100
a – additional-path
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
# Display information about all BGP IPv6 multicast routes advertised to peer 1::1.
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 advertised-routes
a – additional-path
NextHop : :: LocPrf : 100
MED : 0 OutLabel : NULL
Path/Ogn: ?
NextHop : ::1 LocPrf : 100
Path/Ogn: ?
# Display information about all BGP IPv6 multicast routes received from peer 1::1.
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 received-routes
a – additional-path
MED : 0
Path/Ogn: ?
MED : 0
Path/Ogn: ?
Table 38 Command output
Status codes |
Origin |
Network |
PrefixLen |
NextHop |
Next hop IP address. |
LocPrf |
PrefVal |
OutLabel |
This field is not supported in the current software version. Outgoing label of the route. |
MED |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed, which avoids routing loops. · ORIGIN—Identifies the origin of the route. |
# Display detailed information about BGP IPv6 multicast routes destined to network 2::2/128.
<Sysname> display bgp routing-table ipv6 multicast 2::2 128
Local AS number: 100
BGP routing table information of 2::2/128:
Imported route.
Original nexthop: ::1
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Table 39 Command output
Paths |
Number of routes: · available—Number of valid routes. · best—Number of optimal routes. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message. |
OutLabel |
RxPathID |
TxPathID |
AS-path |
AS_PATH attribute of the route, which records the ASs the route has passed and avoids routing loops. |
Origin |
Attribute value |
BGP path attributes: · MED—MED value. · localpref—Local preference value. · pref-val—Preferred value. · pre—Route preference. |
State |
From |
Rely Nexthop |
IP precedence |
IP precedence in the range of 0 to 7. N/A indicates that the route does not support this field. |
QoS local ID |
QoS local ID in the range of 1 to 4095. N/A indicates that the route does not support this field. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field. |
# Display advertisement information for BGP IPv6 multicast routes destined to network 2::2/128.
<Sysname> display bgp routing-table ipv6 multicast 2::2 128 advertise-info
BGP routing table information of 2::2/128(TxPathID:0):
Table 40 Command output
Local AS number |
Local AS number. |
Paths |
BGP routing table information of 2::2/128(TxPathID:0) |
Advertisement information for network 2::2/128. |
Advertised to peers (1 in total) |
# Display statistics for BGP IPv6 multicast routes advertised to peer 1::1.
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 advertised-routes statistics
# Display statistics for BGP IPv6 multicast routes received from peer 1::1.
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 received-routes statistics
Table 41 Command output
# Display BGP IPv6 multicast route statistics.
<Sysname> display bgp routing-table ipv6 multicast statistics
Table 42 Command output
ip as-path
ip community-list
display bgp routing-table ipv6 unicast
Use display bgp routing-table ipv6 unicast to display BGP IPv6 unicast routing information.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer { ipv4-address | link-local-address interface interface-type interface-number } { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP IPv6 unicast routing information for the default BGP instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the BGP IPv6 unicast routing information for the public network.
ipv6-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If you do not specify this argument, the command displays brief information about all BGP IPv6 unicast routing information.
advertise-info: Displays advertisement information for BGP IPv6 unicast routes. If you do not specify this keyword, the command displays the BGP IPv6 unicast routing table.
as-path-acl as-path-acl-number: Displays BGP IPv6 unicast routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv6 unicast routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
community-list: Displays BGP IPv6 unicast routes that match a community list.
peer: Displays BGP IPv6 unicast routing information advertised to or received from the specified peer.
ipv4-address: Specifies the peer IPv4 address.
This command displays BGP IPv6 unicast routing information regardless of whether the unicast keyword is specified.
# Display brief information about all BGP IPv6 unicast routes.
a – additional-path
* >e Network : 3:: PrefixLen : 64
NextHop : 1::2 LocPrf :
MED :
Path/Ogn: 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290 4294967215 4294967225 4294967235 4294967245 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290... i
# Display information about BGP IPv6 unicast routes that match AS path list 1.
<Sysname> display bgp routing-table ipv6 as-path-acl 1
a – additional-path
* >e Network : 2:: PrefixLen : 64
MED :
Path/Ogn: 100i
MED :
Path/Ogn: 100i
# Display information about BGP IPv6 unicast routes that match BGP community list 100.
<Sysname> display bgp routing-table ipv6 community-list 100
a – additional-path
MED :
Path/Ogn: 100i
MED :
Path/Ogn: 100i
# Display information about all BGP IPv6 unicast routes advertised to peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes
a – additional-path
* > Network : 2:: PrefixLen : 64
Path/Ogn: i
# Display information about all BGP IPv6 unicast routes received from peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes
a – additional-path
NextHop : ::FFFF:10.1.1.1 LocPrf :
MED : 0
Path/Ogn: 100i
Status codes |
Origin |
Network |
PrefixLen |
Prefix length of the destination network address. |
NextHop |
Next hop IPv6 address. |
LocPrf |
PrefVal |
OutLabel |
MED |
MULTI_EXIT_DISC attribute. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH attribute—Records the ASs the route has passed, which avoids routing loops. This field can display only 16 AS numbers. Exceeding AS numbers are omitted. You can view the omitted AS numbers by displaying the detailed route information. · ORIGIN attribute—Identifies the origin of the route. |
# Display detailed information about BGP IPv6 unicast routes destined to network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64
Local AS number: 200
BGP routing table information of 2::/64:
Relay nexthop : ::FFFF:10.1.1.1
Original nexthop: ::FFFF:10.1.1.1
OutLabel : NULL
Ext-Community : <HostRoute>, <IP Mobility: Flag 0, SeqNum 1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 100
Origin : igp
State : valid, external, best, delay, bgp-rib-only
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Relay nexthop : 1::1
Original nexthop: 1::1
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 100
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Table 44 Command output
Paths |
Original nexthop |
OutLabel |
Ext-Community |
RxPathID |
TxPathID |
AS-path |
Origin |
Attribute value |
State |
Current state of the route: · valid. · internal. · external. · local. · best. · delay—The route will be delayed for optimal route selection. This field is displayed only in the detailed command output. · bgp-rib-only—The route will not be flushed to the routing table. This field is displayed only in the detailed command output. |
From |
Relay Nexthop |
IP precedence |
QoS local ID |
Traffic index |
Tag |
Route tag. This field is available in Release 6526 and later. |
Tunnel policy |
Rely Tunnel IDs |
# Display advertisement information for BGP IPv6 unicast routes destined to network 2::/64.
<Sysname> display bgp routing-table ipv6 2:: 64 advertise-info
BGP routing table information of 2::/64(TxPathID:0):
Advertised to peers (2 in total):
10.1.1.2
1::2
Table 45 Command output
Paths |
Number of optimal routes destined to the specified network. |
BGP routing table information of 2::/64(TxPathID:0) |
Advertisement information for BGP routes destined to network 2::/64. |
Advertised to peers (2 in total) |
Peers to which the route has been advertised, and the number of peers. |
# Display statistics for BGP IPv6 unicast routes advertised to peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes statistics
# Display statistics for BGP IPv6 unicast routes received from peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes statistics
Table 46 Command output
# Display BGP IPv6 unicast route statistics.
<Sysname> display bgp routing-table ipv6 statistics
Table 47 Command output
ip as-path
ip community-list
display bgp rpki server
Use display bgp rpki server to display information about connections to RPKI servers.
display bgp [ instance instance-name ] rpki server [ [ vpn-instance vpn-instance-name ] ipv4-address ]
display bgp [ instance instance-name ] rpki server [ [ vpn-instance vpn-instance-name ] ipv6-address ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the default BGP instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the public network.
ipv4-address: Specifies an RPKI server by its IPv4 address.
ipv6-address: Specifies an RPKI server by its IPv6 address.
# Display brief information about connections to RPKI servers.
<Sysname> display bgp rpki server
Server VPN-index Port State Time ROAs(IPv4/IPv6)
1.1.1.2 0 1234 Establish 00:05:51 1/0
2.2.2.2 0 1234 Establish 00:06:07 3/1
Table 48 Command output
Server |
IP address of the RPKI server. |
VPN-index |
VPN index. |
Port |
Port number of the RPKI server. |
State |
Connection state: · Establish—BGP has established a connection to the RPKI server. · Connect—BGP is establishing a connection to the RPKI server. · Shutdown—BGP has not established a connection to the RPKI server. |
Time |
Duration of the current connection state. |
ROAs(IPv4/IPv6) |
Number of IPv4/IPv6 ROAs. |
# Display detailed information about the connection to RPKI server 2.2.2.1.
<Sysname> display bgp rpki server 2.2.2.1
RPKI Cache-Server 2.2.2.1
Port: TCP port 1234
Local addr: 2.2.2.2, Local port: 14342
Connect state: Establish
Total byte Rx: 72
Total byte Tx: 8
Session ID: 1
Serial number: 1
Last PDU type 7, Time: 00:00:15
Last disconnect reason: Response timer expired
Table 49 Command output
RPKI Cache-Server |
Port |
Local addr |
Local IP address of the connection. |
Local port |
Local port number of the connection. |
Connect state |
Total byte Rx |
Number of received bytes. |
Total byte Tx |
Number of sent bytes. |
Session ID |
Session ID assigned by the RPKI server. |
Serial number |
Serial number assigned by the RPKI server. |
Last PDU Type |
Type of the most recently received PDU. |
Time |
Last disconnect reason |
Reason for the most recent connection interruption: · Confingure reset—The port number used to establish the connection was changed or the reset bgp rpki server command was executed. · Receive error report PDU—Received error report packets from the server. · Response timer expired—No response was received within the response time from the RPKI server. · Receive error PDU—Received error packets. · TCP connect failed—The TCP connection was down. · Shutdown port—No port number was specified. · Not enough memory—The memory was insufficient. · Receive cache reset PDU—Received reset packets from the RPKI server. |
display bgp rpki table
Use display bgp rpki table to display the ROA information obtained from RPKI servers.
display bgp [ instance instance-name ] rpki table ipv4 [ ipv4-address min min-length max max-length ]
display bgp [ instance instance-name ] rpki table ipv6 [ ipv6-address min min-length max max-length ]
ipv4: Displays information about ROAs with IPv4 prefixes.
ipv4-address: Specifies an IPv4 prefix.
ipv6: Displays information about ROAs with IPv6 prefixes.
ipv6-address: Specifies an IPv6 prefix.
min-length: Specifies the minimum prefix length. The value range for this argument is 0 to 32 for IPv4 prefixes and 0 to 128 for IPv6 prefixes.
max-length: Specifies the maximum prefix length. The value range for this argument is 0 to 32 for IPv4 prefixes and 0 to 128 for IPv6 prefixes.
# Display brief information about ROAs with IPv4 prefixes.
<Sysname> display bgp rpki table ipv4
Total number of entries: 4
Status codes: S - stale, U - used
Network Mask-range Origin-AS Server Status
1.2.3.4 8-32 100 1.1.1.2 U
5.2.3.4 8-32 100 2.2.2.2 U
6.6.6.6 8-32 100 2.2.2.2 U
7.7.7.7 8-32 20 2.2.2.2 U
Table 50 Command output
Total number of entries |
Total number of ROAs. |
Network |
Network address. |
Mask-range |
Mask or prefix length range. |
Server |
Status |
ROA state: · U—The ROA is available. · S—The ROA is in aging state. |
# Display detailed information about ROAs with IPv4 prefixes.
<Sysname> display bgp rpki table ipv4 5.2.3.4 min 8 max 32
RPKI ROA entry for 5.2.3.4/8-32
Origin-AS: 100 from 2.2.2.1, used
Table 51 Command output
Origin-AS |
ROA information: · AS number. · IP address of the RPKI server. · ROA state: ¡ used—The ROA is available. ¡ stale—The ROA is in aging state. |
display bgp troubleshooting
Use display bgp troubleshooting to display information about BGP peer relationship down events.
display bgp [ instance instance-name ] troubleshooting [ event-count ] [ reverse ]
event-count: Specifies the number of peer relationship down events to display, in the range of 1 to 1000. If you do not specify this argument, the command displays information about the earliest or most recent 20 events based on the configuration of the reverse keyword.
reverse: Displays peer relationship down events in chronological order. If you do not specify this keyword, the command displays peer relationship down events in reverse chronological order.
Configure this command to display information about BGP peer relationship down events, including the time, reason, and recommended action.
# Display reasons why BGP peer relationships went down.
<Sysname> display bgp troubleshooting
Total number: 1
Date Time Event description
2019-10-06 09:39:18 The BGP peer 10.1.1.1 went down because the
peer ignore command was configured manually.
Please check local BGP configuration.
Table 52 Command output
Total number |
Total number of peer relationships that went down. |
Date |
Date (in YYYY-MM-DD format) on which a specific BGP peer relationship went down. |
Time |
Time (in HH:MM:SS format) when a specific BGP peer relationship went down. |
Event description |
Description for a specific peer down event. The description format is The BGP peer ip-address went down because peer-down-reason. Please treatment-suggestion. ip-address represents the IP address of the peer, peer-down-reason represents the down reason, and treatment-suggestion represents the recommended action to take. |
mtp enable (Layer 3—IP Routing Command Reference)
domain-distinguisher
Use domain-distinguisher to specify an AS number and a router ID for BGP LS messages.
Use undo domain-distinguisher to restore the default.
domain-distinguisher as-number:router-id
The AS number and router ID of the current BGP process are used.
BGP LS address family view
as-number:router-id: Specifies the AS number and router ID. The value range for the as-number argument is 1 to 4294967295, and the router ID is in IP address format.
# Set the AS number and router ID for BGP LS messages to 65009 and 1.1.1.1, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] address-family link-state
[Sysname-bgp-default-ls] domain-distinguisher 65009:1.1.1.1
ebgp-interface-sensitive
Use ebgp-interface-sensitive to enable immediate re-establishment of direct EBGP sessions.
Use undo ebgp-interface-sensitive to disable immediate re-establishment of direct EBGP sessions.
Immediate re-establishment of direct EBGP sessions is enabled.
When a direct link to an EBGP peer fails, BGP tears down the session and re-establishes a session to the peer immediately. If the feature is not enabled, the router does not tear down the session until the hold time expires. However, disabling this feature can prevent routing flaps from affecting EBGP session state.
This command applies only to direct EBGP sessions.
# Enable immediate re-establishment of direct EBGP sessions.
[Sysname] bgp 100
[Sysname-bgp-default] ebgp-interface-sensitive
fast-reroute route-policy
Use fast-reroute route-policy to apply a routing policy to fast reroute (FRR) for a BGP address family.
Use undo fast-reroute route-policy to restore the default.
No routing policy is applied to FRR.
BGP IPv4 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv6 unicast address family view
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can use the following methods to configure BGP FRR:
· Method 1—Execute the pic command in BGP address family view. BGP calculates a backup next hop for a BGP route in the address family if there are two or more unequal-cost routes to reach the destination.
· Method 2—Execute the fast-reroute route-policy command to use a routing policy in which a backup next hop is specified by using the command apply [ ipv6 ] fast-reroute backup-nexthop. For BGP to generate a backup next hop for the primary route, the backup next hop calculated by BGP must be the same as the specified backup next hop. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
# Apply routing policy frr-policy to FRR in BGP IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4
[Sysname-bgp-default-ipv4] fast-reroute route-policy frr-policy
apply fast-reroute
apply ipv6 fast-reroute
pic
route-policy
filter-policy export
Use filter-policy export to filter advertised BGP routes.
Use undo filter-policy export to remove the route filter.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP IPv4 multicast address family view:
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } export [ direct | { isis | ospf | rip } process-id | static ]
undo filter-policy export [ direct | { isis | ospf | rip } process-id | static ]
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view/BGP IPv6 multicast address family view:
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-list-name } export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
undo filter-policy export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
Advertised BGP routes are not filtered.
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999, to match routes by destination.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999, to match routes by destination.
name ipv4-acl-name: Specifies an IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
prefix-list ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to match routes by destination.
prefix-list ipv6-prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to match routes by destination.
direct: Filters direct routes.
isis: Filters IS-IS routes.
isisv6: Filters IPv6 IS-IS routes.
ospf: Filters OSPF routes.
ospfv3: Filters OSPFv3 routes.
rip: Filters RIP routes.
ripng: Filters RIPng routes.
static: Filters static routes.
process-id: Specifies a routing protocol by its ID in the range of 1 to 65535.
If you specify a protocol (such as direct and isis), this command filters only routes redistributed from the specified protocol. If you do not specify a protocol, this command filters all advertised routes, including the following routes:
· Redistributed from IGP.
· Injected by the network command.
· Learned from BGP peers.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches routes whose destination network addresses match the source-address source-wildcard argument. However, it does not match the masks of the destination addresses.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following steps:
· To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
· To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address. For the mask configuration to take effect, specify a contiguous subnet mask.
# In BGP IPv4 unicast address family view, use IPv4 basic ACL 2000 to filter advertised BGP IPv4 routes.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] filter-policy 2000 export
filter-policy import
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
Use filter-policy import to filter received BGP routes.
Use undo filter-policy import to restore the default.
Received BGP routes are not filtered.
# In BGP IPv4 unicast address family view, use IPv4 basic ACL 2000 to filter received BGP routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] filter-policy 2000 import
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
flush suboptimal-route
Use flush suboptimal-route to enable BGP to flush the suboptimal BGP route to the RIB.
Use undo flush suboptimal-route to disable BGP from flushing the suboptimal BGP route to the RIB.
BGP is disabled from flushing the suboptimal BGP route to the RIB. Only the optimal route is flushed to the RIB.
This command flushes the suboptimal BGP route to the RIB when the following conditions are met:
· The optimal route is generated by the network command or is redistributed by the import-route command.
· The suboptimal route is received from a BGP peer.
After the suboptimal route is flushed to the RIB on a network, BGP immediately switches traffic to the suboptimal route when the optimal route fails.
For example, the device has a static route to the subnet 1.1.1.0/24 that has a higher priority than a BGP route. BGP redistributes the static route and receives a route to 1.1.1.0/24 from a peer. After the flush suboptimal-route command is executed, BGP flushes the received BGP route to the RIB as the suboptimal route. When the static route fails, BGP immediately switches traffic to the suboptimal route if inter-protocol FRR is enabled. For more information about inter-protocol FRR, see Layer 3—IP Routing Configuration Guide.
# Enable BGP to flush the suboptimal BGP route to the RIB.
[Sysname] bgp 100
[Sysname-bgp-default] flush suboptimal-route
forwarding-conversational-learning
Use forwarding-conversational-learning to enable conversational remote host route learning.
Use undo forwarding-conversational-learning to disable conversational remote host route learning.
forwarding-conversational-learning [ route-policy route-policy-name ]
In BGP IPv4/IPv6 address family view, conversational remote host route learning is disabled.
In BGP EVPN address family view, conversational remote host route learning is enabled.
route-policy route-policy-name: Issues only the remote host routes matching the specified routing policy to the FIB. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a routing policy or the specified routing policy does not exist, BGP issues all remote host routes to the FIB. The apply clauses in the specified routing policy do not take effect.
By default, BGP generates FIB entries for all host routes received from peers (remote host routes) and issues the routes to the FIB. To conserve device resources, execute this command in BGP IPv4/IPv6 unicast address family view to enable conversational remote host route learning. The command enables BGP to issue a remote host route to the FIB only if it is required for forwarding a packet.
When you execute this command in BGP IPv4/IPv6 unicast address family view, follow these restrictions and guidelines:
· This command takes effect only on remote host routes generated based on ARP or ND entries and does not take effect on local host routes and other BGP routes. Host routes generated based on ARP or ND entries carry a special mark advertised through the extended community attribute. Executing this command also enables BGP to advertise the extended community attribute to all peers and peer groups.
· This command takes effect only when you execute the ip forwarding-conversational-learning command.
In an EVPN VXLAN distributed gateway network, a distributed gateway issues ARP entries received from other gateways as host routes to the FIB. To conserve device resources, execute this command in BGP EVPN address family view to enable conversational remote host route learning. The command enables the device to issue a remote ARP entry to the hardware only when the entry is required for packet forwarding.
When you execute this command in BGP EVPN address family view, follow these restrictions and guidelines:
· This command takes effect only on remote EVPN MAC/IP advertisement routes carrying ARP information.
· This command takes effect only when you execute the arp forwarding-conversational-learning command.
# In BGP IPv4 unicast address family view, conversational remote host route learning and specify routing policy policy1 to match remote host routes.
<Sysname>system-view
[Sysname] bgp 200
[[Sysname-bgp-default-ipv4] forwarding-conversational-learning route-policy policy1
arp forwarding-conversational-learning (EVPN Command Reference)
ip forwarding-conversational-learning (EVPN Command Reference)
peer advertise-ext-community
graceful-restart
Use graceful-restart to enable BGP Graceful Restart (GR) capability.
Use undo graceful-restart to disable BGP GR capability.
graceful-restart
BGP GR capability is disabled.
GR ensures continuous forwarding when BGP restarts or an active/standby switchover occurs.
BGP peers exchange Open messages containing GR information. If both parties have GR capability, they establish a GR-capable session.
After you execute this command, the device re-establishes BGP sessions.
# Enable GR capability for BGP process 100.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
graceful-restart peer-reset
Use graceful-restart peer-reset to enable BGP to reset peer sessions gracefully.
Use undo graceful-restart peer-reset to disable BGP from resetting peer sessions gracefully.
graceful-restart peer-reset [ all ]
BGP does not reset peer sessions gracefully.
BGP instance view
all: Enables BGP to reset peer sessions gracefully when the TCP connection goes down, the hold timer expires, or the support for a new address family is added. If you do not specify this keyword, BGP resets peer sessions gracefully only when the support for a new address family is added.
When the TCP connection goes down, the hold timer expires, or the support for a new address family is added, BGP tears down and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, execute this command to enable BGP to reset peer sessions gracefully.
# Enable BGP to reset peer sessions gracefully.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart peer-reset
graceful-restart
Use graceful-restart timer purge-time to set the Routing Information Base (RIB) purge timer.
Use undo graceful-restart timer purge-time to restore the default.
The RIB purge timer is 480 seconds.
timer: Sets the RIB purge timer in the range of 1 to 6000 seconds.
BGP starts the RIB purge timer when an active/standby switchover occurs or BGP restarts. If BGP route exchange is not completed within the RIB purge timer, the GR restarter quits the GR process. It updates the RIB with the BGP routes already learned, and removes the stale routes from RIB.
Enable BGP GR before you execute this command.
Set the RIB purge timer to be long enough to complete GR, especially when large numbers of BGP routes exist.
As a best practice, set the RIB purge timer in the following way:
· Set the timer to be greater than the timer set by the graceful-restart timer wait-for-rib command
· Set the timer to be less than the timer set by the protocol lifetime command.
# Set the RIB purge timer to 300 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer purge-time 300
graceful-restart
protocol lifetime (Layer 3—IP Routing Command Reference)
Use graceful-restart timer restart to configure the GR timer.
Use undo graceful-restart timer restart to restore the default.
The GR timer is 150 seconds.
timer: Specifies the GR timer in the range of 3 to 600 seconds.
The GR restarter sends the GR timer to the GR helper in an Open message. When the GR helper detects that an active/standby switchover or a BGP restart occurred on the GR restarter, the GR helper performs the following operations:
1. Marks all routes learned from the GR restarter as stale.
2. Starts the GR timer.
3. If no BGP session is established before the GR timer expires, the GR helper removes the stale routes.
Before you configure this command, enable the BGP GR capability.
To apply a new GR timer, you must re-establish BGP sessions.
# Set the GR timer to 300 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer restart 300
Use graceful-restart timer wait-for-rib to configure the time to wait for the End-of-RIB marker.
Use undo graceful-restart timer wait-for-rib to restore the default.
The time to wait for the End-of-RIB marker is 600 seconds.
timer: Specifies the time to wait for the End-of-RIB marker, in the range of 3 to 3600 seconds.
BGP uses this timer to control the time to receive updates from the peer. The timer is not advertised to the peer.
After the GR restarter and GR helper re-establish a BGP session, they start this timer. If they do not complete route exchange within the time period, the GR restarter does not receive new routes. It updates its routing table and forwarding table with learned BGP routes, and the GR helper removes the stale routes. Set a large value for the maximum time to wait for the End-of-RIB marker when a large number of routes exist.
This command controls the routing convergence speed. A smaller timer value means faster routing convergence but possibly results in incomplete routing information.
Before configuring this command, you must enable the BGP GR capability.
# Set the time to wait for the End-of-RIB marker on the local end to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer wait-for-rib 100
graceful-restart
group
Use group to create a peer group.
Use undo group to delete a peer group.
group group-name [ external | internal ]
undo group group-name
No peer groups exist.
BGP-VPN instance view
group-name: Specifies a name for the peer group, a case-sensitive string of 1 to 47 characters.
external: Creates an EBGP peer group.
internal: Creates an IBGP peer group.
In a large-scale network, many peers can use the same route selection policy. You can configure a peer group and add these peers into this group. In this way, peers can share the same policy as the peer group. When the policy of the group is modified, the modification also applies to peers in it.
If you do not specify the internal or external keyword, this command creates an IBGP peer group.
If you perform configurations on a peer group and peers of the peer group, the most recent configuration takes effect.
After you create a peer group, you must use the peer enable command to enable BGP to exchange routing information with the specified peer group.
# In BGP instance view, create EBGP peer group test with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group.
[Sysname] bgp 100
[Sysname-bgp-default] group test external
[Sysname-bgp-default] peer test as-number 200
[Sysname-bgp-default] peer 10.1.1.1 group test
[Sysname-bgp-default] peer 10.1.2.1 group test
display bgp group
peer enable
ignore all-peers
Use ignore all-peers to disable BGP session establishment with all peers and peer groups.
Use undo ignore all-peers to restore the default.
ignore all-peers [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
BGP can establish sessions to all peers and peer groups.
BGP instance view
graceful graceful-time: Gracefully shuts down BGP sessions to all peers and peer groups in the specified graceful shutdown period of time. The value range for the graceful-time argument is 60 to 65535 seconds. If you do not specify this option, the command immediately shuts down the sessions to all peers and peer groups.
community { community-number | aa:nn }: Specifies the community attribute for routes advertised to all peers and peer groups. The community-number argument represents the community sequence number in the range of 1 to 4294967295. The aa:nn argument represents the community number. Both aa and nn are in the range of 0 to 65535. If you do not specify this option, the command does not change the community attribute for routes advertised to all peers and peer groups.
local-preference preference: Specifies the local preference for routes advertised to all peers and peer groups, in the range of 0 to 4294967295. A larger value represents a higher preference. If you do not specify this option, the command does not change the local preference for routes advertised to all peers and peer groups.
med med: Specifies the MED value for routes advertised to all peers and peer groups, in the range of 0 to 4294967295. The smaller the MED value, the higher the route priority. If you do not specify this option, the command does not change the MED value for routes advertised to all peers and peer groups.
CAUTION: Executing the ignore all-peers command disables the sessions to all peers and peer groups and clears all related routing information. |
This command enables you to temporarily tear down the BGP sessions to all peers and peer groups. You can perform network upgrade and maintenance without needing to delete and reconfigure the peers and peer groups. To recover the sessions, execute the undo ignore all-peers command.
If you specify the graceful keyword in the ignore all-peers command, BGP performs the following tasks:
· Gracefully shuts down the sessions to all peers and peer groups in the specified graceful shutdown period of time.
· Advertises all routes to all peers and peer groups and changes the attribute for the advertised routes to the specified value.
For a BGP peer or peer group, the configuration made by the peer ignore command takes precedence over the configuration made by the ignore all-peers command.
# In BGP instance view, configure BGP to gracefully shut down the sessions to all peers and peer groups in 60 seconds, advertise all routes to all peers and peer groups, and change the community attribute and local preference for the advertised routes to 1:1 and 200, respectively.
[Sysname] bgp 1
[Sysname-bgp-default] ignore all-peers graceful 60 community 1:1 local-preference 200
peer ignore
ignore-first-as
Use ignore-first-as to configure BGP to ignore the first AS number of EBGP route updates.
Use undo ignore-first-as to restore the default.
ignore-first-as
BGP checks the first AS number of a received EBGP route update. If the first AS number is neither that of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
# Configure BGP to ignore the first AS number of EBGP route updates.
[Sysname] bgp 100
[Sysname-bgp-default] ignore-first-as
peer ignore-first-as
import-route
Use import-route to enable BGP to redistribute routes from an IGP protocol.
Use undo import-route to disable route redistribution from an IGP protocol.
import-route { direct | static } [ med med-value | route-policy route-policy-name ]
undo import-route { direct | { isis | ospf | rip } [ process-id | all-processes ] | static }
undo import-route { direct | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static }
BGP does not redistribute IGP routes.
direct: Redistributes direct routes.
isis: Redistributes IS-IS routes.
isisv6: Redistributes IPv6 IS-IS routes.
ospf: Redistributes OSPF routes.
ospfv3: Redistributes OSPFv3 routes.
rip: Redistributes RIP routes.
ripng: Redistributes RIPng routes.
static: Redistributes static routes.
local-aggregate: Redistributes the local network specified in the public instance or a VPN instance.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default is 1. For IPv4 routes, it is available only when the protocol is isis, ospf, or rip. For IPv6 routes, it is available only when the protocol is isisv6, ospfv3, or ripng.
all-processes: Redistributes routes from all the processes of the specified IGP protocol.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. By default, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
med med-value: Specifies a MED value for redistributed routes, in the range of 0 to 4294967295. If you do not specify an MED, the metric of a redistributed route is used as its MED.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes or set route attributes for redistributed routes.
The import-route command cannot redistribute default IGP routes. To redistribute default IGP routes, use the default-route imported command together with the import-route command.
Only active routes can be redistributed. You can use the display ip routing-table protocol or display ipv6 routing-table protocol command to view route state information.
The ORIGIN attribute is INCOMPLETE for routes redistributed by the import-route command.
If you have specified the all-processes keyword to redistribute all routes of a routing protocol, this command no longer takes effect on any processes of the routing protocol.
# In BGP IPv4 unicast address family view, redistribute routes from RIP process 1, and set the MED value for redistributed routes to 100.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route rip 1 med 100
import-route multipath
Use import-route multipath to redistribute all routes with the same destination address to BGP.
Use undo import-route multipath to restore the default.
When multiple routes with the same destination address exist, BGP redistributes only the optimal routes to its routing table.
This command takes effect only on the routes redistributed by the import-route command in the same address family.
By default, the import-route command redistributes only the optimal routes to BGP when multiple routes with the same destination address exist. To redistribute all routes with the same destination address to BGP, execute this command and BGP can advertise these routes to its peers.
# In BGP IPv4 unicast address family view, enable BGP to redistribute all routes with the same destination address.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route multipath
import-route
ip vpn-instance (BGP instance view)
Use ip vpn-instance to create a BGP-VPN instance and enter its view, or enter the view of an existing BGP-VPN instance.
Use undo ip vpn-instance to remove a BGP-VPN instance and all its configurations.
No BGP-VPN instances exist.
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After you create a BGP peer in BGP-VPN instance view, the BGP routes learned from the peer are added into the routing table of the specified VPN instance.
This command and all commands in BGP-VPN instance view are typically executed on provider edge (PE) or Multi-VPN-Instance CE (MCE) devices. The commands add routes learned from different sites into different VPN instances.
Before you execute this command, you must perform the following tasks:
· Use the ip vpn-instance command to create the VPN instance in system view.
· Use the route-distinguisher command to configure a route distinguisher (RD) for the VPN instance.
# Create a BGP-VPN instance and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1]
ip vpn-instance (system view)(MCE Command Reference)
route-distinguisher(MCE Command Reference)
isolate enable
Use isolate enable to enable BGP isolation.
Use undo isolate enable to restore the default.
isolate enable
undo isolate enable
BGP isolation is disabled.
BGP instance view
This feature is available in Release 6526 and later.
To maintain a BGP network device, you can use BGP isolation to remove the device from the network. This feature reduces configuration cost and impact on the network by retaining the device configuration during the maintenance. After maintenance, you can disable BGP isolation to add the device back to the network.
BGP isolation works as follows:
1. BGP withdraws all routes advertised by the device except for the direct routes.
2. BGP keeps all routes learned from its peers.
3. Each peer of the device reselects an optimal route and updates the FIB table. During optimal route selection, the peers can still use the routes advertised by the device to forward traffic.
4. After an optimal route is selected and the FIB table is updated, the peers stop forwarding packets except for those destined for the device to the device. The device is fully isolated from the network and you can upgrade it.
5. After the maintenance, disable BGP isolation on the device to gracefully add it back to the network. After returning to the network, the device advertises and learns routes as follows:
¡ Advertises routes to its peers.
¡ Learns routes if BGP was reset during the isolation.
To avoid isolation failure, do not use this feature when GR or NSR is enabled for the device.
# Isolate the device from the network in BGP instance view.
[Sysname] bgp 100
[Sysname-bgp-default] isolate enable
log-peer-change
Use log-peer-change to enable logging for BGP session state changes globally.
Use undo log-peer-change to disable logging for BGP session state changes globally.
log-peer-change
Logging for BGP session state changes is enabled globally.
After you execute both the log-peer-change and peer log-change commands, BGP logs session establishment and disconnection events for the peer or peer group. To display the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center of the device. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
If you disable logging for BGP session state changes globally or disable logging for a peer or peer group, BGP does not generate logs for session establishments and disconnections.
# Enable logging for session state changes globally.
[Sysname] bgp 100
[Sysname-bgp-default] log-peer-change
display bgp peer
log-route-flap
Use log-route-flap to enable logging for BGP route flapping.
Use undo log-route-flap to restore the default.
undo log-route-flap
Logging for BGP route flapping is disabled.
monitor-time: Specifies the monitoring interval for route flapping, in the range of 1 to 600 minutes.
monitor-count: Specifies the number of route flaps for triggering a log, in the range of 2 to 8.
log-count-limit: Specifies the maximum number of logs allowed to be generated in a minute. The value range for this argument is 1 to 600, and the default value is 200.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
This command is applicable only to incoming routes of the specified address family.
# In BGP IPv4 unicast address family view, enable logging for BGP route flapping. Set the monitoring interval to 10 minutes, the number of route flaps for triggering a log to 5, and the maximum number of allowed logs in a minute to 100.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] log-route-flap 10 5 100
network
Use network to inject a network to the BGP routing table and configure BGP to advertise the network.
Use undo network to remove a local network.
undo network ipv4-address [ mask-length | mask ]
undo network ipv6-address prefix-length
BGP does not advertise local networks.
ipv4-address: Specifies an IPv4 network address. If you do not specify the mask or mask-length argument, natural mask is used.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a mask in dotted decimal notation.
ipv6-address: Specifies an IPv6 network address.
prefix-length: Specifies a prefix length in the range of 0 to 128.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter routes or set the route attributes.
The network to be injected must be available and active in the local IP routing table.
The ORIGIN attribute of the route injected with the network command is IGP.
When you execute the undo network command, you must specify the same mask or mask length/prefix length that you specified for the network command. Otherwise, the configuration cannot be removed.
# In BGP IPv4 unicast address family view, inject local network 10.0.0.0/16 to the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] network 10.0.0.0 255.255.0.0
network short-cut
Use network short-cut to increase the preference for a received EBGP route. This EBGP route is called a shortcut route.
Use undo network short-cut to remove the configuration.
undo network ipv4-address [ mask-length | mask ] short-cut
undo network ipv6-address prefix-length short-cut
A received EBGP route has a preference of 255.
mask: Specifies a mask for the network address, in dotted decimal notation.
Different routing protocols might find different routes to the same destination. However, not all of those routes are optimal. For route selection, routing protocols, direct routes, and static routes are assigned different preferences. The route with the highest preference is preferred.
By default, the preference of an EBGP route is lower than a local route. If a device has an EBGP route and a local route to reach the same destination, the device does not select the EBGP route. You can use the network shortcut command to configure the EBGP route to have the same preference as the local route so the EBGP route is more likely to become the optimal route.
You can use the preference command to modify the preferences for external and local BGP routes.
# In BGP IPv4 unicast address family view, increase the preference of EBGP route 10.0.0.0/16.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] network 10.0.0.0 255.255.0.0 short-cut
preference
non-stop-routing
Use non-stop-routing to enable BGP nonstop routing (NSR).
Use undo non-stop-routing to disable BGP NSR.
non-stop-routing
BGP NSR is disabled.
BGP NSR ensures continuous routing by synchronizing BGP state and data information from the active BGP process to the standby BGP process. The standby BGP process can seamlessly take over all services when the active process fails.
# Enable BGP NSR.
[Sysname] bgp 100
[Sysname-bgp-default] non-stop-routing
display bgp non-stop-routing status
passwords
Use passwords to set the MD5 authentication password.
Use undo passwords to restore the default.
passwords { cipher | simple } string
undo passwords
The MD5 authentication password is not set.
BGP RPKI server view
string: Specifies the password. Its encrypted form is a case-sensitive string of 33 to 137 characters. Its plaintext form is a case-sensitive string of 1 to 80 characters.
This command can enhance security in the following ways:
· Perform MD5 authentication when establishing TCP connections. Only the two parties that have the same password configured can establish TCP connections.
· Perform MD5 calculation on the packets transmitted over the TCP connections to avoid packet modification.
# In BGP RPKI server view, set the MD5 authentication password.
[Sysname] bgp 100
[Sysname-bgp-default] rpki
[Sysname-bgp-default-rpki] server tcp 1.1.1.1
[Sysname-bgp-default-rpki-server] passwords simple 123456
peer additional-paths
Use peer additional-paths to configure the BGP Additional Paths capabilities.
Use undo peer additional-paths to remove the configuration.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP EVPN address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } additional-paths { receive | send } *
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } additional-paths { receive | send } *
No BGP Additional Paths capabilities are configured.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the BGP Additional Paths capabilities for all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the BGP Additional Paths capabilities for all dynamic peers in the subnet.
link-local-address: Specifies a peer by its link-local address.
receive: Enables the BGP additional path receiving capability.
send: Enables the BGP additional path sending capability.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the Additional Paths capabilities, make sure one end has the sending capability and the other end has the receiving capability.
# In BGP IPv4 unicast address family view, enable the BGP additional path receiving capability.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 additional-paths receive
peer advertise additional-paths best
Use peer advertise additional-paths best to set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
Use undo peer advertise additional-paths best to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise additional-paths best
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise additional-paths best number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise additional-paths best
A maximum of one Add-Path optimal route can be advertised to a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command sets the maximum number of Add-Path optimal routes that can be advertised to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command sets the maximum number of Add-Path optimal routes that can be advertised to all dynamic peers in the subnet.
number: Specifies the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group, in the range of 2 to 32.
If the number of Add-Path optimal routes advertised to a peer or peer group exceeds the number of optimal routes, the number of optimal routes takes effect.
# In BGP IPv4 unicast address family view, set the maximum number to 3 for Add-Path optimal routes that can be advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise additional-paths best 3
additional-paths select-best
peer advertise origin-as-validation
Use peer advertise origin-as-validation to configure BGP to advertise the BGP RPKI validation state to a peer or peer group.
Use undo peer advertise origin-as-validation to restore the default.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise origin-as-validation
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise origin-as-validation
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise origin-as-validation
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise origin-as-validation
BGP does not advertise the BGP RPKI validation state to any peer or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. To configure this command, you must first enable BGP to advertise the extended community attribute to the peer or peer group.
In the current software version, BGP can advertise the BGP RPKI validation state only to IBGP peers and peer groups.
# In BGP IPv4 unicast address family view, configure BGP to advertise the BGP RPKI validation state to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-ext-community
[Sysname-bgp-default-ipv4] peer test advertise origin-as-validation
peer advertise-community
Use peer advertise-community to advertise the COMMUNITY attribute to a peer or peer group.
Use undo peer advertise-community to disable the COMMUNITY attribute advertisement to a peer or peer group.
In BGP IPv4 multicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] } advertise-community
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-community
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-community
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-community
In BGP IPv6 multicast address family view:
peer { group-name | ipv6-address [ prefix-length ] } advertise-community
undo peer { group-name | ipv6-address [ prefix-length ] } advertise-community
No COMMUNITY attribute is advertised to any peers or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises the COMMUNITY attribute to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises the COMMUNITY attribute to all dynamic peers in the subnet.
The COMMUNITY attribute is a group of specific data carried in update messages. A route can carry one or more COMMUNITY attribute values (each is represented by a 4-byte integer). The receiving router processes the route (for example, determining whether to advertise the route and the scope for advertising the route) based on the COMMUNITY attribute values.
After you execute the peer advertise-community command, routing updates advertised to the peer carry the COMMUNITY attribute.
After you execute the undo peer advertise-community command, BGP, upon receiving a route with the COMMUNITY attribute, removes the COMMUNITY attribute before sending the route to the peer or peer group.
# In BGP IPv4 unicast address family view, advertise the COMMUNITY attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-community
apply community
if-match community
ip community-list
Use peer advertise-ext-community to advertise the extended community attribute to a peer or peer group.
Use undo peer advertise-ext-community to disable the extended community attribute advertisement to a peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } advertise-ext-community
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-ext-community
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number} advertise-ext-community
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-ext-community
peer { group-name | ipv6-address [ prefix-length ] } advertise-ext-community
undo peer { group-name | ipv6-address [ prefix-length ] } advertise-ext-community
No extended community attribute is advertised to any peers or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises the extended community attribute to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises the extended community attribute to all dynamic peers in the subnet.
To meet increasing user demands, BGP defines a new attribute—extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
· The extended community attribute has an 8-byte length.
· The extended community attribute supports various types. You can select an extended community attribute type as needed to implement route filtering and control. This simplifies configuration and management.
After you execute the peer advertise-ext-community command, route updates sent to the peer or peer group carry the extended community attribute.
After you execute the undo peer advertise-ext-community command, BGP, upon receiving a route with the extended community attribute, removes the extended community attribute before sending the route to the peer or peer group.
# In BGP IPv4 unicast address family view, advertise the extended community attribute to peer group test.
[Sysname] bgp 100
apply extcommunity
if-match extcommunity
ip extcommunity-list
peer advertise-policy exist-policy
Use peer advertise-policy exist-policy to specify an existent policy to control route advertisement.
Use undo peer advertise-policy exist-policy to remove the configuration.
In BGP IPv4 unicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy exist-policy
In BGP IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-policy advertise-policy-name exist-policy exist-policy-name
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-policy exist-policy
No existent policy is specified to control route advertisement.
advertise-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The routing policy is used as the route advertisement policy.
exist-policy exist-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The routing policy is used as the existent policy.
After you configure this command, routes that match the route advertisement policy can be advertised only when the BGP routing table contains prefixes that match the existent policy.
The existent policy does not apply to routes that do not match the route advertisement policy.
# In BGP IPv4 unicast address family view, configure BGP to advertise routes matching routing policy adv-policy to peer 1.1.1.1 only when the BGP routing table contains prefixes matching routing policy ex-policy.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise-policy adv-policy exist-policy ex-policy
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
peer advertise-policy non-exist-policy
route-policy
Use peer advertise-policy non-exist-policy to specify a nonexistent policy to control route advertisement.
Use undo peer advertise-policy non-exist-policy to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy non-exist-policy
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-policy advertise-policy-name non-exist-policy exist-policy-name
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-policy non-exist-policy
No nonexistent policy is specified to control route advertisement.
non-exist-policy non-exist-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The routing policy is used as the nonexistent policy.
After you configure this command, routes that match the route advertisement policy can be advertised only when the BGP routing table does not contain any prefixes that match the nonexistent policy.
The nonexistent policy does not apply to routes that do not match the route advertisement policy.
# In BGP IPv4 unicast address family view, configure BGP to advertise routes matching routing policy adv-policy to peer 1.1.1.1 only when the BGP routing table does not contain any prefixes matching routing policy n-ex-policy.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise-policy adv-policy non-exist-policy n-ex-policy
peer as-path-acl
peer filter-policy
peer prefix-list
peer route-policy
route-policy
peer allow-as-loop
Use peer allow-as-loop to allow a local AS number to exist in the AS_PATH attribute of routes from a peer or peer group, and to set the number of times the local AS number can appear.
Use undo peer allow-as-loop to remove the configuration.
In /BGP IPv4 multicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] } allow-as-loop
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP EVPN address family view/BGP dedicated address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } allow-as-loop
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } allow-as-loop [ number ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } allow-as-loop
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
undo peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop
The local AS number is not allowed to exist in the AS_PATH attribute of routes from a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP allows a local AS number to exist in the AS_PATH attribute of routes from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP allows a local AS number to exist in the AS_PATH attribute of routes from all dynamic peers in the subnet.
number: Specifies the number of times for which the local AS number can appear, in the range of 1 to 10. The default number is 1. If the number of times for which the local AS number appears in a route is more than the specified number, BGP considers that a routing loop occurs and discards the route.
By default, BGP does not receive routes that contain the local AS number in the AS_PATH attribute to avoid routing loops. However, in some network environments, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
# In BGP IPv4 unicast address family view, set the number of times the local AS number can appear in AS_PATH attribute of routes from peer group test to 2.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test allow-as-loop 2
peer as-number (for a BGP peer group)
Use peer as-number to specify an AS number for a peer group.
Use undo peer as-number to delete the AS number of a peer group.
undo peer group-name as-number
No AS number is specified for a peer group.
group-name: Specifies a name for a peer group, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
as-number: Specifies an AS number for a peer group, in the range of 1 to 4294967295.
This command applies only to a peer group with no peers in it.
When you specify an AS number for a peer group and want to add peers to it, make sure the AS number of the peers is the same as the peer group.
If you do not specify an AS number for a peer group, peers added to it can use their own AS numbers.
# In BGP instance view, set the AS number for peer group test to 100.
[Sysname] bgp 100
[Sysname-bgp-default] peer test as-number 100
peer as-number (for a BGP peer)
Use peer as-number to create a BGP peer and specify its AS number.
Use undo peer to delete a BGP peer.
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } as-number as-number
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number }
No BGP peers exist.
ipv4-address: Specifies the IPv4 address of a peer.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to establish dynamic peer relationships with all devices in the subnet.
ipv6-address: Specifies the IPv6 address of a peer.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to establish dynamic peer relationships with all devices in the subnet.
as-number: Specifies an AS number for the peer, in the range of 1 to 4294967295. If the AS numbers of the peer and the local router are the same, the peer is an IBGP peer. If they are different, the peer is an EBGP peer.
You can also create a peer and add it to a peer group by using the peer group command.
To modify the AS number of a peer, do not execute the peer as-number command repeatedly. Instead, you must first delete the peer and configure it again.
After you create a peer, you must use the peer enable command to enable BGP to exchange routing information with the specified peer.
For a remote device to establish a peer relationship with the local device, you must specify the IP address of the local device on the remote device.
# In BGP instance view, create BGP peer 1.1.1.1 and set its AS number to 100.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 100
display bgp peer
peer enable
peer group
peer as-path-acl
Use peer as-path-acl to specify an AS path list to filter routes incoming from or outgoing to a peer or peer group.
Use undo peer as-path-acl to delete the AS path list specified to filter routes incoming from or outgoing to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } as-path-acl [ as-path-acl-number | as-path-acl-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl [ as-path-acl-number | as-path-acl-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } as-path-acl [ as-path-acl-number | as-path-acl-name ] { export | import }
peer { group-name | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } as-path-acl [ as-path-acl-number | as-path-acl-name ] { export | import }
No AS path list is specified for filtering.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies an AS path list to filter routes incoming from or outgoing to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies an AS path list to filter routes incoming from or outgoing to all dynamic peers in the subnet.
as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256.
as-path-acl-name: Specifies an AS path list by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
export: Filters outgoing routes.
import: Filters incoming routes.
The specified AS path list must have been created with the ip as-path command in system view. If you specify a nonexistent AS path list, all routes can pass the AS path list.
# In BGP IPv4 unicast address family view, specify AS path list 1 to filter routes outgoing to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test as-path-acl 1 export
ip as-path
peer filter-policy
peer prefix-list
peer route-policy
peer bfd
Use peer bfd to enable BFD for the link to a BGP peer or peer group.
Use undo peer bfd to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd [ echo | multi-hop | single-hop ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd
peer link-local-address interface interface-type interface-number bfd [ multi-hop | single-hop ]
undo peer link-local-address interface interface-type interface-number bfd
BFD is disabled for the link to a BGP peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BFD for links to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BFD for links to all dynamic peers in the subnet.
echo: Specifies the echo packet mode for BFD.
multi-hop: Specifies the control packet mode for multi-hop BFD.
single-hop: Specifies the control packet mode for single-hop BFD.
When you do not specify the multi-hop, single-hop, or echo keyword:
· If an IBGP peer or peer group is specified, this command enables multi-hop BFD in control packet mode for the IBGP peer or peer group.
· If a directly connected EBGP peer or peer group is specified and the peer ebgp-max-hop command is not configured, this command enables single-hop BFD in control packet mode for the EBGP peer or peer group. If the EBGP peer or peer group is not directly connected or the peer ebgp-max-hop command is configured, this command enables multi-hop BFD in control packet mode for the EBGP peer or peer group.
Follow these restrictions and guidelines when you configure echo packet mode BFD:
· Echo packet mode BFD is applicable only to directly connected BGP peers.
· Echo packet mode BFD is not applicable to BGP peers established by using a link-local address or loopback interface.
· For successful BFD session establishment, make sure a source address has been specified for echo packets by using the bfd echo-source-ip or bfd echo-source-ipv6 command.
To establish a control packet mode BFD session to a BGP peer, you must configure the same BFD detection mode (multi-hop or single-hop) on the local router and the BGP peer.
For more information about BFD, see BFD configuration in High Availability Configuration Guide.
BFD helps speed up BGP routing convergence upon link failures. However, if you have enabled GR, use BFD with caution. BFD might detect a failure before the system performs GR, resulting in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
# In BGP instance view, enable control packet mode single-hop BFD for the link to BGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test bfd single-hop
bfd echo-source-ip (High Availability Command Reference)
bfd echo-source-ipv6 (High Availability Command Reference)
display bgp peer
display bfd session (High Availability Command Reference)
peer bmp server
Use peer bmp server to specify a peer or peer group to be monitored by the specified BMP servers.
Use undo peer bmp server to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } bmp server server-number-list
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length | link-local-address interface interface-type interface-number] } bmp server
No peer or peer group is specified.
BGP instance view
server-number-list: Specifies a list of up to 8 BMP servers. The value range for the BMP server number is 1 to 8. The BMP servers must have been created.
If you execute this command multiple times for a peer or peer group, the most recent configuration takes effect.
# In BGP instance view, configure BMP server 1 to monitor peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 bmp server 1
bmp server
peer capability-advertise conventional
Use peer capability-advertise conventional to disable the BGP multi-protocol extension, route refresh, and 4-byte AS number features for a peer or peer group.
Use undo peer capability-advertise conventional to enable the BGP multi-protocol extension, route refresh, and 4-byte AS number features for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
The BGP multi-protocol extension, route refresh, and 4-byte AS number features are enabled.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command disables BGP multi-protocol extension and route refresh for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command disables BGP multi-protocol extension and route refresh for all dynamic peers in the subnet.
The route refresh feature enables BGP to send and receive Route-refresh messages and implement BGP session soft-reset.
The multi-protocol extension feature enables BGP to advertise and receive routing information for various protocols (for example, IPv6 routing information).
The 4-byte AS number feature enables BGP to use 4-byte AS numbers in the range of 1 to 4294967295.
If both the peer capability-advertise conventional and peer capability-advertise route-refresh commands are executed, the most recent configuration takes effect.
# In BGP instance view, disable the multi-protocol extension, route refresh, and 4-byte AS number features for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise conventional
display bgp peer
peer capability-advertise orf non-standard
Use peer capability-advertise orf non-standard to enable nonstandard ORF capabilities negotiation for a peer or peer group.
Use undo peer capability-advertise orf non-standard to disable nonstandard ORF capabilities negotiation for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
Nonstandard ORF capabilities negotiation is disabled for a peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to negotiate nonstandard ORF capabilities with all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to negotiate nonstandard ORF capabilities with all dynamic peers in the subnet.
To enable BGP peers to negotiate nonstandard ORF capabilities, you must configure this command together with the peer capability-advertise orf prefix-list command.
# Enable nonstandard ORF capabilities negotiation for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise orf non-standard
Use peer capability-advertise orf prefix-list to enable BGP ORF capabilities negotiation for a peer or peer group.
Use undo peer capability-advertise orf prefix-list to disable BGP ORF capabilities negotiation for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise orf prefix-list { both | receive | send }
undo peer { group-name | ipv4-address [ mask-length ] } capability-advertise orf prefix-list { both | receive | send }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } capability-advertise orf prefix-list { both | receive | send }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } capability-advertise orf prefix-list { both | receive | send }
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
undo peer { group-name | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
BGP ORF capabilities are disabled.
both: Enables BGP to send and receive route fresh messages that carry the ORF information.
receive: Enables BGP to receive route fresh messages that carry the ORF information.
send: Enables BGP to send route fresh messages that carry the ORF information.
After you configure this command, the BGP peers negotiate the ORF capabilities through Open messages. After completing the negotiation process, the BGP peers can exchange ORF information through route refresh messages. To enable the peers to exchange nonstandard ORF information, you must also configure the peer capability-advertise orf non-standard command.
# Enables BGP ORF capabilities negotiation for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4
[Sysname-bgp-default-ipv4] peer 1.1.1.1 capability-advertise orf prefix-list both
Use peer capability-advertise route-refresh to enable BGP route refresh for a peer or peer group.
Use undo peer capability-advertise route-refresh to disable BGP route refresh for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
BGP route refresh is enabled.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP route refresh for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP route refresh for all dynamic peers in the subnet.
The route refresh feature enables BGP to send and receive Route-refresh messages.
BGP uses the route refresh feature to implement BGP session soft-reset. After a policy is modified, the router advertises a Route-refresh message to the peers. The peers resend their routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy. This method allows you to refresh the BGP routing table and apply the new route selection policy without tearing down BGP sessions.
BGP route refresh requires that both the local router and the peer support route refresh.
If both the peer capability-advertise route-refresh and peer capability-advertise conventional commands are executed, the most recent configuration takes effect.
# In BGP instance view, enable BGP route refresh for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise route-refresh
display bgp peer
peer keep-all-routes
refresh bgp
peer capability-advertise suppress-4-byte-as
Use peer capability-advertise suppress-4-byte-as to enable 4-byte AS number suppression.
Use undo peer capability-advertise suppress-4-byte-as to disable 4-byte AS number suppression.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
The 4-byte AS number suppression feature is disabled.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables 4-byte AS number suppression for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables 4-byte AS number suppression for all dynamic peers in the subnet.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an Open message to the peer device for session establishment. The Open message indicates that the device supports 4-byte AS numbers. If the peer device supports 2-byte AS numbers instead of 4-byte AS numbers, the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression feature. The device then sends an Open message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers, do not enable the 4-byte AS number suppression feature. If this feature is enabled, the BGP session cannot be established.
# In BGP instance view, enable 4-byte AS number suppression for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise suppress-4-byte-as
display bgp peer
peer connect-interface
Use peer connect-interface to specify a source interface (IPv4 address/IPv6 address) for establishing TCP connections to a peer or peer group.
Use undo peer connect-interface to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } connect-interface interface-type interface-number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } connect-interface
BGP uses the primary IPv4 or IPv6 address of the output interface in the optimal route destined for the BGP peer or peer group as the source address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source interface for establishing TCP connections to all dynamic peers in the network.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source interface for establishing TCP connections to all dynamic peers in the subnet.
The peer connect-interface command and the peer source-address command can both change the source address for establishing TCP connections. If you execute both commands, the most recent configuration takes effect.
The peer source-address and peer connect-interface commands are applicable to the following scenarios:
· The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡ Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡ Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
· A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
· On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this problem, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
· You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this problem, use one of the following methods:
¡ If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡ If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
The source interfaces on the local router and the peer must be reachable to each other.
To specify an indirectly connected interface on an EBGP peer as the source interface, use the peer ebgp-max-hop command. The command allows the establishment of an EBGP session to the indirectly connected peer.
If an interface has multiple IPv4 addresses, BGP uses the primary IPv4 address to establish TCP connections. If an interface has multiple IPv6 addresses, BGP selects a source IPv6 address. To use an IPv6 address as the source address, specify that IPv6 address by using the peer source-address command.
You cannot specify a virtual template (VT) interface as the source interface for establishing TCP connections because a VT interface cannot process services.
If you execute this command for a peer group, the configuration does not take effect on peers established through link-local addresses.
# In BGP instance view, specify loopback 0 as the source interface for TCP connections to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test connect-interface loopback 0
peer ebgp-max-hop
peer source-address
peer default-route-advertise
Use peer default-route-advertise to advertise a default route to a peer or peer group.
Use undo peer default-route-advertise to disable default route advertisement to a peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } default-route-advertise
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } default-route-advertise
peer { group-name | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ipv6-address [ prefix-length ] } default-route-advertise
In BGP IPv4 RT filter address family view:
In BGP EVPN address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise { ipv4 | ipv6 } vpn-instance vpn-instance-name
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise { ipv4 | ipv6 } vpn-instance vpn-instance-name
No default route is advertised to any peers or peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises a default route to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises a default route to all dynamic peers in the subnet.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to modify the route attribute.
ipv4: Specifies the IPv4 default route. This keyword is available in Release 6526 and later.
ipv6: Specifies the IPv6 default route. This keyword is available in Release 6526 and later.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
This command is supported in BGP EVPN address family view in Release 6526 and later.
This command enables the router to send a default route with the next hop being itself to the peer or peer group regardless of whether the default route exists in the routing table.
# In BGP IPv4 unicast address family view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] peer test default-route-advertise
peer description
Use peer description to configure a description for a peer or peer group.
Use undo peer description to remove the description for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } description text
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } description
No description information is configured for a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures a description for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures a description for all dynamic peers in the subnet.
text: Specifies a description for a peer or peer group, a case-sensitive string of 1 to 79 characters.
# In BGP instance view, set the description for peer group test to ISP1.
[Sysname] bgp 100
[Sysname-bgp-default] peer test description ISP1
peer dscp
Use peer dscp to set a DSCP value for outgoing BGP packets.
Use undo peer dscp to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } dscp dscp-value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } dscp
The DSCP value for outgoing BGP packets is 48.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a DSCP value for outgoing BGP packets to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a DSCP value for outgoing BGP packets to all dynamic peers in the subnet.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet. A larger DSCP value represents a higher priority.
# In BGP instance view, set the DSCP value to 10 for outgoing BGP packets to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test dscp 10
peer ebgp-max-hop
Use peer ebgp-max-hop to enable BGP to establish an EBGP session to an indirectly connected peer or peer group and specify the maximum hop count.
Use undo peer ebgp-max-hop to disable BGP from establishing an EBGP session to an indirectly connected peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-max-hop
BGP does not establish an EBGP session to an indirectly connected peer or peer group.
BGP-VPN instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP establishes EBGP sessions to all indirectly connected dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP establishes EBGP sessions to all indirectly connected dynamic peers in the subnet.
hop-count: Specifies the maximum number of hop counts, in the range of 1 to 255. The default is 64.
To become EBGP peers, two routers must be directly connected and use directly connected interfaces to establish an EBGP session. If they are not directly connected, use the peer ebgp-max-hop command to establish an EBGP session over multiple hops between two peers.
This command takes effect only on routes received after you execute this command. To apply this command to existing routes, use the refresh bgp command to soft-reset BGP sessions.
When the BGP GTSM feature is enabled, two peers can establish an EBGP session after passing GTSM check, regardless of whether the maximum number of hops is reached.
# In BGP instance view, enable BGP to establish EBGP sessions to indirectly connected EBGP peer group test, and set the maximum hop count to 64 (default).
[Sysname] bgp 100
[Sysname-bgp-default] peer test ebgp-max-hop
peer ttl-security
peer enable
Use peer enable to enable BGP to exchange routing information for an address family with a peer or peer group.
Use undo peer enable to disable BGP from exchanging routing information for an address family with a peer or peer group.
In BGP IPv4 multicast address family view/BGP IPv4 RT filter address family view:
undo peer { group-name | ipv4-address [ mask-length ] } enable
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } enable
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } enable
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } enable
In BGP LS address family view/BGP dedicated address family view:
peer { group-name | ipv6-address [ prefix-length ] } enable
undo peer { group-name | ipv6-address [ prefix-length ] } enable
BGP cannot exchange routing information with a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP exchanges routing information for an address family with all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP exchanges routing information for an address family with all dynamic peers in the subnet.
Executing the peer enable command in different views enables BGP to exchange routing information for the corresponding address families with the specified peer.
· In BGP IPv4 unicast address family view, the command enables the capability to exchange IPv4 unicast routing information. It also adds the learned routes to the BGP routing table of the public network.
· In BGP-VPN IPv4 unicast address family view, the command enables the capability to exchange IPv4 unicast routing information. It also adds the learned routes to the BGP routing table of the specified VPN instance.
· In BGP IPv6 unicast address family view, the command enables the capability to exchange IPv6 unicast routing information. It also adds the learned routes to the IPv6 BGP routing table of the public network.
· In BGP-VPN IPv6 unicast address family view, the command enables the capability to exchange IPv6 unicast routing information. It also adds the learned routes to the IPv6 BGP routing table of the specified VPN instance.
· In BGP IPv4 multicast address family view, the command enables the capability to exchange IPv4 unicast routes used for RPF check. For information about RPF check, see IP Multicast Configuration Guide.
· In BGP IPv6 multicast address family view, the command enables the capability to exchange IPv6 unicast routes used for RPF check. For information about RPF check, see IP Multicast Configuration Guide.
· In BGP IPv4 RT filter address family view, the command enables the capability to exchange IPv4 RT filter routing information.
· In BGP dedicated address family view, the command enables the capability to exchange dedicated routing information. BGP peers use dedicated routes to exchange IPv4SG or IPv6SG bindings. For more information about IPSG and IPSG bindings, see IP source guard configuration in Security Configuration Guide.
The undo peer enable command disables BGP to exchange routing information for the corresponding address family with the peer.
Executing the peer enable command for a peer group might cause session re-establishment to some peers in the peer group. Make sure you fully understand this impact on the network before executing the command.
# In BGP IPv4 unicast address family view, enable BGP to exchange IPv4 unicast routing information with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 enable
display bgp peer
peer fake-as
Use peer fake-as to advertise a fake AS number to a peer or peer group.
Use undo peer fake-as to remove the fake AS number advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } fake-as as-number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } fake-as
No fake local AS number is advertised to a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises a fake AS number to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command advertises a fake AS number to all dynamic peers in the subnet.
as-number: Specifies a fake AS number in the range of 1 to 4294967295.
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
The peer fake-as command is applicable only to EBGP peers or peer groups.
If you execute the peer fake-as command on the local router, specify the local router's AS number on the peer as the fake local AS number specified in the command.
# In BGP instance view, advertise a fake AS number of 200 to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test fake-as 200
peer filter-policy
Use peer filter-policy to filter routes advertised to or received from a peer or peer group by using an ACL.
Use undo peer filter-policy to remove the ACL specified to filter routes advertised to or received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy [ ipv4-acl-number | name ipv4-acl-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } filter-policy [ ipv4-acl-number | name ipv4-acl-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } filter-policy { ipv6-acl-number | name ipv6-acl-name } { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } filter-policy [ ipv6-acl-number | name ipv6-acl-name ] { export | import }
peer { group-name | ipv6-address [ prefix-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } filter-policy [ ipv6-acl-number | name ipv6-acl-name ] { export | import }
No ACL-based filtering is configured.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command filters routes advertised to or received from all dynamic peers in the subnet by using an ACL.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command filters routes advertised to or received from all dynamic peers in the subnet by using an ACL.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
export: Filters routes advertised to the peer/peer group.
import: Filters routes received from the peer/peer group.
The specified ACL used by the peer filter-policy command must have been created with the acl command in system view. Otherwise, all routes can pass the ACL.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches routes whose destination network addresses match the source-address source-wildcard argument without matching the masks of the destination addresses.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following steps:
· To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
· To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address. For the mask configuration to take effect, specify a contiguous subnet mask.
# In BGP IPv4 unicast address family view, apply ACL 2000 to filter routes advertised to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test filter-policy 2000 export
acl (ACL and QoS Command Reference)
filter-policy export
filter-policy import
peer as-path-acl
peer prefix-list
peer route-policy
peer graceful-restart timer restart extra
Use peer graceful-restart timer restart extra to set the extra time to wait after the restart timer expires.
Use undo peer graceful-restart timer restart extra to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } graceful-restart timer restart extra { time | no-limit }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } graceful-restart timer restart extra
The extra time to wait after the restart timer expires is 0 seconds.
BGP instance view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
time: Specifies the extra time to wait after the restart timer expires, in the range of 0 to 86400 seconds.
no-limit: Sets an unlimited time to wait for BGP session re-establishment.
After the active/standby switchover or BGP restart completes, the GR helper marks the routes it learned from the GR restarter as stale routes. If the GR helper fails to establish a BGP session after both the GR timer and the extra timer to wait expire, the GR helper removes the stale routes.
# Set the extra time to wait after the restart timer expires to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.100.2 graceful-restart timer restart extra 100
peer group
Use peer group to add a peer to a peer group.
Use undo peer group to delete a peer from a peer group.
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } group group-name [ as-number as-number ]
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } group group-name
No peers exist in a peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command adds all dynamic peers in the subnet to a peer group.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command adds all dynamic peers in the subnet to a peer group.
link-local-address: Specifies a peer by its link-local address.
as-number as-number: Specifies an AS for a peer by its number in the range of 1 to 4294967295.
You can add a peer to a peer group in the following ways:
· Use the peer as-number command to create a peer and specify its AS number, and then use the peer group command to add the peer to the peer group.
¡ You can specify the as-number keyword for the peer group command. The AS number must be the same as the AS number specified in the peer as-number command.
¡ If you have specified the AS number of the peer group with the peer as-number command, the peer to be added must have the same AS number as the peer group.
¡ To add a peer to an IBGP peer group, the peer must be an IBGP peer.
· Use the peer group command to create a peer and add it to the peer group.
¡ If you have specified the AS number of the peer group with the peer as-number command, you do not need to specify the as-number keyword when you execute the peer group command. This is because the AS number of the peer is the same as the peer group. To specify the as-number keyword for the peer group command, make sure the AS number is the same as the peer group.
¡ If no AS number is specified for an EBGP peer group, specify the as-number keyword when you execute the peer group command.
¡ If no AS number is specified for an IBGP peer group, you do not need to specify the as-number keyword when you execute the peer group command. This is because the AS number of the IBGP peer group is the local AS number. To specify the as-number keyword for the peer group command, make sure the AS number is the same as the local AS number.
If you have specified the AS number of a peer group with the peer as-number command, only the peers with the same AS number can be added to the peer group. All peers in the group share the same AS number. If you have not specified the AS number for a peer group, peers added to it can use their own AS numbers.
After you add a peer to a peer group, you must use the peer enable command to enable BGP to exchange routing information with the peer group.
# In BGP instance view, add peer 10.1.1.1 to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] group test external
[Sysname-bgp-default] peer 10.1.1.1 group test as-number 2004
group
peer as-number
peer enable
peer ignore
Use peer ignore to disable BGP session establishment with a peer or peer group.
Use undo peer ignore to enable BGP session establishment with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore
BGP can establish a session to a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP tears down sessions to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP tears down sessions to all dynamic peers in the subnet.
graceful graceful-time: Gracefully shuts down the session to a peer or peer group in the specified graceful shutdown period of time. The value range for the graceful-time argument is 60 to 65535 seconds. If you do not specify this option, the command immediately shuts down the session to the peer or peer group.
community { community-number | aa:nn }: Specifies the community attribute for advertised routes. The community-number argument represents the community sequence number in the range of 1 to 4294967295. The aa:nn argument represents the community number. Both aa and nn are in the range of 0 to 65535. If you do not specify this option, the command does not change the community attribute for advertised routes.
local-preference preference: Specifies the local preference for advertised routes, in the range of 0 to 4294967295. A larger value represents a higher preference. If you do not specify this option, the command does not change the local preference for advertised routes.
med med: Specifies the MED value for advertised routes, in the range of 0 to 4294967295. The smaller the MED value, the higher the route priority. If you do not specify this option, the command does not change the MED value for advertised routes.
CAUTION: · If a session has been established to a peer, executing the peer ignore command for the peer tears down the session and clears all related routing information. · If sessions have been established to a peer group, executing the peer ignore command for the peer group disables the sessions to all peers in the group and clears all related routing information. |
This command enables you to temporarily tear down the BGP session to a peer or peer group. You can perform network upgrade and maintenance without needing to delete and reconfigure the peer or peer group. To recover the session, execute the undo peer ignore command.
If you specify the graceful keyword in the peer ignore command, BGP performs the following tasks:
· Gracefully shuts down the session to the specified peer or peer group in the specified graceful shutdown period of time.
· Advertises all routes to the specified peer or peer group and changes the attribute for the advertised routes to the specified value.
· Advertises routes from the specified peer or peer group to other IBGP peers and peer groups and changes the attribute for the advertised routes to the specified value.
For a BGP peer or peer group, the configuration made by the peer ignore command takes precedence over the configuration made by the ignore all-peers command.
# In BGP instance view, disable session establishment with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 ignore
# In BGP instance view, configure BGP to gracefully shut down the session to peer 1.1.1.1 in 60 seconds, advertise all routes to peer 1.1.1.1, and change the community attribute and local preference for the advertised routes to 1:1 and 200, respectively.
[Sysname] bgp 1
[Sysname-bgp-default] peer 1.1.1.1 ignore graceful 60 community 1:1 local-preference 200
ignore all-peers
peer ignore-first-as
Use peer ignore-first-as to enable BGP to ignore the first AS number of EBGP route updates received from a peer or peer group.
Use undo peer ignore-first-as to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore-first-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore-first-as
BGP checks the first AS number of a received EBGP route update. If the first AS number is neither that of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the first AS number of EBGP route updates received from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the first AS number of EBGP route updates received from all dynamic peers in the subnet.
This command takes effect only on the EBGP routes received after you execute this command. After you execute the undo peer ignore-first-as command, BGP advertises a ROUTE-REFRESH message to request the routing information from the EBGP peer or peer group.
# In BGP instance view, enable BGP to ignore the first AS number of EBGP route updates received from peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test ignore-first-as
ignore-first-as
peer ignore-originatorid
Use peer ignore-originatorid to configure BGP to ignore the ORIGINATOR_ID attribute in BGP route updates.
Use undo peer ignore-originatorid to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore-originatorid
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore-originatorid
BGP does not ignore the ORIGINATOR_ID attribute in BGP route updates.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the ORIGINATOR_ID attribute in BGP route updates from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP ignores the ORIGINATOR_ID attribute in BGP route updates from all dynamic peers in the subnet.
Before using this command, make sure it does not cause any routing loops to the network.
Before forwarding a route received from a client, the route reflector adds an ORIGINATOR_ID attribute (the router ID of the client) to the route. By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID.
Some networks such as firewall networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
# In BGP instance view, configure BGP to ignore the ORIGINATOR_ID attribute in BGP route updates from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 ignore-originatorid
peer ipsec-profile
Use peer ipsec-profile to apply an IPsec profile to an IPv6 BGP peer or peer group.
Use undo peer ipsec-profile to remove the profile from an IPv6 BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ipsec-profile profile-name
undo peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ipsec-profile
No IPsec profile is configured for any IPv6 BGP peers or peer groups.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command applies an IPsec profile to all dynamic peers in the subnet.
profile-name: Specifies an IPsec profile by its name, a case-sensitive string of 1 to 63 characters.
IPsec can protect IPv6 BGP packets from data eavesdropping, tampering, and attacks caused by forged IPv6 BGP packets.
When two IPv6 BGP neighbor devices, for example Device A and Device B, are configured with IPsec, Device A encapsulates an IPv6 BGP packet with IPsec before sending it to Device B. If Device B successfully receives and decapsulates the packet, it establishes an IPv6 BGP peer relationship with Device A or learns IPv6 BGP routes to Device A. If Device B receives but fails to decapsulate the packet, or receives a packet not protected by IPsec, it discards the packet.
Configure IPsec to protect IPv6 BGP packets through the following steps:
1. Configure an IPsec transform set.
2. Configure a manual IPsec profile.
3. Execute this command to apply the IPsec profile to an IPv6 BGP peer or peer group.
For more information about IPsec transform sets and IPsec profiles, see Security Configuration Guide.
This command supports only IPsec profiles in manual mode.
If you configure IPsec on a device, you must configure IPsec on its IPv6 BGP peer. Otherwise, IPv6 BGP packets cannot be received.
# In BGP instance view, apply IPsec profile profile001 to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test ipsec-profile profile001
display bgp group
display bgp peer
Use peer keep-all-routes to save all route updates from a peer or peer group, regardless of whether the routes have passed the configured routing policy.
Use undo peer keep-all-routes to remove the configuration.
In BGP IPv4 multicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] } keep-all-routes
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keep-all-routes
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keep-all-routes
In BGP IPv6 multicast address family view:
peer { group-name | ipv6-address [ prefix-length ] } keep-all-routes
undo peer { group-name | ipv6-address [ prefix-length ] } keep-all-routes
Route updates from a peer or peer group are not saved.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command saves all route updates from all dynamic peers in the subnet, regardless of whether the routes have passed the configured routing policy.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command saves all route updates from all dynamic peers in the subnet, regardless of whether the routes have passed the configured routing policy.
To implement BGP session soft-reset when the local router and a peer or peer group do not support the route refresh feature, use the peer keep-all-routes command. The command saves all route updates received from the peer or peer group. After modifying the route selection policy, filter all saved routes with the new policy to refresh the routing table. This method avoids tearing down BGP sessions.
# In BGP IPv4 unicast address family view, save all route updates from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 keep-all-routes
peer keychain
Use peer keychain to enable keychain authentication for a BGP peer or peer group.
Use undo peer keychain to remove keychain authentication for a BGP peer or peer group.
peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keychain keychain-name
undo peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keychain
Keychain authentication is disabled.
ip-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables keychain authentication for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables keychain authentication for all dynamic peers in the subnet.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters. The keychain must have been created.
Keychain authentication enhances the security of TCP connection establishment between BGP peers. It allows BGP peers to establish TCP connections only when the following conditions are met:
· Keychain authentication is enabled on both BGP peers.
· The keys used by the BGP peers at the same time must have the same ID.
· The keys with the same ID must use the same authentication algorithm and key string.
BGP supports the HMAC-MD5 and MD5 authentication algorithms. To specify an authentication algorithm for a key, use the authentication-algorithm command.
The ID of keys used for authentication can only be in the range of 0 to 63. To create a key, use the key command.
The peer keychain and peer password commands are mutually exclusive.
# In BGP instance view, configure peer 10.1.1.1 to use keychain abc for authentication.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.1 as-number 100
[Sysname-bgp-default] peer 10.1.1.1 keychain abc
authentication-algorithm (Security Command Reference)
key (Security Command Reference)
peer log-change
Use peer log-change to enable logging for BGP session state changes for a peer or peer group.
Use undo peer log-change to disable logging for BGP session state changes for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } log-change
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } log-change
Logging for BGP session state changes is enabled for all peers or peer groups.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must already exist.
ipv4-address: Specifies the IPv4 address of a peer. The peer must already exist.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables the logging of BGP session state changes for all dynamic peers in the subnet.
ipv6-address: Specifies the IPv6 address of a peer. The peer must already exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables the logging of BGP session state changes for all dynamic peers in the subnet.
After you execute both the log-peer-change and peer log-change commands, BGP logs session establishment and disconnection events for the peer or peer group. To view the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center of the device. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
If you disable logging for BGP session state changes globally or disable logging for a peer or peer group, BGP does not generate logs for session establishments and disconnections.
# In BGP instance view, enable logging for BGP session state changes for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default] peer 1.1.1.1 log-change
display bgp peer
log-peer-change
peer low-memory-exempt
Use peer low-memory-exempt to configure BGP to protect EBGP peers or peer groups when the memory usage reaches level 2 threshold.
Use undo peer low-memory-exempt to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } low-memory-exempt
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } low-memory-exempt
When the memory usage reaches level 2 threshold, BGP tears down an EBGP session to release memory resources periodically.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP protects all dynamic peers in the subnet when the memory usage reaches level 2 threshold.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP protects all dynamic peers in the subnet when the memory usage reaches level 2 threshold.
When level 2 memory usage threshold is reached, BGP tears down an EBGP session to release memory resources periodically until the memory usage is exempt from level 2 threshold. You can use this command to avoid tearing down the BGP session to an EBGP peer when memory usage reaches level 2 threshold. For more information about thresholds, see Fundamentals Configuration Guide.
# In BGP instance view, configure BGP to protect EBGP peer 1.1.1.1 when the memory usage reaches level 2 threshold.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 low-memory-exempt
peer next-hop-local
Use peer next-hop-local to set the local router as the next hop for routes sent to a peer or peer group.
Use undo peer next-hop-local to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-local
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-local
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } next-hop-local
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } next-hop-local
peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
undo peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
In BGP EVPN address family view/BGP dedicated address family view:
BGP sets the local router as the next hop for all routes sent to an EBGP peer or peer group.
It does not set the local router as the next hop for EBGP routes sent to an IBGP peer or peer group for other address families.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command sets the local router as the next hop for routes sent to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command sets the local router as the next hop for routes sent to all dynamic peers in the subnet.
By default, BGP does not set the local router as the next hop for EBGP routes sent to an IBGP peer or peer group. To ensure that an IBGP peer can find the next hop, you can use this command to specify the router as the next hop for routes sent to the IBGP peer.
The peer next-hop-local command is mutually exclusive with the peer next-hop-invariable command. Follow these restrictions and guidelines when you configure the commands for a peer or peer group:
· After you configure the peer next-hop-local command for a peer group, you cannot configure the peer next-hop-invariable command for the peer group or any peers in the peer group.
· After you configure the peer next-hop-local command for a peer, do not configure the peer next-hop-invariable command for the peer group to which the peer belongs. The configuration on the peer group will overwrite the configuration on the peer.
# In BGP IPv4 unicast address family view, specify the router as the next hop for routes sent to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test next-hop-local
peer nexthop-recursive-policy disable
Use peer nexthop-recursive-policy disable to disable route recursion policy control for routes received from the specified peer or peer group.
Use undo peer nexthop-recursive-policy disable to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } nexthop-recursive-policy disable
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } nexthop-recursive-policy disable
The route recursion policy applies to routes received from the specified peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
If you configure routing policy-based recursive lookup for BGP routes, this route recursion policy applies to BGP routes learned from all peers. This command allows you to disable route recursion policy control for routes learned from certain peers, for example, direct EBGP peers.
# In BGP instance view, disable route recursion policy control for routes received from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 nexthop-recursive-policy disable
protocol nexthop recursive-lookup
peer password
Use peer password to enable MD5 authentication for a BGP peer or peer group.
Use undo peer password to remove MD5 authentication for a BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } password { cipher | simple } password
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } password
MD5 authentication is disabled.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables MD5 authentication for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables MD5 authentication for all dynamic peers in the subnet.
password: Specifies the password. Its encrypted form is a case-sensitive string of 33 to 137 characters. Its plaintext form is a case-sensitive string of 1 to 80 characters.
You can enable MD5 authentication to enhance security using the following methods:
· Perform MD5 authentication when establishing TCP connections. Only the two parties that have the same password configured can establish TCP connections.
· Perform MD5 calculation on TCP segments to avoid modification to the encapsulated BGP packets.
The peer password and peer keychain commands are mutually exclusive.
# In BGP instance view, perform MD5 authentication on the TCP connection between local router 10.1.100.1 and peer router 10.1.100.2. Set the authentication password to aabbcc in plaintext form.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.100.2 password simple aabbcc
peer preferred-value
Use peer preferred-value to set a preferred value for routes received from a peer or peer group.
Use undo peer preferred-value to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] } preferred-value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } preferred-value
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } preferred-value value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } preferred-value
peer { group-name | ipv6-address [ prefix-length ] } preferred-value value
undo peer { group-name | ipv6-address [ prefix-length ] } preferred-value
The preferred value is 0 for routes received from a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a preferred value for routes received from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a preferred value for routes received from all dynamic peers in the subnet.
value: Specifies a preferred value in the range of 0 to 65535.
If multiple routes that have the same destination are learned from different peers, you can specify different preferred values for the routes as needed to control BGP path selection. The one with the greatest preferred value is selected as the optimal route to the destination.
The preferred value is used for route selection on the local router and is not advertised to the peer. It has only local significance.
You can also use the apply preferred-value command in a routing policy to configure the preferred value for BGP routes. If both the peer preferred-value and apply preferred-value commands are configured, the apply preferred-value command applies. If the preferred value is not set in the routing policy or no routing policy is configured, the peer preferred-value command applies.
# In BGP IPv4 unicast address family view, set the preferred value to 50 for routes from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 preferred-value 50
route-policy
peer prefix-list
Use peer prefix-list to specify a prefix list to filter routes received from or advertised to a peer or peer group.
Use undo peer prefix-list to remove the prefix list specified to filter routes received from or advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length } prefix-list ipv4-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length } prefix-list [ ipv4-prefix-list-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] } prefix-list ipv4-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } prefix-list [ ipv4-prefix-list-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } prefix-list ipv6-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } prefix-list [ ipv6-prefix-list-name ] { export | import }
peer { group-name | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } prefix-list [ ipv6-prefix-list-name ] { export | import }
No prefix list based filtering is configured.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command uses a prefix list to filter routes received from or advertised to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command uses a prefix list to filter routes received from or advertised to all dynamic peers in the subnet.
ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the filter to routes advertised to the specified peer/peer group.
import: Applies the filter to routes received from the specified peer/peer group.
The specified prefix list must have been created with the ip prefix-list or ipv6 prefix-list command in system view. If you specify a nonexistent IPv4/IPv6 prefix list, all routes can pass the prefix list.
# In BGP IPv4 unicast address family view, use IPv4 prefix list list1 to filter routes advertised to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test prefix-list list1 export
ip prefix-list
ipv6 prefix-list
peer as-path-acl
peer filter-policy
peer route-policy
peer public-as-only
Use peer public-as-only to remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
Use undo peer public-as-only to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] } public-as-only
undo peer { group-name | ipv4-address [ mask-length ] } public-as-only
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } public-as-only
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } public-as-only
In BGP-VPN IPv6 unicast address family view/BGP IPv6 multicast address family view:
peer { group-name | ipv6-address [ prefix-length ] } public-as-only
undo peer { group-name | ipv6-address [ prefix-length ] } public-as-only
BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command removes private AS numbers in BGP updates sent to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command removes private AS numbers in BGP updates sent to all dynamic peers in the subnet.
Private AS numbers are typically used in test networks, and need not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
After you execute the command, you can get the following results:
· If the AS_PATH attribute of a BGP update carries only private AS numbers, the device removes the AS numbers before sending the update to the EBGP peer or peer group.
· If the AS_PATH attribute carries both public and private AS numbers, the command does not take effect. The device sends the BGP update to the EBGP peer or peer group without removing the private AS numbers.
· If the AS_PATH attribute carries AS numbers of the peer or peer group, the command does not take effect. The device sends the BGP update to the peer or peer group without removing the private AS numbers.
This command is applicable only to EBGP peers and peer groups.
# In BGP IPv4 unicast address family view, remove private AS numbers in BGP updates sent to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test public-as-only
peer reflect-client
Use peer reflect-client to configure the device as a route reflector and specify a peer or peer group as a client.
Use undo peer reflect-client to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] } reflect-client
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP EVPN address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } reflect-client
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } reflect-client
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } reflect-client
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
undo peer { group-name | ipv6-address [ prefix-length ] } reflect-client
Neither the route reflector nor the client is configured.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the device as a route reflector and specifies all dynamic peers in the subnet as clients.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the device as a route reflector and specifies all dynamic peers in the subnet as clients.
Using route reflectors can solve the issue brought by too many IBGP connections. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards the routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
# In BGP IPv4 unicast address family view, configure the local device as a route reflector and specify IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test reflect-client
reflect between-clients
reflect change-path-attribute
reflector cluster-id
peer route-limit
Use peer route-limit to set the maximum number of routes that can be received from a peer or peer group.
Use undo peer route-limit to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] } route-limit
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-limit
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-limit
peer { group-name | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
undo peer { group-name | ipv6-address [ prefix-length ] } route-limit
The number of routes that can be received from a peer or peer group is not limited.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies the maximum number of routes that can be received from all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies the maximum number of routes that can be received from all dynamic peers in the subnet.
prefix-number: Specifies the number of routes that can be received from the peer or peer group.The value range for this argument is 1 to 4294967295. The router will tear down the session to the peer or peer group if the following conditions exist:
· The alert-only, discard, and reconnect keywords are not specified.
· The number of routes received from the peer or peer group reaches the prefix-number.
The router will not attempt to re-establish the session to a dynamic BGP peer until the router receives a connection request from the peer. For other peers, you can use the reset bgp command to re-establish the sessions.
alert-only: If the number of routes received from the peer or peer group reaches the prefix-number, the router generates a log message instead of tearing down the session to the peer or peer group. The router can continue to receive routes from the peer or peer group.
discard: If the number of routes received from the peer or peer group reaches the prefix-number, the router retains the session to the peer or peer group. However, it discards excess routes and generates a log message. After the number of routes received from the peer or peer group falls below the prefix-number, the router can continue to receive routes from the peer or peer group. To restore the discarded routes, use the refresh bgp import command to request the peer or peer group to resend the routes.
reconnect reconnect-time: Specifies a reconnect time. After the specified time is reached, the router re-establishes a session to the peer or peer group when the number of routes received from the peer or peer group reaches the prefix-number. The value range for the reconnect-time argument is 1 to 65535 seconds. This option is not available for dynamic BGP peers.
percentage-value: Specifies the threshold value for the router to generate a log message (the router generates a log message when the ratio of the number of received routes to the prefix-number exceeds the percentage value). The value range of this argument is 1 to 100, and the default is 75.
# In BGP IPv4 unicast address family view, set the maximum number of routes that can be received from peer 1.1.1.1 to 10000. Configure the router to tear down the session to the peer if the number is exceeded.
[Sysname] bgp 109
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] peer 1.1.1.1 route-limit 10000
peer route-policy
Use peer route-policy to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use undo peer route-policy to remove the configuration.
In BGP EVPN address family view/BGP IPv4 multicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] } route-policy [ route-policy-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy [ route-policy-name ] { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-policy route-policy-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-policy [ route-policy-name ] { export | import }
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } route-policy [ route-policy-name ] { export | import }
No routing policy is applied to routes incoming from or outgoing to a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command applies a routing policy to routes incoming from or outgoing to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command applies a routing policy to routes incoming from or outgoing to all dynamic peers in the subnet.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the routing policy to routes outgoing to the peer or peer group.
import: Applies the routing policy to routes incoming from the peer or peer group.
The specified routing policy must have been configured with the route-policy command in system view. If you specify a nonexistent routing policy, all routes can pass the routing policy.
The if-match interface command, if configured for the applied routing policy, does not take effect on routes.
# In BGP IPv4 unicast address family view, apply routing policy test-policy to routes outgoing to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test route-policy test-policy export
peer as-path-acl
peer filter-policy
peer prefix-list
route-policy
peer route-update-interval
Use peer route-update-interval to specify an interval for sending the same update to a peer or peer group.
Use undo peer route-update-interval to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-update-interval interval
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-update-interval
The interval for sending the same update to an IBGP peer is 15 seconds and the interval for sending the same update to an EBGP peer is 30 seconds.
BGP-VPN instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies an interval for sending the same update to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies an interval for sending the same update to all dynamic peers in the subnet.
interval: Specifies a minimum interval for sending the same update message, in the range of 0 to 600 seconds.
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. By configuring the interval for sending the same update to a peer or peer group, you can avoid such routing flaps.
This command takes effect on withdrawn routes only after you apply the route update interval setting to withdrawn routes.
# In BGP instance view, set the interval for sending the same update to peer group test to 10 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] peer test as-number 100
[Sysname-bgp-default] peer test route-update-interval 10
route-update-interval withdrawn enable
peer soo
Use peer soo to configure the Site of Origin (SoO) attribute for a BGP peer or peer group.
Use undo peer soo to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] } soo
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } soo
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } soo site-of-origin
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } soo
peer { group-name | ipv6-address [ prefix-length ] } soo site-of-origin
undo peer { group-name | ipv6-address [ prefix-length ] } soo
No SoO attribute is configured for a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the SoO attribute for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the SoO attribute for all dynamic peers in the subnet.
site-of-origin: Specifies the SoO attribute, a string of 3 to 21 characters. The SoO attribute has the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 100:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
The SoO attribute specifies the site where the route was originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
After you configure the SoO attribute for a BGP peer or peer group, BGP adds the SoO attribute into the route updates received from the BGP peer or peer group. Before advertising route updates to the peer or peer group, BGP checks the SoO attribute of the route update against the configured SoO attribute. If they are the same, BGP does not advertise the route updates to the BGP peer or peer group to avoid loops.
If a PE configured with AS number substitution connects to multiple CEs in the same VPN site through different interfaces, routing loops will occur. To avoid routing loops, configure the same SoO attribute for the CEs on the PE.
# In BGP IPv4 unicast address family view, set the SoO attribute to 100:1 for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 soo 100:1
peer substitute-as
peer source-address
Use peer source-address to specify a source IPv4 or IPv6 address for establishing TCP connections to a peer or peer group.
Use undo peer source-address to remove the configuration.
peer ipv4-address [ mask-length ] source-address source-ipv4-address
peer ipv6-address [ prefix-length ] source-address source-ipv6-address
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } source-address
peer group-name source-address { source-ipv4-address | source-ipv6-address } *
undo peer group-name source-address [ source-ipv4-address | source-ipv6-address ]
BGP uses the primary IPv4 or IPv6 address of the output interface in the optimal route destined for the BGP peer or peer group as the source address for TCP connection establishment.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source IP address for establishing TCP connections to all dynamic peers in the subnet.
source-ipv4-address: Specifies a source IPv4 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a source IPv6 address for establishing TCP connections to all dynamic peers in the subnet.
source-ipv6-address: Specifies a source IPv6 address.
The peer connect-interface command and the peer source-address command can both change the source address for establishing TCP connections. If you execute both commands, the most recent configuration takes effect.
The peer source-address and peer connect-interface commands are applicable to the following scenarios:
· The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡ Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡ Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
· A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
· On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this problem, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
· You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this problem, use one of the following methods:
¡ If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡ If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
The source addresses on the local router and the peer must be reachable to each other.
To specify the address of an indirectly connected interface as the source address, use the peer ebgp-max-hop command. The command allows the establishment of an EBGP session to the indirectly connected peer.
You can specify both a source IPv4 address and a source IPv6 address for a peer group. BGP uses the source IPv4 address to establish TCP connections to IPv4 peers in the group. It also uses the source IPv6 address to establish TCP connections to IPv6 peers in the group.
# In BGP instance view, specify source IPv4 address 1.1.1.1 for peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test source-address 1.1.1.1
peer ebgp-max-hop
peer substitute-as
Use peer substitute-as to replace the AS number of a peer or peer group in the AS_PATH attribute with the local AS number.
Use undo peer substitute-as to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ]| link-local-address interface interface-type interface-number } substitute-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ]| link-local-address interface interface-type interface-number } substitute-as
The AS number of a peer or peer group in the AS_PATH attribute is not replaced.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command replaces the AS number of all dynamic peers in the subnet in the AS_PATH attribute with the local AS number.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command replaces the AS number of all dynamic peers in the subnet in the AS_PATH attribute with the local AS number.
If different CEs use the same AS number, you must configure the relevant PE to replace the AS number of the CE as its own AS number. This ensures correct advertisement of private network routes.
# In BGP instance view, substitute the local AS number for the AS number of peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 substitute-as
peer soo
peer tcp-mss
Use peer tcp-mss to set the TCP maximum segment size (MSS) for TCP connections with a peer or peer group.
Use undo peer tcp-mss to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tcp-mss mss-value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tcp-mss
The TCP MSS is not set.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. If you use the ipv4-address and mask-length arguments together to specify a subnet, this command applies to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. If you use the ipv6-address and prefix-length arguments together to specify a subnet, this command applies to all dynamic peers in the subnet.
mss-value: Specifies the TCP MSS in bytes. The value range for this argument is 176 to 4096.
This feature is available in Release 6526 and later.
BGP typically establishes a multihop TCP connection with a peer. Multiple intermediate devices might fragment BGP packets due to their MTU settings, resulting in frequent packet encapsulations and decapsulations that reduce forwarding efficiency.
To resolve this issue, you can execute this command to set the TCP MSS for TCP connections with a peer or peer group. TCP segments sent by the source will not be re-fragmented along the path to the destination.
This command might cause BGP session re-establishment. Make sure you understand the potential impact before executing this command.
During TCP connection establishment, the minimum of the following MSSs takes effect:
· The MSS calculated according to the IPv4 MTU set by the ip mtu command.
· The interface MSS set by the tcp mss command.
· The MSS calculated according to the path MTU detected by TCP path MTU discovery (enabled with the tcp path-mtu-discovery command).
· The MSS set by the peer tcp-mss command.
The MSS is calculated by using the following formula:
MSS = path MTU (or interface MTU) – IP header length – TCP header length
For more information about MTU and MSS, see IP performance optimization configuration in Layer 3—IP Services Configuration Guide.
# Set the TCP MSS to 500 for TCP connections with peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test tcp-mss 500
Warning:This operation might reset the peer session. Continue? [Y/N]:
tcp path-mtu-discovery (Layer 3—IP Services Command Reference)
peer timer
Use peer timer to set a keepalive interval and hold time for a peer or peer group.
Use undo peer timer to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer keepalive keepalive hold holdtime
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer
The keepalive interval is 60 seconds, and the hold time is 180 seconds.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures a keepalive interval and hold time for all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures a keepalive interval and hold time for all dynamic peers in the subnet.
link-local-address: Specifies a peer by its link-local address.
keepalive keepalive: Sets a keepalive interval in the range of 0 to 21845 seconds.
hold holdtime: Sets a hold time in the range of 3 to 65535 seconds. The hold time must be at least three times the keepalive interval.
After establishing a BGP session, two routers send keepalive messages at the specified keepalive interval to each other to keep the session.
If a router receives no keepalive or update message from the peer within the hold time, it tears down the session.
The timers configured with this command are preferred to the timers configured with the timer command.
If the hold time settings on the local and peer routers are different, the smaller one is used.
If the hold time is set to 0, no keepalive message will be sent to the peer, and the peer session will never time out. If neither the hold time nor the keepalive interval is set to 0, the actual keepalive interval is the smaller one between one third of the hold time and the keepalive interval.
The timers configured with this command do not take effect until a session is re-established (for example, a session is reset).
# In BGP instance view, set the keepalive interval and hold time for peer group test to 60 seconds and 180 seconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] peer test timer keepalive 60 hold 180
display bgp peer
timer
peer timer connect-retry
Use peer timer connect-retry to set the session retry timer for a peer or peer group.
Use undo peer timer connect-retry to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer connect-retry retry-time
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer connect-retry
The session retry timer is 32 seconds a peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command sets a connection retry timer for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command sets a connection retry timer for all dynamic peers in the subnet.
retry-time: Specifies a session retry timer in the range of 1 to 65535 seconds.
To speed up session establishment to a peer or peer group and route convergence, set a small session retry timer. If the BGP session flaps, you can set a large session retry timer to reduce the impact.
The timer set by the peer timer connect-retry command takes precedence over the timer set by the timer connect-retry command.
# In BGP instance view, set the session retry timer to 30 seconds for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 timer connect-retry 30
timer connect-retry
peer ttl-security
Use peer ttl-security to configure Generalized TTL Security Mechanism (GTSM) for a BGP peer or peer group.
Use undo peer ttl-security to disable BGP GTSM for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ttl-security hops hop-count
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ttl-security hops
GTSM is disabled for BGP.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures GTSM for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures GTSM for all dynamic peers in the subnet.
hops hop-count: Specifies the maximum number of hops to the specified peer, in the range of 1 to 254.
GTSM protects a BGP session by comparing the TTL value of an incoming IP packet against the valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the BGP packets sent by the device have a TTL of 255.
When GTSM is configured, the local device can establish an EBGP session to the peer after they pass GTSM check, regardless of whether the maximum number of hops is reached.
To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
# In BGP instance view, enable GTSM for BGP peer group test and set the maximum number of hops to the specified peer in the peer group to 1.
[Sysname] bgp 100
[Sysname-bgp-default] peer test ttl-security hops 1
peer ebgp-max-hop
pic
Use pic to enable BGP FRR for a BGP address family.
Use undo pic to disable BGP FRR for a BGP address family.
pic
undo pic
BGP FRR is disabled.
FRR is used in a dual-homing network to protect a primary route with a backup route. It uses ARP (for IPv4), ND (for IPv6), or echo-mode BFD (for IPv4) to detect the connectivity of the primary route. When the primary route fails, BGP directs packets to the backup route.
After you enable FRR, BGP calculates a backup route for each BGP route in the address family if there are two or more unequal-cost routes to reach the destination.
You can also configure BGP FRR by using the fast-reroute route-policy command, which takes precedence over the pic command. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
Use the pic command with caution because it might cause routing loops in specific scenarios.
# Enable BGP FRR in BGP IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] pic
port
Use port to specify the port number of the RPKI server.
Use undo port to restore the default.
port port-number
undo port
The port number of the RPKI server is not specified.
BGP RPKI server view
port-number: Specifies the port number of the RPKI server, in the range of 1 to 65535.
After you specify the IP address and port number of the RPKI server, the device automatically establishes a TCP connection to the server.
Make sure the specified port number is the same as the port number used by the RPKI server.
Changing the port number will cause temporary connection interruption.
# In BGP RPKI server view, specify 1234 as the port number of the RPKI server.
[Sysname] bgp 100
[Sysname-bgp-default] rpki
[Sysname-bgp-default-rpki] server tcp 1.1.1.1
[Sysname-bgp-default-rpki-server] port 1234
server tcp
preference
Use preference to configure preferences for BGP routes.
Use undo preference to restore the default.
undo preference
The preferences of external, internal, and local BGP routes are 255, 255, and 130, respectively.
external-preference: Specifies a preference for EBGP routes, in the range of 1 to 255.
internal-preference: Specifies a preference for IBGP routes, in the range of 1 to 255.
local-preference: Specifies a preference for local routes, in the range of 1 to 255.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set the route preference for matching routes. Routes not matching the routing policy use the default preference.
Different routing protocols might find different routes to the same destination. However, not all of those routes are optimal. For route selection, routing protocols, direct routes, and static routes are assigned different preferences. The route with the highest preference is preferred.
Configuring the preferences for BGP routes changes the possibility for the routes to become the optimal route.
To use a routing policy to set the preference, you must configure the preference with the apply preference command in the routing policy in advance. Otherwise, all matching routes use the default preference.
# In BGP IPv4 unicast address family view, set preferences for EBGP, IBGP, and local routes to 20, 20, and 200, respectively.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] preference 20 20 200
primary-path-detect bfd
Use primary-path-detect bfd to configure BGP FRR to use BFD to detect next hop connectivity for the primary route.
Use undo primary-path-detect bfd to restore the default.
primary-path-detect bfd echo
BGP FRR uses ARP to detect the connectivity to the next hop of the primary route.
echo: Uses echo-mode BFD to detect the connectivity to the next hop of the primary route.
# In BGP instance view, configure BGP FRR to use echo-mode BFD to detect next hop connectivity for the primary route.
[Sysname] bgp 100
[Sysname-bgp-default] primary-path-detect bfd echo
pic
purge-time
Use purge-time to set the aging time for the ROA information.
Use undo purge-time to restore the default.
purge-time purge-time
undo purge-time
The aging time for the ROA information is 60 seconds.
purge-time: Specifies the aging time for the ROA information, in the range of 30 to 360 seconds.
When the connection between a router and an RPKI server goes down (except when the shutdown command is executed), the router takes the following actions:
· Attempts to reconnect to the server.
· Places the ROA information obtained from the server in aging state, and starts the aging timer for the ROA information.
If the router reconnects to the server before the aging timer expires, it releases the ROA information from the aging state. If the router fails to reconnect to the server when the aging timer expires, it deletes the ROA information obtained from the server.
# Set the aging time for the ROA information to 150 seconds.
[Sysname] bgp 100
[Sysname-bgp-default-rpki-server] purge-time 150
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable route reflection between clients.
Route reflection between clients is enabled.
BGP LS address family view
BGP IPv4 RT filter address family view
When a route reflector is configured, and the clients of a route reflector are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use the undo reflect between-clients command to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
# In BGP IPv4 unicast address family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] undo reflect between-clients
peer reflect-client
Use reflect change-path-attribute to enable the route reflector to change the attributes of routes to be reflected.
Use undo reflect change-path-attribute to restore the default.
A route reflector cannot change the attributes of routes to be reflected.
BGP VPNv4 address family view
BGP VPNv6 address family view
Execute this command to allow the route reflector to change the attributes of routes when reflecting the routes.
# In BGP IPv4 unicast address family view, enable the route reflector to change the attributes of routes to be reflected.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflect change-path-attribute
peer reflect-client
Use reflector cluster-id to configure the cluster ID for a route reflector.
Use undo reflector cluster-id to restore the default.
A route reflector uses its router ID as the cluster ID.
BGP IPv6 unicast address family view
cluster-id: Specifies the cluster ID in the format of an integer, in the range of 1 to 4294967295.
ipv4-address: Specifies the cluster ID in the format of an IPv4 address in dotted decimal notation.
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the cluster ID.
You can configure more than one route reflector in a cluster to improve network reliability and prevent a single point of failure. Use this command to configure the same cluster ID for all route reflectors in the cluster to avoid routing loops.
Do not configure the router ID of a client as the cluster ID.
# In BGP IPv4 unicast address family view, set the cluster ID on the local router (a reflector in the cluster) to 80.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflector cluster-id 80
peer reflect-client
refresh bgp
Use refresh bgp to manually soft-reset BGP sessions.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 [ multicast | rtfilter | [ unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] ipv6-address [ mask-length ] { export | import } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number | all | external | group group-name | internal } { export | import } ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } dedicated
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command soft-resets BGP sessions for the default BGP instance.
ipv4-address: Soft-resets the BGP session to a peer specified by its IP address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command soft-resets BGP sessions to all dynamic peers in the subnet.
ipv6-address: Soft-resets the BGP session to a peer specified by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command soft-resets BGP sessions to all dynamic peers in the subnet.
link-local-address: Specifies a peer by its link-local address. This argument is not supported in multicast address family view.
all: Soft-resets all BGP sessions.
external: Soft-resets all EBGP sessions.
group group-name: Soft-resets the BGP sessions to the peers of the specified peer group. The group-name argument refers to the name of a peer group, a case-sensitive string of 1 to 47 characters.
internal: Soft-resets all IBGP sessions.
export: Performs outbound soft-reset (filters routes advertised to the specified peer or peer group by using the new configuration).
import: Performs inbound soft-reset (filters routes received from the specified peer or peer group by using the new configuration).
ipv4: Soft-resets BGP sessions for IPv4 address family.
ipv6: Soft-resets BGP sessions for IPv6 address family.
link-state: Soft-resets BGP sessions for LS address family.
multicast: Soft-resets BGP sessions for multicast address family.
rtfilter: Soft-resets BGP sessions for IPv4 RT filter address family
unicast: Soft-resets BGP sessions for unicast address family.
evpn: Soft-resets BGP sessions for EVPN address family.
dedicated: Soft-resets BGP sessions for dedicated address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command soft-resets BGP sessions for the specified address family on the public network.
A soft-reset operation enables the router to apply a new route selection policy without tearing down BGP connections.
To apply a new policy to outbound BGP sessions, execute this command with the export keyword. The router uses the new policy to filter routing information and sends the routing information that passes the filtering to the BGP peers.
To apply a new policy to inbound sessions, execute this command with the import keyword. The router advertises a route-refresh message to the peer and the peer resends its routing information to the router. After receiving the routing information, the router uses the new policy to filter the routing information.
This command requires that both the local router and the peer support route refresh.
If the peer keep-all-routes command is configured, the refresh bgp import command does not take effect.
By default, the unicast keyword is used if neither the multicast keyword nor the unicast keyword is specified.
# Soft-reset all inbound BGP sessions for the IPv4 unicast address family.
<Sysname> refresh bgp all import ipv4
peer capability-advertise route-refresh
refresh-time
Use refresh-time to set the RPKI connection check interval.
Use undo refresh-time to restore the default.
refresh-time refresh-time
undo refresh-time
The RPKI connection check interval is 600 seconds.
refresh-time: Specifies the RPKI connection check interval in the range of 15 to 3600 seconds.
After a router establishes a TCP connection with an RPKI server, the router checks the connection at the specified interval. If the router does not receive a response from the RPKI server within the specified time period, it tears down the connection to the RPKI server.
# Set the RPKI connection check interval to 15 seconds.
[Sysname] bgp 100
[Sysname-bgp-default-rpki-server] refresh-time 15
response-time
reset bgp
Use reset bgp to reset BGP sessions for the specified address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ multicast | rtfilter | [ unicast ] [ vpn-instance vpn-instance-name ] ]
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number | all | external | group group-name | internal } ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } link-state
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } l2vpn
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } l2vpn evpn
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } dedicated
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command resets BGP sessions for the default BGP instance.
as-number: Resets BGP sessions to peers in the AS specified by its number in the range of 1 to 4294967295.
ipv4-address: Resets the BGP session to a peer specified by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command resets BGP sessions to all dynamic peers in the subnet.
ipv6-address: Resets the BGP session to a peer specified by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command resets BGP sessions to all dynamic peers in the subnet.
all: Resets all BGP sessions.
external: Resets all EBGP sessions.
group group-name: Resets the BGP sessions to the peers in the peer group specified by its name, a case-sensitive string of 1 to 47 characters.
internal: Resets all IBGP sessions.
ipv4: Resets BGP sessions for IPv4 address family.
ipv6: Resets BGP sessions for IPv6 address family.
link-state: Resets BGP sessions for LS address family.
multicast: Resets BGP sessions for multicast address family.
rtfilter: Resets BGP sessions for IPv4 RT filter address family.
unicast: Resets BGP sessions for unicast address family.
evpn: Resets BGP sessions for EVPN address family.
dedicated: Resets BGP sessions for dedicated address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command resets BGP sessions for the specified address family on the public network.
CAUTION: Executing this command breaks down BGP sessions for a short period of time. |
A reset operation enables the router to apply a new route selection policy by re-establishing BGP sessions.
By default, the unicast keyword is used if the unicast and multicast keywords are not specified.
# Reset all BGP sessions for the IPv4 unicast address family.
reset bgp all
Use reset bgp all to reset all BGP sessions for all address families.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command resets all BGP sessions for all address families of the default BGP instance.
A reset operation enables the router to apply a new route selection policy by re-establishing BGP sessions. This operation breaks down BGP sessions for a short while.
# Reset all BGP sessions.
reset bgp bmp server statistics
Use reset bgp bmp server statistics to clear BMP server statistics.
reset bgp [ instance instance-name ] bmp server server-number statistics
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears the BMP server statistics of the default BGP instance.
server-number: Specifies a BMP server by its number in the range of 1 to 8.
# Clear the statistics of BMP server 1.
<Sysname> reset bgp bmp server 1 statistics
display bgp bmp server
reset bgp dampening
Use reset bgp dampening to clear BGP route dampening information and release suppressed BGP routes.
reset bgp [ instance instance-name ] dampening ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ mask-length | mask ] ]
reset bgp [ instance instance-name ] dampening ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length ]
reset bgp [ instance instance-name ] dampening vpnv4 [ ipv4-address [ mask | mask-length ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears BGP route dampening information and releases suppressed BGP routes for the default BGP instance.
ipv4: Clears BGP IPv4 route dampening information and releases suppressed BGP IPv4 routes.
ipv6: Clears BGP IPv6 route dampening information and releases suppressed BGP IPv6 routes.
vpnv4: Clears IBGP VPNv4 route dampening information and releases suppressed IBGP VPNv4 routes.
multicast: Clears BGP multicast route dampening information and releases suppressed BGP multicast routes.
unicast: Clears BGP unicast route dampening information and releases suppressed BGP unicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears BGP route dampening information for the public network, and releases suppressed BGP routes.
ipv4-address: Specifies an IPv4 destination network address. If you do not specify a network address, this command clears all BGP route dampening information, and releases all suppressed BGP routes.
mask: Specifies a network mask in dotted decimal notation.
ipv6-address: Specifies an IPv6 destination network address. If you do not specify a network address, this command clears all BGP route dampening information, and releases all suppressed BGP routes.
When you execute the reset bgp dampening ipv4 command:
· If you specify only the ipv4-address argument, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command clears dampening information for the route, and releases the suppressed route.
· If you specify the ipv4-address mask or ipv4-address mask-length argument, this command does the following:
¡ Clears dampening information for the route that matches both the specified destination network address and the mask (or mask length).
¡ Releases the suppressed route.
By default, the unicast keyword is used if neither the unicast keyword nor the multicast keyword is specified.
# Clear dampening information for the BGP IPv4 unicast route to network 20.1.0.0/16 and release the suppressed route.
<Sysname> reset bgp dampening ipv4 20.1.0.0 255.255.0.0
dampening
dampening ibgp (MPLS Command Reference)
display bgp routing-table dampened
reset bgp flap-info
Use reset bgp flap-info to clear flap statistics for BGP routes.
reset bgp [ instance instance-name ] flap-info ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ]
reset bgp [ instance instance-name ] flap-info ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv6-address [ prefix-length ] ]
reset bgp [ instance instance-name ] flap-info vpnv4 [ ipv4-address [ mask | mask-length ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer [ ipv4-address [ mask-length ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears flap statistics for the default BGP instance.
ipv4: Clears flap statistics for BGP IPv4 routes.
ipv6: Clears flap statistics for BGP IPv6 routes.
vpnv4: Clears flap statistics for IBGP VPNv4 routes.
multicast: Clears flap statistics for BGP multicast routes.
unicast: Clears flap statistics for BGP unicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears flap statistics for public BGP routes.
as-path-acl as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256, to filter BGP route flap statistics.
as-path-acl as-path-acl-name: Specifies an AS path list by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
peer ipv4-address [ mask-length ]: Clears flap statistics for BGP routes learned from the specified IPv4 BGP peer. The mask-length argument specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command clears flap statistics for BGP routes learned from all dynamic peers in the subnet.
peer ipv6-address [ prefix-length ]: Clears flap statistics for BGP routes learned from the specified IPv6 BGP peer. The prefix-length argument specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command clears flap statistics for BGP routes learned from all dynamic peers in the subnet.
When you execute the reset bgp flap-info ipv4 command:
· If you specify only the ipv4-address argument, the system ANDs the IPv4 network address with the mask of a route. If the result matches the IPv4 network address of the route, this command clears the flap statistics of the route.
· If you specify the ipv4-address mask or ipv4-address mask-length argument, this command clears the flap statistics of the route that matches both the specified IPv4 destination network address and the mask (or mask length).
# Clear flap statistics for the BGP IPv4 unicast route to network 20.1.0.0/16.
<Sysname> reset bgp flap-info ipv4 20.1.0.0 16
dampening
display bgp routing-table flap-info
reset bgp rpki server
Use reset bgp rpki server to reset BGP RPKI sessions.
reset bgp [ instance instance-name ] rpki server [ vpn-instance vpn-instance-name ] tcp { ipv4 address | ipv6 address }
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command resets BGP RPKI sessions for the default BGP instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command resets BGP RPKI sessions for the public network.
ipv4-address: Specifies an RPKI server by its IPv4 address.
ipv6-address: Specifies an RPKI server by its IPv6 address.
CAUTION: Executing this command will tear down and then re-establish the specified BGP RPKI session, causing temporary BGP RPKI session interruption. |
# Reset the BGP RPKI session to RPKI server 2.2.2.1.
<Sysname> reset bgp rpki server tcp 2.2.2.1
response-time
Use response-time to set the time to wait for the response from the RPKI server.
Use undo response-time to restore the default.
response-time response-time
undo response-time
The time to wait for the response from the RPKI server is 30 seconds.
response-time: Specifies the time to wait for the response from the RPKI server, in the range of 15 to 3600 seconds.
A router checks the connection to an RPKI server at the check interval. If the router does not receive a response from the RPKI server within the specified time period, it tears down the connection to the RPKI server.
# Set the time to wait for the response from RPKI server 1.1.1.1 to 15 seconds.
[Sysname] bgp 100
[Sysname-bgp-default-rpki-server] response-time 15
refresh-time
route-mode adj-rib-out
Use route-mode adj-rib-out to configure BGP to send routes advertised to the monitored peer or peer group to the BMP server.
Use undo route-mode adj-rib-out to restore the default.
BGP does not send routes advertised to the monitored peer or peer group to the BMP server.
BMP server view
To configure BGP to send routes advertised to the monitored peer or peer group to the BMP server, make sure BGP has established a TCP connection to the BMP server.
# Configure BGP to send routes advertised to the monitored peer or peer group to the BMP server.
[Sysname] bmp server 5
[Sysname-bmpserver-5] route-mode adj-rib-out
route-mode loc-rib
Use route-mode loc-rib to configure BGP to send the optimal routes in the routing table to the BMP server.
Use undo route-mode loc-rib to restore the default.
route-mode loc-rib
BGP does not send the optimal routes in the routing table to the BMP server.
BMP server view
To configure BGP to send the optimal routes in the routing table to the BMP server, make sure BGP has established a TCP connection to the BMP server.
This command takes effect only on BGP IPv4 unicast and BGP-VPN IPv4 unicast routes.
# Configure BGP to send the optimal routes in the routing table to the BMP server.
[Sysname-bmpserver-5] route-mode loc-rib
route-select delay
Use route-select delay to configure optimal route selection delay.
Use undo route-select delay to restore the default.
The optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
BGP-VPN IPv6 unicast address family view
BGP IPv6 multicast address family view
delay-value: Specifies the optimal route selection delay timer in the range of 0 to 600 seconds. A value of 0 means optimal route selection is not delayed.
To avoid packet loss caused by path switchover, configure this command to delay optimal route selection upon a route change.
Follow these restrictions and guidelines when you configure the command:
· The optimal route selection delay setting applies only when multiple effective routes with the same prefix exist after a route change occurs.
· For routes being delayed for optimal route selection, modifying the optimal route selection delay timer has the following effects:
¡ If you modify the delay timer to a non-zero value, the routes are not affected, and they still use the original delay timer.
¡ If you execute the undo form of the command or modify the delay timer to 0, the device performs optimal route selection immediately.
· If you execute the command multiple times for an address family, the most recent configuration takes effect.
· The optimal route selection delay configuration does not apply to the following conditions:
¡ A route change is caused by execution of a command or by route withdrawal.
¡ After a route change occurs, only one route exists for a specific destination network.
¡ An active/standby process switchover occurs.
¡ A route change occurs among equal-cost routes.
¡ Only the optimal and suboptimal routes exist when FRR is configured.
¡ Optimal route selection is triggered by a redistributed route.
# In BGP IPv4 unicast address family view, set the optimal route selection delay timer to 100 seconds.
[Sysname] bgp 65009
[Sysname-bgp-default-ipv4] route-select delay 100
Use route-update-interval withdrawn enable to apply route update interval setting to withdrawn routes.
Use undo route-update-interval withdrawn enable to restore the default.
Route update interval setting does not apply to withdrawn routes. BGP sends withdrawal messages for withdrawn routes immediately.
BGP instance view
This command does not take effect on routes that exist before the command is configured.
By default, for a route to be withdrawn, a BGP router immediately sends a withdrawal message to its peers. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. To avoid this issue, use this command to apply the route update interval configured in the peer route-update-interval command to withdrawn routes. BGP will send withdrawn and update messages at the specified intervals.
# In BGP instance view, apply route update interval setting to withdrawn routes.
[Sysname] bgp 100
[Sysname-bgp-default] route-update-interval withdrawn enable
router id
Use router id to configure a global router ID.
Use undo router id to restore the default.
router id router-id
undo router id
No global router ID is configured.
router-id: Specifies a router ID in IP address format.
Some routing protocols use a router ID to identify a device. You can configure a global router ID, which is used by routing protocols that have no router ID configured.
If no global router ID is configured, the highest loopback address, if any, is used as the router ID. If no loopback address is available, the highest physical interface IP address is used, regardless of the interface status. If no IP address is configured for any interface, the router ID is 0.0.0.0.
During an active/standby switchover, the standby main processing unit (MPU) checks the validity of the previous router ID backed up before switchover. If it is not valid, it selects a new router ID.
If the interface IP address that is selected as the router ID is removed or modified, a new router ID is selected. The following events will not trigger a router ID re-selection:
· The interface goes down.
· After a physical interface address is selected as the router ID, an IP address is configured for a loopback interface.
· A higher interface IP address is configured.
After you modify the global router ID and reset BGP sessions, the modification does not take effect for a BGP instance that uses the global router ID. To modify the router ID for the BGP instance, use the router-id command in BGP instance view.
# Configure a global router ID as 1.1.1.1.
[Sysname] router id 1.1.1.1
router-id (BGP instance view)
router-id (BGP-VPN instance view)
Use router-id to configure a router ID for a BGP instance.
Use undo router-id to restore the default.
router-id router-id
undo router-id
No router ID is configured for a BGP instance, and the BGP instance uses the global router ID configured by the router id command in system view.
router-id: Specifies a router ID for BGP, in IP address format.
To run BGP, a BGP instance must have a router ID, which is an unsigned 32-bit integer that uniquely identifies the router in the AS.
To modify a non-zero router ID for BGP, execute the router-id command in BGP instance view.
To improve availability, specify the IP address of a loopback interface as the router ID for BGP.
If you execute this command in the same BGP instance view multiple times, the most recent configuration takes effect.
You can configure the same router ID for different BGP instances.
# In BGP instance view, set the router ID for BGP to 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] router-id 1.1.1.1
router id
Use router-id to configure a router ID for a BGP VPN instance.
undo router-id
No router ID is configured for a BGP VPN instance, and the BGP VPN instance uses the router ID configured in BGP instance view. If no router ID is configured in BGP instance view, the BGP VPN instance uses the global router ID configured in system view.
auto-select: Automatically selects a router ID for the BGP VPN instance.
To run BGP, a VPN instance of a BGP instance must have a router ID, which is an unsigned 32-bit integer that uniquely identifies the BGP VPN router in the AS.
If the auto-select keyword is specified, the system selects a router ID for the BGP VPN instance in the following order:
1. The highest loopback address in the BGP VPN instance as the router ID.
2. The highest physical interface address in the BGP VPN instance as the router ID, regardless of the interface status.
3. 0.0.0.0 as the router ID.
If a non-zero router ID is selected for the BGP VPN instance, the router ID will not change when a more preferable router ID is available in the BGP VPN instance.
To improve availability, specify the IP address of a loopback interface as the router ID.
You can specify a different router ID for each VPN instance on a device.
If you execute this command in the same BGP-VPN instance view multiple times, the most recent configuration takes effect.
# In BGP-VPN instance view, set the router ID to 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] router-id 1.1.1.1
router id
route-rate-limit
Use route-rate-limit to set the BGP route sending rate.
Use undo route-rate-limit to restore the default.
route-rate-limit rate
The BGP route sending rate is not limited.
BGP instance view
rate: Specifies the number of new routes that BGP can send per second, in the range of 0 to 4294967295. A value of 0 means that BGP does not send newly added routes.
If a device sends many new routes within a short time period, it might be unable to add the routes to the FIB before the peer device adds them. This might result in traffic forwarding failure. To avoid this problem, you can configure this command to set an appropriate route sending rate for the device. For a device with high performance, you can set a high BGP route sending rate as needed. For a device without high performance, set a relatively low BGP route sending rate as a best practice.
As a best practice to avoid route withdrawal failures, do not set the BGP route sending rate to 0 or a small value when network flapping occurs.
This command applies only to IPv4 unicast routes and IPv6 unicast routes.
# In BGP instance view, set the BGP route sending rate to 1000.
[Sysname] bgp 100
[Sysname-bgp-default] route-rate-limit 1000
routing-table bgp-rib-only
Use routing-table bgp-rib-only to enable BGP to not flush routes matching the specified routing policy to the routing table.
Use undo routing-table bgp-rib-only to restore the default.
routing-table bgp-rib-only [ route-policy route-policy-name ]
BGP flushes the optimal routes to the routing table.
BGP-VPN IPv4 unicast address family view
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a routing policy or the specified routing policy does not exist, BGP does not flush any routes to the routing table. The apply clauses in the specified routing policy do not take effect.
This command applies to the following scenarios:
· In an MPLS L3VPN network, all the optimal private BGP routes will be flushed to the routing table of a PE by default. You can execute this command to prevent unnecessary routes from being flushed to the IP routing table and improve the forwarding performance of the PE.
· In a route reflection network, execute this command to not flush specific BGP routes to the routing table of the RR. Then, the RR only advertises and receives routes but does not forward service traffic, which saves the system resources of the RR.
This command is mutually exclusive with the advertise-rib-active command.
# In BGP IPv4 unicast address family view, enable BGP to not flush BGP IPv4 unicast routes matching routing policy policy1 to the routing table.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] routing-table bgp-rib-only route-policy policy1
rpki
Use rpki to enter BGP RPKI view.
Use undo rpki to remove all configurations in BGP RPKI view.
rpki
undo rpki
BGP instance view
# Enter BGP RPKI view.
[Sysname] bgp 100
server
Use server to configure an IP address and port number for a BMP server.
Use undo server to remove the configuration.
server address ipv4-address port port-number
undo server
No IP address and port number are configured for the BMP server.
BMP server view
ipv4-address: Specifies an IP address for the BMP server.
port-number: Specifies a port number for the BMP server, in the range of 1 to 65535.
After you configure an IP address and port number for a BMP server, the BMP client establishes a TCP connection to the BMP server and sends BMP messages to the BMP server.
# Configure IP address 100.1.1.1 and port number 8888 for BMP server 5.
[Sysname-bmpserver-5] server address 100.1.1.1 port 8888
server connect-interface
Use server connect-interface to specify the source interface of TCP connections to the BMP server.
Use undo server connect-interface to restore the default.
server connect-interface interface-type interface-number
BGP uses the primary IPv4 address of the output interface in the optimal route to the BMP server as the source address of TCP connections to the BMP server.
BMP server view
After you configure this command, BGP uses the address of the specified interface to establish TCP connections to the BMP server.
This command does not take effect if the specified interface's VPN instance is different from that configured in the server vpn-instance command for the same server.
Do not specify a virtual template (VT) interface for this command.
# Configure Loopback 0 as the source interface of TCP connections to BMP server 5.
[Sysname-bmpserver-5] server connect-interface loopback0
ip binding vpn-instance (system view) (MCE Command Reference)
server vpn-instance
server tcp
Use server tcp to specify an RPKI server and enter BGP RPKI server view.
Use undo server tcp to cancel the configuration.
server [ vpn-instance vpn-instance-name ] tcp { ipv4-address | ipv6-address }
undo server [ vpn-instance vpn-instance-name ] tcp { ipv4-address | ipv6-address }
No RPKI server is specified.
BGP RPKI view
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command specifies an RPKI server in the public network.
You can execute this command multiple times to configure a router to establish TCP connections to multiple RPKI servers.
After you execute the undo server command, all configurations in BGP RPKI server view are deleted.
# Specify an RPKI server with the IP address 1.1.1.1 and enter BGP RPKI server view.
[Sysname] bgp 100
server vpn-instance
Use server vpn-instance to specify a VPN instance for a BMP server.
Use undo server vpn-instance to restore the default.
server vpn-instance vpn-instance-name
No VPN instance is specified for the BMP server. The BMP server belongs to the public network.
BMP server view
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must have been created.
Deleting the specified VPN instance terminates the connection to the BMP server, but does not remove your configuration. After you create the VPN instance again, the connection to the BMP server is automatically reestablished.
# Assign BMP server 5 with IP address 100.1.1.1 and port number 8888 to VPN instance vpna.
[Sysname-bmpserver-5] server vpn-instance vpna
snmp context-name
Use snmp context-name to configure an SNMP context for a BGP instance.
Use undo snmp context-name to restore the default.
No SNMP context is configured for a BGP instance.
context-name: Specifies an SNMP context by its name, a case-sensitive string of 1 to 32 characters.
BGP does not know the BGP instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different BGP instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
· For an SNMPv3 packet:
¡ The device selects the MIB of the BGP instance default if the packet does not carry a context and no SNMP context was configured for the BGP instance default.
¡ The device selects the MIB of a BGP instance if the packet meets the following conditions:
- Carries a context that was configured with the snmp-agent context command in system view.
- Matches the context of the BGP instance.
¡ The device does not process any MIBs in other situations.
· For an SNMPv1/v2c packet:
¡ The device selects the MIB of the BGP instance default if the following conditions are met:
- No SNMP community to SNMP context mapping was configured with the snmp-agent community-map command in system view.
- No SNMP context was configured for the BGP instance default.
¡ The device selects the MIB of a BGP instance if the SNMP community is mapped to an SNMP context and the context matches the context of the BGP instance.
For more information about SNMP contexts and community names, see Network Management and Monitoring Configuration Guide.
Do not configure the same SNMP context for different BGP instances.
# Configure SNMP context bgp-abc for BGP instance abc.
[Sysname-bgp-abc] snmp context-name bgp-abc
snmp-agent community-map (Network Management and Monitoring Command Reference)
snmp-agent context (Network Management and Monitoring Command Reference)
snmp-agent trap enable bgp
Use snmp-agent trap enable bgp to enable SNMP notifications for BGP.
Use undo snmp-agent trap enable bgp to disable SNMP notifications for BGP.
snmp-agent trap enable bgp [ instance instance-name ]
undo snmp-agent trap enable bgp [ instance instance-name ]
SNMP notifications for BGP are enabled.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command enables SNMP notifications for the default BGP instance.
After you enable SNMP notifications for BGP, the device generates a notification when a BGP neighbor state change occurs. The notification includes the neighbor address, the error code and subcode of the most recent error, and the current neighbor state.
For BGP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for BGP.
[Sysname] snmp-agent trap enable bgp
statistics-interval
Use statistics-interval to set the interval at which BGP sends statistics information to the BMP server.
Use undo statistics-interval to restore the default.
statistics-interval value
BGP does not send statistics information to the BMP server.
BMP server view
value: Specifies the interval at which BGP sends statistics information to the BMP server, in the range of 1 to 3600 seconds.
After establishing a TCP connection to the BMP server, BGP sends statistics information to the BMP server at the specified interval.
# Set the interval to 5 seconds at which BGP sends statistics information to the BMP server.
[Sysname-bmpserver-5] statistics-interval 5
summary automatic
Use summary automatic to configure automatic route summarization for redistributed IGP subnet routes.
Use undo summary automatic to restore the default.
summary automatic
Automatic route summarization is not performed for redistributed IGP subnet routes.
BGP IPv4 multicast address family view
After the summary automatic command is configured, BGP summarizes IGP subnets redistributed by the import-route command.
Automatic summary routes can be manually summarized, but cannot be added to the IP routing table.
# In BGP IPv4 unicast address family view, configure automatic route summarization for redistributed IGP subnet routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] summary automatic
aggregate
import-route
timer
Use timer to configure a BGP keepalive interval and hold time.
Use undo timer to restore the default.
undo timer
The BGP keepalive interval and the hold time are 60 seconds and 180 seconds, respectively.
keepalive keepalive: Configures a keepalive interval in the range of 0 to 21845 seconds.
hold holdtime: Configures a hold time in seconds, whose value is 0 or in the range of 3 to 65535. The hold time must be at least three times the keepalive interval.
Use the timer command to configure the keepalive interval and hold time for all BGP peers. Use the peer timer command to configure the keepalive interval and hold time for a peer or peer group. If both commands are configured, the intervals configured by the peer timer command have higher priority.
The timer command affects only new BGP sessions.
After the timer command is executed, no peer session is closed at once. The configured hold time is used for negotiation in session re-establishment (for example, when you reset the BGP session).
# In BGP instance view, set the keepalive interval and hold time to 60 seconds and 180 seconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] timer keepalive 60 hold 180
display bgp peer
peer timer
timer connect-retry
Use timer connect-retry to set the session retry timer for all peers and peer groups.
Use undo timer connect-retry to restore the default.
The session retry timer is 32 seconds for all peers and peer groups.
BGP instance view
# In BGP instance view, set the session retry timer to 30 seconds for all peers.
[Sysname] bgp 100
[Sysname-bgp-default] timer connect-retry 30
update-first route-policy
Use update-first route-policy to configure BGP to send withdrawal messages of routes matching the specified routing policy prior to other routes.
Use undo update-first route-policy to restore the default.
BGP does not send withdrawal messages of any routes prior to other routes.
This command enables BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast route switchover and reduce the traffic interruption time.
# In BGP IPv4 unicast address family view, configure BGP to send withdrawal messages of routes matching routing policy test-policy prior to other routes
[Sysname] bgp 1
[Sysname-bgp-default-ipv4] update-first route-policy test-policy
default-route update-first
route-policy
user-move fast-update
Use user-move fast-update to enable fast host route update upon user migration.
Use undo user-move fast-update to disable fast host route update upon user migration.
Fast host route update upon user migration is disabled.
An access device does not detect the online state of a client actively or update the host route entries in real time. Traffic forwarding might be affected when a client roams between access devices. To resolve this issue, execute this command to enable fast host route update upon user migration.
Executing this command also enables BGP to advertise the extended community attribute to all peers and peer groups.
# In BGP IPv4 unicast address family view, enable fast host route update upon user migration.
<Sysname>system-view
[Sysname] bgp 200
[Sysname-bgp-default-ipv4] user-move fast-update
peer advertise-ext-community
