00-Preface | 100.45 KB |
Preface
This command reference describes the configuration commands for the following user access and authentication features:
· WLAN authentication.
· WLAN IP snooping.
· AAA.
· 802.1X.
· 802.1X client.
· MAC authentication.
· Port security.
· Portal.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
