02-License management commands | 66.01 KB |
The access controller modules do not support parameters or commands that are available only in IRF mode.
display license
Use display license to display detailed license information.
display license [ activation-file ]
activation-file: Displays license information about activation files.
If you do not specify any parameters, this command displays detailed information about all licenses.
# Display detailed information about all licenses.
<Sysname> display license
flash:/license/210235A1AMB1450000272015052317092592481.ak
Feature: APMGR
Product Description: Enhanced Access Controller License,128 APs,for Verticals,for V7 Registered at: 2017-05-28 16:54:24
License Type: Trial (days restricted)
Trial Time Left (days): 30
Current State: In use
Product Description |
License description. |
Registered at |
Time when the license was installed. |
License Type |
License type by validity period: · NA—The system cannot obtain the license type. · Permanent—Purchased license that never expires and is always valid. · Days restricted—Purchased license that is valid for a period of days, for example, 30 days. · Trial (days restricted)—Free trial license that is valid for a period of days. |
Time Left (days) |
Remaining days of the license. This field is available for a purchased license. |
Trial Time Left (days) |
Remaining days of the trial period. This field is available for a trial license. |
Current State |
State of the license: · In use—The license is being used. · Usable—The license is available for use. ¡ If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state. ¡ A date restricted license is in this state if its start date is not reached. · Expired—The license has expired. · Uninstalled—The license has been uninstalled. · Unusable—The license cannot be used. · Invalid—The license is invalid and cannot be used. |
Uninstall Key |
This field is available for licenses that have been uninstalled. |
Uninstall Date |
Date when the activation file was uninstalled. |
display license device-id
Use display license device-id to display SN and DID information.
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# Display the device SN and DID.
<Sysname> display license device-id
SN: 210200A00JN173000801
SN CHECK_SUM: 920AA224
Device ID: flash:/license/210200A00JN173000801.did
display license feature
Use display license feature to display brief license information for features.
# Display brief feature license information.
<Sysname> display license feature
Total: 10240 Usage: 0
Feature Licensed State
APMGR N -
ELEMGR N -
Total |
Total number of licenses that can be installed. |
Usage |
Number of licenses stored in the license storage. |
Feature |
Feature that must be licensed before being used. |
Licensed |
Licensing state of the feature: · N—Not licensed. · Y—Licensed. |
State |
License type by purchasing state: · Trial—Trial license. · Pre-licensed—Pre-installed license. If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file. |
license activation-file install
Use license activation-file install to install an activation file.
license activation-file install license-file
license-file: Specifies the path of an activation file, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
License registration requires the device's hardware SN and DID.
# Install activation file 20170810.ak.
[Sysname] license activation-file install flash:/license/20170810.ak
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...Done.
# Install activation file package 20170101.tar to the specified slot.
[Sysname] license activation-file install flash:/license/20170101.tar slot 1
Decompress......Done.
Begain to install test01.ak …Done.
Begain to install test02.ak …Done.
Begain to install test03.ak …Done.
Total Num:3
Success Num:3
Failed Num:0
display license
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
license activation-file uninstall license-file
license-file: Specifies the file path, a case-sensitive string of 1 to 127 characters.
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# Uninstall activation file flash:/license/20130810.ak.
[Sysname] license activation-file uninstall flash:/license/20130810.ak
Uninstall file: flash:/license/20130810.uak
display license
license compress
Use license compress to compress the license storage.
license compress
Use this command if the free license storage (see the display license feature command) is not sufficient.
This command clears expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. You will be unable to install the activation file obtained by using the old DID on the device. As a best practice, install all activation files registered with the old DID before performing a compression.
# Compress the license storage.
[Sysname] license compress
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
