- H3C CR19000-20 Core Router Installation Guide-6W103
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Installing Power Supplies
- 04-Chapter 4 Installing Removable Components
- 05-Chapter 5 Connecting Cables
- 06-Chapter 6 Verifying the Installation
- 07-Chapter 7 Accessing the Router
- 08-Chapter 8 Replacement Procedures
- 09-Chapter 9 Troubleshooting
- 10-Appendix A Engineering Labels
- 11-Appendix B Cable Management
- 12-Appendix C Repacking the Router
| 07-Chapter 7 Accessing the Router | 53.65 KB |
Using a console cable to connect the router to a configuration terminal
Setting up the configuration environment
7 Accessing the router
The first time you access a router you must log in through the console port.
IMPORTANT: When you connect a PC to a powered-on router, first connect the DB-9 connector of the console cable to the PC, and then connect the RJ-45 connector to the router. |
To connect a configuration terminal to the router by using a console cable:
1. Select a configuration terminal, which can be a character terminal with an RS-232 serial port, or a PC.
2. Plug the DB-9 female connector of the console cable into the serial port on the configuration terminal and the RJ-45 connector into the console port on the router.
Setting terminal parameters
To configure and manage the router through the console port, you must run a terminal emulator program, TeraTermPro or PuTTY, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
Start the terminal emulator program and configure the parameters as follows:
· Bits per second—9600.
· Data bits—8.
· Stop bits—1.
· Parity—None.
· Flow control—None.
Starting the router
WARNING! Locate the power switch of the power supply system before power on the router so you can quickly shut power off when an electrical accident occurs. |
IMPORTANT: The router has two switches. As a best practice, turn on the two switches simultaneously to power on the router. |
To start the router:
1. Power on the router.
2. Verify the following items:
¡ The LEDs on the front panel are normal. For the LED description, see "Appendix C LEDs."
¡ The configuration terminal displays information normally.
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--cfa0:/main.bin!............
The main application file is self-decompressing.............................
....................................................................Done!
System application is starting...
Mainboard 1 is master.
User interface con1 is available.
Press ENTER to get started. (Press Enter.)
<sysname> (The router is ready for configuration.)
Configuring basic settings
Configure basic settings for the router after the router starts up. For more information about how to configure the router, see H3C CR19000 Core Routers Configuration Guides and H3C CR19000 Core Routers Command References.
