01-Text | 27.99 MB |
1 Inspecting the router at delivery
Determining the installation personnel
Installation site requirements
General safety recommendations
Attaching slide rails to the rack
DC power supply configuration guidelines
AC power supply configuration guidelines
Installing an interface module that uses detachable ejector levers
Installing an interface module that uses general ejector levers
8 Installing cable management brackets
Installing a filler panel in a fabric module slot
Installing transceiver modules and optical fibers
Cables for connecting E1 ports
When the router is delivered, inspect the items against the packing list. Make sure all items in the list are delivered in good condition. Keep the items secure for future use.
IMPORTANT: · Install the router after finishing inspection. Do not inspect the router when installing it. · Keep the packaging materials secure for future moving or shipment. · If you find a fault with the router before powering it on, stop your operation, keeping the router as it is, and take photos. Keep the original packaging materials and accessories secure. |
2 Preparing for installation
The personnel for installing and maintaining the router must have received professional training and are familiar with the precautions in installation and skilled and professional in router installation and maintenance.
Equipment room requirements
For correct operation of the router, make sure the equipment room meets the following requirements:
The installation site has a good ventilation and cooling system.
· The air inlet and outlet vents of the chassis are not blocked, clear of obstructions.
· The air inlets vents of the chassis are away from the outlet vents of other devices.
· The ambient temperature for the router is maintained in the range of 0°C to 45°C (32°F to 113°F).
· The ambient humidity for the router is maintained in the range of 5% RH to 95 % RH, non-condensing.
· The equipment room is clean, dust-free, and can adequately keep the router from any form of potential water damage.
Grounding requirements
Correctly grounding the router is crucial to lightning protection, anti-interference, and ESD prevention. Use a good grounding system for the router. Make sure the resistance between the chassis and the ground is less than 1 ohm.
Space requirements
IMPORTANT: · For the chassis to be accessible from front and rear, use a rack that has both a front door (single-leaf door as a best practice) and rear door. · For easy installation and maintenance, reserve a minimum clearance of 1200 mm (47.24 in) between the rack and walls or other devices. |
Table 2-1 Router dimensions and rack requirements
Model |
Chassis dimensions |
Rack requirements |
CR19000-16 |
· Height—931 mm (36.65 in)/21 RU · Width—440 mm (17.32 in) · Depth—979 mm (38.54 in) ¡ Chassis—857 mm (33.74 in) ¡ Cable management bracket—92 mm (3.62 in) ¡ Fan tray handle at the rear—30 mm (1.18 in) |
As a best practice, use a rack that meets the following requirements: · With dimensions (H × W × D) of 2200 × 600 × 1200 mm (86.61 × 23.62 × 47.24 in) · A minimum of 105 mm (4.13 in) between the front rack posts and the front door. · A minimum of 880 mm (34.65 in) between the front rack posts and the rear door. |
Figure 2-2 Rack requirements
Cooling requirements
CAUTION: · For adequate heat dissipation, make sure the air inlet and outlet vents of the router are not blocked and adequate clearance is reserved around the air vents. · Make sure the rack for the router has a good cooling system, with the perforation rate of rack doors greater than 50%. · Make sure the air conditioners do not blow air directly onto the router. |
The router uses super-short cut-through air aisles to provide front-to-rear airflow for heat dissipation, as shown in Figure 2-3.
Figure 2-3 Airflow through the chassis
Safety recommendations
To avoid bodily injury and damage to the router, read all safety recommendations carefully before installation. Note that the recommendations do not cover every possible hazardous condition.
Safety symbols
When reading this document, pay special attention to the following symbols:
WARNING means an alert that calls attention to important information that if
not understood or followed can result in personal injury.
CAUTION means an alert that calls attention to important information that if
not understood or followed can result in data loss, data corruption, or damage
to hardware or software.
· Keep the chassis and installation tools away from walk areas.
· Place the router on a dry and flat location. Make sure anti-slip measures are in place.
· When servicing the router, do not wear loose clothing or jewelry (such as a necklace) that could get caught in the chassis.
· If you cannot install a removable component smoothly, stop your operation and troubleshoot the issues, preventing component damages caused by misoperations.
· Clear the work area of any possible electricity hazards, such as ungrounded power extension cables, missing safety grounds, and wet floors.
ESD prevention
To prevent components from ESD damage, wear an ESD wrist strap before working with the router and the modules.
To attach an ESD wrist strap:
1. Put the wrist band of the strap on your wrist and fasten the band so that it makes good contact with your skin.
2. Attach the other end of the strap to an ESD jack on the chassis or rack. Make sure the strap is reliably grounded.
The router has one ESD jack on both the front and rear panels.
Figure 2-4 Attaching an ESD wrist strap ( to the ESD jack on the rear panel)
Moving the chassis
Physical specifications
Table 2-2 Physical specifications
Model |
Shipping weight |
Dimensions (H × W × D) |
CR19000-16 |
119.3 kg (263.01 lb) |
931 × 440 × 857 mm (36.65 × 17.32 × 33.74 in) |
The shipping weight of the router includes the chassis and packaging material. Determine a moving method for the chassis based on its shipping weight.
Moving the chassis
CAUTION: · To avoid chassis damage, use only the chassis handles other than any other component to move the chassis. · During the moving process, keep the router upright and do not put down the router or drag the router on the ground. · When transporting, moving, and installing the router, be careful not to bump the router into the door or wall. |
To move the chassis to the installation location:
1. Unpack the chassis.
2. Remove the screws on the L brackets by using a Phillips screwdriver and an adjustable wrench to separate the router from the pallet.
3. Use a minimum of four people to move the chassis by holding the chassis handles.
Keep the router upright during the moving process.
Figure 2-5 Moving the chassis
Preparing installation tools
Installation tools are required when installing the router. Prepare installation tools as required. Figure 2-6 provides installation tools for your reference.
4 Rack-mounting the router
CAUTION: The router is heavy. For rack stability, install it at a lowest possible position. |
To rack-mount the router, select and attach slide rails to the rack. See Table 4-1 for the slide rail requirements.
Table 4-1 Slide rail requirements
Router model |
Max. chassis weight (fully configured) |
Applicable slide rails |
Slide rail model |
Adjustment range |
Occupied space |
CR19000-16 |
350 kg (771.60 lb) |
LSXM1BSR |
630 mm to 900 mm (24.80 in to 35.43 in) |
1 RU |
For information about installing the slide rails, see H3C LSXM1BSR 1U Bottom-Support Rails Installation Guide (available also at https://www.h3c.com/en/Support/Resource_Center/EN/Routers/Catalog/CR19000/CR19000/).
When installing slide rails, make sure the load-bearing plane of the slide rails is perpendicular to the four rack posts.
Mounting the router in a rack
CAUTION: When you move the router to a low temperature environment from a high temperature environment, condensation might occur. Before installing the router, dry the router to prevent the internal components from being damaged because of short circuit. |
To mount the router in a rack:
1. As shown in Figure 4-1, mark the cage nut installation holes on the front rack post.
Figure 4-1 Marking the cage nut installation holes
2. Insert cage nuts into the marked square holes in the front rack posts.
Cage nuts are not required for the two upper marked installation holes on the right front rack post.
Figure 4-2 Installing the cage nuts
3. Place the router on the slide rails from the front of the rack. Slide the router along the guide rails into the rack.
4. Use M6 screws provided with the router to secure the router to the rack posts.
Figure 4-3 Mounting the router in a rack
5 Grounding the router
CAUTION: Make sure the ground point on the rack is connected reliably to a grounding strip in the equipment room. |
To ground the router:
1. Remove the grounding screws from the grounding point on the chassis.
2. Use the grounding screws to attach the two-hole grounding lug of the grounding cable to grounding point on the chassis.
3. Connect the ring terminal of the grounding cable to the grounding point on the rack.
Figure 5-1 Grounding the router
6 Installing power supplies
Installing DC power supplies
Available DC power supplies
The PSR2400-54D DC power supply is available for the router. Table 6-1 describes the PSR2400-54D DC power supply specifications.
Table 6-1 PSR2400-54D DC power supply specifications
Item |
Specification |
Rated input voltage |
–48 to –60 VDC |
Input voltage range |
–40 to –72 VDC |
Max input current |
80 A |
Rated output voltage |
54 VDC |
Max. output current |
44.5 A |
Max. output power |
2400 W |
Determine the number of DC power supplies based on the system power consumption and the DC power supply configuration based on the power input mode.
· As a best practice, configure N+M (M ≥ 1) DC power supply redundancy. Make sure N+M is not larger than the total number of power supply slots.
N is the number of DC power supplies.
· Make sure the total output power of the power supplies is greater than the system power consumption (with a 20% power surplus as a best practice).
· Provide a circuit breaker or fuse for power input of each DC power supply. Make sure each input line has a current carrying capacity not less than 100 A.
Installing a DC power supply
1. Thread a flat-blade screwdriver through the small handle on the filler panel and pull the filler panel out along the guide rails of the slot.
Figure 6-1 Removing a filler panel
2. Correctly orient the power supply.
3. Align the power supply with the power supply slot. Then slide the power supply along the guide rails into the slot until the latch locks the power supply in place.
Figure 6-2 Installing a DC power supply
Connecting a DC power cord
CAUTION: · Make sure each power cord has a separate circuit breaker. · Before you connect a power cord, turn off the circuit breaker for it. |
To connect a DC power cord:
1. Route the power cord along the cable ladder.
2. Connect the DC power cord connector to the DC input receptacle on the power supply.
3. Fasten the screw on the connector to secure the connector to the receptacle.
4. Connect the other end of the power cord to the DC power distribution panel in the equipment room, with the black wire connected to the positive terminal and the blue wire connected to the negative terminal.
The power supplies are installed along the right and left edges of the rear panel. As a best practice, route the power cords as shown in Figure 6-3.
5. Use cable clips every 250 mm (9.84 in) to bind the power cord to the rack.
6. Affix cable labels to the power cord 20 mm (0.79 in) to each end of the power cord.
Figure 6-3 Connecting a DC power cord
Installing AC power supplies
Available AC power supplies
The PSR2400-54A and PSR3000-54A power supplies are available for the router. Table 6-2 describes the available AC power supply specifications.
Table 6-2 Available AC power supply specifications
Item |
PSR2400-54A |
PSR3000-54A |
· AC power input: ¡ 100 to 130 VAC @ 60 Hz ¡ 200 to 240 VAC @ 50 Hz · High voltage DC power input: 240 VDC |
· AC power input: 90 to 264 VAC @ 47 to 63 Hz · High voltage DC power input: 190 to 320 VDC |
· AC power input: 90 to 290 VAC @ 47 to 63 Hz · High voltage DC power input: 190 to 320 VDC |
Rated input current |
16 A |
16 A |
54 VDC |
54 VDC |
44.5 A |
55.6 A |
Max. output power |
· 100 to 130 VAC @ 60 Hz: 1200 W · 200 to 240 VAC @ 50 Hz: 2400 W · 240 VDC: 2400 W |
· 100 to 130 VAC @ 60 Hz: 1200 W · 200 to 240 VAC @ 50 Hz: 3000 W · 240 VDC: 3000 W |
Determine the number of AC power supplies based on the system power consumption and the AC power supply configuration based on the power input mode.
· As a best practice, configure N+N (dual power sources) AC power supply redundancy. Make sure N+N is not larger than the total number of power supply slots.
N is the number of AC power supplies.
· Provide a circuit breaker for power input of each AC power supply. Make sure each circuit breaker has a current rating not less than 20 A.
Installing an AC power supply
1. Thread a flat-blade screwdriver through the small handle of the filler panel and pull the filler panel out along the guide rails of the slot.
Figure 6-4 Removing a filler panel
Figure 6-5 Installing an AC power supply
Connecting an AC power cord
To connect an AC power cord:
2. Connect the AC power cord female connector to the AC input receptacle on the power supply.
3. Use a releasable cable tie or Velcro strap to secure power cord to the handle of the AC power supply.
4. Connect the other end of the power cord to the AC power distribution panel in the equipment room.
Figure 6-6 Connecting an AC power cord (using a releasable cable tie)
7 Installing modules
Slot arrangement
The CR19000-16 router has an MPU section, interface module section, fabric module section, power supply section, and fan tray section.
"LPU" in Figure 7-1 refers to an interface module and "SFU" refers to a fabric module.
Figure 7-1 CR19000-16 router main sections
Installing MPUs
CAUTION: · The router supports active/standby MPU switchover. For the standby MPU to operate correctly, make sure the active and standby MPUs are the same model. · If you are not to install an MPU in an MPU slot, keep the filler panel in the slot. |
The router has two MPU slots. You can install one MPU, or two MPUs in 1+1 redundancy for the router.
To install an MPU:
1. Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2. Remove the filler panel from the target MPU slot.
Keep the removed filler panel secure for future use.
3. Open the ejector levers of the MPU.
4. Insert the MPU steadily into the slot along slide rails.
5. Continue to push the MPU by its middle part on the front panel until the ejector levers touch the slot edges tightly.
6. Close the ejector levers until they come in close contact with the front panel.
7. Use a Phillips screwdriver to fasten the captive screws on the MPU.
Installing interface modules
CAUTION: If you are not to install an interface module in an interface module slot, keep the filler panel in the slot. |
CAUTION: · Put the detachable ejector lever back on its holder after use and then attach it to the chassis or cabinet for future use. · The ejector lever holder is magnetic. Be aware of electromagnetic interference. · Do not use only one detachable ejector lever to install or remove an interface module. · Do not hold detachable ejector levers to lift an interface module. |
Figure 7-3 Detachable ejector lever
To install an interface module that uses detachable ejector levers:
1. Wear an ESD wrist strap. Make sure the wrist strap makes good skin contact and is reliably grounded.
2. Remove the filler panel from the target interface module slot.
3. Remove the protection box (if any) from the connector side of the interface module, as shown in Figure 7-4.
Keep the removed protection box secure for future use.
The number of screws for securing the protection box in Figure 7-4 is for illustration only and the actual number of screws on your interface module might differ from that.
Figure 7-4 Removing the protection box
4. Correctly orient the interface module. Align the module with the slot and push it steadily into the slot along the guide rails until about half of the module is in the slot.
Figure 7-5 Installing an interface module that uses detachable ejector levers
5. Attach the ejector lever holders to the chassis or cabinet and then remove the ejector levers from the holders.
6. Identify the "L" and "R" marks on the ejector levers and attach them to left and right ejector lever retainers of the interface module, with the lettering on the ejector levers facing upward.
Figure 7-6 Installing an ejector lever
7. Open the ejector levers and continue to push the module by its middle part on the front panel until you cannot push it any further.
8. As shown in Figure 7-7, close the ejector levers until they come in close contact with the front panel. Use a Phillips screwdriver to fasten the captive screws on the interface module.
Figure 7-7 Closing an ejector lever
9. As shown in Figure 7-8, press the spring tab on each ejector lever retainer to remove the ejector levers. Place the ejector lever back on their holders and keep them secure for future use.
Figure 7-8 Removing an ejector lever
3. Open the ejector levers of the module. Gently push the module into the slot along the guide rails.
4. Continue to push the module by its middle part on the front panel until you cannot push it any further. Then close the ejector levers.
5. Use a Phillips screwdriver to fasten the captive screws on the module.
6. Pivot up the ejector levers on the module.
Figure 7-9 Installing an interface module that uses general ejector levers
Installing interface subcards
For the interface subcard compatibility with interface modules, see H3C CR19000-16 Core Router Hardware Information and Specifications.
If you are not to install an interface subcard in a slot on an interface module, keep the filler panel in the slot.
To install an interface subcard:
2. Remove the filler panel from the target slot on the interface module.
3. Correctly orient the interface subcard and open the right ejector lever of the interface subcard.
4. Insert the interface subcard into the slot and push it steadily into the slot along slide rails.
5. Continue to push the interface subcard by its middle part on the front panel until you cannot push it any further.
6. Close the right ejector lever until it comes in close contact with the front panel.
7. Use a screwdriver to fasten the captive screw on the interface subcard.
Figure 7-10 Installing an interface subcard
The cable management brackets are to be installed along the left and right edges of the interface module slots.
To install a cable management bracket, insert the cable management bracket end that has a spring tab into the cable management bracket hole until the bracket has close contact with the hole, as shown in Figure 8-1.
Figure 8-1 Installing cable management brackets
NOTE: You must press the spring tab while removing a cable management bracket. |
9 Installing fabric modules
CAUTION: · If you are not to install a fabric module in a fabric module slot, keep the filler panel in the slot. · The router does not allow a mixture of different models of fabric modules. · When you install a fabric module, avoid touching the connectors on it. |
Installing a fabric module
The router provides six vertical fabric module slots at the rear and comes with all the fabric module slots empty.
The router supports N+1 fabric module redundancy. You can install two to six fabric modules for the router.
To install a fabric module:
1. Place the fabric module on a workbench and remove the protection box from the connector side of the fabric module.
Figure 9-1 Removing the protection box
2. Press the spring clip for each ejector lever of the fabric module to release the ejector levers.
3. Orient the fabric module with the "Up" sign facing up. Align the fabric module with the target slot and then insert it into the slot along the guide rails.
4. Continue to push the fabric module until the brakes on its ejector levers touch the slot edges tightly. Simultaneously close the two ejector levers until the spring clips lock the ejector levers in place.
Figure 9-2 Installing a fabric module
1. Loosen the captive screws on the ejector levers of the filler panel and then open the ejector levers.
2. Align the filler panel with the fabric module slot. Push the filler panel slowly into the slot along the guide rails.
3. Continue to push the filler panel until the brakes on its ejector levers touch the slot edges tightly. Then simultaneously close the ejector levers.
4. Fasten the captive screws on the ejector levers.
Figure 9-3 Installing a filler panel in a fabric module slot
10 Installing fan trays
CAUTION: · The fan tray is high and heavy. To avoid device damage, use two people to install or remove a fan tray. · To ensure adequate heat dissipation, make sure the router has two fan trays installed. |
IMPORTANT: A fan tray covers fabric module slots. Install fabric modules or filler panels in the fabric module slots before installing a fan tray. |
The procedure is the same for installing a fan tray in the FAN1 slot and FAN2 slot. The following procedure installs a fan tray in the FAN1 slot.
To install a fan tray:
2. Correctly orient the fan tray and align the fan tray with the fan tray slot.
3. Holding the fan tray handles, steadily insert the fan tray into the slot.
4. Fasten the captive screws on the fan tray.
Figure 10-1 Installing a fan tray
11 Connecting signal cables
WARNING! Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the router is operating. |
CAUTION: · Before installing a transceiver module, remove the optical fibers, if any, from it. For more information about installing transceiver modules, see the installation guide for the transceiver modules. · If you are not to use a fiber port or transceiver module, insert dust plugs into the port or module. If you are not to connect an optical fiber, install dust caps for the fiber connector. |
To install a transceiver module and optical fiber:
1. Wear an ESD wrist strap and make sure the wrist strap is reliably grounded.
2. Remove the dust plug from the target fiber port.
3. Pull the bail latch on the transceiver module upwards.
Skip this step if the bail latch is plastic.
4. Take the transceiver module by its two sides and align it with the fiber port.
5. Push the transceiver module gently into the port until it is firmly seated in the fiber port.
6. Remove the dust plug and dust cap from the transceiver module and fiber connector, respectively.
7. Connect the optical fiber to the transceiver module.
¡ LC connector—Align the connector with the transceiver module and push it into the transceiver module slightly until it clicks into place.
¡ MPO connector—Orient the connector with the white spot on it facing right. Insert the MPO fiber connector straight into the transceiver module and push it slightly forward until it clicks into place.
8. Use cable ties at a spacing of 150 mm (5.91 in) to bind optical fibers.
9. Label optical fibers according to the cable labeling specifications.
Figure 11-1 Installing a transceiver module and optical fiber (LC port)
Figure 11-2 Installing a transceiver module and optical fiber (MPO port)
Connecting cables to E1 ports
You can use an E1 cable to connect an E1 port (HM96 male connector). Typically, an E1 cable has an HD96 female connector at one end and multiple BNC, RJ-45, or SMB connectors at the other end.
When connecting an E1 cable, you might need also coaxial connectors and 75-ohm E1 adapter cables. No coaxial connectors and 75-ohm E1 adapter cables are provided with interface subcards. Purchase them yourself as needed.
Connecting an E1 cable
CAUTION: To avoid interface subcard or chassis damage, identify the target E1 port before your connection. Avoid connecting the cable to another port. |
Connecting an E1 120-ohm RJ-45 cable
1. Connect the HD96 connector of the E1 120-ohm cable to the HM96 connector on the interface subcard and fasten the screws on the connector.
2. Connect the RJ-45 connectors at the other end of the E1 cable to the peer device.
Connecting an E1 75-ohm BNC/SMB cable
The E1 75-ohm BNC cable and SMB cable use the same connection procedure. The following procedure connects an E1 75-ohm BNC cable.
To connect an E1 75-ohm BNC cable:
· If you do not need to extend the cable, perform these steps:
a. Connect the HD96 connector of the E1 75-ohm cable to the HM96 connector on the interface subcard and fasten the screws on the connector.
b. The other end of the cable provides multiple pairs of 75-ohm BNC connectors. Identify the number of each pair of BNC connectors. Connect the TX connector and the RX connector of the cable to the RX connector and the TX connector on the peer device, respectively.
Figure 11-3 Connecting an E1 75-ohm cable
· If you need to extend the cable, connect each BNC connector of the E1 75-ohm cable to a coaxial connector and then use an E1 75-ohm adapter cable to connect the coaxial connector to the peer device.
Figure 11-4 Connecting an E1 75-ohm cable (using coaxial connectors and 75-ohm adapter cables)
· If the impedance of the E1 port on the peer device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure 11-5 Connecting an E1 75-ohm cable (using an impedance converter)
Routing signal cables
The cable management brackets are installed along the left and right edges of the front panel. As a best practice, route signal cables along the cable management brackets as shown in Figure 11-6.
Figure 11-6 Routing signal cables
12 Verifying the installation
Table 12-1 Post-installation checklist
Item |
Requirements |
Installation location |
· No condensation is on the surface of the router or inside the router. · The router is clean and dust-free. · No packaging boxes, packaging bags, or other packaging materials are left around the chassis. · The air inlet and outlet vents of the router are not blocked, free of obstructions. |
Router |
· All components are installed correctly. · Each slot is installed with a module or filler panel. · Fan trays are installed correctly. |
Cables |
· The router is grounded reliably with the provided grounding cable. Both ends of the grounding cable are securely connected. · No switch or fuse is installed on the grounding cable. · The power cords are connected reliably and no short circuit has occurred in power input and output. · Power cords, grounding cables and fiber cables are routed and bound separately. · The cables are bound neatly with cable ties at an even distance. · The cable labels are correct, clear, and affixed to the cable in the same direction. |
Electricity safety |
· A circuit breaker is provided for each power input line. · Turn off the circuit breaker before you connect the power cord. · The power supply system can output enough voltage to ensure the normal operation of the router. · Locate the emergency power-off switch in the room before installation so you can quickly shut power off when an electrical accident occurs. |
13 Power-on check
WARNING! Locate the power switch in the equipment room before powering on the router so you can quickly shut power off when an electrical accident occurs. |
Power-on check flowchart
Figure 13-1 Power-on check flowchart
Checking the LEDs
After the router powers up, you can determine whether the router and the components are operating correctly by observing the LEDs on the MPUs and other components. When the router and components are operating correctly, the LEDs are as described in Table 13-1 and Table 13-2. If the LED states are not as described in Table 13-1 and Table 13-2, the router and components might be faulty.
For more information about the LEDs, see H3C CR19000-16 Core Router Hardware Information and Specifications.
Table 13-1 MPU LED descriptions
LED |
Status |
FAN |
OK |
Steady green |
All the fan trays are operating correctly. |
FAIL |
Off |
PWR |
OK |
Steady green |
All the installed power supplies are operating correctly. |
FAIL |
Off |
RUN |
Slow flashing green (4 Hz) |
The modules are loading software. To avoid damaging the modules, do not power off the router or hot swap the modules when the modules are loading software. |
Fast flashing green (0.5 Hz) |
The modules are operating correctly. |
ALM |
Off |
No alarm has occurred on the system |
ACT |
Steady green |
The MPU is in active mode. |
Off |
The MPU is in standby mode. |
Table 13-2 Module LED descriptions
LED |
Status |
Interface module LED |
RUN |
Fast flashing green (4 Hz) |
The interface module is loading software. |
Slow flashing green (0.5 Hz) |
The interface module is operating correctly. |
Fan tray LED |
OK |
Steady green |
The fan tray is in normal state. |
FAIL |
Off |
The fan tray is operating correctly. |
RUN |
The fabric module is operating correctly. |
The fabric module is loading software. |
ALM |
Off |
No alarm has occurred on the fabric module, or no fabric module is present. |
Fabric module LED |
RUN/ALM |
AC Power supply LED |
AC OK DC OK |
Steady green |
The power supply is operating correctly. |
DC Power supply LED |
INPUT OK OUTPUT OK |
Steady green |
