01-text | 154.66 KB |
1 About the PSR800-12AHD power supply
IMPORTANT: · The information in this document might differ from your product if it contains custom configuration options or features. · The figures in this document are for illustration only. · The model name of a hardware option in this document might differ slightly from its model name label. A model name label might add a prefix or suffix to the hardware-coded model name. For example, the PSR800-12AHD power supply model represents power supply labels including PSR800-12AHD and PSR800-12AHD-FIO, which have different suffixes. |
The PSR800-12AHD power supply supports AC input, high-voltage DC input, and DC output, and provides a maximum rated output of 800 W.
Figure1-1 PSR800-12AHD power supply
Figure1-2 Front panel
(1) Latch |
(2) Power supply LED |
(3) Power receptacle |
(4) Handle |
2 Key features
Protection
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output limit, output short circuit, and overtemperature conditions.
Redundancy
Multiple power supplies can be connected in parallel to achieve N+1 or N+N redundancy and load balancing.
Hot swapping
You can install or remove a power supply when the device is operating.
Tool free replacement
You can replace a power supply without using the tools.
3 Technical specifications
Table3-1 Technical specifications
Item |
Specifications |
Model |
PSR800-12AHD |
Rated input voltage range |
· 100 VAC to 240 VAC @ 800 W · 180 VDC to 400 VDC (240 HVDC or 336 HVDC power source) @ 800 W |
Maximum rated input current |
· 10 A @ 100 VAC to 240 VAC · 3.8 A @ 240 VDC |
Maximum rated output power |
800 W |
Efficiency at 50 % load |
80 Plus Platinum |
Temperature |
· Operating: 0°C to 50°C (32°F to 122°F) · Storage: –40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5% to 90% |
Maximum altitude |
5000 m (16404.20 ft) |
Redundancy |
Yes |
Cold backup |
Yes |
4 LEDs
Table4-1 Power supply LED description
LED status |
Steady green |
The power supply is operating correctly. |
Flashing green (1 Hz) |
Power is being input correctly but the system is not powered on. |
Flashing green (0.33 Hz) |
The power supply is in standby state and does not output power. |
Flashing green (2 Hz) |
The power supply is updating its firmware. |
Steady amber |
· The power supply is faulty. · The power supply does not have power input, but the other power supply has correct power input. |
Flashing amber (1 Hz) |
An alarm has occurred on the power supply. |
Off |
No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown. |
