01-Text | 209.89 KB |
1 About the GW-CRPS2000D power supply
IMPORTANT: · The information in this document might differ from your product if it contains custom configuration options or features. · The figures in this document are for illustration only. · The model name of a hardware option in this document might differ slightly from its model name label. A model name label might add a prefix or suffix to the hardware-coded model name. For example, the GW-CRPS2000D power supply model represents power supply labels including UN-GW-CRPS2000D that has a prefix added to GW-CRPS2000D. |
The GW-CRPS2000D is an AC input or high-voltage DC input and DC output power supply. It provides a maximum rated output of 2000 W.
Figure1-1 GW-CRPS2000D power supply
Figure1-2 Front panel
(1) LED |
(2) Latch |
(3) Power receptacle |
(4) Handle |
2 Key features
Protection
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output overcurrent, output short circuit, and overtemperature conditions.
Redundancy
Multiple power supplies can be connected in parallel to achieve N+1 or N+N redundancy and load balancing.
Hot swapping
You can install or remove a power supply when the device is operating.
Tool-free replacement
You can replace a power supply without using tools.
3 Technical specifications
Table3-1 Technical specifications
Item |
Specifications |
Model |
GW-CRPS2000D |
Rated input voltage range |
· 100 VAC to 127 VAC @ 1000 W · 200 VDC to 240 VDC @ 2000 W · 192 VDC to 230 VDC (240 HVDC power source) @ 1800 W · 230 VDC to 288 VDC (240 HVDC power source) @ 2000 W |
Maximum rated input current |
· 12.0 A @ 100 VAC to 127 VAC · 11.5 A @ 200 VAC to 220 VAC · 10.0 A @ 220 VAC to 240 VAC · 10 A @ 240 VAC |
Maximum rated output power |
2000 W |
Efficiency at 50 % load |
80 Plus Platinum |
Temperature |
· Operating: 0°C to 50°C (32°F to 122°F) · Storage: –40°C to +85°C (–40°F to +185°F) |
Operating humidity |
5% to 90% |
Maximum altitude |
5000 m (16404.20 ft) |
Redundancy |
Yes |
Cold backup |
Yes |
4 LEDs
Table4-1 LED description
LED status |
Steady green |
The power supply is operating correctly. |
Flashing green (1 Hz) |
Power is being input correctly but the system is not powered on. |
Flashing green (0.33 Hz) |
The power supply is in standby state and is not outputting power. |
Flashing green (2 Hz) |
The power supply is updating its firmware. |
Steady amber |
· The power supply is faulty. · The power supply is not receiving power, but the other power supply is receiving power. |
Flashing amber (1 Hz) |
An alarm has occurred on the power supply. |
Off |
The power supply is not receiving power. Either or both of the following conditions might exist: · Power cord connection failure. · Power source shutdown. |
5 Installing and removing the power supply
For information about installing and removing the power supply, see the user guide for the device.
