H3C DPS-1600AB-13 R Power Supply Manual-6W100
HomeSupportServersPower SupplyInstall & UpgradePower Supply ManualsH3C DPS-1600AB-13 R Power Supply Manual-6W100
Table of Contents
Related Documents
01-text
01-text 205.03 KB
1 About the DPS-1600AB-13 R power supply
IMPORTANT
IMPORTANT:
·     The information in this document might differ from your product if it contains custom configuration options or features.
·     The figures in this document are for illustration only.
·     The model name of a hardware option in this document might differ slightly from its model name label. A model name label might add a prefix or suffix to the hardware-coded model name. For example, the DPS-1600AB-13 R power supply model represents power supply labels including DPS-1600AB-13 R and DPS-1600AB-13 R-M, which have different suffixes.
The DPS-1600AB-13 R power supply supports AC input, high-voltage DC input, and DC output, and provides a maximum rated output of 1600 W.
Figure1-1 DPS-1600AB-13 R power supply
Figure1-2 Front panel
(1) Handle
(2) Power receptacle
(3) Latch
(4) Power supply LED
2 Key features
Protection
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output limit, output short circuit, and overtemperature conditions.
Redundancy
Multiple power supplies can be connected in parallel to achieve N+1 or N+N redundancy and load balancing.
Hot swapping
You can install or remove a power supply when the device is operating.
Tool free replacement
You can replace a power supply without using the tools.
3 Technical specifications
Table3-1 Technical specifications
Item
Specifications
Model
DPS-1600AB-13 R
Rated input voltage range
·     100 VAC to 127 VAC @ 1000 W
·     200 VAC to 240 VAC @ 1600 W
·     192 VDC to 288 VDC (240 HVDC power source) @ 1600 W
Maximum rated input current
·     13.8 A @ 100 VAC to 127 VAC
·     9.6 A @ 200 VAC to 240 VAC
Maximum rated output power
1600 W
Efficiency at 50 % load
80 Plus Platinum
Temperature
·     Operating: 0°C to 50°C (32°F to 122°F)
·     Storage: –40°C to +70°C (–40°F to +158°F)
Operating humidity
5% to 90%
Maximum altitude
5000 m (16404.20 ft)
Redundancy
Yes
Cold backup
Yes
4 LEDs
Table4-1 Power supply LED description
LED status
Steady green
The power supply is operating correctly.
Flashing green (1 Hz)
Power is being input correctly but the system is not powered on.
Flashing green (0.33 Hz)
The power supply is in standby state and does not output power.
Flashing green (2 Hz)
The power supply is updating its firmware.
Steady amber
·     The power supply is faulty.
·     The power supply does not have power input, but the other power supply has correct power input.
Flashing amber (1 Hz)
An alarm has occurred on the power supply.
Off
No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown.
5 Installing and removing the power supply
For information about installing and removing the power supply, see the user guide for the device.
  • Become a Partner
  • Partner Resources
