- 11-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-SNMP commands
- 05-RMON commands
- 06-Event MIB commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Mirroring commands
- 12-sFlow commands
- 13-Information center commands
- 14-Packet capture commands
- 15-VCF fabric commands
10-Process monitoring and maintenance commands | 259.37 KB |
display kernel deadloop configuration
display kernel starvation configuration
display process memory heap address
display process memory heap size
monitor kernel deadloop action
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
The display memory, display process, display process cpu, monitor process and monitor thread commands display information about both user processes and kernel threads. In these commands, "process" refers to both user processes and kernel threads.
display exception context
Use display exception context to display context information for process exceptions.
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
count value: Specifies the number of context information entries, in the range of 1 to 20. The default value is 1.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays context information for process exceptions on the IRF master device.
cpu cpu-number: Specifies a CPU by its number.
The system generates a context information entry for each process exception. A context information entry includes the process ID, the crash time, the core file directory, stack information, and register information.
# Display the exception context information on the x86-based 32-bit terminal.
<Sysname> display exception context
Index 1 of 1
Crashed PID: 120 (routed)
Crash signal: SIGBUS
Crash time: Tue Apr 9 17:14:30 2013
Core file path:
flash:/core/node0_routed_120_7_20130409-171430_1365527670.core
#0 0xb7caba4a
#1 0x0804cb79
#2 0xb7cd77c4
#3 0x08049f45
Backtrace stopped.
Registers' content
eax:0xfffffffc ebx:0x00000003 ecx:0xbfe244ec edx:0x0000000a
esp:0xbfe244b8 ebp:0xbfe244c8 esi:0xffffffff edi:0xbfe24674
eip:0xb7caba4a eflag:0x00000292 cs:0x00000073 ss:0x0000007b
ds:0x0000007b es:0x0000007b fs:0x00000000 gs:0x00000033
# Display the exception context information on the x86-based 64-bit terminal.
Index 1 of 1
Crashed PID: 121 (routed)
Crash time: Sun Mar 31 11:12:21 2013
Core file path:
flash:/core/node0_routed_121_7_20130331-111221_1364728341.core
#0 0x00007fae7dbad20c
#1 0x00000000004059fa
#2 0x00007fae7dbd96c0
#3 0x0000000000402b29
Backtrace stopped.
Registers' content
rax:0xfffffffffffffffc rbx:0x00007fff88a5dd10
rcx:0xffffffffffffffff rdx:0x000000000000000a
rsi:0x00007fff88a5dd10 rdi:0x0000000000000003
rbp:0x00007fff88a5dcf0 rsp:0x00007fff88a5dcf0
r8:0x00007fae7ea587e0 r9:0x0000000000000079
r10:0xffffffffffffffff r11:0x0000000000000246
r12:0x0000000000405b18 r13:0x00007fff88a5ff7a
r14:0x00007fff88a5de30 r15:0x0000000000000000
rip:0x00007fae7dbad20c flag:0x0000000000000246
cs:0x0000000000000033 ss:0x000000000000002b
ds:0x0000000000000000 es:0x0000000000000000
fs:0x0000000000000000 gs:0x0000000000000000
fs_base:0x00007fae80a5d6a0 gs_base:0x0000000000000000
orig_ax:0x00000000000000e8
# Display the exception context information on the PowerPC-based 32-bit terminal.
Index 1 of 1
Crashed PID: 133 (routed)
Crash time: Wed Apr 10 15:47:49 2013
Core file path:
flash:/core/node0_routed_133_7_20130410-154749_1365608869.core
#0 0x184720bc
#1 0x10006b4c
Backtrace stopped.
Registers' content
grp00: 0x000000ee 0x7ffd6ad0 0x1800f440 0x00000004
grp04: 0x7ffd6af8 0x0000000a 0xffffffff 0x184720bc
grp08: 0x0002d200 0x00000003 0x00000001 0x1847209c
grp12: 0x10006b4c 0x10020534 0xd6744100 0x00000000
grp16: 0x00000000 0xa0203ff0 0xa028b12c 0xa028b13c
grp20: 0xa028b148 0xa028b168 0xa028b178 0xa028b190
grp24: 0xa028b1a8 0xa028b1b8 0x00000000 0x7ffd6c08
grp28: 0x10006cac 0x7ffd6f92 0x184c1b84 0x7ffd6ae0
nip:0x184720bc lr:0x10006b4c cr:0x38000022 ctr:0x1847209c
msr:0x0002db00 xer:0x00000000 ret:0xfffffffc dsisr:0x08000000
gr3:0x00000003 mq:0x00000000 trap:0x00000c00 dar:0x1833114c
# Display the exception context information on the PowerPC-based 64-bit terminal.
Index 1 of 1
Crashed PID: 172 (routed)
Crash time: Sat Sep 15 16:53:16 2007
Core file path:
flash:/core/node1_routed_172_7_20070915-165316_1189875196.core
#0 0x00000fff803c66b4
#1 0x0000000010009b94
#2 0x00000fff80401814
Backtrace stopped.
Registers' content
grp00: 0x00000000000000ee 0x00000fffffd04840
grp02: 0x00000fff80425c28 0x0000000000000004
grp04: 0x00000fffffd048c0 0x000000000000000a
grp06: 0xffffffffffffffff 0x00000fff803c66b4
grp08: 0x000000008002d000 0x0000000000000000
grp10: 0x0000000000000000 0x0000000000000000
grp12: 0x0000000000000000 0x00000fff80a096b0
grp14: 0x000000007b964c00 0x000000007b7d0000
grp16: 0x0000000000000001 0x000000000000000b
grp18: 0x0000000000000031 0x0000000000a205b8
grp20: 0x0000000000a20677 0x0000000000000000
grp22: 0x000000007bb91014 0x0000000000000000
grp24: 0xc0000000005ae1c8 0x0000000000000000
grp26: 0xc0000001f00bff20 0xc0000001f00b0000
grp28: 0x00000fffffd04a30 0x000000001001aed8
grp30: 0x00000fffffd04fae 0x00000fffffd04840
nip:0x00000fff803c66b4 lr:0x0000000010009b94
cr:0x0000000058000482 ctr:0x00000fff803c66ac
msr:0x000000008002d000 xer:0x0000000000000000
ret:0xfffffffffffffffc dsisr:0x0000000000000000
gr3:0x0000000000000003 softe:0x0000000000000001
trap:0x0000000000000c00 dar:0x00000fff8059d14c
# Display the exception context information on the MIPS-based 32-bit terminal.
Index 1 of 1
Crashed PID: 182 (routed)
Crash time: Sun Jan 2 08:11:38 2013
Core file path:
flash:/core/node4_routed_182_10_20130102-081138_1293955898.core
#0 0x2af2faf4
#1 0x00406d8c
Backtrace stopped.
Registers' content
zero:0x00000000 at:0x1000dc00 v0:0x00000004 v1:0x00000003
a0:0x00000003 a1:0x7fd267e8 a2:0x0000000a a3:0x00000001
t0:0x00000000 t1:0xcf08fa14 t2:0x80230510 t3:0xfffffff8
t4:0x69766520 t5:0x00000000 t6:0x63cc6000 t7:0x44617461
s0:0x7fd26f81 s1:0x00401948 s2:0x7fd268f8 s3:0x803e1db0
s4:0x803e1da0 s5:0x803e1d88 s6:0x803e1d70 s7:0x803e1d60
t8:0x00000008 t9:0x2af2fae0 k0:0x00000000 k1:0x00000000
gp:0x2af9a3a0 sp:0x7fd267c0 s8:0x7fd267c0 ra:0x00406d8c
sr:0x0000dc13 lo:0xef9db265 hi:0x0000003f bad:0x2add2010
cause:0x00800020 pc:0x2af2faf4
# Display the exception context information on the MIPS-based 64-bit terminal.
Index 1 of 1
Crashed PID: 270 (routed)
Crash time: Wed Mar 27 12:39:12 2013
Core file path:
flash:/core/node16_routed_270_10_20130327-123912_1364387952.core
#0 0x0000005555a3bcb4
#1 0x0000000120006c1c
Backtrace stopped.
Registers' content
zero:0x0000000000000000 at:0x0000000000000014
v0:0x0000000000000004 v1:0x0000000000000003
a0:0x0000000000000003 a1:0x000000ffff899d90
a2:0x000000000000000a a3:0x0000000000000001
a4:0x0000005555a9b4e0 a5:0x0000000000000000
a6:0xffffffff8021349c a7:0x20696e206368616e
t0:0x0000000000000000 t1:0xffffffff80105068
t2:0xffffffff80213890 t3:0x0000000000000008
s0:0x0000005555a99c40 s1:0x000000ffff89af5f
s2:0x0000000120007320 s3:0x0000005555a5f470
s4:0x000000ffff899f80 s5:0xffffffff803cc6c0
s6:0xffffffff803cc6a8 s7:0xffffffff803cc690
t8:0x0000000000000002 t9:0x0000005555a3bc98
k0:0x0000000000000000 k1:0x0000000000000000
gp:0x0000000120020460 sp:0x000000ffff899d70
s8:0x000000ffff899d80 ra:0x0000000120006c1c
sr:0x000000000400fff3 lo:0xdf3b645a1cac08c9
hi:0x000000000000007f bad:0x000000555589ba84
cause:0x0000000000800020 pc:0x0000005555a3bcb4
Filed |
Crashed PID |
ID of the crashed process. |
Crash signal |
Signals that led to the crash: · SIGABRT—Abort. · SIGBUS—Bus error. · SIGFPE—Erroneous arithmetic operation. · SIGILL—Illegal hardware instructions. · SIGQUIT—Quit signal sent by the controlling terminal. · SIGSEGV—Invalid memory access. · SIGSYS—Invalid system call. · SIGTRAP—Trap message. · SIGXCPU—CPU usage limit exceeded. · SIGXFSZ—File size limit exceeded. · SIGUNKNOW—Unknown reason. |
Crash time |
Time when the crash occurred. |
Core file path |
Directory where the core file is saved. |
Backtrace stopped |
All stack information has been displayed. |
reset exception context
display exception filepath
Use display exception filepath to display the core file directory.
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays the core file directory on the IRF master device.
# Display the core file directory on the specified slot.
<Sysname> display exception filepath slot 1
The exception filepath on slot 1 is flash:.
Use display kernel deadloop to display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of deadloops to display, in the range of 1 to 20.
offset: Specifies the offset between the starting deadloop and the most recent deadloop, in the range of 0 to 19. The default value is 0.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays kernel thread deadloop information for the master device.
# Display brief information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1
----------------- Deadloop record 1 -----------------
Description : BUG: soft lockup - CPU#0 stuck for 61! [comsh: 16306]
Recorded at : 2013-05-01 11:16:00.823018
Occurred at : 2013-05-01 11:16:00.823018
Instruction address : 0x4004158c
Thread : comsh (TID: 16306)
Context : thread context
Slot : 1
Cpu : 0
VCPU ID : 0
Kernel module info : module name (mrpnc) module address (0xe332a000)
# Display detailed information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1 verbose
Slot : 1
Cpu : 0
VCPU ID : 0
Last 5 thread switches : migration/0 (11:16:00.823018)-->
swapper (11:16:00.833018)-->
kthreadd (11:16:00.833518)-->
swapper (11:16:00.833550)-->
disk (11:16:00.833560)
Register content:
Reg: r0, Val = 0x00000000 ; Reg: r1, Val = 0xe2be5ea0 ;
Reg: r2, Val = 0x00000000 ; Reg: r3, Val = 0x77777777 ;
Reg: r4, Val = 0x00000000 ; Reg: r5, Val = 0x00001492 ;
Reg: r6, Val = 0x00000000 ; Reg: r7, Val = 0x0000ffff ;
Reg: r8, Val = 0x77777777 ; Reg: r9, Val = 0x00000000 ;
Reg: r10, Val = 0x00000001 ; Reg: r11, Val = 0x0000002c ;
Reg: r12, Val = 0x057d9484 ; Reg: r13, Val = 0x00000000 ;
Reg: r14, Val = 0x00000000 ; Reg: r15, Val = 0x02000000 ;
Reg: r16, Val = 0xe2be5f00 ; Reg: r17, Val = 0x00000000 ;
Reg: r18, Val = 0x00000000 ; Reg: r19, Val = 0x00000000 ;
Reg: r20, Val = 0x024c10f8 ; Reg: r21, Val = 0x057d9244 ;
Reg: r22, Val = 0x00002000 ; Reg: r23, Val = 0x0000002c ;
Reg: r24, Val = 0x00000002 ; Reg: r25, Val = 0x24000024 ;
Reg: r26, Val = 0x00000000 ; Reg: r27, Val = 0x057d9484 ;
Reg: r28, Val = 0x0000002c ; Reg: r29, Val = 0x00000000 ;
Reg: r30, Val = 0x0000002c ; Reg: r31, Val = 0x00000000 ;
Reg: cr, Val = 0x84000028 ; Reg: nip, Val = 0x057d9550 ;
Reg: xer, Val = 0x00000000 ; Reg: lr, Val = 0x0186eff0 ;
Reg: ctr, Val = 0x682f7344 ; Reg: msr, Val = 0x00784b5c ;
Reg: trap, Val = 0x0000b030 ; Reg: dar, Val = 0x77777777 ;
Reg: dsisr, Val = 0x40000000 ; Reg: result, Val = 0x00020300 ;
Dump stack (total 1024 bytes, 16 bytes/line):
0xe2be5ea0: 02 be 5e c0 24 00 00 24 00 00 00 00 05 7d 94 84
0xe2be5eb0: 00 00 00 04 00 00 00 00 00 00 00 28 05 8d 34 c4
0xe2be5ec0: 02 be 60 a0 01 86 ef f0 00 00 00 00 00 00 00 00
0xe2be5ed0: 02 04 05 b4 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ee0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ef0: 95 47 73 35 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f00: a0 e1 64 21 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f10: 00 00 00 00 00 00 00 00 00 00 00 00 01 e9 00 00
0xe2be5f20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f30: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be5f40: 02 be 61 e0 00 00 00 02 00 00 00 00 02 44 b3 a4
0xe2be5f50: 02 be 5f 90 00 00 00 08 02 be 5f e0 00 00 00 08
0xe2be5f60: 02 be 5f 80 00 ac 1b 14 00 00 00 00 00 00 00 00
0xe2be5f70: 05 b4 5f 90 02 be 5f e0 00 00 00 30 02 be 5f e0
0xe2be5f80: 02 be 5f c0 00 ac 1b f4 00 00 00 00 02 45 00 00
0xe2be5f90: 00 03 00 00 00 00 00 00 02 be 5f e0 00 00 00 30
0xe2be5fa0: 02 be 5f c0 00 ac 1b 14 61 f1 2e ae 02 45 00 00
0xe2be5fb0: 02 44 b3 74 02 be 5f d0 00 00 00 30 02 be 5f e0
0xe2be5fc0: 02 be 60 60 01 74 ff f8 00 00 00 00 00 00 08 00
0xe2be5fd0: 02 be 5f f0 00 e8 93 7e 02 be 5f f8 02 be 5f fc
0xe2be5fe0: 00 00 00 00 00 00 00 00 00 00 00 00 02 be 60 18
0xe2be5ff0: 02 be 60 10 00 e9 65 98 00 00 00 58 00 00 2a 4f
0xe2be6000: 02 be 60 10 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6010: 02 be 60 40 00 e8 c6 a0 00 00 11 17 00 00 00 00
0xe2be6020: 02 be 60 40 00 00 00 00 00 00 00 00 02 be 60 98
0xe2be6030: 02 27 00 00 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6040: 02 be 60 60 00 00 00 01 00 00 b0 30 02 be 60 98
0xe2be6050: 00 00 00 04 02 21 00 00 00 00 00 00 01 e9 00 00
0xe2be6060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be6070: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be6080: 02 be 61 e0 00 00 00 02 00 00 00 00 02 be 61 70
0xe2be6090: 00 00 00 00 02 21 00 00 05 8d 34 c4 05 7d 92 44
Call trace:
Function Address = 0x8012a4b4
Function Address = 0x8017989c
Function Address = 0x80179b30
Function Address = 0x80127438
Function Address = 0x8012d734
Function Address = 0x80100a00
Function Address = 0xe0071004
Function Address = 0x8016ce0c
Function Address = 0x801223a0
Instruction dump:
41a2fe9c 812300ec 800200ec 7f890000 409efe8c 80010014 540b07b9 40a2fe80
4bfffe6c 80780290 7f64db78 4804ea35 <807f002c> 38800000 38a00080 3863000c
Description for the kernel thread deadloop, including the CPU number, thread running time, thread name, and thread number. |
Recorded at |
Time when the kernel thread deadloop was recorded, with microsecond precision. |
Occurred at |
Time when the kernel thread deadloop occurred, with microsecond precision. |
Instruction address |
Instruction address for the kernel thread deadloop. |
Thread |
Name and number of the kernel thread deadloop. |
Context |
Context for the kernel thread deadloop. |
Cpu |
Number of the CPU where the kernel thread ran. |
VCPU ID |
Number of the CPU core where the kernel thread ran. |
Kernel module info |
Information about kernel modules that had been loaded when the kernel thread deadloop was detected, including: · Module name—Kernel module name. · Module address—Memory address of the module. |
Last 5 thread switches |
Last five kernel thread switches on the CPU before the kernel thread deadloop was detected, including kernel thread name and kernel thread switching time with microsecond precision. |
Register content |
Register information: · Reg—Name of a register. · Val—Value saved in a register. |
Dump stack |
Stack information. |
Call trace |
Function call stack information, which shows the instruction address of a called function at each level. |
Instruction dump |
Instruction code when the kernel thread deadloop was detected. ffffffff indicates an illegitimate instruction code. |
No information to display |
No kernel thread deadloop information. |
reset kernel deadloop
Use display kernel deadloop configuration to display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays kernel thread deadloop detection configuration for the master device.
# Display kernel thread deadloop detection configuration.
<Sysname> display kernel deadloop configuration
Thread dead loop detection: Enabled
Dead loop timer (in seconds): 20
Dead loop core list: 0-1
Dead loop action: Record-only
Threads excluded from monitoring: 1
TID: 15 Name: co0
Dead loop timer (in seconds): n |
Time interval (in seconds) to identify a kernel thread deadloop. A kernel thread deadloop occurs if a kernel thread runs more than n seconds. |
Dead loop core list |
CPU cores for which kernel thread deadloop detection is performed. |
Dead loop action |
Action to be taken in response to a kernel thread deadloop: · Reboot—Logs the event and reboots the hardware. · Record-only—Logs the event. |
Threads excluded from monitoring |
Kernel threads excluded from kernel thread deadloop detection. This field appears only if the monitor kernel deadloop exclude-thread command is configured. |
Name |
Kernel thread name. |
TID |
Kernel thread number. |
No thread is excluded from monitoring |
All kernel threads are monitored by kernel thread deadloop detection. |
display kernel exception
Use display kernel exception to display kernel thread exception information.
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of kernel exceptions to display, in the range of 1 to 20.
offset: Specifies the offset between the starting exception and the most recent exception, in the range of 0 to 19. The default value is 0.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays kernel thread exception information for the master device.
If an exception occurs to a running kernel thread, the system automatically records the exception information.
# Display brief information about the most recent kernel thread exception.
<Sysname> display kernel exception 1
----------------- Exception record 1 -----------------
Description : Oops[#0]
Slot : 1
Cpu : 0
VCPU ID : 0
module name (disk) module address (0xe00bd000)
# Display detailed information about the most recent kernel thread exception.
<Sysname> display kernel exception 1 verbose
Slot : 1
Cpu : 0
VCPU ID : 0
module name (12500) module address (0xe00bd000)
Register content:
Call trace:
Instruction dump:
For more information about the command output, see Table 2.
reset kernel exception
display kernel reboot
Use display kernel reboot to display reboot information for member devices.
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of reboots to display, in the range of 1 to 20.
offset: Specifies the offset between the starting reboot and the most recent reboot, in the range of 0 to 19. The default value is 0.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays reboot information for the master device. Reboot information for member devices is recorded in the memory of the master device. If the master device is powered off, the reboot information is lost.
# Display brief information about the most recent reboot.
<Sysname> display kernel reboot 1
----------------- Reboot record 1 -----------------
Reason : 0x31
Slot : 1
Target Slot : 0
Cpu : 0
VCPU ID : 0
# Display detailed information about the most recent reboot.
<Sysname> display kernel reboot 1 verbose
Reason : 0x31
Slot : 1
Target Slot : 0
Cpu : 0
VCPU ID : 0
Call trace:
Recorded at |
Time when the reboot was recorded, with microsecond precision. |
Occurred at |
Time when the reboot occurred, with microsecond precision. |
Reason |
Reboot reason. |
Thread |
Name and number of the kernel thread that was running when the reboot occurred. |
Context |
Context where the reboot occurred. |
Slot |
Number of the slot that triggered the reboot. |
Target Slot |
Number of the rebooted slot. |
Cpu |
Number of the CPU that triggered the reboot. |
VCPU ID |
Number of the CPU core that triggered the reboot. |
Information about kernel modules that had been loaded when the reboot occurred, including the kernel module names and memory addresses. |
Last five kernel thread switches that occurred on the CPU before the reboot, including the kernel thread names and kernel thread switching time points, with microsecond precision. |
Dump stack |
Stack information for the threads that were running when the reboot occurred. |
Call trace |
Function call stack information. |
No reboot information exists. |
reset kernel reboot
Use display kernel starvation to display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of thread starvations to display, in the range of 1 to 20.
offset: Specifies the offset between the starting starvation and the most recent starvation, in the range of 0 to 19. The default value is 0.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays kernel thread starvation information for the master device.
# Display brief information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1
----------------- Starvation record 1 -----------------
Description : INFO: task comsh: 16306 blocked for more than 10 seconds.
Slot : 1
Cpu : 0
VCPU ID : 0
# Display detailed information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1 verbose
Slot : 1
Cpu : 0
VCPU ID : 0
Register content:
Call trace:
Instruction dump:
For detailed information about the command output, see Table 2.
reset kernel starvation
Use display kernel starvation configuration to display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays kernel thread starvation detection configuration for the master device.
# Display kernel thread starvation detection configuration.
<Sysname> display kernel starvation configuration
Thread starvation detection: Disabled
Starvation timer (in seconds): 10
TID: 123 Name: co0
Table 5 Command output
Starvation timer (in seconds): n |
Time interval (in seconds) to identify a kernel thread starvation. A kernel thread starvation occurs if a kernel thread does not run within n seconds. |
Kernel threads excluded from kernel thread starvation detection. |
Name |
TID |
display process
Use display process to display process state information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
all: Specifies all processes. With the all keyword or without any parameters, the command displays state information for all processes.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. Each process has a fixed job ID.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters that must not contain question marks or spaces.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command displays process state information for the master device.
# Display state information for the process scmd.
<Sysname> display process name scmd
Job ID: 1
PID: 1
Parent JID: 0
Parent PID: 0
Executable path: /sbin/scmd
Instance: 0
Respawn: OFF
Respawn count: 1
Max. spawns per minute: 0
Last started: Wed Jun 1 14:45:46 2013
Process state: sleeping
Max. core: 0
ARGS: -
TID LAST_CPU Stack PRI State HH:MM:SS:MSEC Name
1 0 0K 120 S 0:0:5:220 scmd
Table 6 Command output
Job ID |
Job ID of the process. The job ID never changes. |
PID |
Number of the process. The number identifies the process, and it might change as the process restarts. |
Parent JID |
Job ID of the parent process. |
Parent PID |
Number of the parent process. |
Executable path |
Executable path of the process. For a kernel thread, this field displays a hyphen (-). |
Instance |
Instance number of the process. Whether a process can run multiple instances depends on the software implementation. |
Respawn |
Indicates whether the process restarts when an error occurs: · ON—The process automatically restarts. · OFF—The process does not automatically restarts. |
Respawn count |
Times that the process has restarted. The starting value is 1. |
Max. spawns per minute |
Maximum number of times that the process can restart within one minute. If the threshold is reached, the system automatically shuts down the process. |
Last started |
Time when the most recent restart occurred. |
Process state |
State of the process: · running—Running or waiting in the queue. · sleeping—Interruptible sleep. · traced or stopped—Stopped. · uninterruptible sleep—Uninterruptible sleep. · zombie—The process has quit, but some resources are not released. |
Max. core |
Maximum number of core files that the process can create. 0 indicates that the process never creates a core file. A process creates a core file after it abnormally restarts. If the number of core files reaches the maximum value, no more core files are created. Core files are helpful for troubleshooting. |
ARGS |
Parameters carried by the process during startup. If the process carries no parameters, this field displays a hyphen (-). |
TID |
Thread ID. |
LAST_CPU |
Number of the CPU on which the process is last scheduled. |
Stack |
Stack size. |
PRI |
Thread priority. |
State |
Thread state: · R—Running. · S—Sleeping. · T—Traced or stopped. · D—Uninterruptible sleep. · Z—Zombie. |
HH:MM:SS:MSEC |
Running time since the most recent start. |
Name |
Process name. |
# Display state information for all processes.
<Sysname> display process all
JID PID %CPU %MEM STAT PRI THIRD TTY HH:MM:SS COMMAND
1 1 0.0 0.0 S 120 N - 00:00:04 scmd
2 2 0.0 0.0 S 115 N - 00:00:00 [kthreadd]
3 3 0.0 0.0 S 99 N - 00:00:00 [migration/0]
4 4 0.0 0.0 S 115 N - 00:00:05 [ksoftirqd/0]
5 5 0.0 0.0 S 99 N - 00:00:00 [watchdog/0]
6 6 0.0 0.0 S 115 N - 00:00:00 [events/0]
7 7 0.0 0.0 S 115 N - 00:00:00 [khelper]
8 8 0.0 0.0 S 115 N - 00:00:00 [kblockd/0]
9 9 0.0 0.0 S 115 N - 00:00:00 [ata/0]
10 10 0.0 0.0 S 115 N - 00:00:00 [ata_aux]
11 11 0.0 0.0 S 115 N - 00:00:00 [kseriod]
12 12 0.0 0.0 S 120 N - 00:00:00 [vzmond]
13 13 0.0 0.0 S 120 N - 00:00:00 [pdflush]
14 14 0.0 0.0 S 120 N - 00:00:00 [pdflush]
15 15 0.0 0.0 S 115 N - 00:00:00 [kswapd0]
16 16 0.0 0.0 S 115 N - 00:00:00 [aio/0]
17 17 0.0 0.0 S 115 N - 00:00:00 [scsi_eh_0]
18 18 0.0 0.0 S 115 N - 00:00:00 [scsi_eh_1]
19 19 0.0 0.0 S 115 N - 00:00:00 [scsi_eh_2]
35 35 0.0 0.0 D 100 N - 00:00:00 [lipc_topology]
---- More ----
Table 7 Command output
JID |
Job ID of a process. It never changes. |
PID |
Number of a process. |
%CPU |
CPU usage in percentage (%). |
%MEM |
Memory usage in percentage (%). |
STAT |
State of a process: · R—Running. · S—Sleeping. · T—Traced or stopped. · D—Uninterruptible sleep. · Z—Zombie. |
PRI |
Priority of a process for scheduling. |
THIRD |
Whether the process is a third party process: · Y—The process is a third party process. · N—The process is not a third party process. |
TTY |
TTY used by a process. |
HH:MM:SS |
COMMAND |
Name and parameters of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
display process cpu
Use display process cpu to display CPU usage for all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for the master device.
# Display CPU usage for all processes.
<Sysname> display process cpu
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
JID 5Sec 1Min 5Min Name
1 0.0% 0.0% 0.0% scmd
2 0.0% 0.0% 0.0% [kthreadd]
3 0.1% 0.0% 0.0% [ksoftirqd/0]
Table 8 Command output
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7% |
System CPU usage within the last 5 seconds, 1 minute, and 5 minutes. |
JID |
5Sec |
CPU usage of the process within the last 5 seconds. |
1Min |
CPU usage of the process within the last minute. |
5Min |
CPU usage of the process within the last 5 minutes. |
Name |
Name of the process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
display process log
Use display process log to display log information for all user processes.
display process log [ slot slot-number [ cpu cpu-number ] ]
# Display log information for all user processes.
<Sysname> display process log
Process JobID PID Abort Core Exit Kill StartTime EndTime
knotify 92 92 N N 0 36 12-17 07:10:27 12-17 07:10:27
knotify 93 93 N N 0 -- 12-17 07:10:27 12-17 07:10:27
automount 94 94 N N 0 -- 12-17 07:10:27 12-17 07:10:28
knotify 111 111 N N 0 -- 12-17 07:10:28 12-17 07:10:28
comsh 121 121 N N 0 -- 12-17 07:10:30 12-17 07:10:30
knotify 152 152 N N 0 -- 12-17 07:10:31 12-17 07:10:31
autocfgd 155 155 N N 0 -- 12-17 07:10:31 12-17 07:10:31
pkg_update 122 122 N N 0 -- 12-17 07:10:30 12-17 07:10:31
Table 9 Command output
Process |
Name of a user process. |
JobID |
Job ID of a user process. |
PID |
Abort |
Indicates whether the process exited abnormally: · Y—Yes. · N—No. |
Core |
Indicates whether the process can generate core files: · Y—Yes. · N—No. |
Exit |
Process exit code. This field displays two hyphens (--) if the process was killed by a signal. |
Kill |
Code of the signal that killed the process. This field displays two hyphens (--) if the process exited instead of being killed. |
StartTime |
Time when the user process started. |
EndTime |
Time when the user process ended. |
Use display process memory to display memory usage for all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
When a user process starts, it requests the following types of memory from the system:
· Text memory—Stores code for the user process.
· Data memory—Stores data for the user process.
· Stack memory—Stores temporary data.
· Dynamic memory—Heap memory dynamically assigned and released by the system according to the needs of the user process. To view dynamic memory information, execute the display process memory heap command.
# Display memory usage for all user processes.
<Sysname> display process memory
JID Text Data Stack Dynamic Name
1 384 1800 16 36 scmd
2 0 0 0 0 [kthreadd]
3 0 0 0 0 [ksoftirqd/0]
4 0 0 0 0 [watchdog/0]
5 0 0 0 0 [events/0]
6 0 0 0 0 [khelper]
29 0 0 0 0 [kblockd/0]
49 0 0 0 0 [vzmond]
52 0 0 0 0 [pdflush]
---- More ----
Table 10 Command output
JID |
Text |
Text memory used by the user process, in KB. The value for a kernel thread is 0. |
Data |
Data memory used by the user process, in KB. The value for a kernel thread is 0. |
Stack |
Stack memory used by the user process, in KB. The value for a kernel thread is 0. |
Dynamic |
Dynamic memory used by the user process, in KB. The value for a kernel thread is 0. |
Name |
Name of the user process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
Use display process memory heap to display heap memory usage for a user process.
display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a user process by its job ID, in the range of 1 to 2147483647.
Heap memory comprises fixed-sized blocks such as 16-byte or 64-byte blocks. It stores data and variables used by the user process. When a user process starts, the system dynamically allocates heap memory to the process.
Each memory block has an address represented in hexadecimal format, which can be used to access the memory block. You can view memory block addresses by using the display process memory heap size command, and view memory block contents by using the display process memory heap address command.
# Display brief information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1
Total virtual memory heap space(in bytes) : 2228224
Total physical memory heap space(in bytes) : 262144
Total allocated memory(in bytes) : 161576
# Display detailed information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1 verbose
Heap usage:
Size Free Used Total Free Ratio
16 8 52 60 13%
64 3 1262 1265 0.2%
128 2 207 209 1%
512 3 55 58 5.1%
4096 3 297 300 1%
8192 1 19 20 5%
81920 0 1 1 0%
Summary:
Total virtual memory heap space (in bytes) : 2293760
Total physical memory heap space (in bytes) : 58368
Total allocated memory (in bytes) : 42368
Table 11 Command output
Size |
Size of each memory block, in bytes. |
Free |
Number of free memory blocks. |
Used |
Number of used memory blocks. |
Total |
Total number of memory blocks. |
Free Ratio |
Ratio of free memory to total memory. It helps identify fragment information. |
Use display process memory heap address to display heap memory content starting from a specified memory block for a process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
address starting-address: Specifies the starting memory block by its address.
length memory-length: Specifies the memory block length in the range of 1 to 1024 bytes.
When a user process runs abnormally, the command helps locate the problem.
# Display 128-byte memory block content starting from the memory block 0xb7e30580 for the process job 1.
<Sysname> display process memory heap job 1 address b7e30580 length 128
B7E30580: 14 00 EF FF 00 00 00 00 E4 39 E2 B7 7C 05 E3 B7 .........9..|...
B7E30590: 14 00 EF FF 2F 73 62 69 6E 2F 73 6C 62 67 64 00 ..../sbin/slbgd.
B7E305A0: 14 00 EF FF 00 00 00 00 44 3B E2 B7 8C 05 E3 B7 ........D;......
B7E305B0: 14 00 EF FF 2F 73 62 69 6E 2F 6F 73 70 66 64 00 ..../sbin/ospfd.
B7E305C0: 14 00 EF FF 00 00 00 00 A4 3C E2 B7 AC 05 E3 B7 .........<......
B7E305D0: 14 00 EF FF 2F 73 62 69 6E 2F 6D 73 74 70 64 00 ..../sbin/mstpd.
B7E305E0: 14 00 EF FF 00 00 00 00 04 3E E2 B7 CC 05 E3 B7 .........>......
B7E305F0: 14 00 EF FF 2F 73 62 69 6E 2F 6E 74 70 64 00 00 ..../sbin/ntpd..
Use display process memory heap size to display the addresses of heap memory blocks with a specified size used by a process.
display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
size memory-size: Specifies the memory block size in the range of 1 to 4294967295.
offset offset-size: Specifies an offset in the range of 0 to 4294967295. The default value is 128. For example, suppose the system allocates 100 16-byte memory blocks to process job 1, and the process has used 66 blocks. Then if you execute the display process memory heap job 1 size 16 offset 50 command, the output shows the addresses of the 51st through 66th 16-byte blocks used by the process.
The command displays memory block addresses in hexadecimal format. To view memory block content, execute the display process memory heap address command.
# Display the addresses of 16-byte memory blocks used by process job 1.
<Sysname> display process memory heap job 1 size 16
0xb7e300c0 0xb7e300d0 0xb7e300e0 0xb7e300f0
0xb7e30100 0xb7e30110 0xb7e30120 0xb7e30130
0xb7e30140 0xb7e30150 0xb7e30160 0xb7e30170
0xb7e30180 0xb7e30190 0xb7e301a0 0xb7e301b0
0xb7e301c0 0xb7e301d0 0xb7e301e0 0xb7e301f0
0xb7e30200 0xb7e30210 0xb7e30220 0xb7e30230
# Display the addresses of 16-byte memory blocks starting from the fifth block used by process job 1.
<Sysname> display process memory heap job 1 size 16 offset 4
exception filepath
Use exception filepath to specify the directory for saving core files.
Use undo exception filepath to remove the specified directory.
exception filepath directory
undo exception filepath directory
The directory for saving core files is flash:.
directory: Specifies the directory for saving core files.
The specified directory must be the root directory of a file system on the master.
You can use the command to change the directory if there are different types of storage media on the device.
The system saves core files to the core directory in the specified directory. If the core directory does not exist in the specified directory, the system creates the core directory before saving core files.
If no directory is specified or the specified directory is not accessible, the system cannot save core files.
# Specify the directory for saving core files as flash:/.
<Sysname> exception filepath flash:/
process core
Use monitor kernel deadloop action to specify the action to be taken in response to a kernel thread deadloop.
Use undo monitor kernel deadloop action to restore the default.
monitor kernel deadloop action { reboot | record-only } [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop action [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop protection action is record-only.
reboot: Logs the event and reboots the specified slot or CPU.
record-only: Logs the event.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command specifies the action for the master device.
Use this command only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
# Set the kernel thread deadloop protection action to reboot for slot 1.
[Sysname] monitor kernel deadloop action reboot slot 1
Use monitor kernel deadloop enable to enable kernel thread deadloop detection.
Use undo monitor kernel deadloop enable to disable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
undo monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection is enabled.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the master device is specified.
core core-number&<1-64> ]: Specifies a maximum of 64 CPU cores. If you do not specify this option, the command applies to all cores of the specified CPU.
CAUTION: Use this command only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged. |
Kernel threads share resources in kernel space. If a kernel thread monopolizes the CPU for a long time, other threads cannot run, resulting in a deadloop.
This command enables the device to detect deadloops. If a thread occupies the CPU regularly, the device considers that a deadloop has occurred.
# Enable kernel thread deadloop detection.
[Sysname] monitor kernel deadloop enable
monitor kernel deadloop time
Use monitor kernel deadloop exclude-thread to disable kernel thread deadloop detection for a kernel thread.
Use undo monitor kernel deadloop exclude-thread to enable kernel thread deadloop detection for a kernel thread.
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection monitors all kernel threads.
tid: Specifies a kernel thread by its ID, in the range of 1 to 2147483647. If no kernel thread is specified for the undo command, the default is restored.
Inappropriate use of the command can cause service problems or system breakdown. Make sure you understand the impact of the command on your network before you use it.
You can disable kernel thread deadloop detection for up to 128 kernel threads by executing the command.
# Disable kernel thread deadloop detection for kernel thread 15.
[Sysname]monitor kernel deadloop exclude-thread 15
Use monitor kernel deadloop time to set the interval for identifying a kernel thread deadloop.
Use undo monitor kernel deadloop time to restore the default.
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop time [ slot slot-number [ cpu cpu-number ] ]
The interval for identifying a kernel thread deadloop is 20 seconds.
time time: Specifies the interval for identifying a kernel thread deadloop, in the range of 1 to 65535 seconds.
If a kernel thread runs for the specified interval, kernel thread deadloop detection considers that a deadloop has occurred.
# Set the interval for identifying a kernel thread deadloop to 8 seconds.
[Sysname] monitor kernel deadloop time 8
Use monitor kernel starvation enable to enable kernel thread starvation detection.
Use undo monitor kernel starvation enable to disable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection is disabled.
Starvation occurs when a thread is unable to access shared resources.
The command enables the system to detect and report thread starvation. If a thread is not executed within an interval, the system considers that a starvation has occurred, and outputs a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
# Enable kernel thread starvation detection.
[Sysname] monitor kernel starvation enable
Use monitor kernel starvation exclude-thread to disable kernel thread starvation detection for a kernel thread.
Use undo monitor kernel starvation exclude-thread to enable kernel thread starvation detection for a kernel thread.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection, if enabled, monitors all kernel threads.
You can disable kernel thread starvation detection for up to 128 kernel threads by executing the command.
# Disable kernel thread starvation detection for kernel thread 15.
[Sysname] monitor kernel starvation exclude-thread 15
Use monitor kernel starvation time to set the interval for identifying a kernel thread starvation.
Use undo monitor kernel starvation time to restore the default.
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation time [ slot slot-number [ cpu cpu-number ] ]
The interval for identifying a kernel thread starvation is 120 seconds.
time time: Specifies the interval for identifying a kernel thread starvation, in the range of 1 to 65535 seconds.
If a thread is not executed within the specified interval, the system considers that a starvation has occurred, and outputs a starvation message.
# Set the interval for identifying a kernel thread starvation to 120 seconds.
[Sysname] monitor kernel starvation time 120
monitor process
Use monitor process to display process statistics.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays process statistics in descending order of CPU usage without refreshing statistics. If you do not specify this keyword, the command displays statistics for the top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times and process statistics are refreshed every 5 seconds.
If you do not specify the dumbtty keyword, the command displays process statistics in an interactive mode. In this mode, the system automatically determines the number of displayed processes according to the screen size, and does not display exceeding processes. You can also input interactive commands as shown in Table 12 to perform relevant operations.
Commands |
? or h |
Displays help information that includes available interactive commands. |
1 |
Displays state information for physical CPUs. For example, if you enter 1 for the first time, the state of each physical CPU is displayed in a separate row. If you enter 1 again, the average value of all CPU states is displayed. If you enter 1 for the third time, separate states are displayed. By default, the average value of all CPU states is displayed. |
c |
Sorts processes by CPU usage in descending order, which is the default setting. |
d |
Sets the interval for refreshing process statistics, in the range of 1 to 2147483647 seconds. The default value is 5 seconds. |
f |
Sorts processes by the number of open files in descending order. Files are identified by file descriptors (FDs). |
k |
Kills a process. Because the command can impact system operation, be cautious to use it. |
l |
Refreshes the screen. |
m |
Sorts processes by memory usage in descending order. |
n |
Changes the maximum number of processes displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only processes not exceeding the screen size can be displayed. |
q |
Quits the interactive mode. |
t |
Sorts processes by running time in descending order. |
Moves sort field to the next left column. |
Moves sort field to the next right column. |
# Display process statistics in dumbtty mode. In this mode, the system displays process statistics once, and then returns to command view.
<Sysname> monitor process dumbtty
76 processes; 103 threads; 687 fds
Thread states: 1 running, 102 sleeping, 0 stopped, 0 zombie
CPU states: 77.16% idle, 0.00% user, 14.96% kernel, 7.87% interrupt
Memory: 496M total, 341M available, page size 4K
JID PID PRI State FDs MEM HH:MM:SS CPU Name
1047 1047 120 R 9 1420K 00:02:23 13.53% diagd
1 1 120 S 17 1092K 00:00:20 7.61% scmd
1000 1000 115 S 0 0K 00:00:09 0.84% [sock/1]
1026 1026 120 S 20 26044K 00:00:05 0.84% syslogd
2 2 115 S 0 0K 00:00:00 0.00% [kthreadd]
3 3 99 S 0 0K 00:00:00 0.00% [migration/0]
4 4 115 S 0 0K 00:00:06 0.00% [ksoftirqd/0]
5 5 99 S 0 0K 00:00:00 0.00% [watchdog/0]
6 6 115 S 0 0K 00:00:01 0.00% [events/0]
7 7 115 S 0 0K 00:00:00 0.00% [khelper]
4797 4797 120 S 8 28832K 00:00:02 0.00% comsh
5117 5117 120 S 8 1496K 00:00:00 0.00% top
<Sysname>
# Display process statistics twice in dumbtty mode.
<Sysname> monitor process dumbtty iteration 2
CPU states: 44.84% idle, 0.51% user, 39.17% kernel, 15.46% interrupt
1047 1047 120 R 9 1420K 00:02:30 37.11% diagd
1 1 120 S 17 1092K 00:00:21 11.34% scmd
1000 1000 115 S 0 0K 00:00:09 2.06% [sock/1]
1026 1026 120 S 20 26044K 00:00:05 1.54% syslogd
1027 1027 120 S 12 9280K 00:01:12 1.03% devd
4 4 115 S 0 0K 00:00:06 0.51% [ksoftirqd/0]
1009 1009 115 S 0 0K 00:00:08 0.51% [karp/1]
1010 1010 115 S 0 0K 00:00:13 0.51% [kND/1]
5373 5373 120 S 8 1496K 00:00:00 0.51% top
4796 4796 120 S 11 2744K 00:00:00 0.00% login
4797 4797 120 S 8 28832K 00:00:03 0.00% comsh
Five seconds later, the system refreshes process statistics as follows (which is the same as executing the monitor process dumbtty command twice at a 5-second interval):
CPU states: 78.71% idle, 0.16% user, 14.86% kernel, 6.25% interrupt
1047 1047 120 R 9 1420K 00:02:31 14.25% diagd
1 1 120 S 17 1092K 00:00:21 4.25% scmd
1027 1027 120 S 12 9280K 00:01:12 1.29% devd
1000 1000 115 S 0 0K 00:00:09 0.37% [sock/1]
5373 5373 120 S 8 1500K 00:00:00 0.37% top
6 6 115 S 0 0K 00:00:01 0.18% [events/0]
1009 1009 115 S 0 0K 00:00:08 0.18% [karp/1]
1010 1010 115 S 0 0K 00:00:13 0.18% [kND/1]
4795 4795 120 S 11 2372K 00:00:01 0.18% telnetd
<Sysname>
# Display process statistics in interactive mode.
CPU states: 78.98% idle, 0.16% user, 14.57% kernel, 6.27% interrupt
1047 1047 120 R 9 1420K 00:02:39 14.13% diagd
1 1 120 S 17 1092K 00:00:23 3.98% scmd
1027 1027 120 S 12 9280K 00:01:13 1.44% devd
1000 1000 115 S 0 0K 00:00:09 0.36% [sock/1]
1009 1009 115 S 0 0K 00:00:09 0.36% [karp/1]
4 4 115 S 0 0K 00:00:06 0.18% [ksoftirqd/0]
5491 5491 120 S 8 1500K 00:00:00 0.18% top
The system refreshes process statistics every 5 seconds. You can enter interactive commands to perform operation as follows:
· Enter h or a question mark (?) to display help information as follows:
Help for interactive commands:
?,h Show the available interactive commands
1 Toggle SMP view: '1' single/separate states
c Sort by the CPU field(default)
d Set the delay interval between screen updates
f Sort by number of open files
k Kill a job
l Refresh the screen
m Sort by memory used
n Set the maximum number of processes to display
q Quit the interactive display
t Sort by run time of processes since last restart
< Move sort field to the next left column
> Move sort field to the next right column
Press any key to continue
· Enter d, and then enter a number to modify the refresh interval. If you enter 3, statistics are refreshed every 3 seconds.
Enter the delay interval between updates(1~2147483647): 3
· Enter n, and then enter a number to modify the maximum number of displayed processes. If you enter 5, statistics for five processes are displayed.
Enter the max number of processes to display(0 means unlimited): 5
87 processes; 113 threads; 735 fds
Thread states: 2 running, 111 sleeping, 0 stopped, 0 zombie
CPU states: 86.57% idle, 0.83% user, 11.74% kernel, 0.83% interrupt
Memory: 755M total, 414M available, page size 4K
864 864 120 S 24 27020K 00:00:43 8.95% syslogd
1173 1173 120 R 24 2664K 00:00:01 2.37% top
866 866 120 S 18 10276K 00:00:09 0.69% devd
1 1 120 S 16 1968K 00:00:04 0.41% scmd
881 881 120 S 8 2420K 00:00:07 0.41% diagd
· Enter f to sort processes by FDs in descending order. (You can also enter command c, m, or t to sort processes.)
Thread states: 1 running, 112 sleeping, 0 stopped, 0 zombie
CPU states: 90.66% idle, 0.88% user, 5.77% kernel, 2.66% interrupt
862 862 120 S 61 5384K 00:00:01 0.00% dbmd
905 905 120 S 35 2464K 00:00:02 0.00% ipbased
863 863 120 S 31 1956K 00:00:00 0.00% had
884 884 120 S 31 30600K 00:00:00 0.00% lsmd
889 889 120 S 29 61592K 00:00:00 0.00% routed
· Enter k and then enter a JID to kill a process. If you enter 884, the process with the JID of 884 is killed.
Enter the JID to kill: 884
84 processes; 107 threads; 683 fds
Thread states: 1 running, 106 sleeping, 0 stopped, 0 zombie
CPU states: 59.03% idle, 1.92% user, 37.88% kernel, 1.15% interrupt
Memory: 755M total, 419M available, page size 4K
862 862 120 S 56 5384K 00:00:01 0.00% dbmd
863 863 120 S 30 1956K 00:00:00 0.00% had
1160 1160 120 S 28 23096K 00:00:01 0.19% sshd
· Enter q to quit interactive mode.
Table 13 Command output
84 processes; 107 threads; 683 fds |
Numbers of processes, threads, and open files. |
JID |
Job ID of a process, which never changes. |
PID |
ID of a process. |
PRI |
Priority level of a process. |
State |
FDs |
Number of open files for a process. |
MEM |
Memory usage. It displays 0 for a kernel thread. |
HH:MM:SS |
Running time of a process since last restart. |
CPU |
CPU usage of a process. |
Name |
Name of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
monitor thread
Use monitor thread to display thread statistics.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays all thread statistics in descending order of CPU usage without refreshing statistics. If you do not specify the keyword, the command displays statistics for top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times.
If you do not specify the dumbtty keyword, the command displays thread statistics in an interactive mode. In this mode, the system automatically determines the number of displayed thread processes according to the screen size and does not display exceeding processes. You can also input interactive commands as shown in Table 14 to perform relevant operations.
Commands |
? or h |
d |
Sets the interval for refreshing statistics. The default interval is 5 seconds. |
k |
Kills a process. Because the command can impact system operation, be cautious when you use it. |
l |
n |
Changes the maximum number of threads displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only threads not exceeding the screen size can be displayed. |
q |
Quits interactive mode. |
# Display thread statistics in dumbtty mode.
<Sysname> monitor thread dumbtty
CPU states: 83.19% idle, 1.68% user, 10.08% kernel, 5.04% interrupt
Memory: 755M total, 417M available, page size 4K
JID TID LAST_CPU PRI State HH:MM:SS MAX CPU Name
1175 1175 0 120 R 00:00:00 1 10.75% top
1 1 0 120 S 00:00:06 1 2.68% scmd
881 881 0 120 S 00:00:09 1 2.01% diagd
776 776 0 120 S 00:00:01 0 0.67% [DEVD]
866 866 0 120 S 00:00:11 1 0.67% devd
2 2 0 115 S 00:00:00 0 0.00% [kthreadd]
3 3 0 115 S 00:00:01 0 0.00% [ksoftirqd/0]
4 4 0 99 S 00:00:00 1 0.00% [watchdog/0]
5 5 0 115 S 00:00:00 0 0.00% [events/0]
6 6 0 115 S 00:00:00 0 0.00% [khelper]
796 796 0 115 S 00:00:00 0 0.00% [kip6fs/1]
<Sysname>
# Display thread statistics in interactive mode.
CPU states: 94.43% idle, 0.76% user, 3.64% kernel, 1.15% interrupt
1176 1176 0 120 R 00:00:01 1 3.42% top
866 866 0 120 S 00:00:12 1 0.85% devd
881 881 0 120 S 00:00:09 1 0.64% diagd
1 1 0 120 S 00:00:06 1 0.42% scmd
1160 1160 0 120 S 00:00:01 1 0.21% sshd
k Kill a job
n Set the maximum number of threads to display
t Sort by run time of threads since last restart
Enter the delay interval between screen updates (1~2147483647): 3
· Enter n, and then enter a number to modify the maximum number of displayed threads. If you enter 5, statistics for five threads are displayed.
Enter the max number of threads to display(0 means unlimited): 5
CPU states: 93.26% idle, 0.99% user, 4.23% kernel, 1.49% interrupt
1176 1176 0 120 R 00:00:02 1 3.71% top
1 1 0 120 S 00:00:06 1 0.92% scmd
866 866 0 120 S 00:00:13 1 0.69% devd
881 881 0 120 S 00:00:10 1 0.69% diagd
720 720 0 115 D 00:00:01 0 0.23% [TMTH]
· Enter k and then enter a JID to kill a thread. If you enter 881, the thread with the JID of 881 is killed.
Enter the JID to kill: 881
83 processes; 106 threads
Thread states: 1 running, 105 sleeping, 0 stopped, 0 zombie
CPU states: 96.26% idle, 0.54% user, 2.63% kernel, 0.54% interrupt
Memory: 755M total, 418M available, page size 4K
1176 1176 0 120 R 00:00:04 1 1.86% top
866 866 0 120 S 00:00:14 1 0.87% devd
1 1 0 120 S 00:00:07 1 0.49% scmd
730 730 0 0 S 00:00:04 1 0.12% [DIBC]
762 762 0 120 S 00:00:22 1 0.12% [MNET]
Table 15 Command output
84 processes; 107 threads |
Numbers of processes and threads. |
JID |
Job ID of a thread, which never changes. |
TID |
ID of a thread. |
LAST_CPU |
Number of the CPU on which the most recent thread scheduling occurs. |
PRI |
Priority level of a thread. |
State |
State of a thread: · R—Running. · S—Sleeping. · T—Traced or stopped. · D—Uninterruptible sleep. · Z—Zombie. |
HH:MM:SS |
Running time of a thread since last restart. |
MAX |
Longest time that a single thread scheduling occupies the CPU, in milliseconds. |
CPU |
CPU usage of a thread. |
Name |
Name of a thread. If square brackets ([ ]) exist in a thread name, the thread is a kernel thread. |
process core
Use process core to enable or disable a process to generate core files for exceptions and set the maximum number of core files.
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
A process generates a core file for the first exception and does not generate any core files for subsequent exceptions.
off: Disables core file generation.
maxcore value: Enables core file generation and sets the maximum number of core files, in the range of 1 to 10.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. The job ID does not change after the process restarts.
The command applies to all instances of a process.
The command enables the system to generate a core file each time the specified process crashes until the maximum number of core files is reached. A core file records the exception information.
Because the core files consume system storage resources, you can disable core file generation for processes for which you do not need to review exception information.
# Disable core file generation for process routed.
<Sysname> process core off name routed
# Enable core file generation for process routed and set the maximum number of core files to 5.
<Sysname> process core maxcore 5 name routed
exception filepath
Use reset exception context to clear context information for process exceptions.
reset exception context [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command clears context information for process exceptions on the IRF master device.
# Clear context information for exceptions.
<Sysname> reset exception context
Use reset kernel deadloop to clear kernel thread deadloop information.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command clears kernel thread deadloop information for the master device.
# Clear kernel thread deadloop information.
<Sysname> reset kernel deadloop
Use reset kernel exception to clear kernel thread exception information.
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command clears kernel thread exception information for the master device.
# Clear kernel thread exception information.
<Sysname> reset kernel exception
reset kernel reboot
Use reset kernel reboot to clear kernel thread reboot information.
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command clears kernel thread reboot information for the master device.
# Clear kernel thread reboot information.
<Sysname> reset kernel reboot
Use reset kernel starvation to clear kernel thread starvation information.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify this option, the command clears kernel thread starvation information for the master device.
cpu cpu-number: Specifies a CPU by its number.
# Clear kernel thread starvation information.
<Sysname> reset kernel starvation
third-part-process start
Use third-part-process start to start a third-party process.
third-part-process start name process-name [ arg args ]
name process-name: Specifies the name of a third-party process. The value can be puppet or chef.
arg args: Specifies the arguments used when the third-party process is started. The value and format of the arguments must conform to the rules of the third party process. If you do not specify this option, the command starts a third-party process without any arguments.
Use this command to start a third-party process, such as Puppet or Chef when the Comware system is operating.
# Start third-party process puppet.
[Sysname] third-part-process start name puppet arg agent --certname=1.1.1.1 --server=1.1.1.2
third-part-process stop
Use third-part-process stop to stop a third-party process.
third-part-process stop pid pid&<1-10>
pid&<1-10>: Specifies a space-separated list of up to 10 third-party processes that have been started.
This command can only be used to stop processes started by the third-part-process start command. To display the ID of a third-party process, use the display process all command. "Y" in the THIRD field from the output indicates the third-party process and the PID field indicates the ID of the process.
# Stop third party process puppet.
20 35 0.0 0.0 D 100 Y - 00:00:00 puppet
---- More ----
[Sysname] third-part-process stop pid 35
display process all
