- 01-AAA configuration
- 02-Password control configuration
- 03-Keychain configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Attack detection and prevention configuration
- 10-IP source guard configuration
- 11-ARP attack protection configuration
- 12-ND attack defense configuration
- 13-uRPF configuration
- 14-Crypto engine configuration
14-Crypto engine configuration | 37.83 KB |
Configuring crypto engines
Overview
Crypto engines encrypt and decrypt data for service modules.
The device supports only one software crypto engine, which is a set of software encryption algorithms. The software crypto engine is always enabled.
When a service module requires data encryption/decryption, it sends the desired data to the crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Display and maintenance commands for crypto engines
Task |
Command |
Display crypto engine information. |
display crypto-engine |
Display crypto engine statistics. |
display crypto-engine statistics [ engine-id engine-id slot slot-number ] |
Clear crypto engine statistics. |
reset crypto-engine statistics [ engine-id engine-id slot slot-number ] |
