01-Service chain commands | 55.49 KB |
display service-chain path
Use display service-chain path to display service chain information.
display service-chain path { path-id | all }
context-admin
context-operator
path-id: Specifies a service chain by its path ID in the range of 1 to 8388606.
all: Displays information for all service chains.
# Display information for all service chains.
<Sysname> display service-chain path all
PathID: 22
Next service node: 4.4.4.4
Previous service node: 5.5.5.5
Function: 1
Service-list: fw
PathID |
Path ID of the service chain. |
Next service node |
IP address of the next service node. |
Previous service node |
IP address of the previous service node. |
Function |
ID of the service node. |
Service-list |
Services in the service list. |
display service-chain statistics
Use display service-chain statistics to display service chain statistics.
context-admin
context-operator
# Display all service chain statistics.
<Sysname> display service-chain statistics
Service-chain statistics
Board : all
Total receive : 0 Total send : 0
Service drop : 0 Error drop : 0
Board |
ID of a card. This field displays all in the current software version. |
Total receive |
Total number of received packets. |
Total send |
Total number of sent packets. |
Service drop |
Total number of dropped packets. |
Error drop |
Total number of dropped error packets. |
next-service-node
Use next-service-node to specify the IP address of the next service node in a service chain.
Use undo next-service-node to restore the default.
next-service-node ip-address
The IP address of the next service node in a service chain is not specified.
Service chain view
context-admin
ip-address: Specifies the IP address of the next service node.
If the service node is the end node, you do not need to specify the IP address of the next service node.
# Specify the IP address of the next service node as 2.2.2.2 for service chain 1.
[Sysname] service-chain path 1
[Sysname-spath1] next-service-node 2.2.2.2
previous-service-node
Use previous-service-node to specify the IP address of the previous service node in a service chain.
Use undo previous-service-node to restore the default.
previous-service-node ip-address
The IP address of the previous service node in a service chain is not specified.
Service chain view
context-admin
ip-address: Specifies the IP address of the previous service node.
If the service node is the head node, you do not need to specify the IP address of the previous service node.
# Specify the IP address of the previous service node as 3.3.3.3 for service chain 1.
[Sysname-spath1] previous-service-node 3.3.3.3
service-chain path
Use service-chain path to create a service chain and enter its view, or enter the view of an existing service chain.
Use undo service-chain path to delete a service chain or all service chains on a device.
service-chain path path-id
undo service-chain path { path-id | all }
No service chains exist.
context-admin
path-id: Specifies the path ID of a service chain, in the range of 1 to 8388606. A path ID uniquely identifies a service chain.
all: Deletes all service chains on the device.
# Create service chain 1 and enter its view.
[Sysname-spath1]
service function
Use service function to create a service node and enter its view, or enter the view of an existing service node.
Use undo service function to delete a service node or all service nodes on the service chain.
service function function-number
undo service function { function-number | all }
No service nodes exist.
Service chain view
context-admin
function-number: Assigns an ID to the service node. The value for the function-number argument is fixed at 1.
all: Deletes all service nodes on the service chain.
You can configure only one service node for a service chain.
# Create service node 1 and enter its view.
[Sysname-spath1] service function 1
[Sysname-spath1-func1]
service list
Use service list to create a service list.
Use undo service list to restore the default.
service list { fw | lb }*
undo service list
No service list exists.
Service node view
context-admin
fw: Specifies the firewall (FW) service.
lb: Specifies the load balancing (LB) service.
You can configure only one service list for each service node. All services in a service chain must be different from each other.
The services in a service list are applied to the traffic in the order they are specified in a service list.
# Create a service list that contains the FW and LB services for service node 1.
[Sysname-spath1-func1] service list fw lb
