02-Layer 2 forwarding commands | 172.13 KB |
Normal Layer 2 forwarding commands
display mac-forwarding statistics
reset mac-forwarding statistics
Fast Layer 2 forwarding commands
display mac-forwarding cache ip
display mac-forwarding cache ip fragment
display mac-forwarding cache ipv6
mac fast-forwarding check-vlan-id
Cut-through Layer 2 forwarding commands
bridge mac-address timer aging
bridge tunnel-encapsulation skip
Fast bridge forwarding commands
bridge fast-forwarding check-vlan-id
display bridge cache ip fragment
Use display mac-forwarding statistics to display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays Layer 2 forwarding statistics on all interfaces.
# Display Layer 2 forwarding statistics on all interfaces.
<Sysname> display mac-forwarding statistics
Input:
Sum: 888 Unknown Unicast: 0
Broadcast: 0 Multicast: 0
Filtered: 0 STP discarded: 0
Service dropped: 0 Source dropped: 0
Unknown dropped: 0 Learning dropped: 0
Blackhole dropped: 0 Suppress dropped: 0
Source MAC dropped:0
Deliver:
Sum: 111 L2 protocol: 11
Local MAC address: 100
Output:
Sum: 666 Filtered: 0
Blackhole dropped: 0 STP discarded: 0
Service dropped: 0 Dest MAC dropped: 0
# Display Layer 2 forwarding statistics on GigabitEthernet 1/0/1.
<Sysname> display mac-forwarding statistics interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Input frames: 100 Output frames:100
Filtered: 0
Input |
Inbound Ethernet frame statistics. · Sum—Total number of received Ethernet frames. · Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN inbound filtering rules. · STP discarded—Number of inbound Ethernet frames dropped on the ports blocked by STP. · Service dropped—Number of Ethernet frames dropped by inbound service features. · Source dropped—Number of Ethernet frames dropped because their source MAC addresses are all-zeros, multicast, or broadcast MAC addresses. · Unknown dropped—Number of Ethernet frames dropped because the device is disabled from forwarding frames with unknown source MAC addresses. · Learning dropped—Number of Ethernet frames dropped because the device is disabled from forwarding unknown frames after the number of learned MAC addresses reaches the upper limit. · Suppress dropped—Number of Ethernet frames dropped by storm suppression. · Broadcast—Number of received broadcast Ethernet frames. · Multicast—Number of received multicast Ethernet frames. · Unknown unicast—Number of received unknown unicast Ethernet frames. · Blackhole dropped—Number of Ethernet frames dropped because they are sourced from blackhole MAC addresses. · Source MAC dropped—Number of Ethernet frames dropped by features based on the source MAC addresses. |
Deliver |
Statistics of Ethernet frames delivered to the CPU. · Sum—Total number of Ethernet frames delivered to the CPU. · L2 protocol—Number of Layer 2 protocol Ethernet frames delivered to the CPU. · Local MAC address—Number of Ethernet frames that use the MAC addresses of local Layer 3 VLAN interfaces as the destination MAC addresses. |
Output |
Outbound Ethernet frame statistics. · Sum—Total number of sent Ethernet frames. · Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN outbound filtering rules. · Blackhole dropped—Number of Ethernet frames dropped because they are destined for blackhole MAC addresses. · STP discarded—Number of outbound Ethernet frames dropped on the ports blocked by STP. · Service dropped—Number of Ethernet frames dropped by outbound service features. · Dest MAC dropped—Number of Ethernet frames dropped by features based on the destination MAC addresses. |
GigabitEthernet1/0/1 |
Layer 2 forwarding statistics on GigabitEthernet 1/0/1: · Input frames—Number of Ethernet frames received on the interface. · Output frames—Number of Ethernet frames sent out of the interface. · Filtered—Number of Ethernet frames filtered out because they are from other VLANs. |
Use reset mac-forwarding statistics to clear Layer 2 forwarding statistics.
context-admin
context-operator
# Clear Layer 2 forwarding statistics.
<Sysname> reset mac-forwarding statistics
Use display mac-forwarding cache ip to display IPv4 fast forwarding entries.
display mac-forwarding cache ip [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all IPv4 fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast forwarding entries for all member devices.
# Display all IPv4 fast forwarding entries.
<Sysname> display mac-forwarding cache ip
Total number of mac-forwarding entries: 2
SIP SPort DIP DPort Pro Input_If Output_If VLAN
1.1.1.2 99 1.1.1.1 2048 1 GE1/0/1 GE1/0/2 2
1.1.1.1 98 1.1.1.2 2012 1 GE1/0/2 GE1/0/1 2
Total number of mac-forwarding entries |
Total number of IPv4 fast forwarding entries. |
SIP |
Source IPv4 address. |
SPort |
Source port number. |
DIP |
Destination IPv4 address. |
DPort |
Destination port number. |
Pro |
Protocol number. |
Input_If |
Input interface type and number. If no input interface is involved in fast forwarding, this field displays N/A. If no input interface is available, this field displays a hyphen (-). |
Output_If |
Output interface type and number. If no output interface is involved in fast forwarding, this field displays N/A. If no output interface is available, this field displays a hyphen (-). |
VLAN |
VLAN ID. |
Use display mac-forwarding cache ip fragment to display IPv4 fast forwarding entries for fragments.
display mac-forwarding cache ip fragment [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays IPv4 fast forwarding entries for all fragments.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast forwarding entries for fragments on all member devices.
# Display IPv4 fast forwarding entries for all fragments.
<Sysname> display mac-forwarding cache ip fragment
Total number of fragment mac-forwarding entries: 2
SIP SPort DIP DPort Pro Input_If ID VLAN
1.1.1.1 117 1.1.1.2 0 1 GE1/0/1 2828 1
1.1.1.2 110 1.1.1.1 67 17 GE1/0/2 2322 1
Total number of fragment mac-forwarding entries |
Total number of IPv4 fast forwarding entries for fragments. |
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
Input_If |
ID |
Fragment ID. |
VLAN |
VLAN ID. |
Use display mac-forwarding cache ipv6 to display IPv6 fast forwarding entries.
display mac-forwarding cache ipv6 [ ipv6-address ] [ slot slot-number ]
context-admin
context-operator
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 fast forwarding entries for all member devices.
# Display all IPv6 fast forwarding entries.
<Sysname> display mac-forwarding cache ipv6
Total number of IPv6 mac-forwarding items: 1
Src IP: 2002::1 Src port: 129
Dst IP: 2001::1 Dst port: 65535
VLAN ID: 2
Protocol: 2
Input interface: GE1/0/2
Output interface: GE1/0/1
Total number of IPv6 mac-forwarding items |
Total number of IPv6 fast forwarding entries. |
Src IP |
Source IPv6 address. |
Src port |
Dst IP |
Destination IPv6 address. |
Dst Port |
Protocol |
Protocol number. |
Input interface |
Output interface |
Use mac fast-forwarding check-vlan-id to enable VLAN ID check for fast Layer 2 forwarding.
Use undo mac fast-forwarding check-vlan-id to disable VLAN ID check for fast Layer 2 forwarding.
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware |
Command compatibility |
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-AI-20, F5000-AI-40, F5000-V30, F5000-C, F5000-S, F5000-M, F5000-A |
Yes |
F1000-AI-20, F1000-AI-30, F1000-AI-50, F1000-AI-60, F1000-AI-70, F1000-AI-80, F1000-AI-90 |
Yes |
F1003-L, F1005-L, F1010-L |
Yes |
F1005, F1010 |
Yes |
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090, F1000-V70 |
Yes |
F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140 |
Yes |
F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332 |
Yes |
F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614 |
Yes |
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710 |
Yes |
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711 |
Yes |
LSU3FWCEA0, LSUM1FWCEAB0, LSX1FWCEA1 |
Yes |
LSXM1FWDF1, LSUM1FWDEC0, IM-NGFWX-IV, LSQM1FWDSC0, LSWM1FWD0, LSPM6FWD, LSQM2FWDSC0 |
Yes |
vFW1000, vFW2000 |
No |
VLAN ID check is enabled for fast Layer 2 forwarding.
context-admin
This feature allows the device to check whether the VLAN ID of a flow matches that of any fast forwarding entry. If no match is found, the flow does not match any fast forwarding entry.
The VLAN ID of a packet helps the device to determine the TCP session to which the packet belongs. On a hot backup system formed by two firewalls, you must disable VLAN ID check if the traffic incoming interfaces on the primary and secondary devices belong to different VLANs. If you enable VLAN ID check, traffic cannot match session entries correctly when asymmetric-path traffic exists.
# Enable VLAN ID check for fast Layer 2 forwarding.
[Sysname] mac fast-forwarding check-vlan-id
The following matrix shows the feature and hardware compatibility:
Hardware |
Cut-through Layer 2 forwarding compatibility |
F5010, F5020, F5020-GM, F5040, F5000-C, F5000-S |
No |
F5030, F5030-6GW, F5060, F5080, F5000-AI-20, F5000-AI-40, F5000-V30, F5000-M, F5000-A |
Yes |
FF1000-AI-20, F1000-AI-30, F1000-AI-50 |
No |
Yes |
Yes |
F1005, F1010 |
Yes |
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1000-V70 |
No |
F1090 |
Yes |
Yes |
No |
Yes |
Yes |
No |
No |
No |
vFW1000, vFW2000 |
No |
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
context-admin
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
Bridge forwarding commands
add interface
Use add interface to add an interface to a reflect-type, forward-type, or blackhole-type bridge instance.
Use undo add interface to remove an interface from a reflect-type, forward-type, or blackhole-type bridge instance.
add interface interface-type interface-number
undo add interface interface-type interface-number
No interfaces exist in a reflect-type, forward-type, or blackhole-type bridge instance.
Reflect-type bridge view
Forward-type bridge view
Blackhole-type bridge view
context-admin
You can add only Layer 2 physical interfaces, Layer 3 physical interfaces, or Layer 2 aggregate interfaces to reflect-type, forward-type, or blackhole-type bridge instances.
Only one interface can be added to a reflect-type or blackhole-type bridge instance.
Only two interfaces can be added to a manually created forward-type bridge instance. The two interfaces must be the same type.
Each interface can be added to only one bridge instance.
This command is not available for a forward-type bridge instance that is automatically created upon insertion of a hardware bypass subcard. An automatically created forward-type bridge instance uses the pair of interfaces on the bypass subcard by default and you cannot edit the interfaces in the instance.
If you execute this command multiple times in reflect-type or blackhole-type bridge view, the most recent configuration takes effect.
If you execute this command multiple times in forward-type bridge view, the most recent two configurations take effect.
# Add GigabitEthernet 1/0/1 to reflect-type bridge instance 1.
[Sysname] bridge 1 reflect
[Sysname-bridge1-reflect] add interface gigabitethernet 1/0/1
add vlan
Use add vlan to add a list of VLANs to an inter-VLAN bridge instance.
Use undo add vlan to remove VLANs from an inter-VLAN bridge instance.
add vlan vlan-id-list
undo add vlan [ vlan-id-list ]
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
No VLANs exist in an inter-VLAN bridge instance.
Inter-VLAN bridge view
context-admin
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN ID or a range of VLAN IDs in the form of start-vlan-id to end-vlan-id. The end VLAN ID must be greater than the start VLAN ID. Valid VLAN IDs are from 1 to 4094.
You can add VLANs to a bridge instance before or after you create the VLANs.
You can add a VLAN to only one bridge instance.
If you execute the command multiple times, all configurations take effect.
If you do not specify the vlan-id-list argument, the undo add vlan command removes all VLANs from the inter-VLAN bridge instance.
# Add VLANs 2, 3, 5, and VLANs 50 through 70 to bridge instance 2.
[Sysname] bridge 2 inter-vlan
[Sysname-bridge2-inter-vlan] add vlan 2 3 5 50 to 70
bridge
Use bridge to create a specific type of bridge instance and enter its view, or enter the view of an existing bridge instance.
Use undo bridge to delete bridge instances.
bridge bridge-index [ blackhole | forward | inter-vlan | reflect ]
undo bridge { bridge-index | all }
No bridge instances exist.
context-admin
bridge-index: Specifies a bridge instance index. For an automatically created forward-type bridge instance, the system will assign an index in the range of 32768 to 1082400.
The following compatibility matrix shows the value ranges for the bridge-index argument for a manually created bridge instance:
Hardware |
Value range |
1 to 2048 |
1 to 128 |
1 to 128 |
1 to 128 |
F1005, F1010 |
1 to 128 |
1 to 128 |
1 to 128 |
1 to 128 |
1 to 128 |
1 to 128 |
1 to 128 |
1 to 2048 |
1 to 2048 |
vFW1000, vFW2000 |
1 to 128 |
blackhole: Specifies a blackhole-type bridge instance.
forward: Specifies a forward-type bridge instance.
inter-vlan: Specifies an inter-VLAN bridge instance.
The following compatibility matrix shows the support of hardware platforms for the inter-vlan keyword:
Hardware |
Parameter compatibility |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
reflect: Specifies a reflect-type bridge instance.
all: Deletes all bridge instances.
Use this command to create a bridge instance. You can create reflect-type, forward-type, and blackhole-type bridge instances for inline forwarding.
When you create a bridge instance, you must specify its type. You can specify only one type for a bridge instance.
The device will automatically create a forward-type bridge instance upon insertion of a hardware bypass subcard. The automatically created forward-type bridge instance uses the pair of interfaces on the bypass subcard by default. You cannot edit the interfaces in the bridge instance or delete the bridge instance.
# Create blackhole-type bridge instance 1 and enter its view.
[Sysname] bridge 1 blackhole
[Sysname-bridge1-blackhole]
# Create forward-type bridge instance 2 and enter its view.
[Sysname] bridge 2 forward
[Sysname-bridge2-forward]
# Create inter-VLAN bridge instance 3 and enter its view.
[Sysname] bridge 3 inter-vlan
[Sysname-bridge3-inter-vlan]
# Create reflect-type bridge instance 4 and enter its view.
[Sysname] bridge 4 reflect
[Sysname-bridge4-reflect]
Use bridge mac-address timer aging to set the aging timer for dynamic MAC address entries in bridge instances.
Use undo bridge to restore the default.
bridge mac-address timer aging seconds
undo bridge mac-address timer aging
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
The aging timer for dynamic MAC address entries is 300 seconds.
context-admin
seconds: Specifies a MAC address aging timer, in seconds. The value range is 60 to 1440.
Follow these guidelines to set the aging timer appropriately:
· A long aging interval causes the MAC address table to retain outdated entries and fail to accommodate the most recent network changes.
· A short aging interval results in removal of valid entries. Then, unnecessary broadcast packets appear and affect device performance.
After you set an aging time for dynamic MAC address entries, the device automatically deletes the expired dynamic MAC address entries. Then, the device learns new MAC addresses to build new MAC address entries.
# Set the aging timer to 500 seconds for dynamic MAC address entries.
[Sysname] bridge mac-address timer aging 500
Use bridge tunnel-encapsulation skip to configure the device to ignore the tunnel encapsulation when forwarding tunneled packets in inline mode.
Use undo bridge tunnel-encapsulation skip to restore the default.
In inline forwarding mode, tunneled packets are forwarded based on information in the tunnel encapsulation.
context-admin
This command takes effect only for inline forwarding.
In inline forwarding mode, tunneled packets are forwarded based on information in the tunnel encapsulation by default.
Use this command to enable the device to ignore the tunnel encapsulation and forward tunneled packets based on the original packet header information.
# Configure the device to ignore the tunnel encapsulation when forwarding tunneled packets in inline mode.
[Sysname] bridge tunnel-encapsulation skip
bypass enable
Use bypass enable to enable internal security service bypass.
Use undo bypass enable to disable security service bypass.
bypass enable
undo bypass enable
Security service bypass is disabled.
context-admin
This feature enables the device to bypass the security service and to directly process received packets according to the configured bridge forwarding mode.
If you configure the bypass enable command and the bypass enable external command multiple times, the most recent configuration takes effect.
# Enable internal security service bypass.
[Sysname] bridge 1 forward
[Sysname-bridge-1-forward] bypass enable
Use bypass enable external to enable external security service bypass.
bypass enable external [ auto [ check-interval interval ] ]
undo bypass enable
Hardware |
Yes |
No |
No |
No |
F1005, F1010 |
No |
No |
No |
No |
No |
No |
No |
No |
No |
vFW1000, vFW2000 |
No |
context-admin
auto: Enables automatic external bypass.
check-interval interval: Specifies the interface status check interval in seconds. The value range is 1 to 3600 and the default is 15.
If you configure this command multiple times, the most recent configuration takes effect.
With external bypass enabled, user traffic will bypass the security device and be forwarded directly by the PFC.
You can specify the auto keyword to enable dynamic external bypass or omit this keyword to enable static external bypass:
· Static external bypass—External bypass takes effect immediately when configured and must be manually disabled.
· Dynamic external bypass—External bypass is enabled or disabled automatically based on the status of the links between the security device and the PFC. The security device polls the link status periodically and enables external bypass if one or both links go down. External bypass is disabled automatically if the failed links come up.
External bypass is not supported in multi-chassis IRF systems.
External bypass is available only in the default context. The following guidelines apply when you configure this feature in the default context that contains a Layer 2 Ethernet interface assigned to it in shared-mode:
· If external bypass takes effect, user traffic will be forwarded by the PFC. On the Layer 2 Ethernet interface, settings of a non-default context that conflict with the external bypass feature do not take effect.
· If external bypass does not take effect, user traffic will not be forwarded by the PFC. On the Layer 2 Ethernet interface, settings of a non-default context that conflict with the external bypass feature take effect, and user traffic will be forwarded accordingly.
For a forward-type bridge instance that is automatically created upon insertion of a hardware bypass subcard, you can enable only internal bypass for the instance.
You can enable external bypass only for one manually created forward-type bridge instance. The interfaces added to the forward-type bridge instance must reside on the same slot.
# Enable external security service bypass for forward-type bridge instance 1.
[Sysname-bridge-1-forward] bypass enable external
display bridge bypass status
Use display bridge bypass status to display the status of the security service bypass feature.
display bridge bridge-index bypass status
Hardware |
Yes |
No |
No |
No |
F1005, F1010 |
No |
No |
No |
No |
No |
No |
No |
No |
No |
vFW1000, vFW2000 |
No |
context-admin
context-operator
bridge-index: Specifies a bridge instance by its index.
This command is supported in the default context.
# Display the status of the security service bypass feature in bridge instance Bridge 1.
<Sysname> display bridge 1 bypass status
Current external bypass status: Disable
The bypass device is faulty.
Table 5 Command output
Current external bypass status |
Status of the external security service bypass feature: · Enable. · Disable. |
The bypass device is faulty |
The bypass device (PFC) is faulty. |
display bridge mac-address
Use display bridge mac-address to display MAC address entries in bridge instances.
display bridge mac-address [ bridge-index [ vlan vlan-id ] ] [ count ] [ slot slot-number ]
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
context-admin
context-operator
vlan vlan-id: Specifies a VLAN by its ID.
count: Displays only the total number of MAC address entries that match all entry attributes you specify in this command. In this case, the detailed information about MAC address entries is not displayed. For example, you can use the display bridge mac-address 2 vlan 20 count command to display the total number of entries for VLAN 20 in bridge instance 2. If you do not specify this keyword, this command displays detailed information about specified MAC address entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays MAC address entries for the master device.
If you do not specify any parameters, this command displays MAC address entries for all bridge instances.
This command displays dynamic MAC address entries because the MAC address entries in a bridge instance are all learned MAC addresses.
# Display MAC address entries for bridge instance 100.
<Sysname> display bridge mac-address 100
MAC Address BRIDGE ID State VLAN ID Port Aging
0033-0033-0033 100 Learned 44 GE1/0/1 Y
0000-0000-0002 100 Learned 66 GE1/0/2 Y
# Display the number of MAC address entries in bridge instance 100.
<Sysname> display bridge mac-address 100 count
1 mac address(es) found.
Table 6 Command output
BRIDGE ID |
Index of the bridge instance to which the MAC address entry belongs. |
State |
MAC address entry state: Learned. |
VLAN ID |
VLAN of the outgoing interface. |
Port |
Outgoing interface. |
Aging |
Whether the entry can age out: · Y—The entry can age out. · N—The entry never ages out. |
1 mac address(es) found |
Number of matching MAC address entries. |
mac-address max-mac-count
Use mac-address max-mac-count to set the MAC learning limit on an inter-VLAN bridge instance.
Use undo mac-address max-mac-count to restore the default.
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
The MAC learning limit is 4096 on an inter-VLAN bridge instance.
context-admin
count: Sets the maximum number of MAC addresses that can be learned on an inter-VLAN bridge instance. The value range for this argument is 0 to 4096. To prevent an inter-VLAN bridge instance from learning any MAC addresses, set the limit to 0 for the bridge instance.
The command sets the size of the inter-VLAN bridge forwarding MAC address table. When the number of MAC address entries learned by an inter-VLAN bridge instance reaches the limit, the bridge instance stops learning MAC address entries.
# Configure inter-VLAN bridge instance 2 to learn a maximum of 10 MAC address entries.
[Sysname-bridge2-inter-vlan] mac-address max-mac-count 10
Use bridge fast-forwarding check-vlan-id to enable VLAN ID check for fast bridge forwarding.
Use undo bridge fast-forwarding check-vlan-id to disable VLAN ID check for fast bridge forwarding.
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
VLAN ID check is enabled for fast bridge forwarding.
context-admin
# Enable VLAN ID check for fast bridge forwarding.
[Sysname] bridge fast-forwarding check-vlan-id
Use display bridge cache ip to display IPv4 fast bridge forwarding entries.
display bridge cache ip { inline | inter-vlan } [ ip-address ] [ slot slot-number ]
context-admin
context-operator
inline: Displays IPv4 inline forwarding entries.
inter-vlan: Displays IPv4 inter-VLAN forwarding entries.
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all IPv4 fast bridge forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast bridge forwarding entries for all member devices.
# Display IPv4 inline fast bridge forwarding entries.
<Sysname> display bridge cache ip inline
Total number of bridge-forwarding entries: 2
SIP SPort DIP DPort Pro InVLAN OutVLAN Output_If
1.1.1.3 470 1.1.1.2 0 1 3 2 GE1/0/1
1.1.1.2 470 1.1.1.3 2048 1 2 3 GE1/0/2
Table 7 Command output
Total number of bridge-forwarding entries |
Total number of IPv4 fast bridge forwarding entries. |
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
InVLAN |
Input VLAN. |
OutVLAN |
Output VLAN. |
Output_If |
Output interface. |
Use display bridge cache ip fragment to display IPv4 fast bridge forwarding entries for fragments.
display bridge cache ip fragment { inline | inter-vlan } [ ip-address ] [ slot slot-number ]
context-admin
context-operator
inline: Displays IPv4 inline forwarding entries for fragments.
inter-vlan: Displays IPv4 inter-VLAN forwarding entries for fragments.
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays IPv4 fast bridge forwarding entries for all fragments.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast bridge forwarding entries for fragments on all member devices.
# Display IPv4 inline fast bridge forwarding entries for fragments.
<Sysname> display bridge cache ip fragment inline
Total number of fragment bridge-forwarding entries: 2
SIP SPort DIP DPort Pro InVLAN ID
2.1.1.2 2320 2.1.1.1 2048 1 2 7298
2.1.1.1 2048 2.1.1.2 2320 1 3 6826
Table 8 Command output
Total number of fragment bridge-forwarding entries |
Total number of IPv4 fast bridge forwarding entries for fragments. |
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
InVLAN |
Input VLAN. |
ID |
Fragment ID. |
display bridge cache ipv6
Use display bridge cache ipv6 to display IPv6 fast bridge forwarding entries.
display bridge cache ipv6 { inline | inter-vlan } [ ipv6-address ] [ slot slot-number ]
context-admin
context-operator
inline: Displays IPv6 inline forwarding entries.
inter-vlan: Displays IPv6 inter-VLAN forwarding entries.
Hardware |
Yes |
Yes |
Yes |
F1005, F1010 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
vFW1000, vFW2000 |
No |
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast bridge forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 fast bridge forwarding entries for all member devices.
# Display IPv6 inline fast bridge forwarding entries.
<Sysname> display bridge cache ipv6 inline
Total number of IPv6 bridge-forwarding items: 1
Src IP: 10::12 Src Port: 427
Dst IP: 10::11 Dst Port: 32768
InVLAN: 2 OutVLAN: 3
Protocol: 58
Context ID: 257
Bridge ID: 10
Table 9 Command output
Total number of IPv6 bridge-forwarding items |
Total number of IPv6 fast bridge forwarding entries. |
Src IP |
Src port |
Dst IP |
Dst Port |
InVLAN |
Input VLAN. |
OutVLAN |
Output VLAN. |
Protocol |
Protocol number. |
Context ID |
Context ID. |
Output interface |
