14-Network Management and Monitoring Configuration Guide
HomeSupportResource CenterRoutersCR19000 Core SeriesCR19000 Core SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C CR19000 Core Router Series Configuration Guides-E3521-5W10014-Network Management and Monitoring Configuration Guide
17-Fast log output configuration
17-Fast log output configuration 82.25 KB
Configuring fast log output
About fast log output
The fast log output feature enables fast output of logs to log hosts.
Typically, logs generated by a service module are first sent to the information center, which then outputs the logs to the specified destination (such as to log hosts). When fast log output is configured, logs of service modules are sent directly to log hosts instead of to the information center. Compared to outputting logs to the information center, fast log output saves system resources. For more information about the information center, see "Configuring the information center."
Logs are classified into eight severity levels from 0 through 7 in descending order.
Table 1 Log levels
Severity value
Level
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debugging
Debug message.
Log formats and field descriptions
Log formats
The following tables show the original log formats, which might be different from what you see. The actual format varies by the log resolution tool used.
Table 2 CMCC log formats
Log type
Format
Example
NAT session log
<PRI> Version Timestamp HostName AppName ProcID MsgID Start Time|End Time|Original Source IP|OriginalSource Port|TranslatedSource IP|Translated Source Port|Destination IP|Destination Port|Protocol
<142> 1 2020 Apr 28 15:35:32 100.0.0.1 H3C - NAT444:SessionA 1588088133|0|100.0.0.18|1111|139.0.0.223|10000|114.0.0.15|2222|17
NAT444 user log
<PRI> Version Timestamp HostName AppName ProcID MsgID Start Time|Original Source IP|Translated Source IP|Translated First Source Port|Translated Last Source Port
<142> 1 2020 Apr 28 15:35:32 100.0.0.1 H3C - NAT444:PortA 1588088133|100.0.0.18|139.0.0.223|10000|10999
NAT alarm log
<142> 1 2020 Apr 28 15:35:32 100.0.0.1 H3C - NAT444:PortF 1588088133|100.0.0.18|139.0.0.223
Table 3 Telecom log formats
Log type
Format
Example
NAT session log
<PRI> Version Timestamp HostName AppName ProcID MsgID [Protocol Original Source IP Original Source IPv6 Translated Source IP Original Source Port Translated Source Port -]
<134> 1 Apr 28 15:35:38 100.0.0.1 H3C - NAT444:sessionbasedA [17 100.0.0.18 - 139.0.0.223 1111 11000 -]
NAT444 user log
<PRI> Version Timestamp HostName AppName ProcID MsgID [Protocol Original Source IP Original Source IPv6 Translated Source IP Original Source Port Translated First Source Port Translated Last Source Port]
<134> 1 Apr 28 15:35:38 100.0.0.1 H3C - NAT444:userbasedA [17 100.0.0.18 - 139.0.0.223 - 11000 11999]
NAT alarm log
<PRI> Version Timestamp HostName AppName ProcID MsgID [Protocol Original Source IP Original Source IPv6 Translated Source IP - - -]
<134> 1 Apr 28 15:35:38 100.0.0.1  H3C - NAT444:userbasedF [17 100.0.0.18 - 139.0.0.223 - - -]
Table 4 Unicom log formats
Log type
Format
Example
NAT session log
<PRI>Version Timestamp HostName AppName ProcID MsgID Start Time|End Time|Original Source IP |Translated Source IP|Translated Source Port|Destination IP|Destination Port|Protocol
<142> 1 2020 Apr 28 15:35:43 100.0.0.1 H3C - NAT444:SessionA 1588088144|0|100.0.0.18|139.0.0.223|12000|114.0.0.15|2222|17
NAT444 user log
<PRI> Version Timestamp HostName AppName ProcID MsgID Start Time|Original Source IP|Translated Source IP |Translated First Source Port|Translated Last Source Port
<142> 1 2020 Apr 28 15:35:43 100.0.0.1 H3C - NAT444:PortA 1588088144|100.0.0.18|139.0.0.223|12000|12999
NAT alarm log
<PRI> Vision Timestamp HostName AppName ProcID MsgID StartTime|OriginalSourceIP|TranslatedSourceIP
<142> 1 2020 Apr 28 15:35:43 100.0.0.1 H3C - NAT444:PortF 1588088144|100.0.0.18|139.0.0.223
Log field description
Each log message contains a header and MSG content, which records log identifier information and detailed log information, respectively. Table 5 displays descriptions of log fields in the header and content.
Table 5 Log field description
Header
PRI
Priority identifier. The priority is calculated by using this formula: facility*8+level, where:
·     facility is the facility name used to identify the log source at the log host. The facility name is fixed to 17, 16, and 17 for CMCC, Telecom, and Unicom, respectively.
·     level is in the range of 0 to 7. See Table 1 for more information about severity levels.
Version
Version of the log. This field is fixed to 1.
Timestamp
Time when the log was generated, accurate to seconds. The timestamp format varies by service provider.
·     Telecom: <mon> <day> <hh:mm:ss>, where:
¡     mon represents the month.
¡     day represents the date.
¡     hh:mm:ss represents the exact time.
·     CMCC and Unicom: <year><mon> <day> <hh:mm:ss>, where:
¡     year represents the year.
You can execute the customlog timestamp localtime command to configure the timestamp of fast output logs to show the system time. By default, the timestamp shows the Greenwich Mean Time (GMT).
HostName
Source IP address of the log. If the customlog host source command is configured, this field displays the IP address of the specified source interface. Otherwise, this field displays a hyphen (-).
AppName
Name of the device that generated the log. You can use the sysname command to modify the name of the device.
ProcID
Reserved field.
This field displays a hyphen (-).
MsgID
Log message type in the format of <device type>:<message type>.
The device type is NAT444, DSLITE, and NAT64 for NAT444, DS-Lite, and NAT64 networks, respectively.
Available message types include:
·     UserbasedA—Specifies user-based port assignment log.
·     UserbasedW—Specifies user-based port withdrawal log.
·     SessionbasedA—Specifies session-based port assignment log.
·     SessionbasedW—Specifies session-based port withdrawal log.
·     PortA—Specifies port range assignment log.
·     PortW—Specifies port range withdrawal log.
·     SessionA—Specifies session start log.
·     SessionW—Specifies session end log.
·     SessionU—Specifies session log with a session URL.
MSG content
Protocol
Transmission layer protocol. Options include:
·     6—TCP.
·     17—UDP.
·     1—ICMP.
Start Time
NAT session start time, seconds elapsed since 1970-1-1 00:00:00.
End Time
NAT session end time, seconds elapsed since 1970-1-1 00:00:00. This field is 0 in a session start log message.
Original Source IP
Source IPv4 address before NAT.
Source IPv6 address before NAT.
Source port number before NAT.
Source IPv4 address after NAT.
Translated First Source port
First source port number after NAT.
Translated Last Source port
Last source port number after NAT.
Destination IP
Destination IP address.
Destination Port
Destination port number.
Restrictions and guidelines: fast log output configuration
The device supports outputting logs from service modules to log hosts by using the following methods in descending order of priority:
1.     Fast log output. Only NAT logs and AFT logs can be output by using this method in the current software version. For more information about NAT logs and AFT logs, see NAT configuration and AFT configuration in Layer 3—IP Services Configuration Guide.
2.     Flow log. For more information about flow log and the service modules supported by flow log, see "Configuring flow log."
3.     Information center.
If you configure multiple log output methods for a service module, the service module outputs its logs in the method that has the highest priority.
To output logs to a log host, you must specify the log format required by the log host in the customlog format and customlog host commands.
2.     Enable fast log output.
customlog format { cmcc | telecom | unicom [ type1 ] }
By default, fast log output is disabled.
3.     Configure fast log output parameters.
customlog host [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] export { cmcc-sessionlog | cmcc-userlog | telecom-sessionlog | telecom-userlog | unicom-sessionlog | unicom-userlog } * [ sysname sysname ]
By default, no fast log output parameters are configured.
The value for the port-number argument must be the same as the port number configured on the log host. Otherwise, the log host cannot receive logs.
4.     (Optional.) Specify the source IP address for fast log output.
customlog host source interface-type interface-number
By default, the source IP address of fast output logs is the primary IP address of the outgoing interface.
If this command is configured, the primary IP address of the specified interface is used as the source IP address of fast output logs regardless of the outgoing interface.
Configure this command when you need to filter logs by source IP address on the log host.
5.     (Optional.) Configure the timestamp of fast output logs to show the system time.
By default, the timestamp of fast output logs shows the Greenwich Mean Time (GMT).
Fast log output configuration examples
Example: Configuring fast log output to a log host
As shown in Figure 1, configure fast log output on the device to send NAT444 user logs to the log host in CMCC format.
Figure 1 Network diagram
1.     Make sure the device and the log host can reach each other. (Details not shown.)
2.     Configure the device:
# Enable fast log output in CMCC format.
[Device] customlog format cmcc
# Output NAT444 user logs in CMCC format to the log host at 1.2.0.1/16.
[Device] customlog host 1.2.0.1 port 1000 export cmcc-userlog
# Enable NAT444 user log.
[Device] nat log enable
[Device] nat log port-block-assign
[Device] nat log port-block-withdraw
3.     Configure the log host:
The log host configuration varies by log host. For more information, see related document of the log host.
  • Become a Partner
  • Partner Resources
