15-Telemetry Command Reference
HomeSupportResource CenterRoutersCR19000 Core SeriesCR19000 Core SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR19000 Core Router Series Command References-E3521-5W10015-Telemetry Command Reference
Table of Contents
Related Documents
01-gRPC commands
01-gRPC commands 100.37 KB
gRPC commands
Generic gRPC commands
grpc data-model
Use grpc data-model to specify the architecture of telemetry data models.
Use undo grpc data-model to restore the default.
grpc data-model { 2-layer | 3-layer }
The device uses the two-layer telemetry data model architecture to push data.
2-layer: Specifies the two-layer telemetry data model architecture.
3-layer: Specifies the three-layer telemetry data model architecture.
This command is available only in gRPC dial-out mode.
If you specify the two-layer telemetry data model, the encoding format for pushed data can only be JSON.
For more information about telemetry data model architectures, see gRPC configuration in Telemetry Configuration Guide.
# Configure the device to use three-layer telemetry data models to push data.
[Sysname] grpc data-model 3-layer
encoding
grpc enable
Use grpc enable to enable the gRPC service.
Use undo grpc enable to disable the gRPC service.
grpc enable
undo grpc enable
The gRPC service is disabled.
You must enable the gRPC service before you can configure gRPC service attributes except the PKI domain attribute.
Disabling the gRPC service deletes all gRPC settings.
# Enable the gRPC service.
<Sysname> system
[Sysname] grpc enable
grpc pki domain
Use grpc pki domain to specify the PKI domain for secure gRPC connections to collectors.
Use undo grpc pki domain to restore the default.
grpc pki domain domain-name
No PKI domain is specified for secure gRPC connections to collectors.
domain-name: Specifies a PKI domain by its name, a case-sensitive string of 1 to 31 characters.
By default, the gRPC connection between the device and a collector does not provide data encryption service or require authentication. After you specify a PKI domain, the device and the collector will use TLS for data encryption and bidirectional certificate-based authentication to improve communication security.
For the device to establish secure gRPC connections to collectors, make sure the PKI domain already exists and has correct certificate and key settings. If these requirements are not met, the connections to collectors are not secure. For more information about PKI configuration, see Security Configuration Guide.
Execute this command before enabling the gRPC service. If you enable the gRPC service before executing this command, this command does not take effect.
# Specify the PKI domain for secure gRPC connections to collectors.
[Sysname] grpc pki domain grpc_test
grpc enable
gRPC dial-in mode commands
display grpc
Use display grpc to display gRPC dial-in mode information.
display grpc
# Display gRPC dial-in mode information.
<Sysname> display grpc
gRPC status : enabled.
gRPC port : 50051
gRPC idle-timeout : 3 minutes
Session count: 1.
  Session ID: 1
    User name: test
    Login time:2011-01-05 06:46:43 Idle time : 2 mins 56 s
    Client IP address : 169.254.100.170:40810
    Received RPCs        : 0         Received error RPCs : 0
    Received subscription: 0         Output notifications: 0
gRPC status
Status of the gRPC service:
·     enabled—The gRPC service is enabled.
·     disabled—The gRPC service is disabled.
gRPC idle-timeout
Setting for the gRPC session idle timeout timer.
Session count
Number of gRPC sessions.
Idle time
Duration in which the session idle timeout timer will expire. If the value of this field is 0, gRPC sessions will never be timed out.
Received error RPCs
Number of received erroneous gRPC requests.
Number of received gRPC subscription requests.
grpc idle-timeout
Use grpc idle-timeout to set the gRPC session idle timeout timer.
Use undo grpc idle-timeout to restore the default.
grpc idle-timeout minutes
The gRPC session idle timeout timer is 5 minutes.
minutes: Specifies the gRPC session idle timeout timer in minutes, in the range of 0 to 30. To disable gRPC sessions from being timed out, set it to 0.
If no gRPC packet exchanges occur on the session between a gRPC and the server before the idle timeout timer expires, the device closes the session.
# Set the gRPC session idle timeout timer to 6 minutes.
<Sysname> system
[Sysname] grpc idle-timeout 6
grpc port
Use grpc port to specify the gRPC service port number.
Use undo grpc port to restore the default.
grpc port port-number
undo grpc port
The gRPC service port number is 50051.
port-number: Specifies the gRPC service port number, in the range of 1 to 65535.
Changing the gRPC service port number reboots the gRPC service and terminates all gRPC sessions to the gRPC server. If the new port is not available, the system reboots the gRPC service again to use the old port.
# Set the gRPC service port number to 50052.
<Sysname> system
[Sysname] grpc port 50052
grpc enable
gRPC dial-out mode commands
destination-group (subscription view)
Use destination-group to specify a destination group for a subscription.
Use undo destination-group to remove a destination group from a subscription.
destination-group group-name
undo destination-group group-name
A subscription does not have a destination group.
Subscription view
group-name: Specifies a destination group by its name, a case-sensitive string of 1 to 31 characters.
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
The specified destination group must have been created by using the destination-group command in telemetry view.
A subscription can have a maximum of five destination groups.
# Specify destination group collector1 for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscription A
[Sysname-telemetry-subscription-A] destination-group collector1
destination-group (telemetry view)
Use destination-group to create a destination group and enter its view, or enter the view of an existing destination group.
Use undo destination-group to delete a destination group.
No destination groups exist.
Telemetry view
group-name: Specifies the destination group name, a case-sensitive string of 1 to 31 characters.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
To delete a destination group that is already used by a subscription, you must remove the destination group from the subscription first.
# Create a destination group named collector1.
[Sysname] telemetry
[Sysname-telemetry] destination-group collector1
[Sysname-telemetry-destination-group-collector1]
subscription
dscp
Use dscp to set the DSCP value for packets sent to collectors.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for packets sent to collectors is 0.
Subscription view
dscp-value: Specifies the DSCP value for packets sent to collectors, in the range of 0 to 63.
A greater DSCP value represents a higher priority.
If you execute this command multiple times in the same view, the most recent configuration takes effect.
# Set the DSCP value for packets sent to collectors to 12 for subscription A.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] dscp 12
encoding
Use encoding to specify the encoding format for pushed data.
Use undo encoding to restore the default.
encoding { gpb | json }
undo encoding
The encoding format for pushed data is JSON.
Subscription view
gpb: Specifies the GPB encoding format. This keyword is available only when the device uses the three-layer telemetry data model architecture to push data.
json: Specifies the JSON encoding format.
The device supports JSON encoding for all data available for subscription. However, it does not support GPB encoding for all data. With GPB encoding, the device will not push data that cannot be GPB encoded. When you choose GPB encoding for a subscription, make sure all data in the subscription can be encoded in GPB.
# Specify the three-layer architecture for telemetry data models and use GPB to encode data for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscrption A
[Sysname-telemetry-subscription-A] encoding gpb
grpc data-model
ipv4-address
Use ipv4-address to add an IPv4 collector to a destination group.
Use undo ipv4-address to remove an IPv4 collector from a destination group.
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv4 collectors.
Destination group view
ipv4-address: Specifies the IPv4 address of the collector.
port port-number: Specifies the listening port of the collector, in the range of 1 to 65535. The default is 50051.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the collector belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the collector belongs to the public network, do not specify this option.
One collector must have a different address, port, or VPN instance than the other collectors.
To add multiple collectors to a destination group, execute this command multiple times.
A destination group can have a maximum of five collectors.
To modify the collector configuration for a destination group that is already used by a subscription, you must remove the destination group from the subscription first.
# Add a collector that uses IPv4 address 192.168.21.21 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv4-address 192.168.21.21
subscription
ipv6-address
Use ipv6-address to add an IPv6 collector to a destination group.
Use undo ipv6-address to remove an IPv6 collector from a destination group.
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv6 collectors.
ipv6-address: Specifies the IPv6 address of the collector. It cannot be an IPv6 link-local address. For more information about IPv6 link-local addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
# Add a collector that uses IPv6 address 1::1 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv6-address 1::1
subscription
sensor path
Use sensor path to configure a sensor path.
Use undo sensor path to delete a sensor path.
sensor path path [ condition node node operator operator value value ]
undo sensor path path [ condition node node operator operator ]
No sensor paths exist.
Sensor group view
path: Specifies a data path by its complete name. The data path name is case insensitive. For information about the available paths, enter sensor path ?.
condition: Adds a data push condition.
node node: Specifies a node by its complete name, a case-insensitive string. For information about the available nodes, enter sensor path condition path node ?.
operator operator: Specifies an operator for the condition. Supported operators vary by node. Operators might include: eq (equal to), ge (greater than or equal to), gt (greater than), le (less than or equal to), lt (less than), and ne (not equal to),
value value: Specifies the reference value.
The device supports a maximum of 128 sensor paths. A sensor group can have a maximum of 128 sensor paths.
A sensor path can have a maximum of five data push conditions. The device pushes data of the sensor path to collectors only when all relevant conditions are met.
For sensor path ifmgr/statistics, you can specify a maximum of 64 filtering conditions. The device pushes data of the sensor path to collectors as long as one of the conditions is met.
·     Use the [ifindex=”index”] format to specify each filtering condition. The index is a case-insensitive string of 1 to 99 characters that represents the type and number or index of an interface.
·     The last character for index can be wildcard character (*), for example, sensor path ifmgr/statistics[ifindex="GigabitEthernet1/2/0/*"].
·     If you specify filtering conditions for this command, you cannot specify data push conditions, and vice versa.
To modify the sensor path configuration for a sensor group that is already used by a subscription, you must remove the sensor group from the subscription first.
# Configure sensor path ifmgr/devicecapabilities for sensor group test.
[Sysname] telemetry
[Sysname-telemetry] sensor-group test
[Sysname-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities
# Configure sensor path device/base for sensor group test so the device pushes data of the sensor path only when the uptime is greater than or equal to 377.
[Sysname] telemetry
[Sysname-telemetry-sensor-group-test] sensor path device/base condition node uptime operator ge value 377
sensor-group (subscription view)
subscription
Use sensor-group to specify a sensor group for a subscription.
Use undo sensor-group to remove a sensor group from a subscription.
sensor-group group-name [ sample-interval [ msec ] interval ]
undo sensor-group group-name
A subscription does not have a sensor group.
Subscription view
group-name: Specifies a sensor group by its name, a case-sensitive string of 1 to 31 characters.
sample-interval: Specifies that the sensor group sample and push data at intervals. If you do not specify this keyword, the sensor group samples and pushes data only when triggered by events.
msec: Specifies the data sampling interval in milliseconds. If you do not specify this keyword, specify the data sampling interval in seconds.
interval: Specifies the data sampling interval. If you do not specify the msec keyword, the value range is 1 to 86400. If you specify the msec keyword, the data sampling interval must be a multiple of 100 in the range of 100 to 900.
Specify the sample-interval interval option for periodic sensor paths and only for periodic sensor paths.
·     If you specify the option for event-triggered sensor paths, the sensor paths do not take effect.
·     If you do not specify the option for periodic sensor paths, the device does not sample or push data.
The specified sensor group must have been created by using the sensor-group command in telemetry view.
# Specify sensor group test for subscription A. Set the data sampling interval to 10 seconds.
[Sysname] telemetry
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
sensor path
sensor-group (telemetry view)
Use sensor-group to create a sensor group and enter its view, or enter the view of an existing sensor group.
Use undo sensor-group to delete a sensor group.
No sensor groups exist.
Telemetry view
group-name: Specifies the sensor group name, a case-sensitive string of 1 to 31 characters.
The device supports a maximum of 32 sensor groups.
To delete a sensor group that is already used by a subscription, you must remove the sensor group from the subscription first.
# Create a sensor group named test.
[Sysname] telemetry
subscription
source-address
Use source-address to specify the source IP address for packets sent to collectors.
Use undo source-address to restore the default.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo source-address
The device uses the primary IPv4 address of the output interface for the route to the collectors as the source address.
Subscription view
ipv4-address: Specifies an IPv4 address.
interface interface-type interface-number: Specifies an interface by its type and number. In the current software version, you must specify a loopback interface. The device will use the interface's primary IPv4 address as the source address. If the interface does not have a primary IPv4 address, the device uses the primary IPv4 address of the output interface for the route to the collectors.
ipv6 ipv6-address: Specifies an IPv6 address.
Changing the source address causes the device to reconnect to the gRPC server.
# Specify the source IPv4 address of 169.254.1.1 for packets sent to collectors.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] source-address 169.254.1.1
subscription
Use subscription to create a subscription and enter its view, or enter the view of an existing subscription.
Use undo sensor-group to delete a subscription.
subscription subscription-name
undo subscription subscription-name
No subscription exists.
Telemetry view
subscription-name: Specifies the subscription name, a case-sensitive string of 1 to 31 characters.
The device supports a maximum of 10 subscriptions.
# Configure a subscription named A.
[Sysname] telemetry
telemetry
Use telemetry to enter telemetry view.
telemetry
In telemetry view, you can configure telemetry parameters.
# Enter telemetry view.
[Sysname] telemetry
[Sysname-telemetry]
  • Become a Partner
  • Partner Resources
