- 14-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PTP commands
- 05-Network synchronization commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-NETCONF commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-Sampler commands
- 13-Mirroring commands
- 14-NetStream commands
- 15-IPv6 NetStream commands
- 16-TCP connection trace commands
- 17-Fast log output commands
- 18-Flow log commands
- 19-Information center commands
- 20-GOLD commands
- 21-Packet capture commands
| 04-PTP commands | 236.61 KB |
display ptp foreign-masters-record
ptp alarm-threshold clock-source-class
ptp alarm-threshold time-offset
ptp alarm-threshold time-offset-sum pk-pk
PTP commands
Only the default MDC supports PTP. Non-default MDCs do not support PTP or PTP commands. For more information about MDCs, see Virtual Technologies Configuration Guide.
display ptp clock
Use display ptp clock to display PTP clock information.
display ptp clock
This command does not display any information if you have not specified a PTP profile (PTP standard) or a PTP mode (PTP clock node type).
# Display PTP clock information.
<Sysname> display ptp clock
PTP profile : IEEE 1588 Version 2
PTP mode : BC
Slave only : No
Sync uncertain : Disabled
Clock state : Disabled
Clock ID : 62EA70-FFFE-AA0100
Clock type : Local
Clock domain : 1
Number of PTP ports : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 65535
Offset from master : 0 (ns)
Mean path delay : 0 (ns)
Steps removed : 0
Local clock time : Fri Jul 17 14:17:41 2020
Clock source info:
Clock Pri1 Pri2 Accuracy Class TimeSrc Direction In-Status Offset(log variance)
Local 128 128 254 248 160 N/A Active 65535
ToD0 128 128 32 6 32 N/A Inactive 65535
ToD1 128 128 32 6 32 N/A Inactive 65535
PTP profile |
PTP standard: · IEEE 1588 version 2. · ITU-T G.8275.1. |
PTP mode |
PTP clock node type: · BC. · E2ETC. · E2ETC-OC. · OC. · P2PTC. · P2PTC-OC. · T-BC. · T-TC. · T-TSC. |
Slave only |
Whether the OC operates in Slave only mode: · Yes. · No. |
Sync uncertain |
Whether the device is enabled to notify the downstream nodes of its time synchronization state: · Disabled. · Enabled. |
Clock state |
PTP clock state: · Disabled—The PTP clock state feature is disabled. · Free-Run—The PTP clock has never been synchronized to a time source and is not in the process of synchronizing to a time source. · Acquiring—The PTP clock is in the process of synchronizing to a time source. · Locked—The PTP clock has been synchronized to a time source. · Holdover—The PTP clock is in holdover state. |
Clock ID |
Clock ID for the device, which uniquely identifies a PTP device. |
Clock type |
Clock type of the device: · Local—Local clock. · ToD0—ToD 0 clock. · ToD1—ToD 1 clock. |
ToD direction |
ToD input or output: · IN—The device receives clock signals from an external ToD clock. · N/A—The device neither receives nor transmits ToD clock signals. This field is not displayed for a local clock. |
ToD delay time |
Delay correction value in nanoseconds for the ToD clock. This field is not displayed when the device is a local clock. |
Clock domain |
PTP domain where the device resides. |
Priority1 |
Priority 1 value for the PTP clock. |
Priority2 |
Priority 2 value for the PTP clock. |
Local priority |
Local priority of the PTP clock. This field is available only for the ITU-T G.8275.1 PTP profile. |
Class |
Time class of the device. |
Accuracy |
Time accuracy of the device. |
Offset (log variance) |
Offset of the grandmaster clock. |
Offset from master |
Offset from the master clock node (parent clock node), in nanoseconds. N/A indicates that information for this field is not obtained. |
Mean path delay |
Mean path delay, in nanoseconds. N/A indicates that information for this field is not obtained. |
Steps removed |
Hops from the grandmaster to the local clock node. N/A indicates that information for this field is not obtained. |
Clock source info |
Information about the clock source. |
Clock |
Clock source type: · Local—Local clock. · ToD0—ToD 0 clock. · ToD1—ToD 1 clock. |
Pri1 |
Priority 1 value of the clock source. |
Pri2 |
Priority 2 value of the clock source. |
LP |
Local priority of the clock source. (This field is available only for the ITU-T G.8275.1 PTP profile.) |
TimeSrc |
Time source of the clock source. |
Direction |
For a local clock source, this field displays N/A. For a ToD clock source, the values include: · IN—The device is configured to receive ToD clock signals. · Out—The device is configured to transmit ToD clock signals. · N/A—Whether to receive or transmit ToD clock signals is not configured. |
In-Status |
Whether the clock source is active: · Active. · Inactive. |
display ptp corrections
Use display ptp corrections to display PTP corrections that have occurred on a subordinate port.
The PTP corrections are displayed only when the following conditions are met:
· You have specified a PTP profile and PTP clock node type for the device.
· The device has a subordinate port and has performed time or frequency synchronization through the port.
If the subordinate port is changed, the recorded information will be cleared.
# Display PTP corrections that have occurred on a subordinate port.
<Sysname> display ptp corrections
Slave port Correction time Corrections(s,ns) Rate ratio
GE1/2/0/1 Mar 11 03:14:54 2012 0,74 0.999999973
GE1/2/0/1 Mar 11 03:14:55 2012 -1,17 0.999999980
Slave port |
Name of the subordinate port. |
Correction time |
Time when the correction occurred. |
Corrections(s,ns) |
Time corrections in seconds or nanoseconds. N/A indicates that no correction occurred this time. |
Rate ratio |
Ratio of the subordinate port rate to the master port rate. N/A indicates that no correction occurred this time. |
Use display ptp foreign-masters-record to display information about foreign master nodes.
display ptp foreign-masters-record [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about foreign master nodes for all interfaces.
Foreign master node information is displayed only when the following conditions are met:
· The PTP profile is IEEE 1588 version 2 or ITU-T G.8275.1.
· You have specified a PTP clock node type for the device.
· The device has a PTP port in slave or uncalibrated state.
# Display information about foreign master nodes for all interfaces.
<Sysname> display ptp foreign-masters-record
P1=Priority1, P2=Priority2, LP=LocalPriority, C=Class, A=Accuracy,
OSLV=Offset-scaled-log-variance, SR=Steps-removed
GM=Grandmaster
Interface Clock ID P1 P2 C A OSLV SR GM
GE1/2/0/1 88DF9E-FFFE-37A400 128 128 248 37 65535 0 Yes
Name of a PTP interface. |
Clock ID |
Clock ID of the foreign master node. |
LP |
Local priority of the interface. It will be used as the local priority of the peer node in BMC selection. This field is available only for the ITU-T G.8275.1 PTP profile. |
C |
Time class. |
A |
Time accuracy. |
OSLV |
SR |
Hops from the grandmaster to the local clock node. |
GM |
Whether the node represents the grandmaster clock: · Yes. · No. |
display ptp interface
Use display ptp interface to display PTP running information for one or all PTP interfaces.
display ptp interface [ interface-type interface-number | brief ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PTP running information for all PTP interfaces.
brief: Displays brief PTP running information for all PTP interfaces. If you do not specify this keyword, this command displays detailed PTP running information for the specified PTP interface or all PTP interfaces.
This command displays detailed PTP information only for PTP-enabled interfaces. The brief PTP running information can be displayed only when PTP is operating on the interface.
# Display brief PTP running information for all PTP interfaces.
<Sysname> display ptp interface brief
Name State Delay mechanism Clock step Asymmetry correction
GE1/2/0/1 Slave E2E Two 0
GE1/2/0/2 Passive E2E Two 0
# Display detailed PTP running information for GigabitEthernet 1/2/0/1.
<Sysname> display ptp interface gigabitethernet 1/2/0/1
Clock ID : 000FE2-FFFE-FF0000
Port number : 15
PTP version : 2
PTP enable : Enabled
Transport of PTP : User Datagram Protocol (IPv4)
Unicast destination address : 10.10.10.2
DSCP priority : 56
Port state : Slave
Unicast negotiate port role : Request-port
Force state : No
Clock step : Two
Asymmetry correction : 0
Delay mechanism : End to End
Announce interval (log mean) : 1
Announce receipt time out : 3
Sync interval (log mean) : 2
Delay request interval (log mean) : 2
Delay response interval (log mean) : 0
Peer delay request interval (log mean) : 0
Local priority : 128
NotSlave : FALSE
Name |
Name of the PTP interface. |
State |
States of the PTP interface: · Slave—Receives synchronization messages. · Uncalibrated—Temporary state before the interface enters Slave state. · Passive—Neither receives nor sends synchronization messages. A PTP interface is in passive state after it receives an announce messages. · Master—Sends synchronization messages. · Premaster—Temporary state before the interface enters Master state. · Listening—Neither receives nor sends synchronization messages. A PTP interface is in listening state after being initialized. · Faulty—PTP is running incorrectly. A PTP interface in faulty state does not process PTP messages. · Disabled—PTP is not running on the interface. A PTP interface in disabled state does not process PTP messages. · Initializing—The interface is initializing. A PTP interface in initializing state does not process PTP messages. · N/A—No PTP interface state is obtained. |
Delay mechanism |
Delay measurement mechanism: · End to End—Request-response mechanism. · Peer to Peer—Peer delay mechanism. |
Clock step |
Mode for carrying timestamps. The value is Two, indicating the two-step mode. |
Asymmetry correction |
Asymmetric delay correction value (in nanoseconds). |
Clock ID |
Clock ID of the device where the interface resides. |
PTP version |
PTP version number. The version number is always 2. |
PTP enable |
Whether PTP is enabled or disabled: · Enabled. · Disabled. |
Transport of PTP |
PTP messages are transported by: User Datagram Protocol (IPv4). |
Unicast destination address |
Destination IP address for unicast PTP messages that are transmitted over IPv4 UDP. This field is not displayed if the ptp unicast-destination command is not executed. |
DSCP priority |
DSCP value for PTP messages that are transmitted over IPv4 UDP. This field is not displayed if the ptp dscp command is not executed. |
VLAN |
VLAN ID for PTP messages. This field is not displayed if the ptp vlan command is not executed. |
Dot1p priority |
802.1p precedence for PTP messages. This field is not displayed if the ptp vlan command is not executed. |
Force state |
Whether the force state is configured: · Yes. · No. |
Announce interval (log mean) |
Announce message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Announce receipt time out |
Number of announcement intervals before the receiving node stops receiving announce messages. If a member node does not receive any announce message from the master node within the specified value, it considers the master node invalid. |
Sync interval (log mean) |
Sync message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Delay request interval (log mean) |
Minimum delay request message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Delay response interval (log mean) |
Delay response message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Peer delay request interval (log mean) |
Peer delay request message sending interval (in seconds) = 2interval (this field displays the value for the interval exponent). |
Local priority |
Priority of the peer node. This field is available only for the ITU-T G.8275.1 profile. |
NotSlave |
Whether or not the NotSlave feature is enabled. This field is available only for the ITU-T G.8275.1 profile. |
Mean path delay |
Mean path delay, in nanoseconds. |
display ptp parent
Use display ptp parent to display parent node (master node) information for the PTP device.
display ptp parent
The command does not display any information when any of the following conditions are met:
· No PTP profile is specified.
· No PTP clock node type is specified, or the PTP clock node type is TC or T-TC.
· The ptp active force-state command has been executed.
# Display parent node information for the PTP device.
<Sysname> display ptp parent
Parent clock:
Parent clock ID : 000FE2-FFFE-FF0005
Parent port number : 15
Observed parent offset (log variance) : N/A
Observed parent clock phase change rate : N/A
Grandmaster clock:
Grandmaster clock ID: 000FE2-FFFE-FF0000
Grandmaster clock quality:
Class : 248
Accuracy : 254
Priority1 : 128
Priority2 : 128
Table 5 Command output
Parent port number |
Outgoing interface number of the parent clock. |
Observed parent offset (log variance) |
Offset from the parent clock node. N/A indicates that information for this field is not obtained. |
Class |
Time class of the grandmaster clock. |
Accuracy |
Time accuracy of the grandmaster clock. |
Priority1 |
Priority 1 value of the grandmaster clock. |
Priority2 |
Priority 2 value of the grandmaster clock. |
display ptp path-trace
Use display ptp path-trace to display brief information about the PTP synchronization path from the GM to the device.
The command displays information correctly only after you have specified a PTP profile and a PTP clock node type.
# Display brief information about the PTP synchronization path from the GM to the device.
<Sysname> display ptp path-trace
Sequence number Clock ID
1 000FE2-FFFE-FF0000
2 000FE3-FFFE-F90000
3 000FE4-FFFE-F50000
4 000FE5-FFFE-F20000
5 000FE6-FFFE-F70000
Table 6 Command output
Sequence number |
Sequence number of the clock node. |
Clock ID |
ID of the clock node |
display ptp statistics
Use display ptp statistics to display PTP statistics.
display ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PTP statistics for all interfaces.
The command does not display any PTP statistics if you have not specified a PTP profile or a PTP clock node type.
# Display PTP statistics on GigabitEthernet 1/2/0/1.
<Sysname> display ptp statistics interface gigabitethernet 1/2/0/1
Received packets
Announce :0 Sync :0 Signaling :0
DelayReq :0 DelayResp :0 FollowUp :0
PdelayReq:0 PdelayResp:0 PdelayRespFollowUp :0
Sent packets
Announce :476 Sync :2543 Signaling :0
DelayReq :0 DelayResp :0 FollowUp :2542
PdelayReq:238 PdelayResp:0 PdelayRespFollowUp :0
Discarded packets
Table 7 Command output
Received packets |
Statistics about received PTP messages. |
Sent packets |
Statistics about sent PTP messages. |
Discarded packets |
Statistics about discarded PTP messages. |
display ptp time-property
Use display ptp time-property to display PTP clock properties.
This command does not display any information in any of the following circumstances:
· You have not specified a PTP standard or a clock node type.
· You have specified the clock node type as e2etc or p2ptc.
· You have executed the ptp active force-state command.
# Display PTP clock properties.
<Sysname> display ptp time-property
PTP clock time property:
Current UTC offset valid : True
Current UTC offset : 33
Leap59 : Yes
Leap61 : No
Time traceable : True
Frequency traceable : True
PTP timescale : True
Time source : 0xA0 (Internal oscillator)
Sync uncertain : False
Table 8 Command output
Current UTC offset valid |
Whether the UTC offset is valid: · True—Yes. · False—No. |
Current UTC offset |
Cumulative offset (in seconds) between the Coordinated Universal Time (UTC) of the grandmaster clock and the International Atomic Time (TAI). |
Leap59 |
Whether cumulative offset is minus 1: · Yes. · No. |
Leap61 |
Whether cumulative offset is plus 1: · Yes. · No. |
Time traceable |
Whether the PTP time is traceable: · True—Yes. · False—No. |
Frequency traceable |
Whether the PTP frequency is traceable: · True—Yes. · False—No. |
PTP timescale |
The possible timescales available for use by the grandmaster clock: · True—PTP timescale. · False—Non-PTP timescale. |
Time source |
Attributes of the grandmaster clock: · Atomic clock. · GPS. · Handset. · Internal oscillator. · NTP. · Other. · PTP. · Terrestrial radio. · Unknown. |
Sync uncertain |
Whether the upstream clock is not reliable: · True—The upstream clock is not reliable. · False—The upstream clock is reliable. |
ptp { tod0 | tod1 }
Use ptp { tod0 | tod1 } to configure ToD input or output.
Use undo ptp { tod0 | tod1 } to restore the default.
ptp { tod0 | tod1 } { input [ delay input-delay-time ] | output [ delay output-delay-time ] }
undo ptp { tod0 | tod1 } { input | output }
The device transmits ToD clock signals from ToD 0 and ToD 1. The transmit and receive delay correction value is 0 nanoseconds.
tod0: Specifies the ToD 0 clock.
tod1: Specifies the ToD 1 clock.
input: Configures the device to receive ToD clock signals.
delay input-delay-time: Specifies the receiving delay correction value in nanoseconds. The value is in the range of 0 to 2000000.The default value is 0.
output: Configures the device to transmit ToD clock signals as a master.
delay output-delay-time: Specifies the transmitting delay correction value in nanoseconds. The value is in the range of 0 to 1600. The default value is 0.
This command is available only after you specify a PTP profile and a PTP clock node type.
For the undo form of the command to take effect, first modify ToD input or output settings by executing this command.
Do not configure the device to receive both ToD 0 and ToD 1 clock signals.
# Configure the device to receive ToD clock signals from ToD 0 and set the receiving delay correction value to 1000 nanoseconds.
[Sysname] ptp profile 1588v2
[Sysname] ptp mode oc
[Sysname] ptp tod0 input delay 1000
ptp mode
ptp profile
Use ptp active force-state to activate the port role configuration.
Use undo ptp active force-state to restore the default.
The port role configuration is not activated.
A T-TSC or T-TSC-P clock node does not support this command.
After you change the role of a PTP port, you must execute this command to activate the port role configuration.
# Activate the port role configuration.
[Sysname] ptp active force-state
ptp force-state
ptp mode
ptp profile
Use ptp alarm-threshold clock-source-class to set the class threshold for the clock source.
Use undo ptp alarm-threshold clock-source-class to restore the default.
ptp alarm-threshold clock-source-class class-value
The class threshold for the clock source is 6.
class-value: Specifies a class threshold, in the range of 0 to 255.
Each PTP clock source has a class value. For a ToD clock source, you can set its class value by using the ptp clock-source command. The higher the value, the lower the class. When the class value of the clock source crosses the class threshold, the system outputs a log for notification.
This command is available only after you specify a PTP profile and PTP clock node type.
Only the IEEE 1588 version 2 and ITU-T G.8275.1 PTP profiles support this command.
# Set the class threshold to 20 for the clock source.
[Sysname] ptp profile g8275.1
[Sysname] ptp clock mode t-bc
[Sysname] ptp alarm-threshold clock-source-class 20
ptp clock mode
ptp clock-source
ptp profile
Use ptp alarm-threshold time-offset to set the time-offset threshold between the external reference clock and the PTP clock.
Use undo ptp alarm-threshold time-offset to restore the default.
ptp alarm-threshold time-offset time-offset-value
The time-offset threshold between the external reference clock and the PTP clock is 500 ns.
time-offset-value: Specifies the time-offset threshold between the external reference clock and the PTP clock, in the range of 200 to 1000, in ns.
If the device uses an external ToD reference clock, it calculates the time offset between the external reference clock and the PTP clock at a pre-defined interval (not configurable). When the offset exceeds the threshold, the device outputs a log for notification.
# Set the threshold to 800 for the time offset between the external reference clock and the PTP clock.
[Sysname] ptp alarm-threshold time-offset 800
ptp mode
ptp profile
Use ptp alarm-threshold time-offset-sum pk-pk to set the time-offset-sum peak-to-peak threshold.
Use undo ptp alarm-threshold time-offset-sum pk-pk to restore the default.
ptp alarm-threshold time-offset-sum pk-pk threshold-value
The time-offset-sum peak-to-peak threshold is 500 ns.
threshold-value: Sets the time-offset-sum peak-to-peak threshold in the range of 0 to 2000, in ns.
The PTP module calculates the time-offset-sum peak-to-peak value at specific intervals and compares the value with the threshold configured by this command. If the value is larger than the threshold, the system outputs a log for notification.
# Set the time-offset-sum peak-to-peak threshold to 1500 ns.
[Sysname] ptp mode t-bc
[Sysname] ptp alarm-threshold time-offset-sum pk-pk 1500
ptp mode
ptp profile
ptp announce-interval
Use ptp announce-interval to set the interval for sending announce messages.
Use undo ptp announce-interval to restore the default.
ptp announce-interval interval
When the PTP profile is IEEE 1588 version 2, the interval argument value is 1 and the announce message sending interval is 2 (21) seconds.
When the PTP profile is ITU-T G.8275.1, the interval argument value is –3 and the announce message sending interval is 1/8 (2-3) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending announce messages. The value range for the interval argument is 0 to 4 for the IEEE 1588 version 2 PTP profile and –3 to 6 for the ITU-T G.8275.1 PTP profile.
# Set the announce message sending interval to 4 (22) seconds on GigabitEthernet 1/2/0/1.
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] ptp announce-interval 2
ptp mode
ptp profile
ptp announce-timeout
Use ptp announce-timeout to set the timeout multiplier for the announce message receiving interval.
Use undo ptp announce-timeout to restore the default.
ptp announce-timeout multiple-value
The timeout multiplier for the announce message receiving interval is 3.
multiple-value: Sets the timeout multiplier for the announce message receiving interval, in the range of 2 to 10.
A master node sends announce messages to the member nodes at the specified interval. If a member node does not receive any announce message from the master node after the timeout expires, it determines that the master node is invalid. The timeout = timeout multiplier × interval at which the master node sends announce messages.
To ensure a stable PTP network, set the timeout multiplier for receiving announce messages to a value in the range of 5 to 7.
# Set the timeout multiplier for the announce message sending interval to 5 on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp announce-timeout 5
ptp mode
ptp profile
ptp asymmetry-correction
Use ptp asymmetry-correction to set the asymmetric delay correction time.
Use undo ptp asymmetry-correction to restore the default.
ptp asymmetry-correction { minus | plus } value
The asymmetric delay correction time is 0 nanoseconds, which means that delay correction is not performed.
minus: Subtracts the specified asymmetric delay correction value.
plus: Adds the specified asymmetric delay correction value.
value: Specifies the asymmetric delay correction value in the range of 0 to 2000000 nanoseconds.
# Set the asymmetric delay correction time to 100 nanoseconds on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp asymmetry-correction plus 100
ptp mode
ptp profile
ptp clock-source
Use ptp clock-source to configure clock source parameters.
Use undo ptp clock-source to restore the default.
Local clock source:
ptp clock-source local { accuracy acc-value | class class-value | time-source ts-value }
undo ptp clock-source local { accuracy | class | time-source }
ToD clock source:
ptp clock-source { tod0 | tod1 } { accuracy acc-value | class class-value | grandmaster-clockid clock-id | offsetscaled-logvariance value | time-source ts-value }
undo ptp clock-source { tod0 | tod1 } { accuracy | class | grandmaster-clockid | offsetscaled-logvariance | time-source }
The clock ID of a GM clock is 000000-0000-000000.
· ITU-T G.8275.1 PTP profile
¡ T-TSC clock node type
- Local clock source—The accuracy value is 254, the time class value is 255, the offset (log variance) value is 65535, and the time source value is 160. The four values are not configurable.
- ToD clock source—The accuracy value is 254, the time class value is 255, the offset (log variance) value is 65535, and the time source value is 32.
¡ T-BC or T-TC clock node type (default PTP technical standard)
- Local clock source—The accuracy value is 37, the time class value is 248, the offset (log variance) value is 65535, and the time source value is 160.
- ToD clock source—The accuracy value is 32, the time class value is 6, the offset (log variance) value is 65535, and the time source value is 32.
¡ Local clock source—The accuracy value is 37, the time class value is 248, the offset (log variance) value is 65535, and the time source value is 160. The offset (log variance) value not configurable.
¡ ToD clock source—The accuracy value is 32, the time class value is 6, the offset (log variance) is 65535, and the time source value is 32.
local: Specifies the local clock.
accuracy acc-value: Specifies the accuracy of the ToD clock, in the range of 0 to 255. A smaller value indicates a higher accuracy. Table 9 shows the description for clock accuracy values.
Table 9 Clock accuracy value description
Clock accuracy value (in hexadecimal format) |
00 through 1F |
Reserved. |
20 |
Less than 25 nanoseconds (1 nanosecond = 10-9 second). |
21 |
Less than 100 nanoseconds. |
22 |
Less than 250 nanoseconds. |
23 |
Less than 1 microsecond (10-6 second). |
24 |
Less than 2.5 microseconds. |
25 |
Less than 10 microseconds. |
26 |
Less than 25 microseconds. |
27 |
Less than 100 microseconds. |
28 |
Less than 250 microseconds. |
29 |
Less than 1 millisecond (10-3 second). |
2A |
Less than 2.5 milliseconds. |
2B |
Less than 10 milliseconds. |
2C |
Less than 25 milliseconds. |
2D |
Less than 100 milliseconds. |
2E |
Less than 250 milliseconds. |
2F |
Less than 1 second. |
30 |
Less than 10 seconds. |
31 |
More than 10 seconds. |
32 through 7F |
Reserved. |
80 through FD |
For use by alternate PTP profiles. |
FE |
Unknown. |
FF |
Reserved. |
class class-value: Specifies the time class of the clock, in the range of 0 to 255. A smaller value indicates a higher time class. Table 10 shows the description for clock classes. The values not listed in the table are reserved by the protocol. As a best practice, do not use those values. The clock's time class is an attribute of the device. For a local clock source, keep its default time class and do not modify it as a best practice.
Table 10 Clock class description
Clock class (in decimal format) |
6 |
The clock node synchronizes its time to the master reference time source. PTP assigns a time table to the clock node. A clock node with time class 6 cannot become a member clock of any other clocks in the domain. |
7 |
The former time class is 6. The clock node cannot synchronize its time to a time source. It enters the reappointment mode and meets the reappointment conditions. PTP assigns a time table to the clock node. A clock node with time class 7 cannot become a member clock of any other clocks in the domain. |
13 |
The clock node synchronizes its time to a time source. ARB assigns a time table to the clock node. A clock node with time class 13 cannot become a member clock of any other clocks in the domain. |
14 |
The former time class is 13. The clock node cannot synchronize its time to a time source. It enters the reappointment mode and meets the reappointment conditions. ARB assigns a time table to the clock node. A clock node with time class 14 cannot become a member clock of any other clocks in the domain. |
52 |
The clock node with time class 7 becomes optional clock A because it does not meet the reappointment conditions. A clock node with time class 52 cannot become a member clock of any other clocks in the domain. |
58 |
The clock node with time class 14 becomes optional clock A because it does not meet the reappointment conditions. A clock node with time class 58 cannot become a member clock of any other clocks in the domain. |
187 |
The clock node with time class 7 becomes optional clock B because it does not meet the reappointment conditions. A clock node with time class 187 can become a member clock of another clock in the domain. |
193 |
The clock node with time class 14 becomes optional clock B because it does not meet the reappointment conditions. A clock node with time class 193 can become a member clock of another clock in the domain. |
248 |
Default time class value. |
255 |
Clock node operating in slave-only mode. |
grandmaster-clockid clock-id: Specifies the GM clock ID. The clock-id argument is in the XXXXXX-XXXX-XXXXXX format. X represents a hexadecimal number. A full 0 number is not supported. This option is not available for a local clock source. For a ToD clock source, you must specify this option.
offsetscaled-logvariance value: Specifies the offset (log variance). The value is in the range of 0 to 65535. This option is not available for a local clock source.
time-source ts-value: Specifies the clock attribute value in the range of 0 to 255. Table 11 shows the description for the clock attribute values (those not listed are reserved for the protocol).
Table 11 GM attribute value description
GM attribute values (in hexadecimal format) |
10 |
Atomic clock. |
20 |
GPS. |
30 |
Terrestrial radio. |
40 |
PTP. |
50 |
NTP. |
60 |
Handset. |
90 |
Other. |
A0 |
Internal oscillator. |
F0 to FE |
FF |
Reserved. |
You can execute this command multiple times to configure different parameters. If you configure a parameter multiple times, the most recent configuration takes effect.
# Set the time accuracy for the ToD 0 clock to 44.
[Sysname] ptp clock-source tod0 accuracy 44
ptp mode
ptp profile
ptp technical-standard
ptp clock-step
Use ptp clock-step to configure the mode for carrying timestamps.
Use undo ptp clock-step to restore the default.
ptp clock-step two-step
undo ptp clock-step
Two-step mode is used for carrying timestamps.
two-step: Specifies the two-step mode.
# Specify the two-step timestamp carrying mode on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp clock-step two-step
ptp mode
ptp profile
ptp delay-mechanism
Use ptp delay-mechanism to specify a PTP delay measurement mechanism.
Use undo ptp delay-mechanism to restore the default.
ptp delay-mechanism { e2e | p2p }
When the PTP profile is IEEE 1588 version 2 or ITU-T G.8275.1, the request-response delay measurement mechanism applies.
e2e: Specifies the request-response mechanism.
p2p: Specifies the peer delay mechanism.
For the IEEE 1588 version 2 PTP profile, you can configure this command only for BCs and OCs. The delay measurement mechanism is Request_Response for E2ETCs and E2ETC+OCs and Peer Delay for P2PTCs and P2PTC+OCs. You cannot change the delay measurement mechanism for these clock nodes.
The ITU-T G.8275.1 PTP profile does not support this command and supports only the request-response delay measurement mechanism.
# Specify the OC clock type. On GigabitEthernet 1/2/0/1, specify the request-response delay measurement mechanism (e2e).
[Sysname-GigabitEthernet1/2/0/1] ptp delay-mechanism e2e
ptp mode
ptp profile
ptp destination-mac
Use ptp destination-mac to configure the destination MAC address for PTP messages.
Use undo ptp destination-mac to restore the default.
ptp destination-mac mac-address
The destination MAC address for non-peer delay messages is 011B-1900-0000.
The destination MAC address for peer delay messages is 0180-C200-000E.
mac-address: Specifies the destination MAC address for PTP unicast messages as any unicast MAC address or specifies the destination MAC address for non-peer delay multicast messages as 0180-C200-000E or 011B-1900-0000.
# Set the destination MAC address for non-peer delay messages to 0180-C200-000E on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp destination-mac 0180-c200-000e
ptp mode
ptp profile
ptp domain
Use ptp domain to specify a PTP domain.
Use undo ptp domain to restore the default.
ptp domain domain-number
undo ptp domain
When the PTP profile is IEEE 1588 version 2, the device is in PTP domain 0.
When the PTP profile is ITU-T G.8275.1, the device is in PTP domain 24.
domain-number: Specifies a PTP domain by its number in the range of 0 to 255. For the ITU-T G.8275.1 PTP profile, the value range for the argument is 24 to 43.
# Configure the PTP domain number to use for the device as 2.
[Sysname] ptp domain 2
ptp mode
ptp profile
ptp dscp
Use ptp dscp to set a DSCP value for PTP messages that are transmitted over IPv4 UDP.
Use undo ptp dscp to restore the default.
ptp dscp dscp
undo ptp dscp
The DSCP value is 56 for PTP messages that are transmitted over IPv4 UDP.
dscp: Sets a DSCP value in the range of 0 to 63 for PTP messages.
This command is available only after you specify a PTP profile and a PTP clock node type. The ITU-T G.8275.1 profile does not support this command.
This command takes effect only if PTP messages are transmitted over IPv4 UDP.
# Set the DSCP value to 63 for PTP messages transmitted over IPv4 UDP on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp transport-protocol udp
[Sysname-GigabitEthernet1/2/0/1] ptp dscp 63
ptp mode
ptp profile
ptp enable
Use ptp enable to enable PTP.
Use undo ptp enable to disable PTP.
ptp enable
undo ptp enable
PTP is disabled.
On an OC or T-TSC clock node, you can enable PTP only on one port.
As a best practice, enable PTP on an interface after you configure PTP parameters.
To enable PTP on a Layer 3 Ethernet interface that has been assigned to a VPN instance, you must specify this VPN instance in the ptp source ip-address vpn-instance vpn-instance-name command if PTP messages are to be transmitted in multicast mode over IPv4 UDP.
# Specify the OC clock node type and enable PTP on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp enable
# Specify the E2ETC clock node type, and enable PTP on GigabitEthernet 1/2/0/1 and GigabitEthernet 1/2/0/2.
[Sysname] ptp mode e2etc
[Sysname-GigabitEthernet1/2/0/1] interface gigabitethernet 1/2/0/2
[Sysname-GigabitEthernet1/2/0/2] ptp enable
ptp mode
ptp profile
ptp source
ptp force-state
Use ptp force-state to configure a role for a PTP port.
Use undo ptp force-state to restore the default.
ptp force-state { master | passive | slave }
The PTP port role is automatically calculated by the BMC algorithm.
master: Specifies the PTP port as a master port.
passive: Specifies the PTP port as a passive port.
slave: Specifies the PTP port as a subordinate port.
By default, the PTP port roles are automatically negotiated based on the BMC algorithm. If you use this command to change the role of one PTP port, all the other PTP ports in the PTP domain stop working. For these PTP ports to function, you must specify roles for each of them by using this command. As a best practice, enable automatic negotiation of PTP port roles based on the BMC algorithm.
The T-TSC and T-TSC-P clock nodes do not support this command.
You can configure only one subordinate port for a device.
After you change the role of a PTP port, you must execute the ptp active force-state command to activate the port role configuration.
# Specify the OC clock node type and configure GigabitEthernet 1/2/0/1 as a subordinate port.
[Sysname-GigabitEthernet1/2/0/1] ptp force-state slave
ptp mode
ptp profile
ptp slave-only
ptp local-priority
Use ptp local-priority to configure a local priority for an interface.
Use undo ptp local-priority to restore the default.
ptp local-priority local-priority
The local priority of an interface is 128.
local-priority: Specifies a priority in the range of 1 to 255. The lower the value, the higher the priority.
This command is available only after you specify a PTP profile and a PTP clock node type. Only the ITU-T G.8275.1 PTP profile supports this command.
An announce message does not carry the local priority of the clock node. Under the ITU-T G.8275.1 PTP profile, each PTP-enabled interface on a clock node has a local priority. This priority will be used as the local priority of the peer node in BMC selection and is one of the factors that determine whether the peer node can be elected as the GM.
# Set the local priority for GigabitEthernet1/2/0/1 to 10.
[Sysname-GigabitEthernet1/2/0/1] ptp local-priority 10
ptp mode
ptp profile
ptp max-steps-removed
Use ptp max-steps-removed to specify the maximum number of removed steps (clock nodes) from the GM to the device.
Use undo ptp max-steps-removed to restore the default.
ptp max-steps-removed step-removed-value
The maximum number of removed steps is 255 from the GM to the device.
step-removed-value: Specifies the maximum number of removed steps from the GM to the device, in the range of 1 to 255.
If the number of removed steps from the GM to the device exceeds the maximum number, the device cannot synchronize time through PTP.
# Set the maximum number of removed steps from the GM to the device to 20.
[Sysname] ptp max-steps-removed 20
ptp mode
ptp profile
ptp min-delayreq-interval
Use ptp min-delayreq-interval to set the minimum interval for sending delay request messages.
Use undo ptp min-delayreq-interval to restore the default.
ptp min-delayreq-interval interval
When the PTP profile is IEEE 1588 version 2, the value of the interval argument is 0 and the minimum interval for sending delay request messages is 1 (20) second.
When the PTP profile is ITU-T G.8275.1, the value of the interval argument is –4 and the minimum interval for sending delay request messages is 1/16 (2-4) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending delay request messages. The value range for the interval argument is –4 to 6. For the ITU-T G8275.2 PTP profile, the value range for the interval argument is –5 to 0.
When a member clock receives a Sync message, it responds by sending a Delay_Req message and starts a timer defined by this command. The member clock will not send another Delay_Req message until it receives a Sync message after the timer expires.
In PTP multicast transport mode, this command takes effect only when configured on the master clock. The master clock sends the value to a member clock through PTP messages to control the interval for the member clock to send Delay_Req messages. To view the value on a member clock, execute the display ptp interface command on the member clock.
In PTP unicast transport mode, this command takes effect when configured on member clocks. It does not take effect when configured on the master clock.
# Set the minimum interval to 4 (22) seconds for sending delay request messages on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp min-delayreq-interval 2
ptp mode
ptp profile
ptp syn-interval
ptp mode
Use ptp mode to specify a clock node type for the device.
Use undo ptp mode to restore the default.
ptp mode { bc | e2etc | e2etc-oc | oc | p2ptc | p2ptc-oc | t-bc |t-tc | t-tsc }
undo ptp mode
No clock node type is specified for the device.
bc: Specifies the boundary clock (BC) type.
e2etc: Specifies the end-to-end transparent clock (E2ETC) type.
e2etc-oc: Specifies the E2ETC+OC type.
oc: Specifies the ordinary clock (OC) type.
p2ptc: Specifies the peer-to-peer transparent clock (P2PTC) type.
p2ptc-oc: Specifies the P2PTC+OC type.
t-bc: Specifies the telecom boundary clock (T-BC) type.
t-tc: Specifies the telecom transparent clock (T-TC) type.
t-tsc: Specifies the telecom time slave clock (T-TSC) type.
CAUTION: If you change the clock node type for the device, all settings except for the PTP profile will be removed. |
This command is available only after you specify a PTP profile.
· When the PTP profile is IEEE 1588 version 2, you cannot specify the T-TC, T-BC, or T-TSC clock node type.
· When the PTP profile is ITU-T G.8275.1, you cannot specify the T-TC, T-BC, or T-TSC clock node type.
You can specify only one clock node type for a device.
Changing or removing the clock node type will restore the default settings of the PTP profile.
# Specify the OC clock node type for the device.
ptp profile
ptp notslave disable
Use ptp notslave disable to disable the NotSlave feature.
Use undo ptp notslave disable to restore the default.
The NotSlave feature is enabled on a PTP interface.
The NotSlave feature, available only for the ITU-T G.8275.1 PTP profile, enables a PTP port to select the clock node where it resides as the master node. You can use this feature to control the master/member role of the clock node. For automatic master/member clock node selection in a PTP domain under the ITU-T G.8275.1 PTP profile, you must disable NotSlave on all PTP ports.
Only the T-BC and T-TC clock node types under the ITU-T G.8275.1 PTP profile support this command.
By default, the ports on a T-BC clock node are in master-only mode. To use a port on a T-BC clock node as a subordinate port, first execute the ptp notslave disable command on the port.
# Disable the NotSlave feature on GigabitEthernet1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp notslave disable
ptp mode
ptp profile
ptp path-trace disable
Use ptp path-trace disable to disable PTP path tracing.
Use undo ptp path-trace disable to enable PTP path tracing.
PTP path tracing is enabled.
PTP path tracing traces the clock nodes that the clock signals traverse from the GM to the device. The system can obtain complete path tracing information only when all clock nodes on the path are enabled with PTP path tracing. If a device on the path does not support PTP path tracing, disable this feature to prevent PTP intercommunication issues.
This command is available only after you have specified a PTP profile and PTP clock node type.
# Disable PTP path tracing.
[Sysname] ptp mode bc
[Sysname] ptp path-trace disable
ptp mode
ptp profile
ptp pdelay-req-interval
Use ptp pdelay-req-interval to set the interval for sending peer delay request messages.
Use undo ptp pdelay-req-interval to restore the default.
ptp pdelay-req-interval interval
The interval argument value is 0 and the interval for sending peer delay request messages is 1 (20) second.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending peer delay request messages. The value range for the interval argument is –4 to 6. If the PTP profile is IEEE 1588 version 2, the value range for the interval argument is 0 to 5.
# Set the interval to 4 (22) seconds for sending peer delay request messages on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp pdelay-req-interval 2
ptp mode
ptp profile
ptp port-mode
Use ptp port-mode to configure the interface type as OC for a TC+OC (including E2ETC+OC and P2PTC+OC) clock node.
Use undo ptp port-mode to restore the default.
ptp port-mode oc
undo ptp port-mode
All interfaces on an E2ETC+OC or a P2PTC+OC clock node is TC type.
oc: Specifies the OC interface type.
This command is available only after you specify a PTP profile and a PTP clock node type. Only E2ETC+OC and P2PTC+OC clock nodes support this command.
The ITU-T G.8275.1 PTP profile does not support this command.
# Specify the P2PTC+OC clock node type for the device. Configure the interface type for GigabitEthernet 1/2/0/1 as OC.
[Sysname] ptp mode p2ptc-oc
[Sysname-GigabitEthernet1/2/0/1] ptp port-mode oc
ptp mode
ptp profile
ptp priority clock-source
Use ptp priority clock-source to configure the priority for a clock source.
Use undo ptp priority clock-source to restore the default.
ptp priority clock-source { local | tod0 | tod1 } { priority1 priority1 | priority2 priority2 }
undo ptp priority clock-source { local | tod0 | tod1 } { priority1 | priority2 }
When the PTP profile is IEEE 1588 version 2, the priority 1 and priority 2 values are both 128.
When the PTP profile is ITU-T G.8275.1, the priority 1 value is 128. The priority 2 value is 128 for both T-BC and T-TC clock nodes and 225 for a T-TSC clock node. The local priority value is 128.
local-priority local-priority: Specifies the local priority for the clock. The value is in the range of 0 to 255. A numerically smaller value has higher priority. This option is available only for the ITU-T G.8275.1 PTP profile.
priority1 priority1: Specifies priority 1 for the clock. The value is in the range of 0 to 255 for the IEEE 1588 version 2 PTP profile and 128 for the ITU-T G.8275.1 PTP profile.
priority2 priority2: Specifies priority 2 for the clock. The value is in the range of 0 to 255 for the IEEE 1588 version 2 PTP profile. For the ITU-T G.8275.1 PTP profile, the value is in the range of 0 to 255 for T-BC and T-TC clock nodes and 255 for a T-TSC clock node. A numerically smaller value has higher priority.
The local priority of a clock will not be carried in PTP announce messages.
# Set priority 1 to 10 for the local clock.
[Sysname] ptp priority clock-source local priority1 10
ptp mode
ptp profile
ptp profile
Use ptp profile to specify a PTP profile.
Use undo ptp profile to restore the default.
ptp profile { 1588v2 | g8275.1 }
undo ptp profile
No PTP profile is specified for a device.
1588v2: Specifies the IEEE 1588 version 2 PTP profile.
g8275.1: Specifies the ITU-T G.8275.1 PTP profile.
You must first specify a PTP profile before configuring PTP commands.
Changing or removing a PTP profile clears all settings under the PTP profile.
# Specify the IEEE 1588 version 2 PTP profile.
ptp slave-only
Use ptp slave-only to configure the OC to operate only as a member clock.
Use undo ptp slave-only to restore the default.
ptp slave-only
undo ptp slave-only
An OC can operate either as a master clock or a member clock.
This command is applicable only to OCs and is available only after you specify a PTP profile and a PTP clock node type.
You can execute the ptp force-state command to specify a subordinate port as a master port or passive port even if the OC operates as a member clock.
# Specify the clock node type as OC for the device. Configure the OC to operate only as a member clock.
[Sysname] ptp slave-only
ptp force-state
ptp mode
ptp profile
ptp source
Use ptp source to configure the source IP address for UDP-encapsulated multicast PTP messages.
Use undo ptp source to remove the specified source IP address for UDP-encapsulated multicast PTP messages.
ptp source ip-address [ vpn-instance vpn-instance-name ]
undo ptp source ip-address [ vpn-instance vpn-instance-name ]
No source IP address is configured for UDP-encapsulated multicast PTP messages.
ip-address: Specifies the source IP address for UDP-encapsulated multicast PTP messages.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance used for communication between the local device and the peer device. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the peer device belongs to the public network, do not specify this option.
This command is available only after you specify a PTP profile and a PTP clock type. The ITU-T G.8275.1 PTP profile does not support this command.
This command takes effect only when PTP messages are transmitted over IPv4 UDP in multicast mode.
If a PTP-enabled Layer 3 Ethernet interface has been assigned to a VPN instance, you must specify the VPN instance in the ptp source ip-address vpn-instance vpn-instance-name command.
# Specify 3.5.1.5 as the source address for UDP-encapsulated multicast PTP messages.
[Sysname] ptp source 3.5.1.5
ptp mode
ptp profile
ptp syn-interval
Use ptp syn-interval to set the interval for sending Sync messages.
Use undo ptp syn-interval to restore the default.
ptp syn-interval interval
When the PTP profile is IEEE 1588 version 2, the interval argument value is 0 and the interval for sending Sync messages is 1 (20) second.
When the PTP profile is ITU-T G.8275.1, the interval argument value is –4 and the interval for sending Sync messages is 1/16 (2-4) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending Sync messages. The value range for the interval argument is -4 to 6for the ITU-T G.8275.1 PTP profile, –1 to 1 for the IEEE 1588 version 2 PTP profile.
# Set the Sync message sending interval to 2 (21) seconds on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] ptp syn-interval 1
ptp mode
ptp profile
ptp sync-uncertain enable
Use ptp sync-uncertain enable to enable the device to notify the downstream nodes of its time synchronization state.
Use undo ptp sync-uncertain enable to disable the device from notifying the downstream nodes of its time synchronization state.
The device does not notify the downstream nodes of its time synchronization state.
By default, the device transfers only the locked and unlocked status of the upstream node to the downstream nodes, and does not transfer its locked or unlocked status to the downstream nodes.
After this command is configured, the device notifies the downstream nodes of its locked and unlocked status through the synchronizationUncertain flag in the announce messages. The downstream nodes do not synchronize to the device when they receive information that the device time is unlocked and synchronize to the device when they receive information that the device time is locked.
This command is available only after you specify a PTP profile and a PTP clock node type. The PTP profile must be IEEE 1588 version 2 or ITU-T G.8275.1.
# Enable the device to notify the downstream nodes of its time synchronization state.
[Sysname] ptp sync-uncertain enable
ptp mode
ptp profile
Use ptp transport-protocol to specify the IPv4 UDP transport protocol for PTP messages.
Use undo ptp transport-protocol to restore the default.
The IEEE 1588 version 2 and ITU-T G.8275.1 PTP profiles transport PTP messages over IEEE 802.3/Ethernet.
udp: Specifies the IPv4 UDP transport protocol.
# Specify the IPv4 UDP transport protocol for PTP messages on GigabitEthernet 1/2/0/1.
ptp mode
ptp profile
Use ptp unicast-destination to configure the destination IP address for UDP-encapsulated unicast PTP messages.
Use undo ptp unicast-destination to restore the default.
ptp unicast-destination ip-address
undo ptp unicast-destination ip-address
No destination IP address is configured for UDP-encapsulated unicast PTP messages.
ip-address: Specifies the destination IP address for UDP-encapsulated unicast PTP messages.
This command is available only after you specify a PTP profile and a PTP clock node type. The ITU-T G.8275.1 PTP profile does not support this command.
This command takes effect only for UDP-encapsulated unicast PTP messages.
# Configure 10.10.10.2 as the destination address for UDP-encapsulated unicast PTP messages.
[Sysname-GigabitEthernet1/2/0/1] ptp unicast-destination 10.10.10.2
ptp mode
ptp profile
ptp utc
Use ptp utc to set the correction date for the UTC.
Use undo ptp utc to remove the correction date configured for the UTC.
ptp utc { leap59-date | leap61-date } date
undo ptp utc { leap59-date | leap61-date }
No correction date is configured for the UTC.
leap59-date: Adjusts the UTC at the last minute (23:59) of the specified date so that the UTC is one second slower than the TAI.
leap61-date: Adjusts the UTC at the last minute (23:59) of the specified date so that the UTC is one second faster than the TAI.
date: Sets the date to adjust the UTC, in the format of YYYY/MM/DD. The value range for YYYY and MM is 2000 to 2035 and 1 to 12, respectively. The value range for DD depends on the specified month. For the configuration to take effect, do not specify a date earlier than the current date.
This command takes effect only when configured on the master clock node, and the local clock of the master clock node is the GM.
Specify either the leap59-date or leap61-date keyword in this command. If you execute this command multiple times, the most recent configuration takes effect.
# Assume the current date is August 8, 2010. Specify the clock node type as BC for the device. Adjust the UTC at the last minute of December 31, 2010 so that the UTC is one second slower than the TAI.
[Sysname] ptp utc leap59-date 2010/12/31
ptp mode
ptp profile
ptp utc offset
Use ptp utc offset to set the cumulative offset between Coordinated Universal Time (UTC) and International Atomic Time (TAI).
Use undo ptp utc offset to restore the default.
ptp utc offset utc-offset
undo ptp utc offset
The cumulative offset between UTC and TAI is 0 seconds.
utc-offset: Sets the cumulative offset between UTC and TAI, in seconds. The value is in the range of 0 to 999.
An offset exists between UTC and TAI. The device displays the UTC time. However, PTP uses TAI for time synchronization. For the device to synchronize correct time to other clock nodes in the PTP domain when its local clock is selected as the GM, configure this command to correct the offset between UTC and TAI.
You can configure this command only after you have specified a PTP profile and PTP mode for the device.
# Set the cumulative offset to 37 seconds between the UTC and TAI.
[Sysname] ptp utc offset 37
ptp mode
ptp profile
ptp vlan
Use ptp vlan to specify a VLAN tag for PTP messages.
Use undo ptp vlan to restore the default.
ptp vlan vlan-id [ dot1p dot1p-value ]
undo ptp vlan [ dot1p ]
PTP messages do not have a VLAN tag.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094.
dot1p dot1p-value: Specifies an 802.1p precedence for PTP messages, in the range of 0 to 7. The default 802.1p precedence is 7 (the highest).
# Specify VLAN 2 and set the 802.1p precedence to 6 for PTP messages.
[Sysname-GigabitEthernet1/2/0/1] ptp vlan 2 dot1p 6
ptp mode
ptp profile
reset ptp statistics
Use reset ptp statistics to clear PTP statistics.
reset ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears PTP statistics on all interfaces.
# Clear PTP statistics on GigabitEthernet 1/2/0/1.
<Sysname> reset ptp statistics interface gigabitethernet 1/2/0/1
