| 03-OTN commands | 77.13 KB |
OTN commands
alarm-detect
Use alarm-detect to enable an alarm and set the action to take when the alarm is triggered on a DWDM interface.
Use undo alarm-detect to restore the default.
alarm-detect { fec-tca | odu-ais | odu-lck | odu-oci | opu-plm | otu-biae | otu-sd | otu-lom | otu-oom | pm-bdi | pm-tim | r-lof | r-los | r-oof | sm-bdi | sm-iae | sm-tim } * action link-down
alarm-detect all
undo alarm-detect { fec-tca | odu-ais | odu-lck | odu-oci | opu-plm | otu-biae | otu-sd | otu-lom | otu-oom | pm-bdi | pm-tim | r-lof | r-los | r-oof | sm-bdi | sm-iae | sm-tim } *
undo alarm-detect all
All alarms are disabled on a DWDM interface.
DWDM interface view
fec-tca: Specifies the FEC threshold crossing alarm.
odu-ais: Specifies the ODU alarm indication signal alarm.
odu-lck: Specifies the ODU locked alarm.
odu-oci: Specifies the ODU open connection indication alarm.
opu-plm: Specifies the OPU payload mismatch alarm.
otu-biae: Specifies the OTU backward incoming alignment error alarm.
otu-sd: Specifies the OTU signal degradation alarm.
otu-lom: Specifies the OTN loss of multiframe alarm. This alarm is generated if the OTU-OOM alarm lasts for 3 ms.
otu-oom: Specifies the OTN out of multiframe alarm.
pm-bdi: Specifies the ODU path monitoring backward defect indication alarm.
pm-tim: Specifies the ODU path monitoring TTI mismatch alarm.
r-lof: Specifies the OTN loss of frame alarm.
r-los: Specifies the OTN loss of signal alarm.
r-oof: Specifies the OTN out of frame alarm.
sm-bdi: Specifies the OTU section monitoring backward defect indication alarm.
sm-iae: Specifies the OTU section monitoring incoming alignment error alarm.
sm-tim: Specifies the OTU section monitoring TTI mismatch alarm.
all: Specifies all alarms.
This command enables the device to shut down a DWDM interface when an enabled alarm is triggered on the interface.
# Configure DWDM 1/2/2/1 to go down when the OTU-TIM alarm is triggered on the interface.
[Sysname] controller dwdm 1/2/2/1
[Sysname-DWDM1/2/2/1] alarm-detect otu-tim action link-down
controller dwdm
Use controller dwdm to enter DWDM interface view.
controller dwdm interface-number
interface-number: Specifies a DWDM interface number.
# Enter the view of DWDM 1/2/1/1.
[Sysname] controller dwdm 1/2/1/1
[Sysname-DWDM1/2/1/1]
display controller dwdm
Use display controller dwdm to display DWDM interface information.
display controller [ dwdm [ interface-number ] ]
dwdm [ interface-number ]: Specifies a DWDM interface number. If you specify only the dwdm keyword, this command displays information about all DWDM interfaces. If you do not specify the dwdm keyword or the interface-number argument, this command displays information about the following interfaces:
· CE1/PRI interfaces.
· CE3 interfaces.
· CPOS interfaces.
· CT1/PRI interfaces.
· CT3 interfaces.
· DWDM interfaces.
# Display information about DWDM 1/2/1/1.
<Sysname> display controller dwdm 1/2/1/1
DWDM 1/2/1/1
Current state:DOWN
Description:DWDM1/2/1/1 Interface
Port BW: 100G, Transceiver max BW: 111.8Gbps
Frame-format is OTN
fec-tca trigger threshold 1E-3 interval 3 recover-threshold 1E-4 interval 30
Sd otu threshold 1E-6
FEC mode: standard
OTN alarm: none
OTU layer: LOS LOF OOF LOM OOM TIM BDI DEG IAE BIAE FEC-TCA
ODU layer:
PM: TIM BDI DEG LCK OCI AIS
TCM1: BDI LCK OCI AIS IAE BIAE
TCM2: BDI LCK OCI AIS IAE BIAE
TCM3: BDI LCK OCI AIS IAE BIAE
TCM4: BDI LCK OCI AIS IAE BIAE
TCM5: BDI LCK OCI AIS IAE BIAE
TCM6: BDI LCK OCI AIS IAE BIAE
OPU layer: NONE
TTI:
OTU TTI Expect: ""
OTU TTI Sent: ""
ODU-PM TTI Expect: ""
ODU-PM TTI Sent: "//"
Last clearing of counters: 10:08:16 06/18/2020
DWDM Error Counter:
FEC: total error 0, fec_0_error 0, fec_1_error 0
uncorrected error: 0
SM: bip 0, bei 0
PM: bip 0, bei 0
DWDM 1/2/1/1 Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Port BW: 100G, Transceiver max BW: 111.8Gbps |
Interface bandwidth and maximum transmission bandwidth. |
TTI: OTU TTI Expect: "" OTU TTI Sent: "" ODU-PM TTI Expect: "" ODU-PM TTI Sent: "//" |
TTI information: · TTI that the OTU layer expects to receive. · TTI sent by the OTU layer. · TTI that the OTU-PM layer expects to receive. · TTI sent by the OTU-PM layer. |
FEC total error |
Total number of FEC-corrected errors. |
fec_0_error |
Number of FEC-corrected 0 bit errors. |
fec_1_error |
Number of FEC-corrected 1 bit errors. |
uncorrected error |
Number of uncorrected errors. |
SM bip |
Number of OTU bit interleaved parity errors. |
SM bei |
Number of OTU backward error indication errors. |
PM bip |
Number of ODU bit interleaved parity errors. |
PM bei |
Number of ODU backward error indication errors. |
fec
Use fec to set the FEC mode on a DWDM interface.
Use undo fec to restore the default.
fec { enhanced | standard | none }
undo fec
The FEC mode is set to standard.
DWDM interface view
enhanced: Specifies enhanced FEC mode.
standard: Specifies standard G.709 FEC mode.
none: Does not set the FEC mode.
FEC improves the transmission reliability and signal transmission distance by using an algorithm to correct errors in data transmission.
You must set the same FEC mode on the DWDM interfaces at the two ends of a link.
# Set the FEC mode to enhanced on DWDM 1/2/1/1.
[Sysname-DWDM1/2/1/1] fec enhanced
fec-tca recover
Use fec-tca recover to set the FEC-TCA alarm recovering threshold and detection interval.
Use undo fec-tca recover to restore the default.
fec-tca recover { threshold recover-coefficient recover-power | interval recover-time-interval }*
The FEC-TCA alarm recovering threshold is e-7, and the detection interval is 30 seconds.
DWDM interface view
threshold recover-coefficient recover-power: Specifies the recovering threshold for the FEC-TCA alarm, in the format of xe-y. The recover-coefficient argument specifies the value of x, an integer in the range of 1 to 9. The recover-power argument specifies the value of y, an integer in the range of 1 to 8.
interval recover-time-interval: Specifies the detection interval for clearing the FEC-TCA alarm. The value range for the recover-time-interval argument is 10 to 100 seconds, and the step is 10 seconds.
The FEC-TCA alarm recovering threshold is set in scientific notation xe-y. The meanings of the parameters are as follows:
· x—Coefficient.
· e—Integer 10.
· -y—Power of e.
# Set the FEC-TCA alarm recovering threshold to e-6 and the detection interval to 10 seconds on DWDM 1/2/1/1.
[Sysname-DWDM1/2/1/1] fec-tca recover threshold 1 6 interval 10
fec-tca trigger
Use fec-tca trigger to set the FEC-TCA alarm triggering threshold and detection interval.
Use undo fec-tca trigger to restore the default.
fec-tca trigger { threshold trigger-coefficient trigger-power | interval trigger-time-interval }*
The FEC-TCA alarm triggering threshold is e-6, and the detection interval is 3 seconds.
DWDM interface view
threshold trigger-coefficient trigger-power: Specifies the triggering threshold for the FEC-TCA alarm, in the format of xe-y. The trigger-coefficient argument specifies the value of x, an integer in the range of 1 to 9. The trigger-power argument specifies the value of y, an integer in the range of 1 to 7.
interval trigger-time-interval: Specifies the detection interval for generating the FEC-TCA alarm. The value range for the trigger-time-interval argument is 1 to 10 seconds.
The FEC-TCA alarm triggering threshold is set in scientific notation xe-y. The meanings of the parameters are as follows:
· x—Coefficient.
· e—Integer 10.
· -y—Power of e.
# Set the FEC-TCA alarm triggering threshold to e-4 and the detection interval to 5 seconds on DWDM 1/2/1/1.
[Sysname-DWDM1/2/1/1] fec-tca trigger threshold 1 4 interval 5
otn-mode
Use otn-mode enable to enable OTN mode on an interface.
Use undo otn-mode enable to restore the default.
otn-mode enable
An interface is operating in LAN mode.
100-GE interface view
During startup, the switch automatically creates a DWDM interface for each 100-GE interface that supports OTN. You can configure OTN settings on DWDM interfaces. The OTN settings take effect after you enable OTN mode on the corresponding Ethernet interfaces.
An interface operating in OTN mode transmits packets of the G.709 frame format.
You must enable OTN mode on the Ethernet interfaces at the two ends of a link.
# Enable OTN mode on HundredGigE 1/2/1/1.
[Sysname] interface hundredgige 1/2/1/1
[Sysname-HundredGigE1/2/1/1] otn-mode enable
reset counters controller dwdm
Use reset counters controller dwdm to clear bit error statistics on DWDM interfaces.
reset counters controller dwdm [ interface-number ]
interface-number: Specifies a DWDM interface number. If you do not specify this argument, the command clears bit error statistics on all DWDM interfaces.
# Clear bit error statistics on all DWDM interfaces.
<Sysname> reset counters controller dwdm
sd otu threshold
Use sd otu threshold to set the OTU-SD alarm threshold.
Use undo sd otu threshold to restore the default.
sd otu threshold coefficient power
The OTU-SD alarm threshold is e-6.
DWDM interface view
coefficient: Specifies the bit error rate coefficient (x in xe-y). The value range for this argument is 1 to 9, and the default value is 1.
power: Specifies the bit error rate power (y in xe-y). The value range for this argument is 1 to 8, and the default value is 6.
The OTU-SD alarm threshold is set in scientific notation xe-y. The meanings of the parameters are as follows:
· x—Coefficient.
· e—Integer 10.
· -y—Power of e.
# Set the OTU-SD alarm threshold to e-7 on DWDM 1/2/1/1.
[Sysname-DWDM1/2/1/1] sd otu threshold 1 7
tti
Use tti to set the OTU TTI or ODU-PM TTI.
Use undo tti to restore the default.
tti { odu-pm | otu } { expected | sent } ascii value
undo tti { odu-pm | otu } { expected | sent }
The TTI is empty (0 in ASCII format).
DWDM interface view
odu-pm: Specifies the ODU-PM TTI.
otu: Specifies the OTU TTI.
expected: Specifies the expected TTI.
sent: Specifies the sent TTI.
ascii: Uses the ASCII format.
value: Specifies a TTI string in the format of SAPI/DAPI/operator-specific identifier. The maximum length of the TTI string is 64 characters. The maximum length of the SAPI string is 15 characters. The maximum length of the DAPI string is 15 characters. The maximum length of the operator-specific identifier string is 32 characters. Segments of the TTI string are separated by a forward slash (/). You can omit a segment by not entering the corresponding string.
For a link, make sure the sent TTI of one end is the same as the expected TTI of the other end.
The TTI must contain a minimum of two forward slashes (/).
# Set the OTU TTI to *!@#&/123/abc on DWDM 1/2/1/1.
[Sysname-DWDM1/2/1/1] tti otu sent ascii *!@#&/123/abc
