09-Security Command Reference
HomeSupportResource CenterSwitchesH3C S6800 Switch SeriesH3C S6800 Switch SeriesTechnical DocumentsCommandCommand ReferencesH3C S6800 Switch Series Command References-Release 26xx-6W10609-Security Command Reference
05-Web authentication commands
05-Web authentication commands 97.15 KB
display web-auth
Use display web-auth to display Web authentication configuration and running status on interfaces.
display web-auth [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays Web authentication configuration for all interfaces.
# Display Web authentication configuration on Ten-GigabitEthernet 1/0/1.
<Sysname> display web-auth interface ten-gigabitethernet 1/0/1
 Global Web-auth parameters  :
  Proxy Port Numbers         : Not configured
  Total online web-auth users: 1
 Ten-GigabitEthernet1/0/1  is link-up
   Port role                  : Authenticator
   Web-auth domain            : my-domain
   Auth-Fail VLAN             : Not configured
   Offline-detect             : Not configured
   Max online users           : 1024
   Web-auth enable            : Enabled
Global Web authentication configuration.
Proxy Port Numbers
Port numbers of the Web proxy servers.
Total number of online Web authentication users on the device.
State of the interface:
·         link-up—The interface is both administratively and physically up.
·         link-down—The interface is down.
Port role
Role of the port. The port functions only as an Authenticator.
Web-auth domain
ISP domain used by Web authentication.
Auth-fail VLAN
Auth-Fail VLAN for Web authentication. This field displays Not configured if no Auth-Fail VLAN is configured.
Offline-detect
Interval of Web authentication user detection. This field displays Not configured if online detection for Web authentication users is disabled.
Max online users
Maximum number of Web authentication users allowed on the interface.
Web-auth enable
State of Web authentication:
·         Enabled.
·         Disabled.
Total number of online Web authentication users on the interface.
display web-auth free-ip
Use display web-auth free-ip to display Web authentication-free subnets.
# Display Web authentication-free subnets.
<Sysname> display web-auth free-ip
       Free IP
                          : 1.1.0.0        255.255.0.0
                          : 1.2.0.0        255.255.0.0
web-auth free-ip
display web-auth server
Use display web-auth server to display Web authentication server information.
display web-auth server [ server-name ]
server-name: Specifies a Web authentication server name, a case-sensitive string of 1 to 32 characters. If you do not specify a Web authentication server, this command displays information about all Web authentication servers.
# Display information about Web authentication server aaa.
<Sysname> display web-auth server aaa
Web-auth server: aaa
  IP                       : 8.8.8.8
  Port                     : 80
  URL                      : http://8.8.8.8/portal/
  Redirect-wait-time    : 5
  URL parameters         : Not configured
Web-auth server
Name of the Web authentication server.
IP
IP address of the Web authentication server.
Port
Port number of the Web authentication server.
URL
Redirection URL of the Web authentication server.
Redirect-wait-time
Time before redirecting an authenticated user to the webpage requested by the user.
URL parameters
Parameters in the redirection URL.
display web-auth user
Use display web-auth user to display information about online Web authentication users on interfaces.
display web-auth user [ interface interface-type interface-number | slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about online Web authentication users on all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays online Web authentication user information for all member devices.
# Display information about online Web authentication users on Ten-GigabitEthernet 1/0/1.
<Sysname> display web-auth user interface ten-gigabitethernet 1/0/1
User name: user1
  MAC address: 0000-2700-b076
  Access interface: Ten-GigabitEthernet 1/0/1
  Initial VLAN: 1
  Authorization VLAN: N/A
  Authorization ACL ID: N/A
Total number of online Web authentication users.
User Name
Name of the online Web authentication user.
MAC address
MAC address of the online Web authentication user.
Access interface
Access interface of the online Web authentication user.
Initial VLAN
Initial VLAN of the user before the user passes Web authentication.
Authorization VLAN
Authorization VLAN ID of the online Web authentication user.
Authorization ACL number of the online Web authentication user.
Status of user profile of the online Web authentication user:
·         N/A—No user profile is authorized.
·         Active—The authorized user profile is applied to the user access interface successfully.
·         Inactive—The authorized user profile is not applied to the user access interface or the user profile does not exist on the device.
ip
Use ip to specify the IP address and port number for a Web authentication server.
Use undo ip to restore the default.
ip ipv4-address port port-number
undo ip
No IP address or port number is specified for a Web authentication server.
Web authentication server view
ipv4-address: Specifies the IPv4 address of the Web authentication server. This IP address is that of a Layer 3 interface on the access device and must be routable to and from the Web authentication user.
port port-number: Specifies the port number of the Web authentication server, in the range of 1 to 65535.
User guidelines
As a best practice, use the IP address of a loopback interface as the IP address of the Web authentication server. A loopback interface has the following advantages:
·          The status of a loopback interface is stable. This can avoid authentication page access failures caused by interface failures.
·          A loopback interface does not forward received packets. This can avoid impacting system performance when there are many network access requests.
The port number of the Web authentication server must be the same as the listening port of the local portal Web service. For more information about the local portal Web service configuration, see portal authentication in Security Configuration Guide.
# Enter the view of Web authentication server wbs.
[Sysname] web-auth server wbs
# Specify 192.168.1.1 as the IP address and 8080 as the port number for Web authentication server wbs.
[Sysname-web-auth-server-wbs] ip 192.168.1.1 port 8080
url
tcp-port
redirect-wait-time
Use redirect-wait-time to set the redirection wait time. After a user passes Web authentication, the device waits for the specified period of time before redirecting the user to the specified webpage.
Use undo redirect-wait-time to restore the default.
redirect-wait-time period
The redirection wait time is 5 seconds.
period: Specifies the redirection wait time in the range of 1 to 90 seconds.
After a user passes Web authentication and is assigned an authorization VLAN, the user might need to change the IP address of the authentication client. To ensure that the redirection URL can be successfully opened, set the redirection wait time to be greater than the time that the user takes to update the IP address of the client.
# Set the redirection wait time for authenticated users to 10 seconds.
[Sysname-web-auth-server-wbs] redirect-wait-time 10
url
Use url to specify the redirection URL for a Web authentication server.
Use undo url to restore the default.
url url-string
undo url
No redirection URL is specified for a Web authentication server.
url-string: Specifies the redirection URL for the Web authentication server, a case-sensitive string of 1 to 256 characters.
The redirection URL is a URL that can be accessed through standard HTTP or HTTPS. The redirection URL should start with http:// or https://. If the redirection URL does not start with http:// or https://, the system determines that the URL begins with http://.
The IP address and port number in the URL must be the same as the IP address and port number of the Web authentication server.
# Specify http://192.168.1.1:80/portal/ as the redirection URL for Web authentication server wbs.
[Sysname-web-auth-server-wbs] url http://192.168.1.1:80/portal/
ip
tcp-port
url-parameter
Use url-parameter to add parameters to the redirection URL of Web authentication.
Use undo url-parameter to delete parameters from the redirection URL of Web authentication.
url-parameter parameter-name { original-url | source-address | source-mac | value expression }
undo url-parameter parameter-name
No URL parameters are added to the redirection URL of Web authentication.
parameter-name: Specifies a URL parameter name, a case-sensitive string of 1 to 32 characters. Content of the parameter is determined by the following keyword you specify.
original-url: Specifies the URL of the original webpage that a portal user visits.
source-address: Specifies the user IP address.
source-mac: Specifies the user MAC address.
value expression: Specifies a custom case-sensitive string of 1 to 256 characters.
You can repeat this command to add multiple URL parameters to the redirection URL of Web authentication. For example, to add the user IP address and a custom string of http://www.abc.com/welcome to the redirection URL, execute the following commands:
·          url-parameter userip source-address.
·          url-parameter userurl value http://www.abc.com/welcome.
The device will redirect Web requests from IP address 1.1.1.1 to the URL at http://192.168.1.1/portal?userip=1.1.1.1&userurl=http://www.abc.com/welcome.
If you execute this command multiple times to configure the same URL parameter, the most recent configuration takes effect.
When you configure the parameter-name argument in this command, you must use the URL parameter name supported by the Web browser. Different Web browsers support different URL parameter names.
# Add parameters userip and userurl to the redirection URL of portal Web server wbs.
[Sysname-web-auth-server-wbs] url-parameter userip source-address
[Sysname-web-auth-server-wbs] url-parameter userurl value http://www.abc.com/welcome
web-auth server
web-auth auth-fail vlan
Use web-auth auth-fail vlan to specify an Auth-Fail VLAN for Web authentication.
Use undo web-auth auth-fail vlan to restore the default.
web-auth auth-fail vlan authfail-vlan-id
No Auth-Fail VLAN is specified for Web authentication.
authfail-vlan-id: Specifies the Auth-Fail VLAN ID in a range of 1 to 4094. The specified VLAN must already exist.
User guidelines
After you configure this command on an interface, users who failed Web authentication on the interface can access resources in the Auth-Fail VLAN. You must also configure the IP address of the server that provides the resources as an authentication-free IP address.
To make the Auth-Fail VLAN take effect, you must also enable MAC-based VLAN on the interface, and set the subnet of the Auth-Fail VLAN as the Web authentication-free subnet.
Because MAC-based VLAN takes effect only on Hybrid ports, Auth-Fail VLAN also takes effect only on Hybrid ports.
If a user fails Web authentication, the device maps the MAC address of the user to the Auth-Fail VLAN.
You cannot delete the VLAN that has been configured as an Auth-Fail VLAN. To delete this VLAN, first cancel the Auth-Fail VLAN configuration by using undo web-auth auth-fail vlan command.
If a VLAN is specified as the super VLAN, do not configure this VLAN as an Auth-Fail VLAN of an interface. If a VLAN is specified as an Auth-Fail VLAN of an interface, do not configure this VLAN as a super VLAN.
# Specify VLAN 5 as Web authentication Auth-Fail VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname–Ten-GigabitEthernet1/0/1] port link-type hybrid
[Sysname–Ten-GigabitEthernet1/0/1] mac-vlan enable
[Sysname–Ten-GigabitEthernet1/0/1] web-auth auth-fail vlan 5
display web-auth
web-auth domain
Use web-auth domain to specify an authentication domain for Web authentication users on an interface.
Use undo web-auth domain to restore the default.
web-auth domain domain-name
No authentication domain is specified for Web authentication users on an interface.
domain-name: Specifies an ISP authentication domain name, a case-insensitive string of 1 to 255 characters.
User guidelines
After you configure this command, the device uses the authentication domain for authentication, authorization and accounting (AAA) of the Web authentication users on the interface.
# Specify domain my-domain as the authentication domain of Web authentication users on Ten-GigabitEthernet 1/0/1.
[Sysname–Ten-GigabitEthernet1/0/1] web-auth domain my-domain
web-auth enable
Use web-auth enable to enable Web authentication.
Use undo web-auth enable to disable Web authentication.
web-auth enable apply server server-name
Web authentication is disabled.
server-name: Specifies the Web authentication server name, a case-sensitive string of 1 to 32 characters.
User guidelines
Use this command to enable Web authentication on an interface and specify a Web authentication server.
For Web authentication to operate correctly, do not enable port security or configure the port security mode on the Layer 2 Ethernet interface enabled with Web authentication.
# Enable Web authentication and specify Web authentication server wbs on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] web-auth enable apply server wbs
web-auth server
web-auth free-ip
Use web-auth free-ip to specify a Web authentication-free subnet.
Use undo web-auth free-ip to restore the default.
web-auth free-ip ip-address { mask-length | mask }
undo web-auth free-ip { ip-address { mask-length | mask } | all }
No Web-authentication-free subnets exist.
ip-address: Specifies the Web authentication-free subnet address.
mask-length: Specifies the mask length of the Web authentication-free subnet address, in the range of 0 to 32.
mask: Specifies a mask for the Web authentication-free subnet in dotted decimal notation.
all: Specifies all Web authentication-free subnets.
User guidelines
Web authentication users can access resources in Web authentication-free subnets without being authenticated.
You can repeat this command to configure multiple Web authentication-free subnets.
# Configure subnet 192.168.0.0/24 as a Web authentication-free subnet.
[Sysname] web-auth free-ip 192.168.0.0 24
web-auth max-user
Use web-auth max-user to set the maximum number of Web authentication users allowed on an interface.
Use undo web-auth max-user to restore the default.
web-auth max-user max-number
undo web-auth max number
The maximum number of Web authentication users on an interface is 1024.
max-number: Specifies the maximum number of Web authentication users allowed on an interface. The value range for this argument is 1 to 2048.
User guidelines
If the specified maximum number is smaller than the number of current online Web authentication users on the interface, the limit can be set successfully. The limit does not impact the online Web authentication users. However, the device does not allow new Web authentication users to log in from the interface until the number drops down below the limit.
A large number of Web authentication users might cause high CPU usage. As a best practice, set the maximum number of Web authentication users to a reasonable value according to the device condition.
This command specifies the maximum number of only IPv4 Web authentication users.
# On Ten-GigabitEthernet 1/0/1, set the maximum number of Web authentication users to 32.
[Sysname-Ten-GigabitEthernet1/0/1] web-auth max-user 32
display web-auth
web-auth offline-detect
Use web-auth offline-detect to enable online detection of Web authentication users.
Use undo web-auth max-user to disable online detection of Web authentication users.
web-auth offline-detect interval interval
undo web-auth offline-detect interval
Online detection of Web authentication users is disabled.
interval: Specifies the Web authentication user detection interval, in the range of 60 to 65535 seconds.
User guidelines
This feature enables the device to detect packets of an online user at the specified detection interval. If no packet from the user is received within the interval, the device logs out the user and notifies the RADIUS server to stop accounting for the user.
To prevent the device from mistakenly logging out users, set the detection interval to be the same as the aging time of MAC address entries.
# On Ten-GigabitEthernet 1/0/1, enable online detection of Web authentication users and set the detection interval to 3600 seconds.
[Sysname-Ten-GigabitEthernet1/0/1] web-auth offline-detect interval 3600
web-auth proxy port
Use web-auth proxy port to add the port number of a Web proxy server, so that HTTP requests forwarded by the Web proxy server trigger Web authentication.
Use undo web-auth proxy port to delete one or all Web proxy server port numbers.
web-auth proxy port port number
undo web-auth proxy port { port-number | all }
No Web proxy server port numbers are configured on the device.
port number: Specifies a Web proxy server TCP port number, in the range of 1 to 65535.
all: Specifies all Web proxy server TCP port numbers.
User guidelines
By default, proxied HTTP requests cannot trigger Web authentication but are silently dropped. To allow such HTTP requests to trigger Web authentication, specify the port numbers of the Web proxy servers on the device.
You can repeat this command to add the port numbers of multiple Web proxy servers.
If a user's browser uses the Web Proxy Auto-Discovery (WPAD) protocol to discover Web proxy servers, you must perform the following tasks:
·          Add the port numbers of the Web proxy servers on the device.
·          Configure authentication-free rules to allow user packets destined for the IP address of the WPAD server to pass without authentication.
·          For Web authentication to support Web proxy:
·          You must add the port numbers of the Web proxy servers on the device.
·          Users must make sure their browsers that use a Web proxy server do not use the proxy server for the listening IP address of the local portal Web service. Then, HTTP packets that the Web authentication user sends to the local portal Web service are not sent to the Web proxy server.
# Add the Web proxy server TCP port number of 7777 for Web authentication.
[Sysname] web-auth proxy port 7777
web-auth server
Use web-auth server to create a Web authentication server and enter its view, or enter the view of an existing Web authentication server.
Use undo web-auth server to delete a Web authentication server.
web-auth server server-name
undo web-auth server server-name
No Web authentication servers exist.
User guidelines
In Web authentication server view, you can configure the following parameters and features for the Web authentication server:
·          IP address of the server.
·          Redirection URL.
·          Parameters to be carried in the redirection URL.
# Create a Web authentication server named wbs and enter its view.
