09-Security Command Reference
HomeSupportResource CenterSwitchesH3C S6800 Switch SeriesH3C S6800 Switch SeriesTechnical DocumentsCommandCommand ReferencesH3C S6800 Switch Series Command References-Release 26xx-6W10609-Security Command Reference
00-Preface
00-Preface 100.83 KB
Preface
This command reference describes security configuration commands, including:
·          Commands for configuring identity authentication features (such as AAA and PKI).
·          Commands for access security features (such as 802.1X, MAC authentication, portal, and port security).
·          Commands for data security features (such as public key management, IPsec, SSL, SSH, Crypto engine and FIPS).
·          Commands for attack protection features (such as IP source guard, ARP attack protection, MFF, uRPF, and Attack detection and prevention).
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators working with the S6800 switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
