03-Layer 2-LAN Switching Command Reference
HomeSupportResource CenterH3C S12500X-AF & S12500-X & S9800 Switch Series Command References(R27xx)-6W10303-Layer 2-LAN Switching Command Reference
15-DRNI commands
15-DRNI commands 156.70 KB
DRNI commands
display drni consistency
Use display drni consistency to display information about the configuration consistency check done by DRNI.
display drni consistency { type1 | type2 } { global | interface interface-type interface-number }
type1: Specifies type 1 configuration consistency check.
type2: Specifies type 1 configuration consistency check.
global: Specifies global information.
interface interface-type interface-number: Specifies a DR interface by its type and number.
# Display global information about type 1 configuration consistency check.
<Sysname> display drni consistency type1 global
VLAN consistency check: Success
Local IPP interface link type: Access
Peer IPP interface link type: Access
Local IPP interface PVID: 1
Peer IPP interface PVID: 1
STP consistency check: Success
Local global STP protocol state: Enabled
Peer global STP protocol state: Enabled
Local STP mode: MSTP
Peer STP mode: MSTP
Local MST region name: text
Peer MST region name: text
Local MSTP revision level: 0
Peer MSTP revision level: 0
MSTP VLAN-to-instance mappings: Consistent
STP-enabled VLANs: Consistent
# Display global information about type 2 configuration consistency check.
<Sysname> display drni consistency type2 global
Local VLAN interfaces:
  2-10, 15, 20-30, 40, 50
Peer VLAN interfaces:
The passing VLANs-tagged or PVID on Local IPP:
  1
The passing VLANs-tagged or PVID on Peer IPP:
  1
Invalid VLANs on Local IPP interface:
  None
# Display information about type 1 configuration consistency check on DR interface Bridge-Aggregation 1.
<Sysname> display drni consistency type1 interface bridge-aggregation 1
LAGG consistency check: Success
Local aggregation mode: Dynamic
Peer aggregation mode: Dynamic
Local STP protocol state: Enabled
Peer STP protocol state: Enabled
VLAN consistency check :Success
Local link type: Trunk
Peer link type: Trunk
Local PVID: 10
Peer PVID: 10
# Display information about type 2 configuration consistency check on DR interface Bridge-Aggregation 1.
<Sysname> display drni consistency type2 interface bridge-aggregation 1
The passing VLANs-tagged on Local DR interface:
  None
The passing VLANs-tagged on Peer DR interface:
  None
The passing VLANs-untagged on Local DR interface:
  1
The passing VLANs-untagged on Peer DR interface:
  1
Invalid VLANs on Local DR interface:
  None
Feature consistency check
Result of configuration consistency check for a feature:
·     Success.
·     Failure.
VLAN interfaces on the local or peer device. These fields display VLAN interfaces that meet the following conditions:
·     The interface is up.
·     The IPP has been assigned to the corresponding VLANs.
VLANs of which the local IPP forwards tagged traffic or PVID of which the IPP forwards traffic. This field does not include VLANs permitted on the IPP but have not been created yet.
VLANs of which the peer IPP forwards tagged traffic or PVID of which the IPP forwards traffic. This field does not include VLANs permitted on the IPP but have not been created yet.
VLANs of which the local IPP cannot forward traffic because of incomplete or inconsistent VLAN settings:
·     VLANs to which the IPP is assigned as an untagged member (PVID not included).
·     VLANs that contain the local IPP but do not contain the peer IPP.
If no invalid VLANs exist, this field displays None.
VLANs of which the local or peer DR interface forwards tagged traffic. These fields do not include VLANs permitted on the DR interfaces but have not been created yet.
VLANs of which the local or peer DR interface forwards untagged traffic. These fields do not include VLANs permitted on the DR interfaces but have not been created yet.
VLANs of which the local DR interface cannot forward traffic because of incomplete or inconsistent VLAN settings. A VLAN is in this list if it meets one of the following conditions:
·     The VLAN is permitted on the local DR interface, but it is not in the passing VLANs-tagged or PVID list on the local or peer IPP.
·     The VLAN is in the passing VLANs-tagged or PVID list on the local or peer IPP, but it is not permitted on the local DR interface.
·     The VLAN has been created on the local DR member device and is permitted on both local and DR interfaces, but it has not been created on the DR peer yet.
A VLAN is permitted on an interface if you have assigned the interface to the VLAN as a tagged or untagged member port.
display drni drcp statistics
Use display drni drcp statistics to display DRCPDU statistics.
display drni drcp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 aggregate interface by its type and number. If you do not specify this option, the command displays the DRCPDU statistics about the IPP and all DR interfaces.
# Display DRCPDU statistics.
<Sysname> display drni drcp statistics
 * indicates the port is the IPP.
Interface type:
BAGG -- Bridge-Aggregation, Tun  -- Tunnel
Interface     State     Sent     Received     Error      Unknown
*BAGG1        UP        6758     5576         50         121
 BAGG5        UP        3324     3300         68         36
 BAGG6        UP        256      124          23         19
 BAGG7        UP        45       41           8          6
Abbreviated interface name. The name of the IPP is prefixed with an asterisk (*).
Physical state of the interface:
·     UP.
·     DOWN.
Sent
Number of sent DRCPDUs.
Received
Number of received DRCPDUs.
Error
Number of error DRCPDUs.
Unknown
Number of unrecognized DRCPDUs.
display drni keepalive
Use display drni keepalive to display DR keepalive packet statistics.
# Display DR keepalive packet statistics.
<Sysname> display drni keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 135642 sec 501 ms
Last keepalive packet sending status: Successful
Last keepalive packet sending time: 2013.03.18 18:23:53 986 ms
Last keepalive packet receiving status: Successful
Last keepalive packet receiving time: 2013.03.18 18:23:54 99 ms
Distributed relay keepalive parameters:
Destination IP address: 10.0.0.2
Source IP address: 10.0.0.1
Keepalive UDP port : 6400
Keepalive vpn-instance : vpn1
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
State of the DR peer:
·     Unknown—No DR peer is detected because the destination IP address of keepalive packets is not specified.
·     Up—The DR peer is up.
·     Down—The DR peer is down.
Time period for which the DR peer has been up.
Result of the most recent keepalive packet transmission:
·     Successful.
·     Failed.
Most recent time when a keepalive packet was sent. If the device has not sent any keepalive packets, this field displays N/A.
Result of the most recent keepalive packet receiving attempt:
·     Successful.
·     Failed.
Most recent time when a keepalive packet was received. If the device has not received any keepalive packets, this field displays N/A.
Destination IP address of keepalive packets sent by the device.
Source IP address
Source IP address of keepalive packets sent by the device.
Keepalive UDP port
Destination UDP port of keepalive packets.
VPN instance for keepalive packets.
Keepalive interval
Interval at which the device sends keepalive packets.
Keepalive timeout
Keepalive timeout timer.
Keepalive hold time
Keepalive hold timer setting. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of an IPL down event.
drni keepalive destination
drni keepalive hold-time
drni keepalive interval
display drni mad verbose
Use display drni mad verbose to display detailed DRNI MAD information.
# Display detailed DRNI MAD information. (Applicable to Release 2710 and earlier.)
<Sysname> display drni mad verbose
DRNI MAD DOWN state    : No
Restore delay          : 30 s
MAD status             : Normal
System number  Keepalive source IP                       UDP port
1              1.1.1.1                                   1000
Excluded ports(user-configured):
Excluded ports(system-configured):
  Management interfaces:
    M-GigabitEthernet0/0/0
  IPP:
    Bridge-Aggregation3
  Member interfaces of IPP Bridge-Aggregation3:
    FortyGigE1/0/1
    FortyGigE1/0/2
# Display detailed DRNI MAD information. (Applicable to Release 2712 and later.)
Keepalive status       : Normal
System number  Keepalive Destination IP                    UDP port
1              1.1.1.1                                     1000
  DR interfaces:
    Bridge-Aggregation4
  IPP:
    Bridge-Aggregation3
    FortyGigE1/0/1
    FortyGigE1/0/2
DRNI MAD DOWN state
(Applicable to Release 2710 and earlier.) This field is not supported in the current software version.
Whether the network interfaces on the device are in MAD DOWN state:
·     Yes—All network interfaces are in MAD DOWN state, except for the following interfaces:
¡     IPP.
¡     Management Ethernet interface.
¡     IRF physical interfaces (if any).
Interfaces excluded from the MAD shutdown action.
·     No—No network interfaces are in MAD DOWN state.
If this field displays Yes, check the IPL for the link down issue to remove multi-active collision.
DRNI MAD DOWN state
(Applicable to Release 2712 and later.) Whether the network interfaces on the device are in DRNI MAD DOWN state:
·     Yes—All network interfaces are in DRNI MAD DOWN state, except for the interfaces excluded from the shutdown action by DRNI or IRF.
·     No—No network interfaces are in DRNI MAD DOWN state.
Restore delay
Data restoration interval, in seconds.
MAD status
(Applicable to Release 2710 and earlier.) DRNI MAD operating status:
·     Normal—DRNI MAD is operating correctly. The device can receive keepalive packets from the peer.
·     Faulty—DRNI MAD is not operating correctly. The device cannot receive keepalive packets from the peer.
Keepalive status
(Applicable to Release 2712 and later.) Keepalive link status:
·     Normal—The keepalive link is operating correctly. The device can receive keepalive packets from the peer.
·     Faulty—The keepalive link is not operating correctly. The device cannot receive keepalive packets from the peer.
System number
DR system number.
Keepalive source IP
(Applicable to Release 2710 and earlier.) Source IP address of keepalive packets.
Keepalive destination IP
(Applicable to Release 2712 and later.) Destination IP address of keepalive packets.
UDP port
Network interfaces manually configured to not shut down by DRNI MAD.
Network interfaces set by the system to not shut down by DRNI MAD, including:
·     Management interfaces.
·     DR interfaces. (Applicable to Release 2712 and later.)
·     IPP.
·     Aggregation member interfaces if a Layer 2 aggregate interface is used as the IPP.
display drni role
Use display drni role to display DR role information.
display drni role
# Display DR role information.
<Sysname> display drni role
DR      Role priority    Bridge MAC          Configured role    Effective role
Local   32667            0000-0001-002e      Primary            Primary
Peer    32667            00e0-fc00-512d      Secondary          Secondary
Table 5 Command output
DR
Device location:
·     Local—The local device.
·     Peer—The DR peer.
Configured role
The DR role you have configured for the device:
·     Primary.
·     Secondary.
If the device role is unknown, this field displays None.
Effective role
Current role of the device:
·     Primary.
·     Secondary.
drni role priority
display drni summary
Use display drni summary to display summary information about the IPP and DR interfaces.
# Display summary information about the IPP and DR interfaces. In this example, global configuration consistency check was successful.
<Sysname> display drni summary
Global consistency check           : SUCCESS
Inconsistent type 1 global settings: -
IPP             IPP ID        State
BAGG2           1             UP
DR interface    DR group ID   State   Check result   Type 1 inconsistency
BAGG1           1             UP      SUCCESS        -
BAGG11          2             DOWN    FAILURE        STP/VLAN/LAGG
BAGG15          5             UP      SUCCESS        -
# Display summary information about the IPP and DR interfaces. In this example, global configuration consistency check failed.
Global consistency check           : FAILURE
Inconsistent type 1 global settings: STP
IPP             IPP ID        State
BAGG2           1             UP
Table 6 Command output
Result of global configuration consistency check:
·     SUCCESS.
·     FAILURE.
IPP
Abbreviated name of the IPP.
DR interface
Abbreviated name of the DR interface.
State of the interface:
·     UP.
·     DOWN.
Check result
Result of interface-specific configuration consistency check:
·     SUCCESS.
·     FAILURE.
port drni group
display drni system
Use display drni system to display the DR system settings.
display drni system
# Display the DR system settings.
<Sysname> display drni system
IPP: Bridge-Aggregation10
State: UP
DR          System number System MAC         System priority
Local       1             0000-fc00-6504     32768
Peer        2             0000-fc00-6504     32768
Table 7 Command output
IPP
Full name of the IPP.
State of the IPP:
·     UP.
·     DOWN.
Local
Information about the local device:
·     System number—This field displays N/A if the system number is not configured.
·     System MAC—This field displays N/A if the system MAC address is not configured.
·     System priority—The DR system priority, which is used as the system LACP priority.
Peer
Information about the DR peer:
·     System number—This field displays N/A if the system number is not configured or no DR peer exists.
·     System MAC—This field displays N/A if the system MAC address is not configured or no DR peer exists.
·     System priority—This field displays N/A if no DR peer exists.
drni system-mac
drni system-number
drni system-priority
port drni intra-portal port
display drni verbose
Use display drni verbose to display detailed information about the IPP and DR interfaces.
display drni verbose [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a DR interface or the IPP by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about the IPP and all DR interfaces.
If the specified interface is not the IPP or a DR interface, no information is displayed.
# Display detailed information about DR interface Bridge-Aggregation 1.
<Sysname> display drni verbose bridge-aggregation 1
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- IPP_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
DR interface/DR group ID: BAGG1/1
State: UP
Local state/Peer state: ABDFG/ABDFG
Local Selected ports Index: 16385, 16386
Peer Selected ports Index: 32769, 32770
# Display detailed information about IPP Bridge-Aggregation 2.
<Sysname> display drni verbose bridge-aggregation 2
IPP/IPP ID: BAGG2/1
State: UP
Table 8 Command output
Flags
DRCP state flags. The flag field is one byte long, represented by ABCDEFGH from the lowest bit to the highest bit. A letter is displayed when its bit is 1 and is not displayed when its bit is 0.
·     A—Indicates whether DRCP is enabled on the local device. 1 indicates enabled. 0 indicates disabled.
·     B—Indicates whether DRCP is enabled on the DR peer. 1 indicates enabled. 0 indicates disabled.
·     C—Indicates whether DRCP is enabled on a third DR member device. 1 indicates enabled. 0 indicates disabled.
·     D—Indicates whether the local IPP has determined that DRCP is enabled on the DR peer. 1 indicates yes. 0 indicates no.
·     E—Indicates the DRCP timeout timer. 1 indicates the short timeout timer. 0 indicates the long timeout timer.
·     F—Indicates whether the local IPP permits the packets that contain the negotiated gateway conversation IDs. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the local IPP permits the packets that contain the negotiated port conversation IDs. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the local DRCPDU receive machine is in default or expired state. 1 indicates yes. 0 indicates no.
IPP
DR interface
·     UP.
·     DOWN.
Local state
Local DRCP state flags. If all bits are set to 0, this field displays Unknown.
Peer state
Peer DRCP state flags. If all bits are set to 0 or no peer exists, this field displays Unknown.
port drni group
drni auto-recovery reload-delay
Use drni auto-recovery reload-delay to enable DR system auto-recovery and set the reload delay timer.
Use undo drni auto-recovery reload-delay to restore the default.
drni auto-recovery reload-delay delay-value
DR system auto-recovery is disabled and the reload delay timer is not set.
delay-value: Specifies a reload delay in the range of 240 to 3600 seconds.
If only one DR member device recovers after the entire DR system reboots, auto-recovery enables that member device to take over the primary role when the reload delay timer expires. Then, the member device can forward traffic through its DR interfaces.
If auto-recovery is disabled, that DR member device will be stuck in the None role with all its DR interfaces being down after it recovers.
If both DR member devices recover after the entire DR system reboots, active-active situation might occur if both IPL and keepalive links were down when the reload delay timer expires. If this rare situation occurs, examine the IPL and keepalive links and restore them.
# Enable DR system auto-recovery and set the reload delay timer to 245 seconds.
[Sysname] drni auto-recovery reload-delay 245
display drni role
drni consistency-check disable
Use drni consistency-check disable to disable DRNI from performing configuration consistency check.
Use undo drni consistency-check disable to enable DRNI to perform configuration consistency check.
DRNI performs configuration consistency check.
To ensure that the DR system can operate correctly, DRNI by default performs configuration consistency check when the DR system is set up.
Configuration consistency check might fail when you upgrade the DR member devices in a DR system. To prevent the DR system from falsely shutting down DR interfaces, you can temporarily disable configuration consistency check.
You must make sure the DR member devices use the same setting for configuration consistency check.
# Disable DRNI from performing configuration consistency check.
[Sysname] drni consistency-check disable
drni drcp period short
Use drni drcp period short to enable the short DRCP timeout timer (3 seconds) on the IPP or a DR interface.
Use undo drni drcp period to restore the default.
An aggregate interface or VXLAN tunnel interface uses the long DRCP timeout timer (90 seconds).
VXLAN tunnel interface view
This command is available in VXLAN tunnel interface view in Release 2712 and later.
This command takes effect only on the IPP or a DR interface.
DRCP uses a timeout mechanism to specify the amount of time that an IPP or DR interface must wait to receive DRCPDUs before it determines that the peer interface is down. This timeout mechanism provides the following timer options:
·     Short DRCP timeout timer, which is fixed at 3 seconds. If this timer is used, the peer interface sends one DRCPDU every second.
·     Long DRCP timeout timer, which is fixed at 90 seconds. If this timer is used, the peer interface sends one DRCPDU every 30 seconds.
Short DRCP timeout timer enables the DR member devices to detect a peer interface down event more quickly than the long DRCP timeout timer. However, this benefit is at the expense of bandwidth and system resources.
To avoid traffic interruption during an ISSU or DRNI process restart, disable the short DRCP timeout timer before you perform an ISSU or restart the DRNI process. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short DRCP timeout timer on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] drni drcp period short
drni keepalive { ip | ipv6 }
Use drni keepalive { ip | ipv6 } to configure DR keepalive packet parameters.
Use undo drni keepalive { ip | ipv6 } to restore the default.
drni keepalive { ip | ipv6 } destination { ipv4-address | ipv6-address } [ source { ipv4-address | ipv6-address } | udp-port udp-number | vpn-instance vpn-instance-name ] *
The following parameters are not specified for DR keepalive packets:
·     Destination IP address.
·     Source IP address.
·     VPN instance.
The keepalive destination UDP port is 6400.
ip: Specifies IPv4 addresses.
ipv6: Specifies IPv6 addresses.
destination: Specifies an IP address of the DR peer as the destination IP address of keepalive packets.
source: Specifies a local IP address as the source IP address of keepalive packets. If you do not specify a source IP address, the device uses the IP address of the packet outgoing interface.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
udp-port udp-number: Specifies the destination UDP port of keepalive packets. The value range for the udp-number argument is 1 to 65535, and the default value is 6400.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the addresses of keepalive packets belong to the public network, do not specify a VPN instance.
The device accepts only keepalive packets that are sourced from the specified destination IP address. The keepalive link goes down if the device receives keepalive packets sourced from any other IP addresses.
Make sure the DR member devices in a DR system use the same keepalive destination UDP port.
# Specify the destination and source IP addresses of keepalive packets as 192.168.68.125 and 192.168.68.100, respectively.
[Sysname] drni keepalive ip destination 192.168.68.125 source 192.168.68.100
Use drni keepalive hold-time to set the keepalive hold timer.
Use undo drni keepalive hold-time to restore the default.
drni keepalive hold-time value
The keepalive hold timer is 3 seconds.
value: Specifies a timer value in the range of 3 to 10 seconds.
IMPORTANT
IMPORTANT:
For the DR member device to correctly determine the cause of an IPL down event, make sure the keepalive hold timer is longer than the keepalive interval and is shorter than the keepalive timeout timer.
The keepalive hold timer starts when the IPL goes down. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of an IPL down event.
·     If the device receives keepalive packets from the DR peer before the timer expires, the IPL is down because the IPL fails.
·     If the device does not receive keepalive packets from the DR peer before the timer expires, the IPL is down because the peer DR device fails.
# Set the keepalive hold timer to 5 seconds.
[Sysname] drni keepalive hold-time 5
Use drni keepalive interval to set the DR keepalive interval and timeout timer.
Use undo drni keepalive interval to restore the default.
drni keepalive interval interval [ timeout timeout ]
The DR keepalive interval is 1000 milliseconds, and the DR keepalive timeout timer is 5 seconds.
interval interval: Specifies the keepalive interval, in the range of 100 to 10000 milliseconds.
timeout timeout: Specifies the keepalive timeout timer, in the range of 3 to 20 seconds. The local keepalive timeout timer must be two times the keepalive interval of the peer at minimum.
The device sends keepalive packets at the specified interval to its DR peer. If the device has not received a keepalive packet from the DR peer before the keepalive timeout timer expires, the device determines that the keepalive link is down.
You must configure the same DR keepalive interval on the DR member devices in a DR system.
# Set the DR keepalive interval and timeout timer to 2000 milliseconds and 6 seconds, respectively.
[Sysname] drni keepalive interval 2000 timeout 6
Changing the keepalive interval might cause system setup failure. Continue? [Y/N]:y
drni mad exclude interface (Release 2712 and later)
Use drni mad exclude interface to exclude an interface from the shutdown action by DRNI MAD.
Use undo drni mad exclude interface to enable DRNI MAD to shut down an interface when a multi-active collision is detected.
drni mad exclude interface interface-type interface-number
undo drni mad exclude interface interface-type interface-number
No interfaces are manually excluded from the DRNI shutdown action.
This command is available in Release 2712 and later.
When DRNI MAD detects a multi-active collision, DRNI shuts down all network interfaces on the secondary DR device except for the interfaces excluded from the MAD shutdown action by DRNI or IRF. The interfaces excluded from the MAD shutdown action by DRNI include the following:
·     Network interfaces manually configured to not shut down by DRNI MAD.
·     Network interfaces set by the system to not shut down by DRNI MAD, including:
¡     IPP.
¡     Aggregation member interfaces if a Layer 2 aggregate interface is used as the IPP.
¡     DR interfaces.
¡     Management interfaces.
For correct keepalive detection, you must exclude the interfaces used for keepalive detection from the shutdown action by DRNI MAD.
If an interface has been placed in DRNI MAD DOWN state, executing the drni mad exclude interface command cannot bring it up.
If the IPP is a tunnel interface, you must exclude the traffic outgoing interface for the tunnel from the shutdown action by DRNI MAD.
To identify the outgoing interface of a tunnel, use the display fib ip-address command or the display ip routing-table ip-address command. The ip-address argument represents the destination IP address of the tunnel, which you can identify by using the display interface tunnel command.
# Exclude FortyGige 1/0/1 from the shutdown action by DRNI MAD.
[Sysname] drni mad exclude interface fortygige 1/0/1
display fib (Layer 3—IP Services Command Reference)
display interface tunnel (Layer 3—IP Services Command Reference)
display ip routing-table (Layer 3—IP Routing Command Reference)
drni restore-delay
Use drni restore-delay to set the data restoration interval.
Use undo drni restore-delay to restore the default.
drni restore-delay value
The data restoration interval is 30 seconds.
value: Specifies the data restoration interval, in the range of 1 to 3600 seconds.
The data restoration interval specifies the maximum amount of time for the secondary DR device to synchronize data with the primary DR device during DR system setup. Within the data restoration interval, the secondary DR device sets all network interfaces to MAD DOWN state, except for the following interfaces:
·     IPP.
·     Management Ethernet interface.
·     Interfaces excluded from the MAD shutdown action.
When the data restoration interval expires, the secondary DR device brings up all network interfaces.
To avoid packet loss and forwarding failure, increase the data restoration interval if the amount of data is large or if an ISSU is to be performed between the DR member devices.
# Set the data restoration interval to 50 seconds.
[Sysname] drni restore-delay 50
drni role priority
Use drni role priority to set the DR role priority of the device.
Use undo drni role priority to restore the default.
drni role priority priority-value
The DR role priority of the device is 32768.
priority-value: Specifies the DR role priority, in the range of 0 to 65535. The lower the value, the higher the priority.
IMPORTANT
IMPORTANT:
To prevent a primary/secondary role switchover from causing network flapping, avoid changing the DR priority assignment after the DR system is established.
For features that require centralized traffic processing, a DR member device is assigned the primary or secondary role based on its DR role priority. The secondary DR device forwards the traffic of those features to the primary DR device for processing. If the DR member devices use the same DR role priority, the member device with a lower bridge MAC address is assigned the primary role.
# Set the DR role priority of the device to 66.
[Sysname] drni role priority 66
display drni role
drni system-mac
Use drni system-mac to configure the DR system MAC address.
Use undo drni system-mac to restore the default.
drni system-mac mac-address
The DR system MAC address is not configured.
mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
CAUTION
CAUTION:
Changing the DR system MAC address causes DR system split. When you perform this task on a live network, make sure you are fully aware of its impact.
The DR system MAC address uniquely identifies the DR system on the network. For the DR member devices to be identified as one DR system, you must configure the same DR system MAC address on them. As a best practice, use the bridge MAC address of one DR member device as the DR system MAC address.
# Configure the DR system MAC address as 0001-0001-0001.
[Sysname] drni system-mac 1-1-1
Changing the system MAC address might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[Sysname]
drni system-number
Use drni system-number to set the DR system number.
Use undo drni system-number to restore the default.
drni system-number system-number
The DR system number is not set.
system-number: Specifies the DR system number. Available values are 1 and 2.
CAUTION
CAUTION:
Changing the DR system number causes DR system split. When you perform this task on a live network, make sure you are fully aware of its impact.
You must assign different DR system numbers to the DR member devices in a DR system.
# Set the DR system number to 1.
[Sysname] drni system-number 1
Changing the system number might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[Sysname]
display drni system
Use drni system-priority to set the DR system priority.
Use undo drni system-priority to restore the default.
drni system-priority priority
The DR system priority is 32768.
priority: Specifies a priority value in the range of 0 to 65535. The lower the value, the higher the priority.
CAUTION
CAUTION:
Changing the DR system priority causes DR system split. When you perform this task on a live network, make sure you are fully aware of its impact.
A DR system uses its DR system priority as the system LACP priority to communicate with the remote aggregation system.
You must configure the same DR system priority for the DR member devices in a DR system.
# Set the DR system priority to 64.
[Sysname] drni system-priority 64
Changing the system priority might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[Sysname]
display drni system
mad exclude interface (Release 2710 and earlier)
Use mad exclude interface to exclude an interface from the shutdown action by DRNI MAD.
Use undo mad exclude interface to enable DRNI MAD to shut down an interface when a multi-active collision is detected.
undo mad exclude interface interface-type interface-number
DRNI MAD shuts down all network interfaces when detecting a multi-active collision, except for the IPP, IRF physical interfaces, and the management Ethernet interface.
When DRNI MAD detects a multi-active collision, DRNI sets all network interfaces on the secondary DR device to MAD DOWN state, except for the following interfaces:
·     IPP.
# Exclude FortyGigE 1/0/1 from the shutdown action by DRNI MAD.
[Sysname] mad exclude interface fortygige 1/0/1
display mad verbose (see Virtual Technologies Command Reference)
port drni group
Use port drni group to assign an aggregate interface to a DR group.
Use undo port drni group to restore the default.
port drni group group-id
undo port drni
An aggregate interface does not belong to a DR group.
group-id: Specifies a DR group number. The value range for the group-id argument is 1 to 1024.
To use a Layer 2 aggregate interface as a DR interface, you must assign it to a DR group.
The device can have multiple DR interfaces. However, you can assign a Layer 2 aggregate interface to only one DR group.
A Layer 2 aggregate interface cannot operate as both IPP and DR interface.
# Assign Bridge-Aggregation 1 to DR group 100.
[Sysname-Bridge-Aggregation1] port drni group 100
port drni intra-portal-port
Use port drni intra-portal-port to specify an aggregate interface or VXLAN tunnel interface as the IPP.
Use undo drni intra-portal-port to restore the default.
port drni intra-portal-port port-id
undo port drni intra-portal-port
A Layer 2 aggregate interface or VXLAN tunnel interface is not the IPP.
port-id: Specifies the IPP ID, which is fixed at 1.
A DR member device can have only one IPP.
A Layer 2 aggregate interface or VXLAN tunnel interface cannot operate as both IPP and DR interface.
Do not associate a VXLAN tunnel interface with a VXLAN if you use it as the IPP. You can use a VXLAN tunnel interface as an IPP only in an EVPN network. For more information about EVPN, see EVPN Configuration Guide.
# Specify Bridge-Aggregation 2 as the IPP.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] port drni intra-portal-port 1
reset drni drcp statistics
Use reset drni drcp statistics to clear DRCPDU statistics.
reset drni drcp statistics [ interface interface-list ]
interface interface-list: Specifies a space-separated list of interface items. Each item specifies an aggregate interface or a range of aggregate interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The value for interface-number2 must be greater than or equal to the value for interface-number1. The aggregate interfaces must be DR interfaces or the IPP. If you do not specify this option, the command clears the DRCPDU statistics about all DR interfaces and the IPP.
# Clear DRCPDU statistics.
<Sysname> reset drni drcp statistics
