03-Layer 2-LAN Switching Command References
HomeSupportResource CenterH3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Command References-6W10103-Layer 2-LAN Switching Command References
18-Cut-through Layer 2 forwarding commands
18-Cut-through Layer 2 forwarding commands 38.17 KB
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
This command does not take effect on the following ports:
·     The two SFP+ ports on the front panel of an S6820-32H switch.
·     The two SFP ports on the back panel of an S6820-56HF or S6820-4C switch.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
