- 03-Layer 2-LAN Switching Command References
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-DRNI commands
- 06-Port isolation commands
- 07-VLAN commands
- 08-MVRP commands
- 09-Loopback, null, and inloopback interface commands
- 10-QinQ commands
- 11-VLAN mapping commands
- 12-PBB commands
- 13-Loop detection commands
- 14-Spanning tree commands
- 15-LLDP commands
- 16-L2PT commands
- 17-Service loopback group commands
- 18-Cut-through Layer 2 forwarding commands
17-Service loopback group commands | 50.29 KB |
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Service Group ID: 5 Service Type: Tunnel
Member:
Ten-GigabitEthernet1/0/1
Ten-GigabitEthernet1/0/2
Service Group ID |
Service loopback group ID. |
Service Type |
Service type of the service loopback group: · Multicast-tunnel—Supports multicast tunnel traffic. · Tunnel—Supports unicast tunnel traffic. · Multiport—Supports multiport ARP traffic. · VSI-gateway—Supports VSI gateway traffic. |
Member |
Member ports of the service loopback group. |
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to a service loopback group.
When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network.
To avoid IRF split, do not assign a port to a service loopback group if that port is the only IRF physical interface of an IRF port.
In an IRF 3.1 system, ports on PEXs cannot be assigned to service loopback groups.
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
A port can belong to only one service loopback group. You can assign a maximum of 32 ports to a service loopback group. Do not assign any of the 48 SFP28 ports on the S6820-56HF switch to a service loopback group. Assigning SFP28 ports on the S6820-56HF switch to a service loopback group reduces the traffic transmission rate of the switch.
For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
# Assign Ten-GigabitEthernet 1/0/1 to service loopback group 5.
[Sysname-Ten-GigabitEthernet1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | vsi-gateway }
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
multicast-tunnel: Specifies the multicast tunnel service.
tunnel: Specifies the unicast tunnel service.
multiport: Specifies the multiport ARP service.
vsi-gateway: Specifies the VSI gateway service.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
You must create a service loopback group before you can use it with a feature.
You can configure only one service loopback group for a service type. You cannot change the service type of a service loopback group.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify the unicast tunnel service for the group.
[Sysname] service-loopback group 5 type tunnel
