- H3C UniServer R4300 G3 Hardware Options Installation and Replacement Videos-6W100
- 01-Install standard, ball-bearing, or short-distance slide rails
- 02-Install the server to a rack
- 03-Remove the server from a rack
- 04-Install and remove a cable management arm (CMA)
- 05-Replace a DIMM
- 06-Replace a processor
- 07-Install a processor
- 08-Replace a drive
- 09-Replace the system board
- 10-Replace the front 24LFF drive backplane
- 11-Install a rear 2LFF drive cage
- 12-Replace a rear 2LFF drive backplane
- 13-Replace the rear 4SFF&2SFF drive backplane
- 14-Install the rear 4SFF drive cage
- 15-Install a rear 2SFF drive cage
- 16-Replace the rear 12LFF drive backplane
- 17-Replace a PCIe module
- 18-Replace a GPU
- 19-Replace a riser card on PCIe riser connector 1 or 2
- 20-Install a riser card on PCIe riser connector 3
- 21-Replace a riser card on PCIe riser connector 3
- 22-Replace an NVMe SSD expander module
- 23-Replace an FLOM network adapter
- 24-Replace a standard storage controller and the power fail safeguard module
- 25-Replace the mezzanine storage controller and the power fail safeguard module
- 26-Replace a SATA M.2 SSD and M.2 transfer module
- 27-Replace a fan
- 28-Replace a power supply
- 29-Connect power cords
- 30-Install a TPM or TCM
- 31-Replace the system battery
- 32-Replace an NVMe VROC module
- 33-Install or remove blanks
| 19-Replace a riser card on PCIe riser connector 1 or 2 | 98.80 MB |
Watch online
