- 12-High Availability Command Reference
- 01-Ethernet OAM commands
- 02-CFD commands
- 03-DLDP commands
- 04-RRPP commands
- 05-ERPS commands
- 06-Smart Link commands
- 07-Monitor Link commands
- 08-VRRP commands
- 09-Reth interface and redundancy group commands
- 10-BFD commands
- 11-Track commands
- 12-Process placement commands
00-Preface | 100.19 KB |
Preface
This command reference covers high availability commands for managing failure detection and failover.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500G-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
