- H3C UniServer R6700 G3 Hardware Options Installation and Replacement Videos-6W100
- 01-Install standard, ball-bearing, or short-distance slide rails
- 02-Install the server to a rack
- 03-Remove the server from a rack
- 04-Install and remove a cable management arm (CMA)
- 05-Replace a DIMM
- 06-Install a processor
- 07-Replace a processor
- 08-Replace a drive
- 09-Replace the system board
- 10-Replace the processor mezzanine board
- 11-Install a drive cage
- 12-Replace a drive backplane
- 13-Install a riser card on PCIe riser connector 3
- 14-Replace a riser card
- 15-Replace the sLOM Ethernet adapter
- 16-Replace a standard storage controller and the power fail safeguard module
- 17-Replace the NVMe VROC module
- 18-Replace a GPU module
- 19-Replace a standard PCIe Ethernet adapter.
- 20-Replace a power supply
- 21-Connect power cords
- 22-Replace an SD card
- 23-Replace the dual SD card extended module.
- 24-Install the diagnostic panel
- 25-Install a TPM or TCM
- 26-Replace the system battery
- 27-Replace the diagnostic panel
- 28-Replace a SATA M.2 SSD
- 29-Replace the M.2 transfer module
- 30-Replace the security bezel
- 31-Install a riser card on PCIe riser connector 4
- 32-Replace a fan
- 33-Replace a chassis ear
31-Install a riser card on PCIe riser connector 4 | 84.75 MB |
Watch online
