- 11-Network Management and Monitoring Command Reference
 - 02-NQA commands
 - 03-NTP commands
 - 04-PTP commands
 - 05-PoE commands
 - 06-SNMP commands
 - 07-RMON commands
 - 08-Event MIB commands
 - 09-NETCONF commands
 - 10-SmartMC commands
 - 11-EPA commands
 - 12-CWMP commands
 - 12-EAA commands
 - 13-Process monitoring and maintenance commands
 - 14-Mirroring commands
 - 15-sFlow commands
 - 16-Information center commands
 - 17-Packet capture commands
 - 18-EPS agent commands
 - 19-Cloud connection commands
 - 20-VCF fabric commands
| 00-Preface | 102.07 KB |
Preface
This command reference describes the configuration commands for network management and monitoring features. It covers the commands for viewing system information, collecting traffic statistics, assessing the network performance, synchronizing time for all devices with clocks in your network, and checking and debugging the current network connectivity with the ping, tracert, and debug commands.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
    Convention  |
    Description  |
   Boldface  |
   Bold text represents commands and keywords that you enter literally as shown.  |
   Italic  |
   Italic text represents arguments that you replace with actual values.  |
   Square brackets enclose syntax choices (keywords or arguments) that are optional.  |
   { x | y | ... }  |
   Braces enclose a set of required syntax choices separated by vertical bars, from which you select one.  |
   [ x | y | ... ]  |
   Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none.  |
   { x | y | ... } *  |
   Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select a minimum of one.  |
   [ x | y | ... ] *  |
   Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you select one choice, multiple choices, or none.  |
   &<1-n>  |
   The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times.  |
   A line that starts with a pound (#) sign is comments.  |
GUI conventions
    Convention  |
    Description  |
   Boldface  |
   Window names, button names, field names, and menu items are in Boldface. For example, the New User window opens; click OK.  |
   Multi-level menus are separated by angle brackets. For example, File > Create > Folder.  |
Symbols
    Convention  |
    Description  |
   An alert that calls attention to important information that if not understood or followed can result in personal injury.  |
   An alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software.  |
   An alert that calls attention to essential information.  |
   NOTE:  |
   An alert that contains additional or supplementary information.  |
   An alert that provides helpful information.  |
Network topology icons
    Convention  |
    Description  |
   Represents a generic network device, such as a router, switch, or firewall.  |
   Represents a routing-capable device, such as a router or Layer 3 switch.  |
   Represents a generic switch, such as a Layer 2 or Layer 3 switch, or a router that supports Layer 2 forwarding and other Layer 2 features.  |
   Represents an access controller, a unified wired-WLAN module, or the access controller engine on a unified wired-WLAN switch.  |
   Represents an access point.  |
   Represents a wireless terminator unit.  |
   Represents a wireless terminator.  |
   Represents a mesh access point.  |
   Represents omnidirectional signals.  |
   Represents directional signals.  |
   Represents a security product, such as a firewall, UTM, multiservice security gateway, or load balancing device.  |
   Represents a security module, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG module.  |
Documentation feedback
We appreciate your comments.
