| 02-CFD commands | 199.62 KB |
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
display cfd ais-track link-status
display cfd dm one-way history
display cfd linktrace-reply auto-detection
CFD commands
cfd ais enable
Use cfd ais enable to enable AIS.
Use undo cfd ais enable to disable AIS.
cfd ais enable
undo cfd ais enable
AIS is disabled.
# Enable AIS.
[Sysname] cfd ais enable
cfd ais level
cfd ais period
cfd ais level
Use cfd ais level to configure the AIS frame transmission level.
Use undo cfd ais level to remove the AIS frame transmission level.
cfd ais level level-value service-instance instance-id
undo cfd ais level level-value service-instance instance-id
The AIS frame transmission level is not configured.
level level-value: Specifies the AIS frame transmission level in the range of 1 to 7.
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
If no AIS frame transmission level is configured for a service instance, the MEPs in the service instance cannot send AIS frames.
The AIS frame transmission level must be higher than the MD level of the service instance.
# Configure the AIS frame transmission level as 3 in service instance 1.
[Sysname] cfd ais level 3 service-instance 1
cfd ais enable
cfd ais period
cfd ais period
Use cfd ais period to configure the AIS frame transmission period.
Use undo cfd ais period to remove the AIS frame transmission period.
cfd ais period period-value service-instance instance-id
undo cfd ais period period-value service-instance instance-id
The AIS frame transmission period is 1 second.
period period-value: Specifies the AIS frame transmission period in the range of 1 to 60 seconds.
# Configure the AIS frame transmission period as 60 seconds in service instance 1.
[Sysname] cfd ais period 60 service-instance 1
cfd ais enable
cfd ais level
Use cfd ais-track link-status global to enable port status-AIS collaboration.
Use undo cfd ais-track link-status global to disable port status-AIS collaboration.
Port status-AIS collaboration is disabled.
# Enable port status-AIS collaboration.
[Sysname] cfd ais-track link-status global
Use cfd ais-track link-status level to configure the EAIS frame transmission level.
Use undo cfd ais-track link-status level to restore the default.
cfd ais-track link-status level level-value
The EAIS frame transmission level is not configured.
level level-value: Specifies the EAIS frame transmission level in the range of 0 to 7.
If no EAIS frame transmission level is configured on a port, the port cannot send EAIS frames.
Follow these guidelines when you use the command:
· Configurations in Ethernet interface view take effect only on the current interface.
· Configurations in aggregate interface view take effect only on the current aggregate interface.
· Configurations on a member port take effect only when the member port leaves the aggregation group.
# Configure the EAIS frame transmission level as 3 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] cfd ais-track link-status level 3
Use cfd ais-track link-status period to configure the EAIS frame transmission period.
Use undo cfd ais-track link-status period to restore the default.
cfd ais-track link-status period period-value
The EAIS frame transmission period is not configured.
period period-value: Specifies the EAIS frame transmission period in the range of 1 to 60 seconds.
If no EAIS frame transmission period is configured on a port, the port cannot send EAIS frames.
# Configure the EAIS frame transmission period as 60 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] cfd ais-track link-status period 60
Use cfd ais-track link-status vlan to specify the VLANs where the EAIS frames can be transmitted.
Use undo cfd ais-track link-status vlan to remove the VLANs where the EAIS frames can be transmitted.
cfd ais-track link-status vlan vlan-list
undo cfd ais-track link-status vlan vlan-list
The EAIS frames can be transmitted only within the default VLAN of the port.
vlan vlan-list: Specifies the VLANs where the EAIS frames can be transmitted. The vlan-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id [ to vlan-id ]. The value range for VLAN IDs is 1 to 4094.
The EAIS frames are transmitted within the intersection of the VLANs specified with this command and the existing VLANs on the device.
If the command is executed multiple times, the combination of the VLANs specified in each command takes effect.
# On port Ten-GigabitEthernet 1/0/1, specify VLANs 100 through 200 as the VLANs where the EAIS frames can be transmitted.
[Sysname-Ten-GigabitEthernet1/0/1] cfd ais-track link-status vlan 100 to 200
cfd cc enable
Use cfd cc enable to enable CCM sending on a specified MEP.
Use undo cfd cc enable to disable CCM sending on a specified MEP.
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
The CCM sending feature is disabled.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
· If the MEP belongs to an MA that does not carry the VLAN attribute, configurations on a member port of an aggregation group view take effect only on the current member port.
· If the MEP belongs to an MA that carries the VLAN attribute, configurations on a member port of an aggregation group take effect only when the member port leaves the aggregation group.
# On port Ten-GigabitEthernet 1/0/1, enable CCM sending on MEP 3 in service instance 5.
[Sysname-Ten-GigabitEthernet1/0/1] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval
Use cfd cc interval to set the value of the interval field in the CCM messages.
Use undo cfd cc interval to remove the value of the interval field in the CCM messages.
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval [ interval-value ] service-instance instance-id
The value of this field is 4 for all CCM messages sent.
interval interval-value: Specifies the value of the interval field in CCM messages. The value range for the interval field is 1 to 7. If you set the value to 1 or 2, the continuity check might work incorrectly due to hardware restrictions.
When setting the CCM interval, use the settings described in Table 1.
Table 1 CCM interval field encoding
CCM interval field |
Transmission interval |
Maximum CCM lifetime |
1 |
10/3 milliseconds |
35/3 milliseconds |
2 |
10 milliseconds |
35 milliseconds |
3 |
100 milliseconds |
350 milliseconds |
4 |
1 second |
3.5 seconds |
5 |
10 seconds |
35 seconds |
6 |
60 seconds |
210 seconds |
7 |
600 seconds |
2100 seconds |
# Set the value of the interval field to 3 in CCM messages sent by MEPs in service instance 2.
[Sysname] cfd cc interval 3 service-instance 2
cfd cc enable
cfd dm one-way
Use cfd dm one-way to enable one-way delay measurement (DM).
cfd dm one-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
mep mep-id: Specifies the source MEP by its ID in the range of 1 to 8191.
target-mac mac-address: Specifies the target MEP by its MAC address in the format of H-H-H.
target-mep target-mep-id: Specifies the target MEP by its ID in the range of 1 to 8191.
number number: Specifies the number of 1DM frames sent. The value range for the number argument is 2 to 10, and the default is 5.
The one-way DM function measures the one-way frame delay between the source and target MEPs by using 1DM frames.
To view the one-way delay test result, use the display cfd dm one-way history command on the target MEP.
# Enable the one-way DM function to test the one-way frame delay from source MEP 1101 to target MEP 1003 in service instance 1.
<Sysname> cfd dm one-way service-instance 1 mep 1101 target-mep 1003
5 1DMs have been sent. Please check the result on the remote device.
reset cfd dm one-way history
cfd dm two-way
Use cfd dm two-way to enable two-way DM.
cfd dm two-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ number number ] [ interval interval ]
target-mac mac-address: Specifies the target MEP by its MAC address, which is in the format of H-H-H.
dot1p dot1p-value: Specifies an 802.1p priority for DMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of DMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the DMM frame sending interval, in seconds. The value takes 1 or 10. The default value is 1.
The two-way DM function measures the two-way frame delay between the source and target MEPs by using DMM frames and DMR frames.
# Enable the two-way DM function to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd dm two-way service-instance 1 mep 1101 target-mep 2001
Frame delay:
Reply from 0010-fc00-6512: 2406us
Reply from 0010-fc00-6512: 2215us
Reply from 0010-fc00-6512: 2112us
Reply from 0010-fc00-6512: 1812us
Reply from 0010-fc00-6512: 2249us
Average: 2158us
Sent DMMs: 5 Received: 5 Lost: 0
Frame delay variation: 191us 103us 300us 437us
Average: 257us
Reply from 0010-fc00-6512 |
Delay of the DMR frames returned from the MEP with MAC address 0010-FC00-6512. |
Average |
Average frame delay or average frame delay variation. |
Sent DMMs |
Number of sent DMM frames . |
Received |
Number of received DMR frames. |
Lost |
Number of lost DMM frames. |
cfd enable
Use cfd enable to enable CFD.
Use undo cfd enable to disable CFD.
cfd enable
undo cfd enable
CFD is disabled.
[Sysname] cfd enable
cfd linktrace
Use cfd linktrace to identify the path between the source MEP and target MP.
cfd linktrace service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ ttl ttl-value ] [ hw-only ]
target-mac mac-address: Specifies the destination MAC address, in the format of H-H-H.
target-map target-mep-id: Specifies the destination MEP by its ID in the range of 1 to 8191.
ttl ttl-value: Specifies the TTL value in the range of 1 to 255. The default value is 64.
hw-only: Sets the hw-only bits of the LTMs sent. If you specify this keyword, the MIP does not flood LTMs that have an unknown destination MAC address.
This command identifies the path between the source MEP and target MP by using LTMs and LTRs.
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd linktrace service-instance 1 mep 1101 target-mep 2001
Linktrace to MEP 2001 with the sequence number 1101-43361:
MAC address TTL Last MAC Relay action
0010-fc00-6512 63 0010-fc00-6500 Hit
Linktrace to MEP 2001 with the sequence number 1101-43361 |
Linktrace to target MEP 2001 with the sequence number 1101-43361. |
MAC address |
Source MAC address in the LTRs. |
TTL |
TTL of the LTM when it passes the device. |
Last MAC |
MAC address of the last-hop device the LTM passes. |
Relay action |
Indicates whether the forwarding device found the destination MAC address in its MAC address table. When the standard version (IEEE 802.1ag) of CFD is used: · Hit—The current device is the destination device. · FDB—The forwarding device found the destination MAC address. · MPDB—The destination MAC address is not found, or the destination MAC address is found in the MEP or MIP database. |
cfd linktrace auto-detection
Use cfd linktrace auto-detection to enable automatic sending of LTMs.
Use undo cfd linktrace auto-detection to disable automatic sending of LTMs.
cfd linktrace auto-detection [ size size-value ]
Automatic sending of LTMs is disabled.
size size-value: Specifies the size of the buffer used to store the auto-detection result, in the range of 1 to 100 (in terms of auto-detection times). The default value is 5, which means the buffer stores the results of the recent five auto-detections.
This command enables the source MEP to send LTMs when it fails to receive CCMs from the target MEP within 3.5 times the sending interval. The destination of the LTMs is the target MEP, and the TTL field value is 255. Based on the returned LTRs, the fault source can be located on the faulty link.
If you disable automatic LTM sending, the content stored in the buffer will be removed.
# Enable automatic LTM sending, and set the size of the buffer used to store the auto-detection result to 100 (in terms of auto-detection times).
[Sysname] cfd linktrace auto-detection size 100
cfd linktrace
cfd loopback
Use cfd loopback to enable loopback (LB).
cfd loopback service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
target-mac mac-address: Specifies the destination MAC address of the MP, in the format of H-H-H.
number number: Specifies the number of the sent LBMs packets. The value is in the range of 1 to 10. The default value is 5.
The LB function verifies link connectivity between the source MEP and the target MP by using LBMs and LBRs.
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mep 2001
Loopback to MEP 2001 with the sequence number start from 1101-43404:
Reply from 0010-fc00-6512: sequence number=1101-43404 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43405 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43406 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43407 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43408 Time=5ms
Sent: 5 Received: 5 Lost: 0
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is abnormal).
Sent: 5 Received: 0 Lost: 5
Loopback to MEP 2001 with the sequence number start from 1101-43404 |
Sends LBMs to remote MEP 2001 with the sequence number starting with 1101-43404. |
Reply from the MP with the MAC address 0010-FC00-6512. |
sequence number |
Sequence number in the LBR messages. |
Time=5ms |
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds. |
Sent |
Number of sent LBMs. |
Received |
Number of received LBRs. |
Lost |
Number of lost LBRs. |
cfd md
Use cfd md to create an MD.
Use undo cfd md to delete an MD.
cfd md md-name [ index index-value ] level level-value [ md-id { dns dns-name | mac mac-address subnumber | none } ]
undo cfd md md-name
No MDs exist.
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
index index-value: Specifies an MD index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
level level-value: Specifies an MD level in the range of 0 to 7.
md-id: Specifies the MD name carried by packets sent by the MEP. If you do not provide this keyword, the MD name is represented by md-name.
dns dns-name: Specifies an MD name in the format of DNS name, where dns-name represents the DNS name.
mac mac-address subnumber: Specifies an MD name containing the MAC address and an integer. The mac-address argument represents the MAC address of the MD, and the subnumber argument is in the range of 0 to 65535.
none: Specifies that no MD name is carried in the packets sent by the MEP.
An MD name must be in compliant with the specifications in IEEE802.1ag-2007.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name or the MD index is in use.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md1, with its level being 3.
[Sysname] cfd md test_md1 level 3
# Create an MD named test_md2, and the MD name carried in the packet sent by the MEP comprises the MAC address 1-1-1 and integer 1.
[Sysname] cfd md test_md2 level 5 md-id mac 1-1-1 1
cfd mep
Use cfd mep to create a MEP.
Use undo cfd mep to delete a MEP.
cfd mep mep-id service-instance instance-id { inbound | outbound }
undo cfd mep mep-id service-instance instance-id
No MEPs exist.
mep mep-id: Specifies the MEP ID, in the range of 1 to 8191.
inbound: Creates an inward-facing MEP.
outbound: Creates an outward-facing MEP.
In creating a MEP, the service instance you specified defines the MD and MA to which the MEP belongs.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
· If the MEP belongs to an MA that does not carry the VLAN attribute, configurations on a member port of an aggregation group take effect only on the current member port.
# Configure a MEP list in service instance 5, and create inward-facing MEP 3 in service instance 5 on Ten-GigabitEthernet 1/0/1.
[Sysname] cfd md test_md level 3
[Sysname] cfd service-instance 5 ma-id vlan-based md test_md vlan 100
[Sysname] cfd meplist 3 service-instance 5
[Sysname-Ten-GigabitEthernet1/0/1] cfd mep 3 service-instance 5 outbound
cfd meplist
cfd meplist
Use cfd meplist to create a MEP list.
Use undo cfd meplist to delete a MEP list.
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
No MEP list is created.
meplist mep-list: Specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id 1 to mep-id 2. The value range for the MEP ID is 1 to 8191. The mep-id 2 must be equal to or greater than mep-id 1.
A MEP list is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Before creating a MEP list, create the relevant MD and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
# Create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd md
cfd mip-rule
Use cfd mip-rule to configure the rules for generating MIPs.
Use undo cfd mip-rule to remove the rules for generating MIPs and the MIPs created in a service instance.
cfd mip-rule { default | explicit } service-instance instance-id
undo cfd mip-rule [ default | explicit ] service-instance instance-id
No rules for generating MIPs are configured and the system does not automatically generate any MIPs.
default: Specifies the default rule. If no lower-level MIP exists on an interface, a MIP is created on the current level. A MIP can be created even if no MEP is configured on the interface.
explicit: Specifies the explicit rule. If no lower-level MIP exists and a lower-level MEP exists on an interface, a MIP is created at the current level. A MIP can be created only when a lower-level MEP is created on the interface.
The system automatically generates MIPs on each port according to the rules configured.
# Configure the MIP generation rule as default in service instance 5.
[Sysname] cfd mip-rule default service-instance 5
Use cfd service-instance to create a service instance.
Use undo cfd service-instance to remove a service instance.
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name | vlan-based [ vlan-id ] } [ ma-index index-value ] md md-name vlan vlan-id
undo cfd service-instance instance-id
No service instances exist.
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767.
ma-id: Creates an MA.
icc-based ma-name: Specifies that an MA is identified by an ICC. The ma-name argument is a string of 1 to 13 characters.
integer ma-num: Specifies that an MA is identified by an integer, where the ma-num argument is in the range of 0 to 65535.
string ma-name: Specifies that an MA is identified by a string, where the ma-name argument is string of 1 to 45 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
vlan-based [ vlan-id ]: Specifies that an MA is identified by a VLAN ID, where the vlan-id argument is in the range of 1 to 4094. If you do not provide the vlan-id argument, the VLAN ID specified by vlan vlan-id is used. If the vlan vlan-id option is not provided, you must specify the vlan-id argument for the vlan-based [ vlan-id ] option.
ma-index index-value: Specifies an MA index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark (’), comma (,), period (.), and slash (/).
vlan vlan-id: Specifies the VLAN that the MA serves. The value range for the vlan-id argument is 1 to 4094.
A service instance is indicated by an integer to represent an MA in an MD. An MA index uniquely identifies a specific MA in an MD. An MA index can be used in different MDs.
With the vlan-based [ vlan-id ] or vlan vlan-id option, the command creates an MA carrying the VLAN attribute. If you do not specify the option, the command creates an MA carrying no VLAN attribute.
You must create the relevant MD before creating a service instance with the MD name.
Deleting a service instance also deletes the configurations related to that service instance.
Deleting a service instance not only removes the connection between the service instance and the relevant MA, but also deletes the MA.
# Create a level-3 MD named test_md and create service instance 5, in which the MA is identified by a VLAN and serves VLAN 100.
cfd md
cfd slm
Use cfd slm to enable loss measurement (LM).
cfd slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ number number ] [ interval interval ]
dot1p dot1p-value: Specifies an 802.1p priority for LMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of LMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the LMM frame sending interval, in seconds. The value takes 1 or 10. The default value is 1.
The LM function measures the frame loss between the source and target MEPs by using LMM frames and LMR frames.
# Enable the LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd slm service-instance 1 mep 1101 target-mep 2001
Far-end frame loss: 10 Near-end frame loss: 20
Far-end frame loss: 40 Near-end frame loss: 40
Far-end frame loss: 0 Near-end frame loss: 10
Far-end frame loss: 30 Near-end frame loss: 30
Average
Far-end frame loss: 20 Near-end frame loss: 25
Far-end frame loss rate: 25.00% Near-end frame loss rate: 32.00%
Sent LMMs: 5 Received: 5 Lost: 0
Table 5 Command output
LMR frames returned from the target MEP with MAC address 0010-FC00-6512. |
Far-end frame loss |
Number of lost frames on the target MEP. |
Near-end frame loss |
Number of lost frames on the source MEP. |
Far-end frame loss rate |
Frame loss ratio on the target MEP. |
Near-end frame loss rate |
Frame loss ratio on the source MEP. |
Average |
Average number of lost frames. |
Sent LMMs |
Number of sent LMM frames. |
Received |
Number of received LMR frames. |
Lost |
Number of lost LMR frames. |
cfd tst
Use cfd tst to enable test (TST).
cfd tst service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ]
number number: Specifies the number of sent TST frames. The value range for the number argument is 1 to 10, and the default is 5.
length-of-test length: Specifies the length of the Test TLV (Type/Length/Value) in the TST frame. The value range for the length argument is 4 to 1400, in bytes. The default value is 64.
pattern-of-test { all-zero | prbs } [ with-crc ]: Specifies the pattern of the Test TLV in the TST frame:
· all-zero (all-zero value without CRC-32), which is the default pattern.
· prbs (pseudo random bit sequence without CRC-32).
· all-zero with-crc (all-zero value with CRC-32).
· prbs with-crc (pseudo random bit sequence with CRC-32).
The TST function detects bit errors between the source and target MEPs by using TST frames.
To view the TST test result, use the display cfd tst command on the target MEP.
# Enable the TST function to test the bit errors between source MEP 1101 and target MEP 1003 in service instance 1.
<Sysname> cfd tst service-instance 1 mep 1101 target-mep 1003
5 TSTs have been sent. Please check the result on the remote device.
display cfd tst
reset cfd tst
display cfd ais
Use display cfd ais to display the AIS configuration and information on the specified MEP or all MEPs.
display cfd ais [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the AIS configuration and information for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the AIS configuration and information for all MEPs.
# Display the AIS configuration and information for all the MEPs in all service instances.
<Sysname> display cfd ais
Service instance: 5
AIS level: 4 AIS period: 1s
MEP ID: 1
AIS condition: yes Time to enter the condition: 2013/01/22 10:43:57
AIS state machine: Previous state: NO_RECEIVE
Current state: RECEIVE
MEP ID: 2
Service instance: 20
AIS level: 3 AIS period: 60s
MEP ID: 10
Service instance: 100
AIS level: 6 AIS period: 1s
MEP ID: 20
AIS condition: no Time to enter the condition: 2013/01/22 11:40:01
AIS state machine: Previous state: IDLE
Current state: NO_RECEIVE
MEP ID: 50
AIS condition: no Time to enter the condition: -
Table 6 Command output
Service instance |
Service instance of the MEP. |
AIS level |
AIS frame transmission level. |
AIS period |
AIS frame transmission period. |
AIS condition |
AIS status: · yes—AIS is running. · no—AIS is not running. |
Time to enter the condition |
Time when the AIS status began. (- means AIS is enabled but the MEP does not receive any AIS frame.) |
AIS state machine |
AIS frame receiving state machine. |
Previous state |
Previous state: · IDLE—Not activated. · NO_RECEIVE—Activated. · RECEIVE—AIS frames are received. |
Current state |
Current state: · IDLE—Not activated. · NO_RECEIVE—Activated. · RECEIVE—AIS frames are received. |
Use display cfd ais-track link-status to display the configuration and information of the AIS associated with the port status.
display cfd ais-track link-status [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the configuration and information of the AIS associated with the status of all ports.
# Display the configuration and information of the AIS associated with the status of all ports.
<Sysname> display cfd ais-track link-status
AIS tracking link-status is enabled.
Interface Ten-GigabitEthernet1/0/1:
AIS level: 5 AIS period: 1s
Configured VLANs: 1, 10-100, 103
Send VLANs: 1, 10-100, 103
AIS condition: yes Time to enter the condition: 2013/02/26 10:43:57
Interface Ten-GigabitEthernet1/0/2:
Configured VLANs: 1-4094
Send VLANs: 1-2000
AIS condition: yes Time to enter the condition: 2013/02/26 10:44:57
Table 7 Command output
AIS tracking link-status is enabled |
Port status-AIS collaboration is enabled. |
AIS tracking link-status is disabled |
Port status-AIS collaboration is disabled. |
Port that collaborates with AIS. |
AIS level |
EAIS frame transmission level on the port. |
AIS period |
EAIS frame transmission period on the port. |
Configured VLANs |
VLANs where the EAIS frames can be transmitted. |
Send VLANs |
Actual VLANs where the EAIS frames can be transmitted. |
AIS condition |
EAIS frame sending status: · yes—EAIS frames are being sent. · no—No EAIS frame is being sent. |
Time when the EAIS frame sending started. |
Use display cfd dm one-way history to display the one-way DM result.
display cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way DM results for all MEPs.
The one-way DM results for all inward-facing MEPs in a service instance are the same.
# Display the one-way DM results for all the MEPs in all service instances.
<Sysname> display cfd dm one-way history
Service instance: 1
MEP ID: 1003
Sent 1DM total number: 0
Received 1DM total number: 5
Frame delay: 10ms 9ms 11ms 5ms 5ms
Delay average: 8ms
Frame delay variation: 5ms 4ms 6ms 0ms 0ms
Variation average: 3ms
MEP ID: 1004
Delay average: 8ms
Delay variation: 5ms 4ms 6ms 0ms 0ms
Service instance: 2
No MEP exists in the service instance.
Service instance: 3
MEP ID: 1023
Sent 1DM total number: 5
Received 1DM total number: 10
Frame delay: 20ms 9ms 8ms 7ms 1ms 5ms 13ms 17ms 9ms 10ms
Delay average: 9ms
Delay variation: 19ms 8ms 7ms 6ms 0ms 4ms 12ms 16ms 8ms 9ms
Variation average: 8ms
Service instance: 4
MEP ID: 1023
Sent 1DM total number: 77
Received 1DM total number: 0
Table 8 Command output
Service instance |
Sent 1DM total number |
Number of sent 1DM frames. |
Received 1DM total number |
Number of received 1DM frames. |
Delay average |
Average frame delay. |
Delay variation |
Frame delay variation. |
Variation average |
Average frame delay variation. |
cfd dm one-way
Use display cfd linktrace-reply to display information about the LTRs received by a MEP.
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the LTR information for all service instances.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191. If you do not specify this option, the command displays the LTR information for all MEPs.
This command displays only information about LTRs received by execution of the cfd linktrace command.
# Display the LTR information saved on all the MEPs in every service instance.
[Sysname] display cfd linktrace-reply
Service instance: 1 MEP ID: 1003
0000-fc00-6505 63 0000-fc00-6504 MPDB
000f-e269-a852 62 0000-fc00-6505 FDB
0000-fc00-6508 61 000f-e269-a852 Hit
Service instance: 2 MEP ID: 1023
Table 9 Command output
Service instance |
Service instance to which the MEPs that send LTMs belong. |
MEP ID |
ID of the MEP that sends LTMs. |
MAC address |
Source MAC address in the LTR. |
TTL |
Last MAC |
Relay action |
cfd linktrace
Use display cfd linktrace-reply auto-detection to display information about the LTRs received as responses to the automatically sent LTMs.
display cfd linktrace-reply auto-detection [ size size-value ]
size size-value: Specifies the times of recent auto-detections, in the range of 1 to 100. If you do not specify this option, the command displays all information in the buffer.
This command displays only information about LTRs received by execution of the cfd linktrace auto-detection command.
# Display the contents of the LTRs received as responses to the LTMs automatically sent.
<Sysname> display cfd linktrace-reply auto-detection
Service instance: 1 MEP ID: 1003 Time: 2013/05/22 10:43:57
Target MEP ID: 2005 TTL: 64
Service instance: 2 MEP ID: 1023 Time: 2013/05/22 10:44:06
Target MEP ID: 2025 TTL: 64
Table 10 Command output
Service instance |
Service instance to which the MEPs that sent LTMs belong. |
MEP ID |
Time |
Time of the LTMs automatically sent. |
Target MEP ID |
ID of the target MEP. |
TTL |
Initial TTL of the automatically sent LTMs. |
MAC address |
TTL |
Last MAC |
Relay action |
display cfd md
Use display cfd md to display the MD configuration information.
display cfd md
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
Maintenance domains configured: 4 in total
Level Index Maintenance domain MD format MD ID
0 1 md_0 CHARSTRING md_0
1 2 md_1 DNS dns1
2 3 md_2 MAC 0001-00
01-0001-1
3 4 md_3 NONE Without
ID
Table 11 Command output
Maintenance domains configured |
Number of MDs configured. |
Level |
Level of MD. |
Index |
MD index. |
Maintenance domain |
Name of MD. |
MD format |
MD name format: · CHARSTRING—Character string. · DNS—DNS name. · MAC—MAC address and an integer. · NONE—No MD name is carried. |
MD ID |
MD ID value: · A character string if the MD format is CHARSTRING. · A DNS name if the MD format is DNS. · A MAC address-subnumber if the MD format is MAC. · No ID if the MD format is NONE. |
display cfd mep
Use display cfd mep to display the attribute and operating information for a MEP.
display cfd mep mep-id service-instance instance-id
# Display the attribute and operating information for MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Interface: Ten-GigabitEthernet1/0/2
Maintenance domain: md_0
Maintenance domain index: 1
Maintenance association: ma_0
Maintenance association index: 1
Level: 0 VLAN: 1 Direction: Outbound
Current state: Active CCM send: Enabled
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s SendCCM: 12018
Loopback:
NextSeqNumber: 8877
SendLBR: 0 ReceiveInOrderLBR: 0 ReceiveOutOrderLBR: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0 ReceiveLTM: 0
No CCM received from some remote MEPs.
One or more streams of error CCMs is received. The last received CCM:
Maintenance domain: (Without ID)
Maintenance association: matest1
MEP ID: 5 Sequence Number:0x50A
MAC Address: 0011-2233-4402
Received Time: 2013/03/06 13:01:34
One or more streams of cross-connect CCMs is received. The last received CCM:
Maintenance domain: mdtest1
Maintenance association:matest1
MEP ID: 6 Sequence Number:0x63A
MAC Address: 0011-2233-4401
Some other MEPs are transmitting the RDI bit.
Table 12 Command output
Interface on which the MEP is configured. |
MD to which the MEP belongs. (If the MD does not have a name, this field is displayed as Without ID.) |
Maintenance domain index |
Index of the MD to which the MEP belongs. |
Maintenance association |
MA to which the MEP belongs. |
Maintenance association index |
Index of the MA to which the MEP belongs. |
Level |
Level of the MD. |
VLAN |
VLAN to which the MA belongs. |
Direction |
Direction of the MEPs. |
Current state |
State of MEP: · Active. · Inactive. |
CCM send |
Whether the MEP sends CCM. |
FNG state |
State of FNG (Fault Notification Generator): · FNG_RESET—A fault has been cleared. · FNG_DEFECT—A fault has been detected. · FNG_REPORT_DEFECT—Report a fault. · FNG_DEFECT_REPORTED—A fault has been reported. · FNG_DEFECT_CLEARING—A fault is being cleared. If this field is not supported, a hyphen (-) is displayed. |
CCM |
Information related to CCM. |
Current state |
State of CCMs sent: · CCI_IDLE—Initial state. · CCI_WAITING—Sending state. If this field is not supported, a hyphen (-) is displayed. |
Interval |
Interval to send CCM. Not supported means the MEP does not support CCM sending. |
SendCCM |
Number of CCMs that have been sent by the MEPs. If this field is not supported, a hyphen (-) is displayed. |
Loopback |
Information related to Loopback. |
NextSeqNumber |
Sequence number of the next LBM to be sent. |
SendLBR |
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted. |
ReceiveInOrderLBR |
Number of LBRs received in correct sequence. |
ReceiveOutOrderLBR |
Number of LBRs received out of order. |
Linktrace |
Information related to linktrace. |
NextSeqNumber |
Sequence number of the next LTM to be sent. |
SendLTR |
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted. |
ReceiveLTM |
Number of LTMs received. |
No CCM received from some remote MEPs. |
Failure to receive CCMs from some remote MEPs. (This information is displayed only when some CCMs are lost.) |
One or more streams of error CCMs is received. The last received CCM: |
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCMs are received.) |
MD of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
MA of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
MEP |
ID of the MEP that sent the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
Sequence Number |
Sequence number of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
Received Time |
Time when the last error CCM is received. If this field is not supported, a hyphen (-) is displayed. |
One or more streams of cross-connect CCMs is received. The last received CCM: |
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCMs are received.) |
Some other MEPs are transmitting the RDI bit. |
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCMs are received.) |
display cfd meplist
Use display cfd meplist to display the MEP list in a service instance.
display cfd meplist [ service-instance instance-id ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
Use display cfd mp to display the MP information.
display cfd mp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays MP information for all ports.
The output is arranged by port name. On a port, the output shows MPs that serve VLANs, and then shows MPs that do not serve any VLANs. The MPs that serve VLANs are displayed in the ascending VLAN ID order. Within the same VLAN, the output is in the order of MIPs and MEPs (from high to low level). The MEPs that do not serve any VLANs are displayed by level (from high to low).
# Display the MP information on all ports.
<Sysname> display cfd mp
Interface Ten-GigabitEthernet1/0/1 VLAN 100
MIP Level: 2 Service instance: 102
Maintenance domain: md_2
Maintenance domain index: 3
Maintenance association: ma_2
Maintenance association index: 3
MEP ID: 101 Level: 1 Service instance: 101 Direction: Inbound
Maintenance domain: md_1
Maintenance domain index: 2
Maintenance association: ma_1
Maintenance association index: 2
MEP ID: 100 Level: 0 Service instance: 100 Direction: Outbound
Table 13 Command output
Interface Ten-GigabitEthernet1/0/1 VLAN 100 |
MP configuration of VLAN 100 on Ten-GigabitEthernet 1/0/1. |
MIP |
A MIP in the MP. |
Level |
MD level to which the MP belongs. |
Service instance |
Service instance to which the MP belongs. |
MD to which the MP belongs. |
Index of the MD to which the MP belongs. |
MA to which the MP belongs. |
Index of the MA to which the MP belongs. |
Direction |
Direction of the MEP, inbound or outbound. |
display cfd remote-mep
Use display cfd remote-mep to display information about a remote MEP.
display cfd remote-mep service-instance instance-id mep mep-id
# Display remote MEP information for MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID MAC address State Time MAC status
20 00e0-fc00-6565 OK 2013/03/06 02:36:38 UP
30 00e0-fc27-6502 OK 2013/03/06 02:36:38 DOWN
40 00e0-fc00-6510 FAILED 2013/03/06 02:36:39 DOWN
50 00e0-fc52-baa0 OK 2013/03/06 02:36:44 DOWN
60 0010-fc00-6502 OK 2013/03/06 02:36:42 DOWN
Table 14 Command output
MEP ID |
ID of the remote MED. |
MAC address |
MAC address of the remote MEP device. If this field is not supported, a hyphen (-) is displayed. |
State |
Running state of the remote MEP: · OK. · FAILED. |
Time |
Time when the remote MEP entered the FAILED or OK state for the last time. If this field is not supported, a hyphen (-) is displayed. |
MAC status |
State of the interface indicated by the last CCM received from the remote MEP: · UP—The interface is ready to pass packets. · DOWN—The interface cannot pass packets. · TESTING—The interface is in some test mode. · UNKNOWN—The interface status cannot be determined. · DORMANT—The interface is not in a state to pass packets. Instead, it is in a pending state, waiting for some external event. · NOT-PRESENT—Some component of the interface is missing. · LLD—The interface is down due to state of the lower layer interfaces. If this field is not supported, a hyphen (-) is displayed. |
display cfd service-instance
Use display cfd service-instance to display the configuration information of service instances.
display cfd service-instance [ instance-id ]
instance-id: Specifies a service instance ID in the range of 1 to 32767. If you do not specify this argument, the command displays configuration information for all service instances.
# Display the configuration information of all service instances.
<Sysname> display cfd service-instance
Service instances configured (2 in total):
Service instance 5:
Maintenance domain: md_5
Maintenance domain index: 5
Maintenance association: ma_5
Maintenance association index: 5
Level: 5 VLAN: 5 MIP rule: NONE CCM interval: 1s Direction: Inbound
MEP ID: 730 Interface: Ten-GigabitEthernet1/0/1
Service instance 6:
Maintenance domain index: 6
Maintenance association: ma_6
Maintenance association index: 6
Level: 6 VLAN: 6 MIP rule: NONE CCM interval: 1s Direction: Outbound
MEP ID: 731 Interface: Ten-GigabitEthernet1/0/2
Table 15 Command output
Service instances are configured. |
Number of service instances configured. |
Service instance |
Service instance ID. |
MD of the service instance. (If the MD does not have a name, this field displays Without ID.) |
Index of the MD to which the service instance belongs. |
Maintenance association: |
MA of the service instance. |
Index of the MA to which the service instance belongs. |
Level |
MD level. |
VLAN |
MIP rule |
MIP generation rules configured on the service instance. |
CCM interval |
Interval to send CCMs. |
Direction |
Direction of the MEPs configured on the service instance. |
MEP ID |
ID of MEPs configured on the service instance. |
Interface of the MEP configured on the service instance. |
display cfd status
Use display cfd status to display the CFD and AIS status.
display cfd status
# Display the CFD and AIS status.
CFD is enabled.
AIS is disabled.
display cfd tst
Use display cfd tst to display the TST result.
display cfd tst [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the TST results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the TST results for all MEPs.
The TST DM results for all inward-facing MEPs in a service instance are the same.
# Display the TST results for all the MEPs in all service instances.
<Sysname> display cfd tst
Service instance: 1
MEP ID: 1003
Sent TST total number: 0
Received TST total number: 5
Received from 0010-fc00-6510, Bit True, sequence number 0
Received from 0010-fc00-6510, Bit True, sequence number 1
Received from 0010-fc00-6510, Bit True, sequence number 2
Received from 0010-fc00-6510, Bit True, sequence number 3
Received from 0010-fc00-6510, Bit True, sequence number 4
MEP ID: 1004
Sent TST total number: 5
Received TST total number: 0
Service instance: 2
Service instance: 3
MEP ID: 1023
Table 16 Command output
Service instance |
Sent TST total number |
Number of sent TST frames. |
Received TST total number |
Number of received TST frames. |
Received from 0010-fc00-6510, Bit True, sequence number 0 |
TST frame with sequence number 0 was received from the MEP with MAC address 0010-FC00-6510: · Bit True—No bit error occurred. · Bit False—Bit errors occurred. |
cfd tst
reset cfd tst
Use reset cfd dm one-way history to clear the one-way DM result.
reset cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the one-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the one-way DM results for all MEPs.
Clearing the one-way DM result for an inward-facing MEP clears all one-way DM results for the service instance where the inward-facing MEP resides.
# Clear the one-way DM results for all MEPs in all service instances.
<Sysname> reset cfd dm one-way history
cfd dm one-way
reset cfd tst
Use reset cfd tst to clear the TST result.
reset cfd tst [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the TST results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the TST results for all MEPs.
Clearing the TST result for an inward-facing MEP clears all TST results for the service instance where the inward-facing MEP resides.
# Clear the TST results for all MEPs in all service instances.
<Sysname> reset cfd tst
cfd tst
display cfd tst
