11-Network Management and Monitoring Configuration Examples
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration ExamplesH3C S10500X Switch Series Configuration Examples-R7595-6W10011-Network Management and Monitoring Configuration Examples
07-H3C_sFlow_Configuration_Examples
07-H3C_sFlow_Configuration_Examples 109.91 KB
H3C sFlow Configuration Examples
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides sFlow configuration examples.
This document assumes that you have basic knowledge of sFlow.
When you configure sFlow, follow these restrictions and guidelines:
·     You can specify only the random sampling mode (the default).
·     For the remote sFlow collector to receive sFlow packets, the IP address of the sFlow collector specified on the sFlow agent must be the same with that of the remote sFlow collector.
·     If the number of packets sampled by an interface is too much in a heavy traffic network, increase the flow sampling interval. If an interface samples insufficient packets in a light traffic network, decrease the flow sampling interval.
·     If an interface collects data too frequently in a heavy traffic network, increase the counter sampling interval. If the sampling statistics is not accurate in a light traffic network, decrease the counter sampling interval.
Example: Configuring sFlow
As shown in Figure 1, perform the following tasks:
·     Configure flow sampling to sample packets on Device A and Device B.
·     Configure counter sampling to periodically collect the counter information on Device A and Device B.
Figure 1 Network diagram
Analysis
To obtain interface counter information and packet information, you must configure both flow sampling and counter sampling.
Procedures
Configuring Device A
# Create VLAN 10. Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port Ten-GigabitEthernet 1/0/1 to Ten-GigabitEthernet 1/0/3
[DeviceA-vlan10] quit
# Assign an IP address to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
# Assign IP addresses to other interfaces. (Details not shown.)
# Assign an IP address to the sFlow agent.
[DeviceA] sflow agent ip 10.1.1.1
# Specify the sFlow collector ID as 1, IP address as 30.1.1.2, and port number as 5000.
[DeviceA] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 120 seconds on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] sflow counter collector 1
# Enable counter sampling and set the counter sampling interval to 120 seconds on Ten-GigabitEthernet 1/0/2.
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] sflow counter collector 1
[DeviceA-Ten-GigabitEthernet1/0/2] quit
# Enable flow sampling and set the sampling interval to 100000 on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] sflow sampling-rate 100000
# Specify sFlow collector 1 for flow sampling on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] sflow flow collector 1
# Enable flow sampling and set the sampling interval to 100000 on Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] sflow sampling-rate 100000
# Specify sFlow collector 1 for flow sampling on Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] sflow flow collector 1
Configuring Device B
# Create VLAN 20. Assign Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port Ten-GigabitEthernet 1/0/1 to Ten-GigabitEthernet 1/0/2
[DeviceB-vlan20] quit
# Assign an IP address to VLAN-interface 20.
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ip address 20.1.1.1 255.255.255.0
[DeviceB-Vlan-interface20] quit
[DeviceB] sflow agent ip 20.1.1.1
[DeviceB] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 30 seconds on Ten-GigabitEthernet 1/0/1.
[DeviceB-Ten-GigabitEthernet1/0/1] sflow counter interval 30
[DeviceB-Ten-GigabitEthernet1/0/1] sflow counter collector 1
# Enable flow sampling and set the sampling interval to 20000 on Ten-GigabitEthernet 1/0/1.
[DeviceB-Ten-GigabitEthernet1/0/1] sflow sampling-rate 20000
[DeviceB-Ten-GigabitEthernet1/0/1] sflow flow collector 1
# Verify the following items on Device A:
·     Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 enabled with sFlow are active.
·     The counter sampling interval is 120 seconds.
·     The flow sampling interval is 100000.
[DeviceA] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.1.1.1(CLI)
Source address:
Port counter sampling information:
Interface   Instance   CID   Interval(s)
XGE1/0/1    1          1     120
XGE1/0/2    1          1     120
Port flow sampling information:
Interface   Instance   FID   MaxHLen Rate       Mode      Status
XGE1/0/1    1          1     128     100000     Random    Active
XGE1/0/2    1          1     128     100000     Random    Active
Configuration files
·     Device A:
vlan 10
interface Vlan-interface10
 sflow collector 1 ip 30.1.1.2 port 5000 description "CLI Collector"
 port link-mode bridge
 port access vlan 10
 port access vlan 10
 port access vlan 10
·     Device B:
vlan 20
interface Vlan-interface20
 port access vlan 20
 port access vlan 20
Related documentation
·     H3C S10500X Ethernet Switch Series Network Management and Monitoring Command Reference-R759X
·     H3C S10500X Ethernet Switch Series Network Management and Monitoring Configuration Guide-R759X
