- 11-Network Management and Monitoring Configuration Examples
- 01-H3C_NQA_Configuration_Examples
- 02-H3C_NTP_Configuration_Examples
- 03-H3C_SNMP_Configuration_Examples
- 04-H3C_EAA_Configuration_Examples
- 05-H3C_Mirroring_Configuration_Examples
- 06-H3C_NetStream_Configuration_Examples
- 07-H3C_sFlow_Configuration_Examples
| 01-H3C_NQA_Configuration_Examples | 279.56 KB |
H3C NQA Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring an ICMP echo operation
Example: Configuring an ICMP jitter operation
Example: Configuring a DHCP operation
Example: Configuring a DNS operation
Example: Configuring an FTP operation
Example: Configuring an HTTP operation
Example: Configuring a UDP jitter operation
Example: Configuring an SNMP operation
Example: Configuring a TCP operation
Example: Configuring a UDP echo operation
Example: Configuring a UDP tracert operation
Example: Configuring a voice operation
Example: Configuring a DLSw operation
Example: Configuring a path jitter operation
Introduction
This document provides NQA configuration examples.
This document assumes that you have basic knowledge of H3C NQA.
The ICMP echo operation is not supported in IPv6 networks. To test the reachability of an IPv6 address, use the ping ipv6 command.
As shown in Figure 1, configure an ICMP echo operation to test the roundtrip time between Device A and Device D through Device B.
When you configure an ICMP echo operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the ICMP echo operation.
· You cannot modify the operation configuration for a running NQA operation.
Procedures
# Create an ICMP echo operation.
[DeviceA] nqa entry admin test
[DeviceA-nqa-admin-test] type icmp-echo
# Specify the destination IP address of ICMP echo requests as 60.1.1.1.
[DeviceA-nqa-admin-test-icmp-echo] destination ip 60.1.1.1
# Specify the next hop of ICMP echo requests as 10.1.1.2.
[DeviceA-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.2
# Configure the ICMP echo operation to perform 10 probes.
[DeviceA-nqa-admin-test-icmp-echo] probe count 10
# Specify the probe timeout time as 500 milliseconds for the ICMP echo operation.
[DeviceA-nqa-admin-test-icmp-echo] probe timeout 500
# Configure the ICMP echo operation to repeat at an interval of 5000 milliseconds.
[DeviceA-nqa-admin-test-icmp-echo] frequency 5000
# Enable saving history records.
[DeviceA-nqa-admin-test-icmp-echo] history-record enable
# Configure the maximum number of history records that can be saved as 10.
[DeviceA-nqa-admin-test-icmp-echo] history-record number 10
[DeviceA-nqa-admin-test-icmp-echo] quit
# Start the ICMP echo operation.
[DeviceA] nqa schedule admin test start-time now lifetime forever
# After the ICMP echo operation runs for a time period, stop the operation.
[DeviceA] undo nqa schedule admin test
# Display the most recent result of the ICMP echo operation.
[DeviceA] display nqa result admin test
NQA entry (admin admin, tag test) test results:
Send operation times: 10 Receive response times: 10
Min/Max/Average round trip time: 2/5/3
Square-Sum of round trip time: 96
Last succeeded probe time: 2019-03-23 15:00:01.2
Extended results:
Packet loss ratio: 0%
Failures due to timeout: 0
Failures due to internal error: 0
Failures due to other errors: 0
# Display the history records of the ICMP echo operation.
[DeviceA] display nqa history admin test
NQA entry (admin admin, tag test) history records:
Index Response Status Time
370 3 Succeeded 2019-03-23 15:00:01.2
369 3 Succeeded 2019-03-23 15:00:01.2
368 3 Succeeded 2019-03-23 15:00:01.2
367 5 Succeeded 2019-03-23 15:00:01.2
366 3 Succeeded 2019-03-23 15:00:01.2
365 3 Succeeded 2019-03-23 15:00:01.2
364 3 Succeeded 2019-03-23 15:00:01.1
363 2 Succeeded 2019-03-23 15:00:01.1
362 3 Succeeded 2019-03-23 15:00:01.1
361 2 Succeeded 2019-03-23 15:00:01.1
The output shows that the packets sent by Device A can reach Device D through Device B. No packet loss occurs during the operation. The minimum, maximum, and average round-trip times are 2, 5, and 3 milliseconds, respectively.
Configuration files
type icmp-echo
frequency 5000
probe count 10
probe timeout 500
As shown in Figure 2, configure an ICMP jitter operation to test the jitter between Device A and Device B.
When you configure an ICMP jitter operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the ICMP jitter operation.
Procedures
# Create an ICMP jitter operation.
[DeviceA-nqa-admin-test] type icmp-jitter
# Specify 10.2.2.2 as the destination address for the operation.
[DeviceA-nqa-admin-test-icmp-jitter] destination ip 10.2.2.2
# Configure the operation to repeat every 1000 milliseconds.
[DeviceA-nqa-admin-test-icmp-jitter] frequency 1000
[DeviceA-nqa-admin-test-icmp-jitter] quit
# Start the ICMP jitter operation.
# After the ICMP jitter operation runs for a period of time , stop the operation.
# Display the most recent result of the ICMP jitter operation.
Min/Max/Average round trip time: 1/2/1
Square-Sum of round trip time: 13
Last packet received time: 2019-03-09 17:40:29.8
Extended results:
Packets out of sequence: 0
Packets arrived late: 0
ICMP-jitter results:
RTT number: 10
Min positive SD: 0 Min positive DS: 0
Max positive SD: 0 Max positive DS: 0
Positive SD number: 0 Positive DS number: 0
Positive SD sum: 0 Positive DS sum: 0
Positive SD average: 0 Positive DS average: 0
Positive SD square-sum: 0 Positive DS square-sum: 0
Min negative SD: 1 Min negative DS: 2
Max negative SD: 1 Max negative DS: 2
Negative SD number: 1 Negative DS number: 1
Negative SD sum: 1 Negative DS sum: 2
Negative SD average: 1 Negative DS average: 2
Negative SD square-sum: 1 Negative DS square-sum: 4
One way results:
Max SD delay: 1 Max DS delay: 2
Min SD delay: 1 Min DS delay: 2
Number of SD delay: 1 Number of DS delay: 1
Sum of SD delay: 1 Sum of DS delay: 2
Square-Sum of SD delay: 1 Square-Sum of DS delay: 4
Lost packets for unknown reason: 0
# Display the statistics of the ICMP jitter operation.
[DeviceA] display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
NO. : 1
Start time: 2019-03-09 17:42:10.7
Life time: 156 seconds
Send operation times: 1560 Receive response times: 1560
Square-Sum of round trip time: 1563
Extended results:
RTT number: 1560
Min positive SD: 1 Min positive DS: 1
Max positive SD: 1 Max positive DS: 2
Positive SD number: 18 Positive DS number: 46
Positive SD sum: 18 Positive DS sum: 49
Positive SD average: 1 Positive DS average: 1
Positive SD square-sum: 18 Positive DS square-sum: 55
Min negative SD: 1 Min negative DS: 1
Negative SD number: 24 Negative DS number: 57
Negative SD sum: 24 Negative DS sum: 58
Negative SD average: 1 Negative DS average: 1
Negative SD square-sum: 24 Negative DS square-sum: 60
One way results:
Min SD delay: 1 Min DS delay: 1
Number of SD delay: 4 Number of DS delay: 4
Sum of SD delay: 4 Sum of DS delay: 5
Square-Sum of SD delay: 4 Square-Sum of DS delay: 7
Configuration files
type icmp-jitter
frequency 1000
As shown in Figure 3, configure a DHCP operation to test the time required for Device A to obtain an IP address from the DHCP server (Device B).
When you configure a DHCP operation, follow these restrictions and guidelines:
· Complete the DHCP server configuration before you start the DHCP operation.
· Make sure the devices can reach each other before you start the DHCP operation.
Procedures
# Create a DHCP operation.
[DeviceA-nqa-admin-test] type dhcp
# Specify the DHCP server IP address 10.1.1.2 as the destination address.
[DeviceA-nqa-admin-test-dhcp] destination ip 10.1.1.2
# Enable the saving of history records.
[DeviceA-nqa-admin-test-dhcp] history-record enable
[DeviceA-nqa-admin-test-dhcp] quit
# Start the DHCP operation.
# After the operation runs for a time period, stop the operation.
# Display the most recent result of the DHCP operation.
NQA entry(admin admin, tag test) test results:
Send operation times: 1 Receive response times: 1
Min/Max/Average round trip time: 624/624/624
Square-Sum of round trip time: 389376
Last succeeded probe time: 2019-03-24 09:56:03.2
Extend results:
Packet lost in test: 0%
# Display the history records of the DHCP operation.
NQA entry(admin admin, tag test) history record(s):
1 624 Succeeded 2019-03-24 09:56:03.2
Configuration files
type dhcp
As shown in Figure 4, configure a DNS operation to test whether Device A can perform address resolution through the DNS server and test the resolution time.
When you configure a DNS operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the DNS operation.
Procedures
# Create a DNS operation.
[DeviceA-nqa-admin-test] type dns
# Specify the IP address of the DNS server 10.2.2.2 as the destination address.
[DeviceA-nqa-admin-test-dns] destination ip 10.2.2.2
# Specify the domain name to be translated as host.com.
[DeviceA-nqa-admin-test-dns] resolve-target host.com
[DeviceA-nqa-admin-test-dns] history-record enable
[DeviceA-nqa-admin-test-dns] quit
# Start the DNS operation.
# After the DNS operation runs for a time period, stop the operation.
# Display the most recent result of the DNS operation.
Min/Max/Average round trip time: 62/62/62
Square-Sum of round trip time: 3844
Last succeeded probe time: 2019-03-24 10:49:37.3
Extended results:
# Display the history records of the DNS operation.
1 62 Succeeded 2019-03-24 10:49:37.3
The output shows that it took Device A 62 milliseconds to translate the domain name host.com into an IP address.
Configuration files
type dns
As shown in Figure 5, configure an FTP operation to test the file transmission time between Device A and the FTP server. The login username and password are admin and systemtest, respectively.
When you configure an FTP operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the FTP operation.
· When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
· Take the network bandwidth into consideration when you set the file size and the probe timeout.
Procedures
# Create an FTP operation.
[DeviceA-nqa-admin-test] type ftp
# Specify the URL of the FTP server.
[DeviceA-nqa-admin-test-ftp] url ftp://10.2.2.2
# Specify 10.1.1.1 as the source IP address.
[DeviceA-nqa-admin-test-ftp] source ip 10.1.1.1
# Specify the FTP operation type as put.
[DeviceA-nqa-admin-test-ftp] operation put
# Specify the file to be uploaded as config.txt.
[DeviceA-nqa-admin-test-ftp] filename config.txt
# Specify the username for the FTP operation as admin.
[DeviceA-nqa-admin-test-ftp] username admin
# Specify the password for the FTP operation as systemtest.
[DeviceA-nqa-admin-test-ftp] password simple systemtest
[DeviceA-nqa-admin-test-ftp] history-record enable
[DeviceA-nqa-admin-test-ftp] quit
# Start the FTP operation.
# After the FTP operation runs for a time period, stop the operation.
# Display the most recent result of the FTP operation.
Min/Max/Average round trip time: 173/173/173
Square-Sum of round trip time: 29929
Last succeeded probe time: 2019-03-25 10:07:28.6
Extend results:
Failures due to disconnect: 0
Failures due to no connection: 0
# Display the history records of the FTP operation.
1 173 Succeeded 2019-03-25 10:07:28.6
The output shows that it took Device A 173 milliseconds to upload a file to the FTP server.
Configuration files
type ftp
filename config.txt
operation put
password cipher $c$3$BP255atzDilAfIPwfh+RMHqmP5LTiKWpVf/hpBs=
source ip 10.1.1.1
url ftp://10.2.2.2
username admin
As shown in Figure 6, configure an HTTP operation on the NQA client to test the time required to obtain data from the HTTP server.
When you configure an HTTP operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the HTTP operation.
Procedures
# Create an HTTP operation.
[DeviceA-nqa-admin-test] type http
# Specify the URL of the HTTP server.
[DeviceA-nqa-admin-test-http] url http://10.2.2.2/index.htm
[DeviceA-nqa-admin-test-http] history-record enable
[DeviceA-nqa-admin-test-http] quit
# Start the HTTP operation.
# After the HTTP operation runs for a time period, stop the operation.
# Display the most recent result of the HTTP operation.
Min/Max/Average round trip time: 64/64/64
Square-Sum of round trip time: 4096
Last succeeded probe time: 2019-03-25 11:12:47.9
Extend results:
# Display the history records of the HTTP operation.
1 64 Succeeded 2019-03-25 11:12:47.9
The output shows that it took Device A 64 milliseconds to obtain data from the HTTP server.
Configuration files
type http
As shown in Figure 7, configure a UDP jitter operation to test the jitter, delay, and round-trip time between Device A and Device B.
When you configure a UDP jitter operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the UDP jitter operation.
· Configure Device B as the NQA server before you start the UDP jitter operation.
Procedures
Configuring Device B
# Enable the NQA server.
[DeviceB] nqa server enable
# Configure a UDP listening service to listen on the IP address 10.2.2.2 and UDP port 9000.
[DeviceB] nqa server udp-echo 10.2.2.2 9000
Configuring Device A
# Create a UDP jitter operation.
[DeviceA-nqa-admin-test] type udp-jitter
# Configure 10.2.2.2 as the destination IP address and port 9000 as the destination port.
[DeviceA-nqa-admin-test-udp-jitter] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-udp-jitter] destination port 9000
# Configure the operation to repeat at an interval of 1000 milliseconds.
[DeviceA-nqa-admin-test-udp-jitter] frequency 1000
[DeviceA-nqa-admin-test-udp-jitter] quit
# Start the UDP jitter operation.
# Stop the UDP jitter operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the UDP jitter operation.
Min/Max/Average round trip time: 1/1/1
Square-Sum of round trip time: 10
Last packet received time: 2019-07-30 09:46:36.9
Extended results:
UDP-jitter results:
RTT number: 10
Min positive SD: 1 Min positive DS: 0
Max positive SD: 1 Max positive DS: 0
Positive SD number: 1 Positive DS number: 0
Positive SD sum: 1 Positive DS sum: 0
Positive SD average: 1 Positive DS average: 0
Positive SD square-sum: 1 Positive DS square-sum: 0
Min negative SD: 0 Min negative DS: 0
Max negative SD: 0 Max negative DS: 0
Negative SD number: 0 Negative DS number: 0
Negative SD sum: 0 Negative DS sum: 0
Negative SD average: 0 Negative DS average: 0
Negative SD square-sum: 0 Negative DS square-sum: 0
One way results:
Max SD delay: 0 Max DS delay: 0
Min SD delay: 0 Min DS delay: 0
Number of SD delay: 0 Number of DS delay: 0
Sum of SD delay: 0 Sum of DS delay: 0
Square-Sum of SD delay: 0 Square-Sum of DS delay: 0
SD lost packets: 0 DS lost packets: 0
# Display the statistics of the UDP jitter operation.
NO. : 1
Start time: 2019-07-30 09:46:22.7
Life time: 14 seconds
Send operation times: 150 Receive response times: 150
Min/Max/Average round trip time: 1/4/1
Square-Sum of round trip time: 165
Extended results:
UDP-jitter results:
RTT number: 150
Max positive SD: 6 Max positive DS: 1
Positive SD number: 11 Positive DS number: 5
Positive SD sum: 16 Positive DS sum: 5
Positive SD square-sum: 46 Positive DS square-sum: 5
Min negative SD: 5 Min negative DS: 1
Max negative SD: 5 Max negative DS: 1
Negative SD sum: 5 Negative DS sum: 1
Negative SD average: 5 Negative DS average: 1
Negative SD square-sum: 25 Negative DS square-sum: 1
One way results:
Configuration files
· Device B:
nqa server enable
· Device A:
type udp-jitter
frequency 1000
As shown in Figure 8, configure an SNMP operation to test the time the NQA client uses to get a response from the SNMP agent.
When you configure an SNMP operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the SNMP operation.
· Configure Device B as the SNMP agent before you start the SNMP operation.
Procedures
# Set the SNMP version to all.
[DeviceB] snmp-agent sys-info version all
# Set the read community to public.
[DeviceB] snmp-agent community read public
# Set the write community to private.
[DeviceB] snmp-agent community write private
# Create an SNMP operation.
[DeviceA-nqa-admin-test] type snmp
# Configure 10.2.2.2 as the destination IP address of the SNMP operation.
[DeviceA-nqa-admin-test-snmp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-snmp] history-record enable
[DeviceA-nqa-admin-test-snmp] quit
# Start the SNMP operation.
# Stop the SNMP operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the SNMP operation.
Last succeeded probe time: 2019-07-30 10:07:28.2
Extended results:
# Display the history records of the SNMP operation.
NQA entry (admin admin, tag test) history record(s):
1 1 Succeeded 2019-07-30 10:07:28.2
Configuration files
· Device B:
snmp-agent
snmp-agent local-engineid 800063A20300E0FC123456
· Device A:
type snmp
As shown in Figure 9, configure a TCP operation to test the time required for Device A and Device B to establish a TCP connection.
When you configure a TCP operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the TCP operation.
· Configure Device B as the NQA server before you start the TCP operation.
Procedures
# Configure a TCP listening service to listen on the IP address 10.2.2.2 and TCP port 9000.
[DeviceB] nqa server tcp-connect 10.2.2.2 9000
# Create a TCP operation.
[DeviceA-nqa-admin-test] type tcp
[DeviceA-nqa-admin-test-tcp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-tcp] destination port 9000
[DeviceA-nqa-admin-test-tcp] history-record enable
[DeviceA-nqa-admin-test-tcp] quit
# Start the TCP operation.
# Stop the TCP operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the TCP operation.
Last succeeded probe time: 2019-07-30 10:37:29.5
Extended results:
# Display the history records of the TCP operation.
2 1 Succeeded 2019-07-30 10:37:29.5
1 0 Unknown error 2019-07-30 10:34:55.9
Configuration files
· Device B:
nqa server enable
· Device A:
type tcp
As shown in Figure 10, configure a UDP echo operation to test the round-trip time between Device A and Device B. The destination port number is 8000.
When you configure a UDP echo operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the UDP echo operation.
· Configure Device B as the NQA server before you start the UDP echo operation.
Procedures
# Configure a UDP listening service to listen on the IP address 10.2.2.2 and UDP port 8000.
[DeviceB] nqa server udp-echo 10.2.2.2 8000
# Create a UDP echo operation.
[DeviceA-nqa-admin-test] type udp-echo
# Configure 10.2.2.2 as the destination IP address and port 8000 as the destination port.
[DeviceA-nqa-admin-test-udp-echo] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-udp-echo] destination port 8000
[DeviceA-nqa-admin-test-udp-echo] history-record enable
[DeviceA-nqa-admin-test-udp-echo] quit
# Start the UDP echo operation.
# Stop the UDP echo operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the UDP echo operation.
Last succeeded probe time: 2019-07-30 11:10:35.2
Extended results:
# Display the history records of the UDP echo operation.
1 1 Succeeded 2019-07-30 11:10:35.2
Configuration files
· Device B:
nqa server enable
· Device A:
type udp-echo
As shown in Figure 11, configure a UDP tracert operation to determine the routing path from Device A to Device B.
When you configure a UDP tracert operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the UDP tracert operation.
Procedures
1. Execute the ip ttl-expires enable command on the intermediate devices and execute the ip unreachables enable command on Device B. (Details not shown.)
2. Configure Device A:
# Create a UDP tracert operation.
[DeviceA-nqa-admin-test] type udp-tracert
# Specify 10.2.2.2 as the destination IP address for the operation.
[DeviceA-nqa-admin-test-udp-tracert] destination ip 10.2.2.2
# Set the destination port number to 33434. (This step is optional because it is the default setting.)
[DeviceA-nqa-admin-test-udp-tracert] destination port 33434
# Configure Device A to perform three probes to each hop. (This step is optional because it is the default setting.)
[DeviceA-nqa-admin-test-udp-tracert] probe count 3
# Set the probe timeout time to 500 milliseconds.
[DeviceA-nqa-admin-test-udp-tracert] probe timeout 500
# Configure the UDP tracert operation to repeat every 5000 milliseconds.
[DeviceA-nqa-admin-test-udp-tracert] frequency 5000
# Specify M-GigabitEthernet 0/0/0 as the output interface for the probe packets.
[DeviceA-nqa-admin-test-udp-tracert] out interface m-gigabitethernet0/0/0
# Enable the no-fragmentation feature.
[DeviceA-nqa-admin-test-udp-tracert] no-fragment enable
# Set the maximum number of consecutive probe failures to 6.
[DeviceA-nqa-admin-test-udp-tracert] max-failure 6
# Set the initial TTL value in the probe packets to 1.
[DeviceA-nqa-admin-test-udp-tracert] init-ttl 1
# Start the UDP tracert operation.
# After the UDP tracert operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP tracert operation.
Send operation times: 6 Receive response times: 6
Last succeeded probe time: 2019-09-09 14:46:06.2
Extended results:
Packet loss in test: 0%
UDP-tracert results:
TTL Hop IP Time
1 3.1.1.1 2019-09-09 14:46:03.2
2 10.2.2.2 2019-09-09 14:46:06.2
# Display the history records of the UDP tracert operation.
Index TTL Response Hop IP Status Time
1 2 2 10.2.2.2 Succeeded 2019-09-09 14:46:06.2
1 2 1 10.2.2.2 Succeeded 2019-09-09 14:46:05.2
1 2 2 10.2.2.2 Succeeded 2019-09-09 14:46:04.2
1 1 1 3.1.1.1 Succeeded 2019-09-09 14:46:03.2
1 1 2 3.1.1.1 Succeeded 2019-09-09 14:46:02.2
1 1 1 3.1.1.1 Succeeded 2019-09-09 14:46:01.2
Configuration files
type udp-tracert
frequency 5000
max-failure 6
no-fragment enable
probe timeout 500
As shown in Figure 12, configure a voice operation to test the jitter, delay, MOS, and ICPIF between Device A and Device B.
When you configure a voice operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the voice operation.
· Configure Device B as the NQA server before you start the voice operation.
Procedures
# Configure a UDP listening service to listen on IP address 10.2.2.2 and UDP port 9000.
# Create a voice operation.
[DeviceA-nqa-admin-test] type voice
[DeviceA-nqa-admin-test-voice] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-voice] destination port 9000
[DeviceA-nqa-admin-test-voice] quit
# Start the voice operation.
# Stop the voice operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the voice operation.
Send operation times: 157 Receive response times: 157
Min/Max/Average round trip time: 1/3/1
Last packet received time: 2019-07-30 14:27:52.8
Extended results:
Voice results:
RTT number: 157
Min positive SD: 2 Min positive DS: 1
Max positive SD: 4 Max positive DS: 1
Positive SD number: 2 Positive DS number: 5
Positive SD sum: 6 Positive DS sum: 5
Positive SD average: 3 Positive DS average: 1
Positive SD square-sum: 20 Positive DS square-sum: 5
Min negative SD: 2 Min negative DS: 1
Max negative SD: 4 Max negative DS: 1
Negative SD number: 2 Negative DS number: 6
Negative SD sum: 6 Negative DS sum: 6
Negative SD average: 3 Negative DS average: 1
Negative SD square-sum: 20 Negative DS square-sum: 6
One way results:
Voice scores:
MOS value: 0.00 ICPIF value: 0
# Display the statistics of the voice operation.
NO. : 1
Start time: 2019-07-30 14:30:30.0
Life time: 204 seconds
Send operation times: 4000 Receive response times: 4000
Min/Max/Average round trip time: 1/32/1
Square-Sum of round trip time: 12853
Extended results:
Voice results:
RTT number: 4000
Max positive SD: 32 Max positive DS: 1
Positive SD number: 76 Positive DS number: 72
Positive SD sum: 567 Positive DS sum: 72
Positive SD average: 7 Positive DS average: 1
Positive SD square-sum: 9011 Positive DS square-sum: 72
Max negative SD: 20 Max negative DS: 1
Negative SD number: 87 Negative DS number: 67
Negative SD sum: 569 Negative DS sum: 67
Negative SD average: 7 Negative DS average: 1
Negative SD square-sum: 6715 Negative DS square-sum: 67
One way results:
Voice scores:
Max MOS value: 4.40 Min MOS value: 4.40
Max ICPIF value: 0 Min ICPIF value: 0
Configuration files
· Device B:
nqa server enable
· Device A:
type voice
As shown in Figure 13, configure a DLSw operation to test the response time of the DLSw device.
When you configure a DLSw operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the DLSw operation.
Procedures
# Create a DLSw operation.
[DeviceA-nqa-admin-test] type dlsw
# Configure 10.2.2.2 as the destination IP address.
[DeviceA-nqa-admin-test-dlsw] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-dlsw] history-record enable
[DeviceA-nqa-admin-test-dlsw] quit
# Start the DLSw operation.
# Stop the DLSw operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the DLSw operation.
Min/Max/Average round trip time: 19/19/19
Square-Sum of round trip time: 361
Last succeeded probe time: 2019-07-22 10:40:27.7
Extended results:
# Display the history records of the DLSw operation.
1 19 Succeeded 2019-07-22 10:40:27.7
Configuration files
type dlsw
As shown in Figure 14, configure a path jitter operation to test the round trip time and jitters from Device A to Device B and Device C.
When you configure a path jitter operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the path jitter operation.
Procedures
1. Execute the ip ttl-expires enable command on Device B and execute the ip unreachables enable command on Device C. (Details not shown.)
# Create a path jitter operation.
[DeviceA-nqa-admin-test] type path-jitter
[DeviceA-nqa-admin-test-path-jitter] destination ip 10.2.2.2
# Configure the path jitter operation to repeat every 10000 milliseconds.
[DeviceA-nqa-admin-test-path-jitter] frequency 10000
[DeviceA-nqa-admin-test-path-jitter] quit
# Start the path jitter operation.
# After the path jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the path jitter operation.
Hop IP 10.1.1.2
Basic Results
Min/Max/Average round trip time: 9/21/14
Square-Sum of round trip time: 2419
Extended Results
Path-Jitter Results
Jitter number: 9
Min/Max/Average jitter: 1/10/4
Positive jitter number: 6
Min/Max/Average positive jitter: 1/9/4
Sum/Square-Sum positive jitter: 25/173
Negative jitter number: 3
Min/Max/Average negative jitter: 2/10/6
Sum/Square-Sum positive jitter: 19/153
Hop IP 10.2.2.2
Basic Results
Min/Max/Average round trip time: 15/40/28
Square-Sum of round trip time: 4493
Extended Results
Path-Jitter Results
Jitter number: 9
Configuration files
type path-jitter
frequency 10000
Related documentation
· H3C S10500X Switch Series Network Management and Monitoring Configuration Guide-R759X
· H3C S10500X Switch Series Network Management and Monitoring Command Reference-R759X
