- 03-Layer 2 - LAN Switching Configuration Examples
- 01-H3C_MAC_Address_Table_Configuration_Examples
- 02-H3C_Ethernet_Link_Aggregation_Configuration_Examples
- 03-H3C_Port_Isolation_Configuration_Examples
- 04-H3C_Spanning_Tree_Configuration_Examples
- 05-H3C_VLAN_Configuration_Examples
- 06-H3C_MVRP_Configuration_Examples
- 07-H3C_QinQ_Configuration_Examples
- 08-H3C_VLAN_Mapping_Configuration_Examples
- 09-H3C_DRNI_Configuration_Examples
- 10-H3C_S-MLAG Configuration Examples
10-H3C_S-MLAG Configuration Examples | 111.98 KB |
H3C S-MLAG Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Establishing a multidevice aggregate link with a network device
Example: Establishing a multidevice aggregate link with a server
Introduction
This document provides configuration examples for using simple multichassis link aggregation (S-MLAG).
S-MLAG enhances dynamic link aggregation to establish an aggregation that spans multiple standalone devices to a remote device.
The following information is provided based on the assumption that you have basic knowledge of S-MLAG.
Device B, Device C, and Device D are standalone devices. As shown in Figure 1, configure Device B, Device C, and Device D as S-MLAG devices to establish a multidevice aggregate link with Device A.
Analysis
To establish a multidevice aggregate link with Device A, you must perform the following tasks on Device B, Device C, and Device D:
1. Create a Layer 2 dynamic aggregate interface and assign Ten-GigabitEthernet 1/0/1 to its aggregation group.
2. Assign the aggregate interfaces to the same DR group.
Before you assign an interface to an aggregation group, use the display this command in interface view to identify whether attribute settings exist, including port isolation, QinQ, VLAN, and VLAN mapping settings. If attribute settings exist, use the corresponding undo commands to remove them.
Configure the link aggregation settings other than S-MLAG settings on each S-MLAG device. Make sure the settings are consistent across the S-MLAG devices.
As a best practice, maintain consistency across S-MLAG devices in service feature configuration.
Procedures
Configuring Device A
# Create Layer 2 aggregate interface Bridge-Aggregation 10, and set the link aggregation mode to dynamic.
[DeviceA] interface bridge-aggregation 10
[DeviceA-Bridge-Aggregation10] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation10] quit
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to aggregation group 10.
[DeviceA-Ten-GigabitEthernet1/0/1] port link-aggregation group 10
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port link-aggregation group 10
[DeviceA-Ten-GigabitEthernet1/0/2] quit
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port link-aggregation group 10
[DeviceA-Ten-GigabitEthernet1/0/3] quit
Configuring Device B
# Set the LACP system MAC address to 0001-0001-0001.
[DeviceB] lacp system-mac 1-1-1
# Set the LACP system priority to 123.
[DeviceB] lacp system-priority 123
# Set the LACP system number to 1.
[DeviceB] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 2, and set the link aggregation mode to dynamic.
[DeviceB] interface bridge-aggregation 2
[DeviceB-Bridge-Aggregation2] link-aggregation mode dynamic
# Assign Bridge-Aggregation 2 to S-MLAG group 100.
[DeviceB-Bridge-Aggregation2] port s-mlag group 100
[DeviceB-Bridge-Aggregation2] quit
# Assign Ten-GigabitEthernet 1/0/1 to aggregation group 2.
[DeviceB-Ten-GigabitEthernet1/0/1] port link-aggregation group 2
Configuring Device C
<DeviceC> system-view
[DeviceC] lacp system-mac 1-1-1
[DeviceC] lacp system-priority 123
# Set the LACP system number to 2.
[DeviceC] lacp system-number 2
# Create Layer 2 aggregate interface Bridge-Aggregation 3, and set the link aggregation mode to dynamic.
[DeviceC] interface bridge-aggregation 3
[DeviceC-Bridge-Aggregation3] link-aggregation mode dynamic
# Assign Bridge-Aggregation 3 to S-MLAG group 100.
[DeviceC-Bridge-Aggregation3] port s-mlag group 100
# Assign Ten-GigabitEthernet 1/0/1 to aggregation group 3.
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] port link-aggregation group 3
[DeviceC-Ten-GigabitEthernet1/0/1] quit
Configuring Device D
<DeviceD> system-view
[DeviceD] lacp system-mac 1-1-1
[DeviceD] lacp system-priority 123
# Set the LACP system number to 3.
[DeviceD] lacp system-number 3
# Create Layer 2 aggregate interface Bridge-Aggregation 4, and set the link aggregation mode to dynamic.
[DeviceD] interface bridge-aggregation 4
[DeviceD-Bridge-Aggregation4] link-aggregation mode dynamic
# Assign Bridge-Aggregation 4 to S-MLAG group 100.
[DeviceD-Bridge-Aggregation4] port s-mlag group 100
# Assign Ten-GigabitEthernet 1/0/1 to aggregation group 4.
[DeviceD] interface ten-gigabitethernet 1/0/1
[DeviceD-Ten-GigabitEthernet1/0/1] port link-aggregation group 4
[DeviceD-Ten-GigabitEthernet1/0/1] quit
# Verify that Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 on Device A are Selected ports.
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation10
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
System ID: 0x8000, a0c7-9afd-0100
Local:
Port Status Priority Index Oper-Key Flag
XGE1/0/1 S 32768 1 1 {ACDEF}
XGE1/0/2 S 32768 2 1 {ACDEF}
XGE1/0/3 S 32768 3 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
XGE1/0/1(R) 32768 16385 50100 0x7b , 0001-0001-0001 {ACDEF}
XGE1/0/2 32768 32769 50100 0x7b , 0001-0001-0001 {ACDEF}
XGE1/0/3 32768 49153 50100 0x7b , 0001-0001-0001 {ACDEF}
Configuration files
· Device A:
interface Bridge-Aggregation10
port link-mode bridge
combo enable fiber
combo enable fiber
combo enable fiber
· Device B:
lacp system-mac 0001-0001-0001
interface Bridge-Aggregation2
combo enable fiber
· Device C:
interface Bridge-Aggregation3
combo enable fiber
· Device D:
interface Bridge-Aggregation4
combo enable fiber
Device A, Device B, and Device C are standalone devices. As shown in Figure 2, configure Device A, Device B, and Device C as S-MLAG devices to establish a multidevice aggregate link with the server. On Device A, Device B, and Device C, configure the server-facing aggregate interfaces as edge aggregate interfaces.
Analysis
To establish a multidevice aggregate link with the server, you must perform the following tasks on Device A, Device B, and Device C:
Procedures
[DeviceA] lacp system-mac 1-1-1
[DeviceA] lacp system-priority 123
[DeviceA] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and set the link aggregation mode to dynamic.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Configure Bridge-Aggregation 1 as an edge aggregate interface.
[DeviceA-Bridge-Aggregation1] lacp edge-port
# Assign Bridge-Aggregation 1 to S-MLAG group 100.
[DeviceA-Bridge-Aggregation1] port s-mlag group 100
[DeviceA-Bridge-Aggregation1] quit
# Assign Ten-GigabitEthernet 1/0/1 to aggregation group 1.
[DeviceB] lacp system-number 2
[DeviceC-Bridge-Aggregation2] link-aggregation mode dynamic
# Configure Bridge-Aggregation 2 as an edge aggregate interface.
[DeviceB-Bridge-Aggregation2] lacp edge-port
[DeviceC] lacp system-number 3
# Configure Bridge-Aggregation 3 as an edge aggregate interface.
[DeviceC-Bridge-Aggregation3] lacp edge-port
# Verify that the aggregation member ports on Device A, Device B, and Device C are working in Individual state when dynamic link aggregation is not configured on the server.
System ID: 0x7b, 0001-0001-0001
Local:
XGE1/0/1 I 32768 16385 50100 {AG}
Remote:
XGE1/0/1 32768 0 0 0x8000, 0000-0000-0000 {DEF}
[DeviceB] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation2
Local:
XGE1/0/1 I 32768 32769 50100 {AG}
Remote:
[DeviceC] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation3
Local:
XGE1/0/1 I 32768 49153 50100 {AG}
Remote:
# Verify that the aggregation member ports on Device A, Device B, and Device C are working in Selected state after dynamic link aggregation is configured on the server.
Local:
XGE1/0/1(R) S 32768 16385 50100 {ACDEF}
Remote:
XGE1/0/1 32768 1 1 0x8000, 5022-e533-0400 {ACDEF}
Local:
XGE2/0/1(R) S 32768 32769 50100 {ACDEF}
Remote:
XGE2/0/1 32768 2 1 0x8000, 5022-e533-0400 {ACDEF}
Local:
XGE2/0/1(R) S 32768 49153 50100 {ACDEF}
Remote:
XGE2/0/1 32768 3 1 0x8000, 5022-e533-0400 {ACDEF}
Configuration files
· Device A:
lacp edge-port
· Device B:
lacp edge-port
· Device C:
lacp edge-port
Related documentation
· H3C S7500X Switch Series Layer 2—LAN Switching Command Reference-R759X
· H3C S7500X Switch Series Layer 2—LAN Switching Configuration Guide-R759X
