- 07-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 policy-based routing configuration
- 12-Guard route configuration
- 13-Routing policy configuration
- 14-MTR configuration
- 15-DCN configuration
14-MTR configuration | 80.68 KB |
Associating an interface with a topology
Configuring an MTR policy node
Display and maintenance commands for MTR
Configuring MTR
About MTR
Multi-Topology Routing (MTR) splits a base topology into multiple topologies, which intersect or overlap with one another. Route calculation is performed on a per-topology basis.
You can configure MTR for IS-IS, OSPF, and static routing. For more information, see "Configuring IS-IS," "Configuring IPv6 IS-IS," "Configuring static routing," and "Configuring OSPF."
For example, IS-IS MTR enables IS-IS to perform separate route calculation for the IPv4 and IPv6 topologies in an IS-IS routing domain.
As shown in Figure 1, the base topology is split into two topologies, topology A and topology B. You can forward voice traffic through topology A and video traffic through topology B.
Router B does not belong to topology A. In topology B, no direct link exists between Router A and Router D, or between Router B and Router C. Route calculation and traffic forwarding are performed in each topology independently.
Figure 1 Work mechanism of MTR
MTR tasks at a glance
To configure MTR, perform the following tasks:
2. Associating an interface with a topology
3. Configuring an MTR policy node
Perform this task to classify traffic.
Perform this task to forward different types of traffic to different topologies.
Configuring a topology
1. Enter system view.
2. Create the global address family and enter its view.
global-address-family ipv4 [ unicast ]
3. Create a topology and enter its view.
topology topo-name
4. (Optional.) Configure the maximum number of active routes supported by the topology.
By default, a topology supports a maximum of 100000 active routes.
2. Enter interface view.
3. Associate the interface with a topology and enter IPv4 unicast topology view of the interface.
topology ipv4 [ unicast ] topo-name
By default, an interface is not associated with any topology.
MTR classifies traffic by MTR policy. An MTR policy can contain multiple nodes, which are in a logical OR relationship. A node with a smaller number is matched first. A packet that matches one node matches the MTR policy.
Each node contains a set of if-match and apply clauses.
· if-match—Defines a criterion to match packet attributes. Available match criteria include ACL, DSCP, and IP precedence. The if-match clauses of a node are in an OR relationship. If a packet matches one of the if-match clauses, it matches the node.
· apply—Specifies a topology for packets matching the MTR policy node.
A node must contain both if-match and apply clauses. Otherwise, the topology configuration cannot take effect.
2. Create an MTR policy node and enter its view.
mtr-policy policy-name node node-value
3. Configure the match criteria.
Choose the options to configure as needed:
¡ Configure an ACL match criterion.
if-match ip acl acl-number
¡ Configure a DSCP match criterion.
if-match ip dscp dscp-value
¡ Configure an IP precedence match criterion.
if-match ip precedence ip-prec-value
By default, no match criterion is configured.
4. Specify a topology for the MTR policy node.
apply topology topo-name
By default, no topology is specified for the MTR policy node.
Enabling an MTR policy
2. Enter global address family view.
3. Enable the MTR policy.
topology-routing mtr-policy policy-name
By default, the MTR policy is disabled.
Command |
Display topology information. |
display topology [ name topo-name ] |
Display MTR policy information. |
display mtr-policy [ name mtr-policy-name ] |
