- 09-MPLS Command Reference
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-MPLS L2VPN commands
- 10-VPLS commands
- 11-L2VPN access to L3VPN or IP backbone commands
- 12-MPLS OAM commands
- 13-MPLS protection switching commands
- 14-MCE commands
- 15-MPLS SR commands
07-Tunnel policy commands | 59.33 KB |
display mpls tunnel
Use display mpls tunnel to display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination { ipv4-address | ipv6-address } }
all: Displays all tunnels. GRE and MPLS TE tunnel information is displayed only when the network layer is up.
statistics: Displays tunnel statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays tunnel information for the public network.
destination: Displays the tunnel destined for the specified address.
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
# Display information about all tunnels.
<Sysname> display mpls tunnel all
Destination Type Tunnel/NHLFE VPN Instance
2.2.2.2 LSP NHLFE1024 -
3.3.3.3 CRLSP Tunnel2 -
Destination |
Tunnel destination address. |
Type |
Tunnel type: LSP, GRE, CRLSP, or SRLSP. |
Tunnel/NHLFE |
Tunnel, tunnel bundle, or NHLFE entry. NHLFEnumber represents the ingress LSP that matches the NHLFE entry with NID of number. |
VPN Instance |
VPN instance name. If the tunnel belongs to the public network, this field displays a hyphen (-). |
# Display tunnel statistics.
<Sysname> display mpls tunnel statistics
LSP : 1
GRE : 0
CRLSP: 0
SRLSP: 0
LSP |
Number of LSP tunnels. |
GRE |
Number of GRE tunnels. |
CRLSP |
Number of CRLSP tunnels. |
SRLSP |
Number of SRLSP tunnels. |
preferred-path
Use preferred-path to configure a tunnel or a tunnel bundle as a preferred tunnel.
Use undo preferred-path to remove the preferred tunnel setting for a tunnel or tunnel bundle.
preferred-path { tunnel number | tunnel-bundle number }
undo preferred-path { tunnel number | tunnel-bundle number }
No preferred tunnels are configured.
Tunnel policy view
tunnel number: Specifies an MPLS TE tunnel or a GRE tunnel by its tunnel interface number. The value range for the tunnel interface number is 0 to 65534.
tunnel-bundle number: Specifies a tunnel bundle by its tunnel bundle interface number. The value range for the tunnel bundle interface number is 0 to 1023.
As a best practice for an MPLS VPN, configure a preferred tunnel and make sure the destination address of the tunnel/tunnel bundle interface identifies the peer PE. In this method, the local PE forwards traffic destined for the peer PE over the preferred MPLS TE tunnel, GRE tunnel, or tunnel bundle.
For a tunnel policy to solely use a tunnel or tunnel bundle, do not configure the tunnel or tunnel bundle as the preferred tunnel in other tunnel policies.
If you configure multiple preferred tunnels that have the same destination address in a tunnel policy, only the first configured tunnel takes effect. If the first tunnel is not available, the second tunnel is used, and so forth. No load balancing will be performed on these tunnels.
You can configure a maximum of 128 preferred tunnels in a tunnel policy.
# Configure tunnel 1 and tunnel 2 as preferred tunnels for tunnel policy policy1.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] preferred-path tunnel 1
[Sysname-tunnel-policy-policy1] preferred-path tunnel 2
select-seq load-balance-number
Use select-seq load-balance-number to configure the tunnel selection order and set the number of tunnels for load balancing.
Use undo select-seq to restore the default.
select-seq [ strict ] { cr-lsp | gre | lsp | sr-lsp } * load-balance-number number
undo select-seq
The device selects only one tunnel in LSP-GRE-CRLSP-SRLSP order.
Tunnel policy view
strict: Uses the same type of tunnels for load balancing.
cr-lsp: Uses CRLSP tunnels.
gre: Uses GRE tunnels.
lsp: Uses LSP tunnels.
sr-lsp: Uses SRLSP tunnels.
load-balance-number number: Specifies the number of tunnels for load balancing. The value range for the number argument is 1 to 32.
A tunnel type closer to the select-seq keyword has a higher priority. The strict keyword determines whether VPN can use a hybrid of the specified types of tunnels for load balancing.
For example, the select-seq lsp cr-lsp load-balance-number 3 command specifies three tunnels for load balancing and gives LSP tunnels higher priority over CRLSP tunnels.
· If you do not specify the strict keyword, VPN can use CRLSP tunnels to remedy the deficiency of LSP tunnels.
· If you specify the strict keyword, VPN uses only one type of tunnels. It uses CRLSP tunnels only if no LSP tunnels are available.
Tunnels selected by this method are not fixed, making it hard to plan VPN traffic. As a best practice, do not use this method.
When you configure both the select-seq load-balance-number and preferred-path commands for a tunnel policy, the tunnel policy selects tunnels in the following steps:
1. If the destination address of the preferred tunnel identifies a peer PE, the tunnel policy uses the preferred tunnel to forward traffic destined for the peer PE.
2. If not, the tunnel policy selects tunnels as configured by the select-seq load-balance-number command.
# Configure tunnel policy policy1 to use only CRLSP tunnels, and set the load balancing number to 2.
[Sysname-tunnel-policy-policy1] select-seq cr-lsp load-balance-number 2
tunnel-policy (system view)
Use tunnel-policy to create a tunnel policy and enter its view, or enter the view of an existing tunnel policy.
Use undo tunnel-policy to delete a tunnel policy.
tunnel-policy tunnel-policy-name [ default ]
undo tunnel-policy tunnel-policy-name
No tunnel policies exist.
tunnel-policy-name: Specifies a name for the tunnel policy, a case-sensitive string of 1 to 19 characters.
default: Uses the policy as the global tunnel policy.
The device supports only one global tunnel policy.
By default, a tunnel policy selects only one tunnel in LSP—GRE—CRLSP—SRLSP order.
An MPLS VPN uses the global tunnel policy if it is not bound with a specific tunnel policy or the bound policy does not exist. If the bound policy exists but is null, the MPLS VPN selects only one tunnel in LSP—GRE—CRLSP—SRLSP order.
# Create tunnel policy policy1 and enter its view.
