02-Ethernet link aggregation commands | 181.07 KB |
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
link-aggregation auto-aggregation enable
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 3 aggregate interface 1.
[Sysname-Route-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ route-aggregation [ interface-number ] ] [ brief [ description | down ] ]
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, this command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP configuration in Layer 2—WAN Access Configuration Guide.
If you specify an aggregate interface type but do not specify an interface number, this command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
Bandwidth: 1000 kbps
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Port priority: 0
0 packets input, 0 bytes, 0 drops
0 packets output, 0 bytes, 0 drops
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1 UP UP --
Route-Aggregation1 |
Layer 3 aggregate interface name. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps. |
Port priority |
Port priority of the interface. |
Output queue - Urgent queuing: Size/Length/Discards |
Information about the urgent output queue: · Size—Number of packets in the queue. · Length—Maximum number of packets that the queue can contain. · Discards—Number of dropped packets. |
Output queue - Protocol queuing: Size/Length/Discards |
Information about the protocol output queue: · Size—Number of packets in the queue. · Length—Maximum number of packets that the queue can contain. · Discards—Number of dropped packets. |
Output queue - FIFO queuing: Size/Length/Discards |
Information about the FIFO output queue: · Size—Number of packets in the queue. · Length—Maximum number of packets that the queue can contain. · Discards—Number of dropped packets. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
Port link-type |
Port link type: · Access. · Trunk. · Hybrid. |
Tagged VLANs |
VLAN whose packets are sent out of this interface with a tag. |
Untagged VLANs |
VLAN whose packets are sent out of this interface without a tag. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 seconds input/output rate |
Average input or output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received or sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received or sent on the interface. |
Line protocol state |
Data link layer state of the interface: · UP. · DOWN. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. |
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Actor System ID: 0x8000, 0000-fc00-6504 |
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output). |
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ route-aggregation | interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The route-aggregation keyword is available only when Layer 3 aggregate interfaces exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
destination-mac address, source-mac address
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode interface route-aggregation 1
Route-Aggregation1 load-sharing mode:
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays a user-configured setting.
Link-aggregation load-sharing mode |
Global link-aggregation load sharing mode. By default, this field displays the link-aggregation load sharing modes for Layer 2 and Layer 3 traffic. If you have configured the global link-aggregation load sharing mode, this field displays the configured mode. |
Route-Aggregation1 load-sharing mode |
Link-aggregation load sharing mode of Layer 3 aggregation group 1. By default, this field displays the global link-aggregation load sharing modes. If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode. |
Layer 2 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, the system automatically selects a load sharing mode for Layer 2 traffic. |
Layer 3 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, the system automatically selects a load sharing mode for Layer 3 traffic. |
MPLS traffic : mpls-label1, mpls-label2, mpls-label3 |
Default link-aggregation load sharing mode for MPLS traffic. In this sample output, MPLS traffic is load shared based on Layer 1 through Layer 3 MPLS labels. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses. |
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about GigabitEthernet 1/0, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0
G -- Defaulted, H -- Expired
GigabitEthernet1/0:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about GigabitEthernet 2/0, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 2/0
GigabitEthernet2/0:
Aggregate Interface: Route-Aggregation2
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0. · A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive. · B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no. · D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no. · E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no. · F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no. · G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no. · H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no. |
Aggregate Interface |
Aggregate interface to which the member port belongs. |
Local |
Information about the local end. |
Oper-key |
Operational key. |
Flag |
LACP protocol state flag. |
Remote |
Information about the peer end. |
System ID |
Peer system ID, containing the system LACP priority and the system MAC address. |
Received LACP Packets |
Total number of LACP packets received. |
Illegal |
Total number of illegal packets. |
Sent LACP Packets |
Total number of LACP packets sent. |
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None or nothing for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
RAGG1 S None 1 0 0 NonS
BAGG2 D 0x8000,00e0-fcff-ff01 2 0 0 Shar
Table 5 Command output
Aggregate Interface Type |
Aggregate interface type: · RAGG—Layer 3. |
Aggregation Mode |
Aggregation group type: · S—Static. · D—Dynamic. |
Loadsharing Type |
Load sharing type: · Shar—Load-sharing. · NonS—Non-load-sharing. |
Actor System ID |
Local system ID, which contains the local system LACP priority and the local system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address. |
Selected Ports |
Total number of Selected ports. |
Unselected Ports |
Total number of Unselected ports. |
Individual Ports |
Total number of Individual ports. |
Share Type |
Load sharing type. |
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ route-aggregation [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
# Display detailed information about Layer 3 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 1
Port: A -- Auto port
Creation Mode: Manual
Aggregation Mode: Dynamic
Local:
Port Status Priority Oper-Key Flag
GE1/0 S 32768 2 {ACDEF}
GE2/0 S 32768 2 {ACDEF}
GE3/0 S 32768 2 {AG}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE1/0 1 32768 2 0x8000, 000f-e267-57ad {ACDEF}
GE2/0 1 32768 2 0x8000, 000f-e267-57ad {ACDEF}
GE3/0 1 32768 2 0x8000, 0000-0000-0000 {DEF}
# Display detailed information about Layer 3 aggregation group 2, which is a static aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 2
Aggregation Mode: Static
GE1/0 S 32768 1
GE2/0 S 32768 1
GE3/0 S 32768 1
Table 6 Command output
Loadsharing Type |
Port Status |
Port state: · Selected. · Unselected. · Individual. |
Port |
Port type. Auto port indicates that the port is enabled with automatic assignment. |
Flags |
Name of the aggregate interface. |
Creation Mode |
Creation mode of the dynamic aggregate interface: · Auto. · Manual. |
Aggregation Mode |
System ID |
Local system ID, containing the local system LACP priority and the local system MAC address. |
Local |
Information about the local end: · Port—Port type and number. · Status—Port state, which can be Selected, Unselected, or Individual. · Priority—Port priority. · Oper-Key—Operational key. · Flag—LACP state flag. NOTE: For static aggregation groups, the Flag field is not displayed. |
Remote |
Information about the peer end: · Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port. · Partner—Index of the peer port. · Priority—Priority of the peer port. · Oper-Key—Operational key of the peer port. · System ID—System ID of the peer end. · Flag—LACP state flag of the peer end. |
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 8.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the interface-number argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames with a maximum length of 16384 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value range for this argument is 1536 to 16384.
# Allow jumbo frames to pass through on Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> System-view
[Sysname-Route-Aggregation1] jumboframe enable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Sysname-Route-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not enable the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] lacp period short
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The system LACP priority is 32768.
priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
Use link-aggregation auto-aggregation enable to enable automatic link aggregation.
Use undo link-aggregation auto-aggregation enable to disable automatic link aggregation.
Automatic link aggregation is disabled.
After you enable automatic link aggregation and LLDP on two connected devices, they automatically establish a dynamic link aggregation based on the information in incoming LLDP frames. The devices each automatically create a dynamic aggregate interface and assign the redundant ports connected to the peer to the aggregation group of that interface. If you disable LLDP or automatic link aggregation on one device, that device removes the aggregation member ports from the aggregation group, but it will retain the aggregate interface. This event will not trigger member port removal actions on the peer device.
If automatic link aggregation is enabled, subinterface creation might fail on LLDP-enabled Layer 3 Ethernet interfaces. As a best practice, do not create subinterfaces on LLDP-enabled Layer 3 Ethernet interfaces.
To ensure correct operation of an automatically created aggregate interface, do not modify the configuration on the member ports of its aggregation group. Doing so might cause the member ports to be removed from the aggregation group.
On an interface, the port link-aggregation group setting takes precedence over automatic link aggregation. The interface will not be added to the aggregation group of an automatically created aggregate interface if it has been the member port of a manually created aggregate interface.
# Enable automatic link aggregation.
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
lldp enable
lldp global enable
link-aggregation bfd ipv4
Use link-aggregation bfd ipv4 to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ip-address destination ip-address
BFD is disabled for an aggregation group.
source ip-address: Specifies the unicast source IP address of BFD sessions. The source IP address cannot be 0.0.0.0.
destination ip-address: Specifies the unicast destination IP address of BFD sessions. The destination IP address cannot be 0.0.0.0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
# Enable BFD for Layer 3 aggregation group 1 and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Route-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { { destination-ip | destination-mac | destination-port | ingress-port | ip-protocol | mpls-label1 | mpls-label2 | mpls-label3 | source-ip | source-mac | source-port | vlan-id } * | flexible | per-packet }
The system automatically chooses a load sharing mode depending on the packet type.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
ingress-port: Distributes traffic based on ingress ports.
ip-protocol: Distributes traffic based on IP protocol types.
mpls-label1: Distributes MPLS traffic based on Layer 1 labels.
mpls-label2: Distributes MPLS traffic based on Layer 2 labels.
mpls-label3: Distributes MPLS traffic based on Layer 3 labels.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
vlan-id: Distributes traffic based on VLAN IDs.
flexible: Automatically chooses a load sharing mode depending on the packet type. For example, load sharing mode differs for Layer 2, IPv4, IPv6, and MPLS packets.
per-packet: Distributes traffic on a per-packet basis. Traffic is distributed across the Selected member ports in proportion to their expected bandwidth, which is configurable with the bandwidth command.
If an unsupported load sharing mode is set, the device displays an error message.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
bandwidth
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if the port is shut down by using the shutdown command.
NOTE: The device does not redirect traffic to member ports that become Selected during the traffic redirection process. |
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-mac | destination-port | ingress-port | ip-protocol | mpls-label1 | mpls-label2 | mpls-label3 | source-ip | source-mac | source-port | vlan-id } * | flexible | per-packet }
The system automatically chooses a link-aggregation load sharing mode for different types of packets.
flexible: Automatically chooses a load sharing mode depending on the packet type. For example, the load sharing mode differs for Layer 2, IPv4, IPv6, and MPLS packets.
# Configure Layer 3 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Route-Aggregation1] link-aggregation load-sharing mode destination-mac
bandwidth
link-aggregation mode
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
Aggregation mode change might cause Selected member ports to become Unselected.
When you change the aggregation mode, make sure you understand the impact of the change on services.
# Configure Layer 3 aggregation group 1 to operate in dynamic aggregation mode.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 3 Ethernet interface GigabitEthernet 2/0.
[Sysname] interface gigabitethernet 2/0
[Sysname-GigabitEthernet2/0] link-aggregation port-priority 64
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 8.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number set by using the link-aggregation selected-port maximum command.
· Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
· Assigning two ports to an aggregation group.
· Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation irf-enhanced
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 8.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum 3
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
link-delay [ msec ] delay-time [ mode { up | updown } ]
undo link-delay [ msec ] delay-time [ mode { up | updown } ]
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
· If you do not specify the msec keyword, the value range is 0 to 30 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses link-up events.
mode updown: Suppresses both link-up and link-down events.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type persists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
· To suppress only link-down events, use the link-delay [ msec ] delay-time command.
· To suppress only link-up events, use the link-delay [ msec ] delay-time mode up command.
· To suppress both link-down and link-up events, use the link-delay [ msec ] delay-time mode updown command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for link-up or link-down events, the most recent configuration takes effect.
# Set the link-down event suppression interval to 8 seconds on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-delay down 8
# Set the link-down event suppression interval to 8 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay down 8
mac-address
Use mac-address to assign a MAC address to an aggregate interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
All aggregate interfaces on the device use the same default MAC address.
mac-address: Specifies a MAC address in the format of H-H-H.
The default MAC address of Layer 3 aggregate interfaces and subinterfaces varies by device. You can use the display interface command to view the MAC address of a Layer 3 aggregate interface or subinterface.
# Assign MAC address 0001-0001-0002 to interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mac-address 1-1-2
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies an MTU in bytes. The value range for this argument is 46 to 9216.
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 8.
You can assign a Layer 3 Ethernet interface only to a Layer 3 aggregation group.
An interface can belong to only one aggregation group.
By default, the following restrictions exist:
· You cannot assign both Ethernet interfaces and Ethernet subinterfaces to an aggregation group.
· You cannot create subinterfaces on an Ethernet interface that is in an aggregation group.
· You cannot assign an Ethernet interface that has subinterfaces to an aggregation group.
You cannot create aggregate subinterfaces on an aggregate interface if its aggregation group contains Ethernet subinterfaces. You cannot assign Ethernet subinterfaces to an aggregation group if its aggregate interface has aggregate subinterfaces.
Before you assign an Ethernet subinterface to an aggregation group, verify that the following requirements are met:
· VLAN termination has been configured on the Ethernet subinterface. You cannot modify VLAN termination configuration on the Ethernet subinterfaces in an aggregation group. To configure VLAN termination, use the following commands:
¡ vlan-type dot1q default.
¡ vlan-type dot1q untagged.
¡ vlan-type dot1q vid.
¡ vlan-type dot1q vid second-dot1q.
· By default, the Ethernet subinterfaces to be assigned to an aggregation group terminate the same VLAN.
· If you execute the vlan-type dot1q vid vlan-id-list [ loose ] command on an Ethernet subinterface to be assigned to a dynamic aggregation group, specify only one VLAN ID.
You cannot assign the following interfaces to an aggregation group:
· Member interfaces of redundant Ethernet interfaces.
· Member interfaces of redundancy group nodes.
For more information about redundant Ethernet interfaces and redundancy group nodes, see High Availability Configuration Guide.
# Assign Layer 3 Ethernet interface GigabitEthernet 2/0 to Layer 3 aggregation group 2.
[Sysname-GigabitEthernet2/0] port link-aggregation group 2
link-aggregation multivlan-termination
vlan-type dot1q vid
Use reset counters interface to clear statistics about the specified aggregate interfaces.
reset counters interface [ route-aggregation [ interface-number ] ]
If you do not specify an aggregate interface type, the command clears statistics about all interfaces in the system except VA interfaces.
If you specify only an aggregate interface type, the command clears statistics about all aggregate interfaces of the specified type.
# Clear statistics for Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> reset counters interface route-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics about the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics about all member ports.
# Clear LACP statistics about all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface or subinterface.
Use undo shutdown to bring up an aggregate interface or subinterface.
shutdown
An interface is not manually shut down.
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] undo shutdown
