01-Fundamentals Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R0621-6W30001-Fundamentals Command Reference
09-Automatic configuration commands
09-Automatic configuration commands 32.27 KB
autodeploy url enable
Use autodeploy url enable to enable URL-based automatic configuration.
Use undo autodeploy url enable to disable URL-based automatic configuration.
URL-based automatic configuration is enabled.
# Disable URL-based automatic configuration.
[Sysname] autodeploy url enable
  • Become a Partner
  • Partner Resources
